  • tjua
    Det er nok bare å sjekke den kalde krigs planverk,
    korrigere for ny teknologi,
    starte å bygge forlegninger i nord,
    kalle inn >85% av de vernepliktige
    sette i gang opplæring; lokalt, nasjonalt, og sammen med partnerland i samme situasjon
    i tillegg til DSBs beredskapsråd legge til ammo til de tusenvis av gevær og pistoler som ligger i de tusen hjem
    håpe på det beste, være forberedt på det verste
    jeg tror fremdeles på vladivostok Lisboa…
    Finske medier er mye tydeligere om situasjonen enn norske. Denne artikkelen skisserer et nokså grimt scenario.
    Bydén was absolutely serious and based his response on intelligence. The same intelligence was undoubtedly behind NATO Commander Perry's statement.
    The statements were no longer about the generals wanting to pester politicians to increase defense spending – they were about telling people that Finns, Swedes, Norwegians, and Estonians should mentally prepare for the possibility of war.
    And since the aggressor would be Russia, war would mean missile attacks on the civilian population.
    Iltalehti followed the JEF summit in Estonia in mid-December.
    In connection with this, NATO sources told and presented to IL what kind of attack Russia has been practicing on Finland, the Baltics and Norway.
    The attack would involve a simultaneous attack by several different Russian military units.
    In the north, the 14th Army Corps would attack the Norwegian coast from the direction of Murmansk by sea, land, and air.
    The Russians would send landing forces to Finnish Lapland. Russian missile forces stationed on the Kola Peninsula would also attack Finland.
    Tens of thousands of Russian soldiers would participate in the attack.
    In Lapland, the Russians would try to quickly seize Ivalo Airport, for example.
    Russia would try to create a buffer zone in Northern Lapland and Finnmark, Norway, that would shift the fighting to NATO territory. At the same time, the Russians would tie down allied forces.
    Stein 99
    Ja, uten USA virker fremtiden skummel. Vi, europere må folde våre hender og håpe at USA og Nato vil bestå og da har Russland ingen sjans.
    I Norge er det fokus på andre ting enn i Finland.
    Ja, f eks om man kan få landet en gjenkjøpsavtale for produksjon av tanks i en kommune med SP-ordfører. Det er strengt tatt ikke korrupsjon, men det begynner å bli et problem når vi snart kan behøve fungerende greier egnet for krigføring i det 21. århundre.
    erato
    Og luftforsvarets nye HK blir en distriktspolitisk sak i diskusjonen Bodø vs Rygge.
    Slikt fører gjerne til stadig nye runder av omkamper og uttværing, siden en mengde aktører foretrekker å hindre at noe skjer fremfor å ta en beslutning som ikke er optimal for deres egen hjembygd.
    Det ligger en del visdom i den finske drikkevisen.
    …NU!!!
    Aurora
    Ytterst i havgapet...
    Om det hadde vært mulig, så hadde Luftforsvarsstaben flytta alt til Rygge.... dvs kanskje ikke F35, for støyen hadde nok gjort at eiendommene deres ble noe mindre verdt...
    Terje-A
    Rygge er et naturlig sted å plassere HK, god plass, sentralt (lett for alle de utenlandske offiserene som skal jobbe der).
    Fjellanlegget på Reitan i Bodø er fullt og Bodø ligger langt unna resten av Europa.
    Men valget blir nok Bodø og da vil det koste milliarder i ekstra kostnader og ikke minst vil det ta så lang tid at Nato velger å legge det i den sørlige delen av Sverige isteden.
    I Norge prioriteres alltid distriktspolitikk foran nasjonale sikkerhetsinteresser. Alltid. :mad: .
    tjua
    Norske politikere er så marinert av oljepenger at begrepet prioritering er ukjent.
    Det er dessverre ingen plasser der Forsvaret kan bygge noe som helst. Det er alltid et sjeldent insekt, fugl, mose, gråstein, helleristning, hoppekreps, radarstråler, ødelagt natur, forurensing, lyd, lukt, våpen, kuler og krutt, eller rett og slett ukjente mennesker fra et annet sted i Norge, ofte fra syd som tar med seg damene når drar, som traver eller raver rundt i bøgda
    PowerMetal
    Må vel være mulig å kjøpe nok stinger og javelin tilsvarende det antall tanks og fly/helikopter russerne har i nærheten av Norge/NATO, uten å gå gjennom en 5-årig utredning i en komitè, som skal gi en rapport til et utvalg. Skjønner at større og mer avansert utstyr må ha lenger prosess, men det må være mulig å styrke forsvarsevnen raskere enn vi gjør nå.
    Deng1
    VestBredden
    Kjøp først og spør etter på - som i at det er lettere for og få tilgivelse enn tillatelse.
    PeterDa
    Melhus
    Nei da, vi har mange som må uttale seg om alt som forregår i det offentlige.
    Mange lag med papir pusjere, EU direktiver, etater, yrkespolitikere, influensere ( :p ) osv.
    Da snakker vi kun utredning , da er ikke anskaffelse i gang.... vi snakker russisk før varene er bestilt.
    Tweedjakke
    Market Snodsbury
    Eg trur kanskje problemet er at vi er i ein 1937-situasjon, med spengt produksjonskapasitet. Jf. Nammo-farsen.
    Eg meiner vel også at Noreg/Europa må byrja å vurdera om det er så frykteleg lurt å kjøpa amerikansk isenkram, men inntil vidare manglar vi særleg gode val.
    Deng1
    VestBredden
    Man bør uansett satse på flere leverandører, verden er for turbulent til og bare satse på en hest.
    Og man må virkelig og bygge stein på stein for og øke forsvarsevne!!
    Denne er leseverdig, selvom ifra 2022, og jeg mener at i 23 så ekspoderte det i interesse for "selvforsvar og bygging av skytterbaner"
    https://www.nettavisen.no/norsk-debatt/finland-vs-norge/o/5-95-469488
    Aurora
    Nå er vel skytterbevegelsen i Norge fortsatt relativt stor, noe man bl.a. kan se av interessen for landsskytterstevnet, men likevel er den liten i forhold til hva den var før og etter krigen. Jeg tviler sterkt på at konge, regjering og gullbeholdninga hadde kommet seg unna i 1940, om det ikke hadde vært for alle frivillige som stilte til oppholdende strid oppetter dalførene.... Legg så til at verneplikten i Norge er såpass uthult at de fleste norske ungdommer og unge voksne knapt vet bak-fram på et våpen.... Legg oggså til den stadig økende motstand mot jakt fra alle byfanter og -fantinner som i fullt alvor tror at kjøtt kommer fre super'n...
    Elmer
    Litt utafor topic, men.... Det Frivillige Skyttervesen (DFS) har ca 135 000 medlemmer. Landskytterstevnet som er et av Norges største idrettsarrangement mønstrer 4-5000 skyttere hvert år fra 830 lokale skytterlag spredt over det ganske land. Ikke akkurat en organisasjon på sotteseng, selv om den har vært større.
    tjua
    Det hardnes til
    Tipper vi får se samme opplegg, kanskje noe forkledd, fra trumpern om litt
    USA ser ut til å ville kopiere russerne på en rekke områder
    tjua
    Og vesten, med, ikke overraskende, trumpern i spissen slapper av.. dessverre noen bak i log
    Her er finlenderne sterkt uenig med annen vestlig etterretning;
    «..embedsmenn fra tre av landene som er involvert i etterforskningen av kabelkuttingene, heller mot at uerfarne sjøfolk og nedslitte skip er årsaken til de tre hendelsene der ankere som er dratt over sjøbunnen har ødelagt viktig undersjøisk infrastruktur..»
    «Men Finlands fremste forsvarspolitiker mener det er «rent pisspreik» å konkludere med tre uhell i Østersjøen.»
    Spennende siden finlenderne vel er de eneste som resolutt har grepet inn. Ingen andre beveger seg særlig mye til tross for vel dokumenterte anslag som det er vanskelig å finne andre som skulle stått bak.. eller kanskje det er ukrainerne som jazzer opp..
    PowerMetal
    Enig med Zelensky, må slutte å vente på USA og starte med å ruste opp egen forsvarsevne umiddelbart. Bør selvfølgelig prøve å smigre Trumpern og vise at vi kan øke investering i forsvarsevne på godt over 2%, med en årlig økning opp til 3-4% over noen år. Er en forskjell på å prøve å opprettholde forsvaralliansen og det å være totalt screwed uten uten.
    Er ikke godt å vite hva som skjer i USA fremover...
    tjua
    Men mat skal dem ha, fra NRK
    Rekordimport av russisk fisk til Norge – stadig mer russisk torsk landes i Norge
    Import av russisk fisk til Norge fordoblet seg fra 2023 til 2024. I 2024 importere Norge fisk fra Russland til en verdi av 1,2 milliarder kroner.
    Det viser handelsstatistikk fra SSB.
    Også landingsstatistikk fra Norges Råfisklag viser at til tross for nedgang i fiskekvotene økte landingene av torsk fra den russiske havfiskeflåten, i Norge, med 19 prosent fra 2023 til 2024.
    I 2024 landet russiske fiskefartøy 57.509 tonn torsk i de tre åpne norske fiskerihavenene. Det betyr at 33 prosent av hele den russiske torskekvoten ble landet i Norge i fjor.
    Handelen med Russland fortsetter å falle
    Norge importerte varer fra Russland til en verdi av 2,4 milliarder kroner i 2024.
    Det viser eksportstatistikk fra SSB.
    Det er en nedgang på 88 prosent siden 2021, og 20 prosent siden 2023.
    I tillegg fortsetter eksporten til Russland å falle og endte i 2024 på en verdi av 735 millioner kroner. En nedgang på 58 prosent fra året før.
    Det er fisk fra den russiske trålerflåten som er den største importartikkelen fra Russland, i tillegg til laksefor for oppdrettsnæringen.
    Sjømatnæringen står dermed for over 70 prosent av importen fra Russland i 2024.
    I tillegg ble det eksportert norsk jern og stål, og andre varer av metaller, til Russland for 260 millioner i fjor.
    Usikker på hvor hardt dette har sunket inn hos oss.. Egentlig
    Espen R
    Den USA-baserte tankesmia ISW: Putin har planene klare for å annektere og innlemme Belarus i det stor-russiske riket.
    Må jo være blind for ikke å se det komme. Dette har jeg tatt som en selvfølge. Luka har solgt landet sitt til Putin for personlig beskyttelse og rikdom, ingen tvil om det.
    otare
    Interessant:
    Syria har avsluttet leieavtalen med Russland til Tartus-basen.
    India har sluttet å betale for russisk olje.
    Russland sender bemanning fra atomrakett-baser til fronten som fotsoldater. De har ikke prøveskutt bæreraletter for atomstridshoder på årevis, og har brukt av arsenalet for bæreraketter til taktiske atomvåpen til å sende "blanks" mot Ukraina. De stoler ikke mye på sine egne atomvåpen og tørr ikke bruke dem.
    PowerMetal
    Kjipern, hadde håpet på at utstyret skulle vært tapt for russerne. Eneste håpet nå er at Ukraina skal klare å lure en sjødrone inn i skipene... som er lite sannsynlig
    Fivus
    «I’m not looking to hurt Russia. I love the Russian people, and always had a very good relationship with President Putin – and this despite the Radical Left’s Russia, Russia, Russia HOAX. We must never forget that Russia helped us win the Second World War, losing almost 60,000,000 lives in the process. All of that being said, I’m going to do Russia, whose Economy is failing, and President Putin, a very big FAVOR. Settle now, and STOP this ridiculous War! IT’S ONLY GOING TO GET WORSE. If we don’t make a “deal,” and soon, I have no other choice but to put high levels of Taxes, Tariffs, and Sanctions on anything being sold by Russia to the United States, and various other participating countries. Let’s get this war, which never would have started if I were President, over with! We can do it the easy way, or the hard way – and the easy way is always better. It’s time to “MAKE A DEAL.” NO MORE LIVES SHOULD BE LOST!!!»
    Gjett hvem? 😅
    Gjett hvem? 😅
    Aner ikke hvem det kan være.
    oen
    Portugal
    tjua
    erato
    Siste video fra Konstantin på Inside Russia på youtube er en interessant drøfting av indre spenninger i Russland og hvordan de er i ferd med å eskalere i vold. Folk går løs på hverandre siden de ikke kan påvirke ledelsen.
    Konstantin ser ingen lystelige utsikter for Russland. Verdt å søke opp.
