Mye av det som skrives her, blir for teknisk innvikla for meg - jeg må bare innrømme det. På den andre siden; Jeg er ikke plaget med hard/skarpt/tynt/klinisk/spisst eller anemisk lydbilde. Kan det være at Densen's forsterkerdesign er bra? Veldig bra? Her er et sitat fra Thomas Sillesen, sakset fra Densen's jnternettside:
"With the introduction of the new DM series all Densen models are zero-feedback designs. This means there is no feedback loop in the amplifier. The problems connected with feedback technology are the following (whether it is low or high feedback): The signal always takes some time to pass through the amplifier stages, therefore the comparison of input andoutput is not the comparison of exactely the same signal. This means that the theory that feed-back should improve sound by avoiding influence on the signal from the amplifier stages is simply theory and not true.
The fact is that feedback -no matter what degree- alters the signal and the result is: -dynamics will be compressed, -micro details compensated away, -details smeared, -soundstage altered, -speed slowed down, -transparency smeared and so on.
Naturally you will not have these problems with a zero-feedback design.
However the basic design must be extremely much better than feedback designs, otherwise the amplifier will not be stable. We are one of the few companies in the world (the only one ?) capable of doing this and the result of this is simply stunning, the combination of a MUCH better basic design and the zero-feedback technology results in: Extreme dynamics, detaillevel, amount of microdetails, perfect soundstage, transfer speed, transparency, and wide open sound. Combining this technology with the extreme care we take in the listening tests, during the development of our products, we can proudly say our amplifiers combine perfectly, high technology with extreme musicallity. In the future ALL products from Densen will be zero-feedback designs."
Det går an å få fram godlyden uten rør... ;D
mvh. VilhelmW
