  • kasol
    Robin Horsfall
    Robin Horsfall
    • Following
    Former SAS Soldier. Writer, Veterans Campaigner and Public Speaker. Operations Nimrod and Mikado
    24m • Edited • 24 minutes ago
    Putin's terrorists will attack you where you are weakest.
    Ukraine is creating absolute chaos behind the Russian lines especially in Crimea. Attacks on three airfields, on the Sevastopol HQ and early attempts of the Kerch Bridge are leaving Russian Forces with nowhere to hide. Whether the attacks are being mounted by drones, HIMARS. Special Forces or local partisans it is clear that there is an organised and coordinated method to these operations. They are not simply raids. They are targeted at command structures, air defences, aircraft, fuel and ammunition supplies and supply routes.
    Back at home the attempted murder of Putin ally, Alexander Dugin by bombing his car will leave Putin searching for someone to blame (even if it was him). Is it Ukrainian or Russian agents who are planting bombs under cars in Moscow?
    Minor Russian advances continue in Donbass but at an ever greater cost. While Chechen mercenaries fight for Putin a larger number see the war in Ukraine as an opportunity to gain their own freedom from Russian oppression.
    Zelensky's growing confidence became clear when he stated that there would be no peace without the return of Crimea. Russian civilians are retreating back home across the Kerch Bridge partly from fear and partly because school starts again soon in Russia. They carry news about the destruction of Saki Airport with them.
    The next two weeks should open the cracks wider in the Russian defences. However, my words of warning are to Ukraine. Be careful when you gather on the streets to celebrate your Independence Day. Putin's terrorists will attack you where you are weakest. Vigilance and high security is essential at home as well as on the battle field.
    Slava Ukraini!
    Who Dares Shares
    Robin Horsfall
    BurntIsland
    ^jeg trodde han hadde klart å komme seg ut?
    "In an exchange of messages on Telegram this week with The Washington Post, Filatyev said he knew that posting his views carried risks. Though technically still in the army, he left Russia this week with the help of the human rights organization Gulagu.net. He declined to give his location because of security concerns."
    Til ingens store overraskelse:
    Det jeg ser om bilbomben i Moskva tyder forresten på at Dugina selv var målet, og at det handlet om noe pengegreier i mer lyssky kretser. Bilen var hennes egen, og overvåkningskameraene på parkeringsplassen hadde blitt satt ut av funksjon. Det er ikke helt klart eksakt hva som lå bak, men ting tyder på et internt russisk mafiaoppgjør heller enn noen forbindelse til «spesialoperasjonen». Men man hadde vel ikke erklært landesorg om Dugin selv hadde gått med også.
    Tweedjakke
    Market Snodsbury
    Tja. Eg veit ingenting om denne gruppa, heller ikkje om det er sant at dei står bak. Det er ikkje heilt ukjent at slike grupper tek på seg ansvar for aksjonar dei på ingen måte står bak.
    Uansett, eg er ikkje veldig entusiastisk til drap på forfattarar, journalistar og "ideologar" som politisk metode. Ok, det er kanskje slik det vert i ein stat som den russiske, men akkurat denne får eg lite lyst til å klappa for.
    JMM
    Slava Ukraini!
    Fredrikstad
    Som man høster, osv.
    Jeg klasker gjerne henda sammen en gang eller tre når en person som har ivret for, hyllet og høylydt heiet på folkemord og krigsforbrytelser selv biter i gresset. Skulle gjerne sett det var to i bilen.
    Står mere her:
    Uansett om det stemmer eller ikke vil det fyre godt opp under paranoiaen i Moskva.
    BT
    Faren er jo kjent som Putins hjerne. Sånn i tilfelle noen trodde han hadde en egen.
    erato
    The natives are gjetting restless.
    Dette er bare ett av mange tegn på noe som er i ferd med å bli definerende for utviklingen. Mer og mer intern støy i takt med at russiske fremganger helt har stoppet opp. Og med at det russiske militæret blir mer og mer desimert.
    Tweedjakke
    Market Snodsbury
    Eg veit ikkje kor treffande det epitetet er; det spørst vel om ein trur at Putin fyrst og fremst er driven av ideologi eller om han er ein pragmatisk oligark som gjer alt for å sikra seg og venene sine og grip til alt som kan skapa oppslutning.
    Inntil nyleg var Dugin først og fremst kjent i vest, trur eg, i tilknyting det besynderlege "alt-right" i USA , eller "dei identitære" i Europa (som ideolog på linje med Alain de Benoist), understreka av at han er omsett til engelsk av kona til Richard Spencer og utgjeve på Arktos forlag. Desse rørslene har heia på både Trump og Putin, men når det galt Trump passa iallfall han på å halda tydeleg avstand.
    otare
    Det interessante i dette er vel egentlig at det begynner å ulme litt i deler av den russiske befolkningen. Jeg tror ikke et øyeblikk at dette er noe Ukraina står bak. Hvorfor skulle de gjøre noe slikt?
    H
    Hardingfele
    Det har jo vært klart fra starten av. Men slik går det når man har en dysfunksjonell og servil kultur i statlige organer. Bemannet av korrupte og lite kompetente mennesker.
    Vis vedlegget 843181
    Sikkerhetstjenestemenn: Russisk etterretning misforsto Ukraina og villedet Kreml | ABC Nyheter
    Dr.E
    Ja, ganske opplagt at russerne innbilte seg at Ukraina var lett å rulle over og at ukrainerne var underlegne, uorganiserte og viljeløse.
    Men det er jammen godt gjort å ta så feil, selv om vi gang på gang detter i den fellen. (Jeg viser til den lille signaturen nederst i innlegget).
    Tweedjakke
    Market Snodsbury
    Nei, det verkar fullstendig irrasjonelt. Det er minst fire andre forklaringar som er meir truverdige:
    1. Indre oligark/mafia-maktkamp
    2. Reelt "russisk" opprør etter mønster frå bombe-anarkistane på slutten av 1800-talet.
    3. Dugin er så uviktig for Putin at han kan ofrast i ein "false flag"-operasjon, og legitimera auka indre kontroll/undertrykking i Russland (tenk "Riksdagsbrannen")
    4. Dugin, med ein ideologi som passa veldig godt som forklaring på Putins utanrikspolitikk dei siste 15 åra, er plutseleg ein "liability" dersom Putin ønskjer handlingsrom til å avslutta denne krigen på ein fornuftig måte.
    Når det gjeld den "russiske republikanske armén" er det interessant
    - om denne finst
    - kven som dreg i trådane om han gjer det
    - kven som lèt som han finst om han ikkje gjer det
    - om denne armen om står bak
    Eg tenkjer/trur at dersom Ukraina (eller ein alliert av Ukraina) står bak, så er det i så fall ved å la ei ikkje-eksisterande gruppe ta på seg skulda for ei brannbombe dei ikkje hadde noko med.
    tkr
    Nede i fjæresteinene
    H
    Hardingfele
    - om denne finst
    FSB er uenige og legger skylden på Ukraina. (Så kan man mene hva man vil om det, men det får sine følger).
    weld77
    Gass, gass gass
    Gassprisen til nye ekstremhøyder: – Markedet har jo egentlig sluttet å fungere | DN
    – Det er bare helt «insane,» sier Schieldrop.
    – Dette blåser hatten av alle konsumenter og industri og alt som er.
    Tidligere på morgenen sendte han ut et notat til kundene sine der han argumenterer for at situasjonen ligger an til å bli enda verre utover høsten og våren. Her påpeker han at det vil være en stor feil å la seg lure av gasslagre som ligger nær normalstanden, fordi Russland og president Vladimir Putin ikke vil nøle med å redusere eksporten enda mer, spesielt når det blir kaldt og gjør ekstra vondt.
    – Mange har fått for seg at nå har vi normale lagre, så derfor er vi nærme «peak crazy» i energi. Men normalt er ikke lenger normalt. Normalt står i en relasjon til at vi får normalt med gass fra Russland. Og det gjør vi jo ikke, understreker analytikeren.
    – Det er en konsekvens av en megatabbe som EU har gjort: At de har trodd at Russland er blitt et annet Russland enn det de var under sovjetunionens tid, hvor Russland var på vei til å åpne opp og gradvis vende seg mot Europa, og at det da var greit å ha 40 prosent av gassimporten sin fra Russland. Det var uimotståelig fordi det var så billig og bra med gass fra Russland. Men det viser seg at det var det dyreste valget Europa kunne ta. Både for den geopolitiske og energipolitiske selvstendigheten, har dette vært verdens største og verdens dyreste tabbe for Europa. Alle alternativer hadde vært grisebillig i forhold til dette katastrofale valget.
    Europa ligger i år an til å bruke mer enn 1000 milliarder euro (nesten 9800 milliarder kroner) på kull, olje og gass, nesten tre ganger mer enn normalt, anslår Schieldrop.
    Schieldrop tror likevel at Europa etter hvert vil tilpasse seg. Det kommer til å bli brukt mer kull, men det kommer også en massiv bølge med energieffektiviseringstiltak og infrastruktur for mottak av flytende gass, for eksempel.
    – Vi tenker at fra 12 måneder, da klarer vi oss relativt bra. Da har du fått kompensert for mye, sier Schieldrop.
    otare
    Nettopp. Man trodde at russerne faktisk hadde pålitelig informasjon om tilstanden i Ukraina og var forberedt på det de møtte.
    otare
    ^^Jeg trodde de ville beholde broen operativ, men gjøre den ubrukelig for tunge kjøretøy.
    Andre muligheter:
    Wishmaster
    Russerne har ikke lært mye siden invasjonens første dager hvor de ikke bare stod tett etter hverandre, men også side om side. Litt uheldig bruk av fyrstikker og sigaretter der så....
    otare
    Skulle til å legge den ut selv, Asbjørn. Utdrag:
    Some unanswered questions:
    • Who was the actual target, Dugin or Dugina? Some claim it must've been the former, because why would someone assassinate a 29-year-old, when her father was the true lightning rod? Yet other reports claim the car was registered to Dugina. Honestly, not sure we can trust anything coming out of Russia right now.
    • No, Ukraine wasn’t involved. Russia’s propagandists immediately pointed their fingers at Ukraine, happy to gin up outrage and support for further escalation in Russia’s brutal, murderous invasion. Yet none of that makes sense. If Ukraine had that kind of murderous capacity, there are better targets than a young wannabe fascist. For example, Russian command and control—generals and other top military leaders. There’s no tactical or strategic gain in assassinating Dugina, and for good measure, Ukraine firmly denied any involvement—a stark departure from the wink-wink “denials” of attacks on infrastructure on Russian soil.
    • Was Putin involved? There is a long history of Putin offing enemies … and friends, if it serves a broader purpose in his Machiavellian machinations. Heck, it could even be a false flag operation to spark outrage among Russian citizens, creating space for mass mobilization or other escalatory measures.
    • Did Dugina make her own enemies? One Russian journalist wrote, “Dugina was involved in the theft of money that the Kremlin allocated to finance the election campaign in France - Le Pen. The money never reached Marine. The same thing happened with European anti-globalists. The girl is a rat. But they wanted to remove the daughter and father." Again, not a lot of confirmation. But if true, that would piss off the FSB, the Russian intelligence agency tasked with International ratfuckery, and it would piss off mafioso-style European far-right Nazis. Neither is a great enemy to have.
    Jeg lurer faktisk på at det var Dugina som var målet. Dugin blir sett på som en skrulling. Allerede på 90-tallet skrev han at Russland skulle ta Tibet og nordlige deler av Kina, det gamle Indo-Kina (unntatt Virtnam av en eller annen grunn) og Australia (China was not amused...). Og nå nylig ta over hele Europa fra Portugal og østover. Han fikk sparken fra universitetet han jobbet på og kollegaene hans mener han var sprø.
    Dugina har vært involvert i "shady dealings" med den russiske mafian. Det var ikke spesielt lurt tror jeg.
    E. Largo
    Disco Volante
    Det er vel litt forsiktig å kalle Dugin sprø. Hakke gal er vel mer passende.
    Jeg sakset dette fra Wiki siden hans.
    In 1980, Dugin joined the "Yuzhinsky circle" [ru], an avant-garde dissident group which dabbled in Satanism and other forms of the occult.[34][35] In the group, he was known for his embrace of Nazism which he attributes to a rebellion against his Soviet raising, as opposed to genuine sympathy for Hitler.[36] He adopted an alter ego with the name of "Hans Siever", a reference to Wolfram Sievers, a Nazi researcher of the paranormal.[37] Studying by himself, he learned to speak Italian, German, French, English[38] and Spanish.[39] He also discovered the writings of Julius Evola in the V. I. Lenin State Library, and adopted the beliefs of the Traditionalist School.
    Enig, det ser mest ut som FSB/mafia (en og samme sak). Det er tre dødssynder i Putins Russland: 1) Kritisere Putin, og 2) stjele mer enn hva som er akseptert for ens posisjon i hierarkiet, og 3) stjele fra noen som er over deg i hierarkiet. Dugin sr ser ut til å ha brutt #1 (hvor f eks Girkin er nøye med bare å kritisere de under), og Dugina ser ut til å ha brutt #2 og #3 hvis hun har tusket til seg FSB-penger som skulle til Le Pen. Det blir høye livsforsikringspoliser av sånt.
    otare
    Russland har invadert land før. Her fra Praha 1968:
    Tsjekkia er et av de landene som er mest avhengig av russisk energi, og samtidig et av de landene som støtter sterkest opp under støtten som gis til Ukraina. De har dyr strøm, dyr gass og dyr bensin, men det spiller liten rolle. De vet hva det vil si å leve under russisk overherredømme.
    Gubra
    Vis vedlegget 843232
    Samme stridsvognene som nå….😂
