  • BT
    Kineserne vet å smi mens russerene har det varmt.
    tjua
    ^sånn skal det være; egen og landets motivasjon kan gjøre underverker og personellet finner frem egenskaper de antagelig ikke selv visste da hadde.
    Det kommer til å bli mange filmer av dette, samt doktorgradsavhandlinger fra alle holde
    Listet opp Putins nederlag
    Kirby, som tidligere var admiral i Pentagon, var ikke nådig i sin beskrivelse av Putins suksess med krigen i Ukraina.
    – Putin har oppnådd, la meg telle ..., null av sine strategiske mål i Ukraina. Null, sa han.
    Jupp. Den siste karoliner ble tydeligvis igjen ved Poltava og er klar for oppdrag.
    Swedish military doctrine of the Carolean era was distinguished by its emphasis on aggressive action and shock tactics, the so-called gå-på (literally "go-on") method. This attitude stood in contrast to other European armies of the period, which were coming to rely increasingly on musketry, delivered in the form of volley fire by line infantry, to win battles.
    Gå-på tactics enabled the Caroleans to repeatedly overcome much larger enemy armies, as the psychological impact of their rapid approach and their steely discipline under fire, combined with their fearsome reputation, often served to unsettle the opposing troops even before physical contact was made. Moreover, if some enemy troops lost their nerve and fled then panic could quite easily spread through the rest of the enemy force, so a quick success against even a relatively small enemy unit was often enough to trigger a general rout.[19] The preference for aggressive action also served, perhaps counterintuitively, as a way to reduce losses, as it ensured that battles would be resolved quickly rather than degenerating into bloody attritional struggles, as often happened when two armies using volley tactics clashed. This was especially important for the Swedish army as it lacked the manpower reserves of larger neighbours like Poland-Lithuania and Russia, and thus could not replenish its ranks after heavy defeats.
    Det man mangler i antall får man kompensere i aggressivitet. Inte med en utredning från ett genusperspektiv.
    Jo, men kanskje ikke det mest effektive for å hive muskovittiske okkupanter ut av riket. Sikkert interessant nok for å katalogisere krigsforbrytelsene deres og holdningene bak, men det er kanskje ikke det jeg ville brukt som verktøy om man skulle storme en skyttergrav. :)
    Espen R
    Dette blir en operasjon for historiebøkene. Og for Hollywood.
    Vis vedlegget 947495
    Rekk opp hånda dem som leser dette og si at dem har guts nok til å kravle flere kilometer fremover på magen, i et terreng som er minelagt med 6 miner pr kvadratmeter, i kampen for å frigjøre fedrelandet.
    Skal være ærlig på at min hånd ikke er i været nå.
    Fivus
    Hvis en skal ta utgangspunkt i ratioen antall norske krigsfilmer og offer, ligger vi an til en ukrainsk bølge. Og de som mente at ukrainerne ikke hadde en sjanse bør pålegges å se hver eneste en.
    Espen R
    ….hadde nå enda denne filmen fått en lykkelig slutt ala hollywood, så kunne vi alle hyle av begeistring. Men det er langt fra gitt.
    tjua
    Fullt forståelig, men dersom du oppfatter at du er i en eksistensiell krig for deg, dine og ditt land er det slett ikke sikkert du tenker så mye på det når situasjonen kaller.
    Men tøft er det åkkesom og man må bare beundre ukrainerne.
    Jeg tar hatten min av hver dag for de, og håper at deres utholdenhet og pågang gir de resultater vi alle håper på og avhenger av
    Hønndjevelen
    Gleder meg til tragedie/komedie musikalen
    "Fred i vår tid"
    Basert på Chamberlain's etterlatte skrifter
    Starring:
    Macron og Merkel og Moxnes
    Espen R
    Det er sant at når situasjonen tilsier at du må være tøff og fryktløs, så kan du bli tøff og fryktløs.
    Vi alle lar oss imponere over det ukrainske folket. Det er nok historien som har gjort dem til det hardbarska folket dem er i dag.
    VDV i Pskov var i sin tid øremerket for innsats i vår retning. Disse troppetransportflyene deres vil ikke bli savnet.
    tjua
    "Fred i vår tid"
    Starring:
    Hørte nettopp at en tysker ved navn Scholz også ønsket å prøvespille for en rolle. Det var egentlig ikke så nøye hvilken rolle, any role will do Omså kun en liten birolle
    Ting endrer seg fortere enn selv eksperter forutser.
    Efter SVT Nyheters intervju med Emil Kastehelmi kommer uppgifter om att ukrainska soldater synts till på andra sidan av den första Surovikinlinjen.
    Espen R
    Uff. To ukrainske helikoptre har kræsjet nær frontlinjen, 6 soldater omkom.
    Tidligere i uken disse to jagerflyene som kolliderte.
    Men dette er krig, og da skjer sånt.
    PowerMetal
    Håper Ukraina har mange flere droner på lager, som gave til enda flere militære flyplasser i russland.
    Odd J
    Det ser ut til at de første ukrainske styrkene allerede er kommet seg forbi/gjennom surovikinlinja og kan rulle opp fra flanken. Antakelig kun lette infanteristyrker foreløpig, men det borger for raskere progresjon enn mange har antatt. Bra gjennomgang av dronekrigen og evolusjonen vi ser mot lettere og stadig billigere droner. De australske pappdronene er flatpakket og kan lett smugles rundt for angrep på militære mål overalt i Russland, i prinsippet.
    Som sagt, det begynner å ligne på noe.
    Fivus
    Vi får håpe, og bidra der vi kan.
    Dette ligner på et sjakkparti der det begynner å rakne for den ene parten. Brikker henger her og der, og til slutt er det opp til flere veier til sjakk matt.
    Tweedjakke
    Market Snodsbury
    Sjakk, og boksing: Det verste er den endelause pirkinga og prøvinga som tappar energi, og som må ta slutt, men der du garantert tapar om du kastar deg inn i eit angrep for tidleg.
    Eg er på lågt amatørnivå i båe greinene fordi eg har så lite tolmod (i tillegg til mange andre dårlege eigenskapar).
    Espen R
    Det er flere grunner til at jeg er betinget optimist på Ukrainas vegne. Det første er at djevelskap ikke lett forgår. Det vil si at Putin mest sannsynlig ønsker at denne krigen skal pågå lenge, om nødvendig. Og Putin har sine likesinnede som backer ham. I går ble det kjent at Iran har levert 600.000 nye artilleri granater og noen millioner nye geværskudd. I tillegg er det samtaler med Nord-Korea om våpenleveranser.
    Det er ett moment som jeg ikke har sett belyst i særlig grad. I en situasjon hvor eventuelt Ukraina tar tilbake land, f eks deler av Krim, vil det medføre at Ukraina må strekke ut styrkene sine over et større geografisk område, det blir altså stadig større områder å forsvare. Motsatt for russerne, dem får konsentrert styrkene sine på det gjenværende areal. Dette gjør ukrainerne sårbare for et større motangrep fra russerne. I en situasjon hvor Ukraina plutselig kommer i ubalanse og må flytte på styrkene sine, kan russerne utnytte situasjonen og gjenerobre områder som Ukraina har tatt tilbake. Dette vil virke demotiverende på Zelenskyjs menn, spesielt om tapene har vært store.
    For ca ett år siden sa Geir Håkon Karlsen at dette mest sannsynlig blir en langvarig og svært blodig krig hvor dynamikken i krigen vil bølge frem og tilbake. Det meste tyder på at han får rett.
    Wishmaster
    ^ Å forsvare Krimhalvøya hvis det blir frigjort fra russerne tror jeg ikke blir så stor utfordring for Ukraina. Hele østkysten av Krim er bare en lang sandbanke med innsjø på innsiden som gjør hele dette område uegnet for en invasjon. Fra Sevastopol og østover er det en fjellkjede på godt over 1000 meters høyde som gjør denne strekningen uegnet. Da gjenstår det bare to alternativer, enten oppover vestkysten eller rett over Kertsj stredet. Det første alternativet krever en båttur på minst 400 km og med tanke på hvor overvåket dette område er, vil det være enkelt å oppdage et slikt antall båter som vil være nødvendig for å få fotfeste på Krim igjen, og da vil det også være god tid på å flytte ukrainske styrker for å ønske dem "velkommen tilbake". Siste alternativ er det relativt smale landområde mot Kertsj stredet og det er bare 20-30km bredt noe som gjør det enkelt for en mindre styrke å forsvare. Det vil også være vanskelig for russerne å angripe på flankene pga den tidligere nevnte sandbanken nordover og fjellkjeden som kommer inn fra sørvest hvis russerne er i stand til å sette styrker i land. I tillegg vil dette kreve større mengde soldater og båter på russisk side som kan bli observert av droner eller satellitt på forhånd. Og, russiske artillerikanoner rekker knapt over Kertsj stredet fra russisk side, så de kan ikke bruke kjent taktikk med å teppebombe område først heller. Dette vil være en utfordrende øvelse for russland, tror jeg...
    Odd J
    Ukraina har utviklet missiler med 700 km rekkevidde leser vi. Bør de ta ut den digre Kertsj-brua en gang for alle nå?
