Diffusor på frontvegg
  • Zerostat
    Strømmen
    Øker baffle-step med størrelsen på frontplaten (baffelen) lineært på høyttalere? På hvilken måte påvirker dette lydbildet typisk?
    Jeg ønsker å beholde og optimalisere omgivelsene for disse høyttalerne fremover innenfor rimelige grenser.
    Leste meg opp for mine høyttalere og fikk frem dette:
    Revel M126Be Overview
    The Revel PerformaBe M126Be is a premium 2-way bookshelf speaker with a 6.5-inch aluminum mid/woofer and 1-inch beryllium tweeter in a waveguide, rear-ported design. Its nominal sensitivity is 86 dB/1W/1m, impedance is 8 ohms (minimum 3.7 ohms), and published frequency response is 54 Hz–44 kHz (±3 dB). It uses a 4th-order crossover with high-quality components (film capacitors, air-core inductors) optimized for low distortion and wide dispersion.
    Does It Have High Baffle Step?
    No, the Revel M126Be does not have high (uncompensated) baffle step. Revel's design incorporates baffle step compensation in the crossover network, resulting in a flat, balanced overall frequency response. This is evident from independent measurements across multiple reviews:
    • On-Axis Response: Smooth and flat from ~300 Hz upward, with a minor dip (~2–3 dB) around 50–70 Hz due to port tuning and enclosure limits (rolls off sharply below 54 Hz). No rising trend toward bass, indicating compensation prevents excess low-end buildup.
    • Off-Axis and Dispersion: Excellent directivity control thanks to the waveguide; horizontal dispersion is 60–70° wide up to 10 kHz, with a slight narrowing above. Vertical response shows a small dip near the 1.7 kHz crossover, but no baffle-step-related flare.
    • Sound Power and Predicted In-Room Response (PIR): These aggregate measurements (weighting listening window ~12%, early reflections ~44%, and sound power ~44%) are notably flat, with minimal deviation (<3 dB) from 100 Hz–10 kHz. A compensated design targets this flatness; uncompensated speakers show a 4–6 dB rise in bass/mids on PIR.
    • Crossover and Diffraction Notes: The high-order crossover minimizes lobing, and the curved cabinet edges reduce edge diffraction (a contributor to baffle step). Reviews praise the neutral, uncolored sound, with no mentions of boomy bass or imbalance—hallmarks of uncompensated high baffle step.
    lydogakustikk
    Revel M126Be vil begynne å sende lyden bakover fra ca. 546 Hz og alt lavere. Baffelstepkompensjon har ingen betydning for dette. Det betyr at vil være fornuftig med tiltak som fungerer opp til ca. 547 Hz på frontvegg med de høyttalerne. Til sammenligning så sender ikke Vera Audio Coherence 12 lyd bakover før man kommer ned til 221 Hz.
    Zerostat
    Strømmen
    Spennende det du skriver. :)
    Antar at det er enklere å tilpasse jo høyere opp i frekvens en kommer.
    Dvs at jeg bør i første omgang konsentrere meg for området der den sorte og røde streken befinner seg i bildet. Området rød strek ryddes med EQ og den sorte med akustiske tiltak. For EQ kan jeg bruke RME ADI-2 DAC fs. For resten noe annet snacks! Kan jeg bruke noe av det jeg allerede har tro? ...kombinert med noe nytt?
    EQ i RME ADI-2 DAC fs:
    lydogakustikk
    Det er langt enklere å gjøre noe akustisk med frekvensområdet over ca. 80Hz.
    EQ til kanselleringer krever betydelig med mer effekt fra forsterkeren og kan dermed øke forvrengning. Greit å lytte til begge deler og ideelt sett løse det med enten flytting eller bruk av ekstern subwoofer.
    Frekvensresponsen er selvsagt viktig for riktig tonalitet, men tidsdomenet er også helt essensielt for virkelig god lyd. Og det fungerer i det store og hele ikke EQ til. Man kan ha frekvenser i nedre mellomtone og under som resonerer og henger igjen lenge tidsmessig som forkludrer mye. Og refleksjoner over 250/300 Hz som går utover over områder som tonalitet, klarhet, mikrodetaljer og som fortere skaper lyttetrettehet.
    Og et stort og omsluttende lydbildet som mange opplever som viktig psykoakustisk og som gjør at det låter enda mer engasjerende, krever helt spesifikke tiltak. Her finnes det flere veier og muligheter. Er mye spennende med akustikk.
    MakkinTosken
    Godseier
    Me? Just hanging around!
    Skjønner at bassen er viktig, men når du føler det er sånn noenlunde i boks, bør du låne et øye til det litt opp i frekvens. Prøve å samle responsen mellom kanalene. Om du kjører sinus på generatoren og huker av for "Frequency tracks cursor". Vil du kanskje høre at fantomkanalen "danser" litt ettersom du beveger deg opp og ned langs kurven. Selv om det kanskje vil oppleves subtilt, bidrar det til smøring av stereobildet. Ikke alltid så lett å fikse det, med mindre du har en viss symmetri og fasekoherens, men skriv det bak øret.:)
    steinost
    Lillestrøm
    @Zerostat
    Du har jo hvert hjemme hos meg, som mange kaller Glava hula :=)
    Blitt enda bedre bredde og lett å plassere ting i lydbilde etter att linjene ble bygget om til bånd.
    Er ikke mer en 3km opp til meg ;=) så bare å ta seg en spasertur igjennom Bråteskogen. Send meg PM.
    Zerostat
    Strømmen
    "mellomtone og under som resonerer og henger igjen lenge tidsmessig som forkludrer mye" Tor jeg kan høre dette ifm at jeg på visse frekvenser hører vokaler som får en litt mer tykk og "omph..." betoning. Kan dette stemme med hva du skriver? Akkurat som at en går over til å synge litt kraftigere med tunga opp i ganen. :eek: Ikke lett å beskrive dette.
    lydogakustikk
    Det er som regel langt mer artifakter i de fleste rom og oppsett enn hva folk er klar over. Det er først når man blir kvitt det og dermed får nye referanser man forstår hvor mye bedre det kan bli.
    Mye ligger begravet i tidsdomenet.
    Zerostat
    Strømmen
    Nettopp! Jeg skjønner nå at det ikke holder å bare slenge opp en haug med dempeelementer og diffusorer overalt uten målinger, lyttetester og en stegvis fremgangsmåte. Jeg forstår i hvert fall at rommet må jobbes med. Etter en del ommøblering av tuningelementene trenger jeg knapt å bruke EQ i RME, og resultatene er helt annerledes. EQ-en er likevel magisk hos meg. Jeg begynner å forstå sammenhengene her nå.
    Jeg nevnte at RME har en Loudness-funksjon man kan stille inn som man vil. Den er fantastisk.
    Tidsdomenet, ja – det tviler jeg ikke på. Å fokusere kun på frekvensgangen blir feil.
    Naturlyd
    Hobbyselger
    Som man spør får man svar. Fikk du med deg at Revelene dine har "høy baffelstep"? Er det den rette betegnelsen btw? Uansett, en konvensjonell høyttaler med smal baffel vil alltid bli rundtstrålende ved litt høyere frekvenser enn en med bredere baffel.
    AI oppgulpet i posten ovenfor tar forbehold selv om den svarer nei på spørsmålet. Og som man spør får man svar. (Har vi sett tap av liv fra AI bruk i Norge enda?)
    Zerostat
    Strømmen
    Ah, dette er da bare relatert til hvor stor/bred baffel er, og ikke høyttalernes elektriske konstruksjon ellers.
    Zerostat
    Strømmen
    Leser dette også via AI:
    Baffle Step Compensation in the Revel PerformaBe M126Be
    The Revel PerformaBe M126Be is a two-way bookshelf loudspeaker featuring a 6.5-inch Deep Ceramic Composite (DCC) aluminum cone woofer and a 1-inch beryllium dome tweeter with a 5th-generation Acoustic Lens waveguide. Its front baffle measures approximately 8.3 inches wide by 15.2 inches tall (211 mm x 386 mm), which influences the baffle step—a natural acoustic phenomenon where the speaker's output transitions from a dipole-like radiation pattern (below the step frequency) to an omnidirectional pattern (above it). This typically causes a ~6 dB rise in midrange output as wavelengths become comparable to the baffle's width.
    Revel does not publicly disclose exact baffle step circuit values (e.g., specific inductor or resistor in the parallel compensation network), as their designs are proprietary and optimized via extensive modeling. However, based on independent measurements and design analysis, the M126Be employs passive crossover-based baffle step compensation integrated into its high-order (approximately 3rd-order on the woofer, 2nd-order on the tweeter) network at the 1.7 kHz crossover point. This uses premium film capacitors and air-core inductors to achieve seamless driver integration, minimizing the step's audible effects while maintaining flat on- and off-axis response.
    Key Design and Measurement Insights:
    Baffle Step Frequency
    For an 8.3-inch (0.21 m) baffle width, the theoretical baffle step occurs around 800–900 Hz
    This is well below the crossover, allowing the woofer to handle the transition with compensation.
    Compensation Approach
    The crossover attenuates the tweeter slightly and shapes the woofer's response to counteract the step, resulting in a smooth power response. The Acoustic Lens waveguide further aids by matching directivity between drivers, reducing lobing and diffraction around the crossover. Minor diffraction effects appear at ~3 kHz and ~7 kHz in CEA-2034 measurements but are smoothed in-room.
    Frequency Response Summary
    (from independent tests; varies slightly by setup):
    Measurement TypeLow-End (-6 dB)Overall CharacterNotes
    On-Axis (Direct)54 HzNeutral with slight rise above 10 kHz; flat 200–5 kHzListening window average is exceptionally linear (±1.5 dB, 100–10 kHz).
    Predicted In-Room (PIR)50–55 HzExtended bass shelf for linear room response down to ~50 HzIncludes 12% listening window + 44% early reflections + 44% sound power; minor vertical dip at 1.7 kHz crossover.
    Horizontal DispersionN/A60–70° wide, balanced to 10 kHzConsistent directivity control; no prominent step artifacts.
    Bass Extension (Ground Plane)-3 dB @ 54 HzPorted alignment rolls off below 50 HzRear-firing port with dual flares minimizes chuffing; foam plug included for tuning.
    Performance Implications
    The compensation yields a cohesive soundstage with wide dispersion and low distortion (<0.5% THD up to 90 dB SPL). No uncompensated step is evident in measurements—response remains smooth without the typical 300–1 kHz "hump." This contributes to the M126Be's neutral voicing, though it benefits from a subwoofer for <50 Hz extension. Sensitivity is 86 dB (2.83V/1m), nominal impedance 8 ohms.
    For DIY replication or deeper analysis, the exact L-pads or parallel inductors aren't available, but simulations using tools like VituixCAD with the baffle's dimensions and measured drivers can approximate it. If you're measuring your own setup, tools like REW (Room EQ Wizard) can reveal room-induced step variations.
    Sources: Audioholics (detailed CEA-2034 spins), Erin's Audio Corner (PIR and compression data), SoundStage! Network (NRC anechoic curves), Revel specs.
    Naturlyd
    Hobbyselger
    Det du får presentert der er en sammenblanding av Revels egen salgsfremmende presentasjon av produktet og generell info om fenomenet baffle step. Alt bakt inn i språkmoddellens standard måte å presentere gjettingene på.
    Ettersom dette er enkel problematikk så har ikke språkmodellen rotet det til denne gangen ser det ut til. Men å presentere Revel sine påstander som "facts" gir meg frysninger.
    Hva skjer om du prompter med "uthev der info er hentet fra produsenten" og samtidig ber om at AIen skal være ekstra kildekritisk? Det har hjulpet meg de få gangene jeg har brukt AI til å samle info.
    Zerostat
    Strømmen
    Hva skjer om du prompter med "fremhev info hentet fra produsenten" og samtidig ber om at AIen skal være ekstra kildekritisk? Det har hjulpet meg de få gangene jeg har brukt AI til å samle info.
    Hei Hobbyselger, vi er alle selgere!
    Jeg er i gang med å endre akustikkprodukter og tiltak i rommet mitt. Har så langt fått med meg at jeg må skjønne hvilke høyttalere jeg vil bruke. Derfor har jeg interesse av å vite hva mine høyttalere skaper/avdekker av behov. Derfor fokuserte jeg på baffel step denne gangen og fant følgende: «For an 8.3-inch (0.21 m) baffle width, the theoretical baffle step occurs around 800–900 Hz» som jeg syns var interessant.
    lydogakustikk fikk meg til å tenke andre tanker i innlegg #48
    Zerostat
    Strømmen
    Jeg forstår at det er umulig å svare ja eller nei på spørsmål om akustikk, men våger meg likevel: Kan jeg se tidsdomenet i REW?
    Naturlyd
    Hobbyselger
    Kort innpå: jeg redigerte noe i den posten som senere ble sitert.
    Jeg skrev først at man kunne promte med "fremhev info hentet fra produsenten" men innså nå at det kunne tolkes av både språkmodellen og HFS lesere som at man ønsket at påstander fra produsenten (reklame) skulle fremheves (ytterligere). Det var ikke det jeg tenkte å foreslå, snarere tvert i mot.
    Redigerte til "uthev der info er hentet fra produsenten". Kan være nyttig når man vil være litt kildekritisk.
    Naturlyd
    Hobbyselger
    Baffle step er ikke en knivskarp grense 😊. Det er mer en gradvis overgang.
    Jeg fikk et intervall fra ca 520-817Hz basert på 21cm bredde fra en nettkalkulator.
    Det er vel mer enn bare bredden som kan påvirke men det er kanskje ikke viktig. Minnes det blir forskjell om man simulerer et stort vs et lite basselement på en gitt/lik baffelbredde.
    MakkinTosken
    Godseier
    Kan være lurt og kikke litt på hvordan andre skalerer. Du har jo zoomet deg ut av folkeregistret.:) IR feks kan 0-40ms og 0- -40db være en grei start
    Zerostat
    Strømmen
    Dette er var ikke et pent tilfelle! Måtte skru av alt sammen. Må nok selge alt jeg har og starte på nytt med noe enda verre. Kanskje Audiolense fikser!
    Flageborg
    Et sted må man begynne så back-to-basic med kun høyttalere kan være lurt
    før man legger teppe på gulv og setter hyller med vinyl langs veggene..... :unsure:
    Det lages også mange produkter man kan la være å bruke penger på (y)
    Zerostat
    Strømmen
    Tusen takk! Registrerte meg og gikk videre.
    Endret bare egen plassering. En helt annen imageing og soundstage. :eek: og ikke minst ballanse.
    Zerostat
    Strømmen
    «Når du sier “det finnes jo en hel haug med akustikk-greier man absolutt ikke trenger å punge ut for” – har du noe veldig konkret i hodet da? For jeg står her litt på bar bakke og trenger noe skikkelig å tygge på.
    Min sterkeste teori akkurat nå er at den frekke baffle step-en fra 300 Hz og nedover smeller rett i trynet fra frontveggen, samtidig som sideveggene og bakveggen spiller ping-pong med basseballene som om det var VM i refleks-tennis. Jeg har jo en hel gjeng med paneler og DAAD’s som var rene rockegudene i forrige leilighet – der sto de og så selvsikre ut og løste alt. Her står de bare og ser på meg med sånn “dette var jammen ikke det vi signerte for”-uttrykk.
    Så: Har du en klar formening om hva som faktisk ville flyttet nåla her, eller skal jeg bare legge alt ut på Finn.no, kjøpe meg et skikkelig par hodetelefoner og oppnå evig indre fred?» 😅
    Flageborg
    Det kan være du trenger litt frisk luft? :unsure:
    Muligens nullstille mest mulig og begynne med noen
    enkle grep kan være en grei begynnelse på fortsettelsen?
    Her er akkurat ramlet inn et slutt-trinn med peak på 4000 Watt
    som skal prøves ut de neste ukene og med såpass power kan
    det være akustikken blir utfordret mer enn tidligere.
    Du må gjerne ta turen hit for å få et inntrykk av diverse tiltak
    som fungerer glimrende i forskjellige rom og kan gi deg
    nyttig informasjon i flere lyd-settinger før du hiver deg på
    eget oppsett for n'te gang...... (y)
    Send PM så finner vi en passende dag ?
    Sven_Palvig
    Sjælland. Danmark.
    Er det da slik å forstå at frontveggen ikke vektlegges stort. Hos meg er denne av tykk betong. Andre steder er det gips med isolasjon bak. Så da kommer jeg et stykke på vei med å lime opp poly diffusorer på bakveggen, hive ut daad'ene og fjerne de platene jeg allerede har.
    Hvis jeg forstår deg rett, så er det første innlegget i denne tråden bakvendt, og dette et korrekt utgangspunkt. Vis vedlegget 1156506
    Min erfaring er, at Frontvæggen er den vigtigste væg i mit Lytterum, og det af mange grunde. En vigtig ting er, at du ikke hører lyd fra venstre højttaler, der kommer fra højre side af Frontvæggen. Lyden går tilbage og rammer Frontvæggen. Jeg har dårlige erfaringer med absorbenter, men rigtig gode med diffusere. Men de bør være tunge, fordi Frontvæggen er en trykzone. Meget bas. Frontvæggen påvirker dybdeperspektivet. Dynamikken. Fornemmelsen af et stort rum. Det er her du skal sætte ind som det allerførste. Diffuserne skal sprede i bredden, kaldet D1. I ørehøjde og gerne 60 cm under og 60 cm over. Over er vigtigere end under, på grund af ørets konstruktion.
    Den store diffusere på dit første indlæg, mener jeg er helt forkert. Dog har jeg ikke hørt den.
    Jeg har lyttet til Hofa diffusere som er D2. De spreder horisontalt og vertikalt. De skal kun sprede horisontalt på Frontvæggen. Samt siderne et stykke ned mod lytteren.
    Den på det store billede er D3 og er helt forkert, fordi den spreder lyden i 3 retninger. Det bliver noget rod, tror jeg. Men dem har jeg ikke erfaring med.
    Mine diffusere er 120 cm høje, men bør hæves lidt. Jeg vil løfte dem op på en hylde, der hviler på fliser.
    Jeg bruger ikke absorbering generelt, men dog foran den gule væg, der er for tæt på højre højttaler. Men det kommer an på, det enkelte rum. Er afstanden kort, skal der nok være absorbenter. Jeg har god plads. :)
    De sorte diffusere på Frontvæggen er fra SMT Svanå Teknik og hedder V-wings. De er i træ og de er tunge. 120 cm x 60 x 25.
    Dem ovenpå de store subwoofere er de samme.
    De to hvide er købt brugt. De er 18 cm dybe.
    Dem på sidevæggen er i pap og nogle man selv samler. Jeg har prøvet dem på Frontvæggen, men V-wings er klart bedst. Jeg har tænkt at sætte træ på siderne for at gøre dem tungere.
    De gullige hvide er fra Tyskland, men er kun 7,5 cm dybe. De er billige. Købt for at gøre rummet pænere. Jeg har krydsfiner foran vinduerne, og det er ikke det pæneste.
    Sevald
    Avviker.
    Aksdal, Rogaland
    Vis vedlegget 1161556
    De sorte diffusere på Frontvæggen er fra Svanå Teknik og hedder V-wings. De er i træ og de er tunge. 120 cm x 60 x 25.
    Du er dedikert😌 Skal ikke se bort fra at det låter pent hos deg😀
    steinost
    Lillestrøm
    @Sven_Palvig jeg har en diger bassfelle på nettopp frontvegg. Har enormt bredre og dybde perspektiv.
    Så der har vi forskjellige erfaringer. Hvor tykt har du prøvd å dempe?
    Jeg har ca 7m3 på frontveggen.
    Sven_Palvig
    Sjælland. Danmark.
    En basfælde på Frontvæggen er et godt sted at placere den, fordi det er en trykzone. (y)
    Jeg tvivler ikke på, at du har god lyd. Det man gør, skal man gøre godt. :)
    Jeg har ikke dæmpet med de tykkelser du bruger. Hofa absorbenter på vist 11 cm. er prøvet og tidligere med Rockwool på 2 x 10 cm. Men det er flere år siden, og meget vand er løbet i åen siden. Jeg vil også i dag være forsigtig med Rockwool og lignende. Derfor har jeg Hofa Absorbenter foran gul væg.
    Hos mig er musikken bag højttalerne med bredde og dybde. Så det er lykkedes hos mig, men jeg har også et dedikeret Lytterum og jeg har lyttet mig frem til en god akustik.
    Højttalerne er flyttet langt frem i rummet, og det gør, at musikkerne står bagved dem og spiller. Subwooferne står i hjørnerne og styres med miniDSP Flex, så der tidsforskubbes. Man har muligheder med et eget Lytterum på 34 m2.
    Zerostat
    Strømmen
    Har tro på at jeg har funnet en brukbar plass for meg selv og høyttalerne.
    Okay, Da skal jeg forsøke å finne noen pene diffusere å sette på frontveggen. Denne veggen er en tykk betongvegg.
    Kanskje noe sånt vi plasse hos meg.
    Artnovion Acoustics - Music Industry & Broadcast
    Blir dette for lite på veggen? 240/120 (veggen er 260x260)
    lydogakustikk
    Skal du gjøre noe med frekvensområdet under 550 Hz, hvor høyttalerne dine begynner omtrentlig og sende betydelig mer lyd bakover, så må du over på helt andre produkter.
    Hvis du i tillegg ønsker diffusjon på frontveggen, selv om effekten av det vil være begrenset sammenlignet med diffusjon på bakvegg og det ikke nødvendigvis utelukkende er positivt å diffusere begge steder (man diffuserer samme energi flere ganger), så må man kombinere en diffusor som slipper gjennom det rette frekvensområdet og ha et annet produkt bak.
    2D diffusjon bør du styre unna til veggene da de bare kaster vekk energi i feile retninger (vertikalt).
    Sven_Palvig
    Sjælland. Danmark.
    Zerostat, jeg tror ikke, at de diffusere dur, du viser.
    D1 diffusere bruger jeg og de er tunge. Jeg bruger D1 alle steder.
    Zerostat
    Strømmen
    Jeg har tenkt litt frem og tilbake på dette nå. Jeg tror jeg lander på det du skriver – at det er mye enklere å håndtere det akustisk for frekvensområdet over ca. 80 Hz. Du kan gjerne sende meg en melding eller starte en samtale her hvis du vil.
    Det som plager meg aller mest, er mangelen på klarhet, ekte nærvær og åpnehet.
    Rommet:
    Uten EQ og det står noe DAAD og demplplater rundt om uten mening
    Med litt eq ved 40Hz og 200Hz.
