Prima Luna
  • Bjørn.H
    Det er jo bare vås.
    Ikke noe som heter eller kan kalles military grade ifm ny produserte rør.
    Militæret kjøper ikke rør. Spesifiserer ikke heller.
    Ingen tester rør mot militære spesifikasjoner.
    Kan du vise sertifikatet på de Kina rørene?
    Ta det helt med ro, og hell opp et glass øl til nytelse. Da jeg brukte uttrykket "military grade", var det ikke med henvisning til hvordan kinesiske produsenter selv markedsfører røret, men heller med tanke på hvordan 5881-rør generelt omtales og beskrives i reklame og produktpresentasjoner. Dette underbygges av følgende eksempler hentet fra ulike nettsteder:
    Built to rigid military standards, the MH 5881 will tolerate higher voltages than any other 6L6. In fact, they're frequently used as replacements for the old 7027 model in vintage Ampegs. Extremely consistent from piece to piece, the 5881 is used by Marshall, Soldano, Solo and others.
    Built to a standard reserved for the Military, these 5881 tubes will tolerate a higher voltage than a 6L6. Often used as an OEM tube for Marshalls, Soldano, Solo etc these tubes are renowned for delivering the tone that guitarist wants and expect from their tubes.
    The Harma 5881 is the button based Russian military valve that powered the Marshall and Mesa Boogie amps( STR 425) in the late eighties. This valve has bullet proof reliability and proven track record over decades of use in Russian military applications.
    So what is the difference between the 5881 tube and the 6L6GB tube? Answer: military ruggedisation. So the 5881 is built to withstand high g-forces as it was used in Russian fighter jets amongst other applications.
    The russian 5881 was born as 6P3S-E in the Saratov plant and was designed for the use in military vehicles and aircrafts.
    jan_rogert
    Hi-Fi entusiast++
    Har hatt 2 stk amp’er fra Primaluna.
    Prologue Premium og en EVO 300. Opplevde at EVO’en responderte veldig bra på rør rulling og kunne tune lyden bra til hyggere jeg brukte.
    Min beste bestykning etter mye testing blei til slutt:
    EL34: Mullard XF2, og XF3
    Telefunken 802S i front (v7/8)
    Amperex Bugle Boy neste (v6/9)
    Phillips Miniwatt ytterst (v5/10)
    Det spilte rimelig oppløst og luftig i toppen med bra tonal balanse og god kontroll i bassen.
    Pedal
    PrimaLuna Prologue Three er noe jeg har stående ubrukt. Slitte rør, men fungerer. Er det noe marked for slikt? Jeg har for lengst gitt meg med rør, og den bare står her.. Jeg kjøpte den så godt som ny i 2012.
    Øyensynlig en god rør-preamp. Dog uten RIAA. Ble (forsøkt) solgt en slik for 2 år siden. Kan jo høre med vedkommende hvordan det gikk:
    Audiomix
    Lett at rent vås blir fakta i HiFi verden.
    Vær helt sikker på at det ikke lages rør til militære standarder i dag.
    Hva skulle en oppnå bortsett fra mye høyere pris?
    Mil rør ble konstruert, produsert og (ikke minst) testet slik at de ble kvalifisert til bruk i militære kjøretøy, fly og båter.
    Hva har dette med HiFi å gjøre? Ikke ofte det oppstår større vibrasjoner enn en fis i et lytte rom🙂
    Ikke bare Mike Matthews (NS) som lot seg forføre.
    Bjørn.H
    Jeg har ingen som helst tro på at de røren vi kjøper nå stammer fra produksjonslinjer beregnet for militær elektronikk og sambandsutstyr. Jeg synes det hele er ganske morsomt likevel. For vår del er det lenge siden rør ble brukt i Forsvaret, dog holdt man i Sovjet, Warszava-pakten og Kina på rør lengre enn i USA/NATO siden radiorør er betydelig mer robuste mot elektromagnetisk puls, eller EMP, enn moderne halvlederbasert elektronikk. Om det fantes radio-rør i Forsvaret eller på Forsvarets lagre på slutten av 80- og på 90-tallet har det nok blitt skrotet seinest under nedskaleringen av Forsvaret på slutten 90-tallet og begynnelsen av 2000-tallet. Nå er hele Forsvaret stort sett gått over til digitalt samband, inkludert HV.
    Audiomix
    Litt pussig at Sovjet holdt på avlegs elektronikk som kanskje kunne overleve det store smellet.
    Mens mennesker ville vært døde som fluer.
    Dagens digitale og krypterte samband ville ikke vært mulig med rør.
    Akkurat som en rør basert DAC til Audio HiFi er umulig.
    Bjørn.H
    Det handlet nok også om det teknologiske forspranget i vest, og at det er kostbart å modernisere materiell. Funker det, så funker det.
    jokris
    For min egen del så har jeg alltid likt at de gamle rørene er av høyeste kvalitet , de som ble målt og plukket til militært bruk var i hvert fall så gode som de kunne
    Tror ikke en eneste produsent hverken produserer eller screener rør på den måten lenger
    Her hjemme skal jeg rulle litt rør i julen, hvis det blir tid
    Gleder meg til lytterom etter hvert , blir værende med PL utstyr , forsatt gir de meg en opplevelse av at musikken er det viktigste , og man kan rulle rør og synse når man føler for det
    god Jul alle sammen 🎄🧑‍🎄
    Laban MK3
    Plankebyen
    Vinner rekka blir som følger :)
    Preamp : Valvo GZ 34 likeretter
    Front rekke Mullard M8136 /cv 4003
    Katodefølger Philips Ecc 82
    Effekforsterker
    Gain rør Philips Ecc 82
    Driverrør Rca 12au7 cleartop
    Effektrør Mullard EL 37
    jokris
    Er det noen som kjører Pylon eller HORNS mummy med prima luna her ?
    Ivgubahta
    Skibotn . Sapmi
    Tja eg lpnte ett par Pylon Diamond Monitor bokhyllehøytalera av en kamerat for maaange år sia, huske bare att selv om lyden va bra nokk , så foretrakk eg Roksan Caspian fremfor min Dialogue Premium på disse.
    Men va kanskje ikke akkurat di her du lurte på, men heller de meire lettdrevne modellansom mala har tilbud på no
    jokris
    All informasjon kan vise seg å verdifull fremover
    Men ja er jade modellene jeg har kikket litt på
    Nå blir det nok ikke noe bytte , var bare oppgraderings syken som kortvarig kom på besøk
    Monterte isoaccoustics Gaia ll under triton one R og wellsound under dac og forsterker og da forsvant det fort
    Ble veldig bra imo
    jokris
    Lurte på om noen har bruks erfaringer med
    Prima luna evo100 phono?
    jokris
    Nå har jeg funnet kanskje den beste rør kombien i Dac og 400 i mitt oppsett
    Men med tid til overs om dagen så skal jeg nok teste videre
    12ax7 samlingen er ferdig gått over , så blir det å kikke igjennom 12au7 i dagene fremover
    HeyHo
    Kunne tenke meg å teste en PrimaLuna altså, den store friheten med effektrør er det vel ingen som kan matche.
    E.I.A.
    Satte i Psvane KT88 Z Treassure, den første serien, kjøpt fra Grants Fidelity 2011.
    Kan ikke for det, men jeg foretrekker KT88, på mine høyttalere.
    Har ikke andre El34 å sammenligne med, så skal ikke være for bastant.
    Psvane Art series innerst og Mullard ytterst, låter ganske ok😎
    Musikalsk flyt og klangfarger over klinisk presisjon.
    jokris
    Har forsatt ikke fått
    Testet KT88 hos meg , håper å komme dit en dag
    Er vel de og 6550 som står øverst på listen over kandidater
    Har funnet så mye nyanser og gleder med forskjellige el34 og 6l6gc at jeg ikke har kommet lenger 😁
    Kjører nå Gjennomgående Phillips i de kritiske posisjonene
    7316 i dac ecc186 og el34xf4 brown base dobbel D getter i evo400
    Forrige rør oppsett var Mullard fokusert fra start til slutt
    gjomle
    Kristiansand
    Vis vedlegget 1188457
    Her kjøres det også med KT88. Testet med EL34, men må innrømme at det låter «tynt og pistrete» sammenlignet med KT88. Mer kjøtt på beinet rett og slett med KT88. Mine er fra Mullard. Spiller gull sammen med Harbeth SHL5+!
    E.I.A.
    Tror jeg kjøpte Mullard KT88 etter en av dine glødende omtaler :cool:
    Har ikke fått testet de enda, gleder meg til det.
    jokris
    Når dere har byttet rør , har dere en spesiell spille liste , album som dere bruker for å høre eventuelle forskjeller?
    Selv pleier jeg å bruke ett album som har fulgt meg siden ungdommen
    The Clash - Sandinista albumet , har god kvalitet masse spacial sounds og variasjoner underveis
    jokris
    Nice , ja jobber med slik jeg også men faller ofte tilbake til gjennom lytting av trippel albumet først
    HeyHo
    På plass side om side med Jazz80.
    Har nappet ut el34 og satt inn JJ6ca7.
    Fy søren som jeg har savnet det trøkket, mitt absolutte favoritt effektrør.
    jokris
    Det er både inspirerende og spennende å følge med på hvordan vi alle finner våre favoritt rør sammensetninger
    Jeg skal nok teste ut flere nye varianter jeg også på sikt takket være denne tråden 😁
    I dag satte jeg inn Bugle Boy ecc83 i Dac , og nærmer meg en ren vintage Phillips rør bestykning, eneste jeg nå mangler å få tak i er disse Phillips GZ like retter rørene
    Den lyden jeg opplever nå stemmer med omtalene av disse klassikerne , jo flere jeg har fått inn jo bedre kommer det frem lydmessig
    Har allerede lagd meg en liten liste over ny produserte rør
    Naturlig
    Nevlunghavn
    Artig og interessant å lese om bruken og erfaringene med ulike rør.
    EVO 300 har 6 smårør originalt med PrimaLuna 12AU7, 3 på hver side h/v. Høyre er merket med V8, V9 og V10
    Et av rørene (V9) begynte å gi fra seg en pop lyd og ble erstattet med Mullard 12AU7.
    Lurer på hvilken funksjon frontrørene på EVO 300 har. Googlet og fant info: V8: buffer, V9: fasevender/driver og V10: Inngangsrør.
    Om jeg skjønner dette riktig er det for høyre siden V9, V10 av smårørene som betyr mest for lydgjengivelsen, V8 minst påvirkning?
    Jeg har 2 stk Mullard 12AU7/CV4003 og 2 stk Genalec Gold Lion 12AU7 tilgjengelig. Hvor bør de monteres?
    jokris
    Jeg hadde 300 før jeg gikk til 400
    Utifra egen erfaring med 400 så har de to rørene i midten, nummer 3 og 4 telt fra venstre mest å si for lyden , på de integrerte i hvert fall
    Jeg ville satt dine favoritter i midt posisjon. , latt de spille 30 timer og eventuelt forsøkt det andre paret
    Behold det du liker best i senter og sett de to andre ytterst på hver side
    Jeg har mye rør liggende derfor tester jeg ut de 4 andre også
    Husker jeg hadde dialog på det Amerikanske PL forumet og ble fortalt at man kunne tweake ørlite
    Med de andre 4
    HeyHo
    Spiller nydelig Evo 200, Nec på front.
    Har inne en bestilling med Watford Valves og Langrex så det blir mer morro også etter påske 😊
    Andy
    Nøtterøy
    Ser det har kommet flere leverandører av KT150 rør. Noen her inne som har sammelignet?
    Ser at Psvane sine har fått god omtale.
