Audio Notes venner
  • wizard
    The Legend, hvis du trodde Gaku On var veldig dyrt, det er ingenting ift disse.
    Alle får navn etter musikere.
    Da de er modulære kan man bestille hvilket utgangs rør man hvil, f.eks. 845, 211, 212D, DA100, 300B osv.
    Her Julius Katchen som var en pianist fra USA.
    “The circuit design on JK mostly references the Gaku-On. A simple and direct balanced signal is first input through the input transformer, then through the VT25 direct heating triode valve for primary amplification, and then through a 1:1 intermediate stage transformer, coupling to the output stage, directly driving a pair of parallel amplified 211 direct heating triode power tubes, and then transmitted to a super large output transformer.
    The only passive components on the entire signal path are two non-magnetic tantalum film silver wire resistors. There are no signal capacitors, so the circuit is simple and clear!
    The input transformer accurately and smoothly passes the music signal transmitted from the pre-stage, so it can eliminate any possible signal interference. The input transformer core is made of Mumetal and wound with silver wire. The precise winding technique makes the positive and negative nodes of the balanced transmission signal completely symmetrical, which can completely eliminate any hum or noise. The JK uses a special coil winding technique, where the primary and secondary coils are almost perfectly coupled, so the secondary coil does not require any resistive damping, and the grids of the VT25 and 211 valves can be simply cross-connected by the magnetic field generated by the silver coil.
    Similarly, the JK’s intermediate stage transformer uses more silver wire that that wound on the Gaku-On’s larger C Cores… Andy especially emphasizes that the power of this 5% upgrade should not be underestimated, because it fundamentally changes the crystal structure of the alloy, which in turn makes the production much more difficult. They worked closely with the transformer factory on the production, and adjusted the alloy heat treatment procedure both through data analysis and listening experience. All adjustments were based on the replay of music. … The resultant music signal has excellent extension on high and low frequencies, and the balance of the full frequency is also excellent.”
    Håkon_Rognlien
    Ja hører det når jeg kommer til UK, skal høre på de AN nivå 5 elektronikk.
    Er det ikke stille nok, har jeg noen alternativer fra produsenten av høyttalerne.
    Hvilke AN forsterkere er ikke stille nok av de dere har hørt?
    Men bruker man de modellene med balanserte inn og utganger, går støyen mye ned.
    Vet ikke hva CMRR og forvrengning specs er, men på de dyrere modellene brukes my-metall på inngangs trafo.
    Nyere utgaver AN-produkter er dørgende stille også på høyttalere med høy virkningsgrad. Enkelte rør kan støye noe, men det er mulig å løse ved å finne feilfrie rør. Min P3 Tonmeister støyer ingenting på 100 dB høyttalere i alle fall, det samme gjaldt også min forrige AN-forsterker, P2 SE Signature.
    Det er korrekt at eldre AN-produkter ofte var ganske hørbare, men det begynner å bli noen år siden nå.
    wizard
    Her Moura Lympany med DA100.
    Utgangs effekt 30 watt.
    The Solomon.
    I sort lakk, vet ikke hvor mange par AN har solgt til nå, men det er nok ikke mer enn maks 10 par pga den ekstreme prisen.
    wizard
    The Legend med 212D blir et utrolig design.
    Trodde det store røret var vanskelig å drive, men de trenger bare ca 150V fra driver røret.
    Utgangs effekt er 50 watt.
    The Legend er klart nivå 6, kanskje opptil nivå 7...
    wizard
    Jeg har hørt Meishu Tonmeister på Klipschhorn, som har 105db følsomhet. Det var tyst som i graven.
    Fra EML "A quick way to test the noise level of your amplifier-tube combination is, to measure the AC signal out of the amplifier with the inputs muted, but the speaker connected. Anything below 3 millivolt at 8 Ohms is a good achievement, and such an amplifier below 1 millivolt can be called a fine piece of work."
    Høyt produsenten jeg skal bestille fra designer også effekt forsterkere, de har 0.5 mV, AN har nok det samme.
    VB
    Tror ikke jeg tør å uttale meg om høyttalerne ennå, for det var så overveldende og uforventet lyd i disse.
    Må finne ut om det er noe som lurer meg her.
    Bassen er helt i en egen klasse i forhold til det meste jeg har hatt i hus. De står kanskje litt vel nærme hjørnene. Må justere litt. En enorm tilstedeværelse av vokalisten.
    Dette var gøy.......veldig gøy.
    Men så var det stativer da.
    Jeg tror de originale AN er litt for høye
    Kunne tenkt meg noen på 22 cm
    Havna i feil Audio Note tråd?
    wizard
    Mer om The Legend:
    “The JK uses three power transformers designed by Andy Grove himself… The power supply transformers and choke coils are made of custom-made high-quality copper wire. All internal wiring is done with Audio Note’s silver wire (parts are even with the flagship-level AN-Sootto). The power supply and decoupling capacitors are top-quality: Black Gate VK, Black Gate NH non-polar and Black Gate N… It is evident that each and every design detail of JK is well thought out, and the production process is bound to be meticulous.”
    “The clarity and detail in the effect of the music replay have been significantly improved. When there is no music, the background noise is a pitch-dark silence. The sound is denser, and the extension of the high and low frequencies are much further. The improvement in these sound effects is at least two-folds compared to Gaku-On.”
    wizard
    AN har solgt de med 212, 845, 2x211 og DA100 til nå.
    Nærmer seg fort 1 MNOK tenker jeg. Helt tussete prising selvsagt. Og de har varslet prisøkninger over hele linja.
    xerxes
    Holmestrand
    Det holder vel ikke til en halv en en gang?
    «The most expensive AN-E is another field-coil speaker, the AN-E-SOOTTO Ltd., at $395,000/pair.»
    wizard
    Trodde faktisk de var enda dyrere.
    Det er 2 modeller ovenfor de, Sogon Ltd Silver Signature, den eneste forskjellen imellom de er at Ltd Signature bruker kobber mylar kondiser i filteret,
    Ltd Silver Signature bruker sølv versjonen.
    Toppmodellen er Sootoo Ltd Silver Signature.
    wizard
    Sjekket priser på kondisene som er brukt i filteret.
    Vet ikke eksakte verdier men f.eks 1 stk 3.3uF kobber foil pris er 1750,-, mens sølv versjonen koster hele 38000,-!?
    Skal man ha 6 stk som det er i det eksterne filteret - 228000,-....
    Pluss 2 stk sølv spoler og Sogon LX kabel.
    Og det er 2 av de, ikke rart det blir dyrt.
    Også veldig stor forskjell på Sogon vs Sootoo kabler, Sootoo er nesten dobbelt så dyre.
    Deng1
    VestBredden
    Imo så er fieldcoil et blindspor, heller lete etter rett element og DSP, bedre billigere og mye bedre.
    Men den dagen AN får seg DSP er vel helvete blåfrossent ;)
    Deng1
    VestBredden
    Hei. Det var da enda godt, at det var din mening.
    Kjell
    Ja, min mening, og så er vel 99.9 % av resten av vi som driver med dette i verden enige med meg.
    Hadde fieldcoil vært et så stort sprang i kvalitet og enkelt og få til hadde vi sett mange flere slike oppsett.
    Og det er noen av de dyktigste her inne på DIY som har prøvd dette, med meget bra strømforsyning, allikevel har dem gått videre ;)
    Fieldcoil er nok morsomt og prøve og se hva en kan tune lyden med driveren, men når man har funnet ut hva som er best, så blir det jo slik resten av tiden. Men igjen, det er en Eq - og det finnes flere alternativer.
    Dette er en vennetråd og jeg lar det ligge med dette. Viste høyttaler har en meget snasen kabelgjennomføring!! :)
    Audiomix
    212???
    Like morsomt som å kaste bunker med 1000-lapper i sjøen?
    Som å gå baklengs inn i fremtiden.
    jane
    Utfordringen er ikke 150v men å holde driveren linear ved overgangen fra klasse A1 til A2.
    Før i tiden ble dette ofte løst ved en beefy driver og step-down, nå kan jo det meste løses med solid-state (men det er jo litt juks, da :)).
    kjellben
    Hei igjen. Veldig bra du sier dette, for dette er en vennetråd for de som ikke er kranglefanter som tror de vet bedre enn andre hva som er god lyd.
    Kjell
    BeetleBug
    Field Coil gir deg ofte en annen lydsignatur som en del syntes er OK. Dette kan man også lese i testen til Stereophile.
    wizard
    212???
    Med den ekstreme prisen på The Legend, så har man råd til å betale 20' pr stk for 212 røret.
    Rallar
    Hadeland
    Har en Audio Note Dac 3.1x Balanced på lån og gud hjelpe meg for en lyd som fyller rommet her nå, det er så gøy og få prøve dette i egen stue, en utrolig mellomtone, nydelig varm klang, mer kjøtt på beinet, en meget god match med Luxman er det også. Skjønner at folk blir hektet på dette merket.
    jabbalabba
    Ferietid og testing av "nye" Svetlana NOS 6L6 GC i Soro'en.
    Må bli toppløst (enn så lenge),.da rørene er litt for høye til å få på topplokket.
    Klart beste effekt rør jeg har hatt i denne så langt 🤩
    jabbalabba
    Rørene blir bare bedre og bedre, så en semi permanent løsning måtte på plass for å få løftet lokket.
    Ble ingen design perle, men bedre enn å kjøre toppløst.
    Skulle hatt sorte skruer, men det blir en billig oppgradering på ett senere tidspunkt.
    For helhetens skyld fikk dac'en samme behandling.
    rca45
    Vest for svenskegrensa
    Litt rør-nerding...
    Jeg har en Audio Note DAC 3.1x Balanced. Den benytter to signalrør... 12AU7/ecc82 og E182CC/5687. I posisjonen der 5687 røret sitter benytter jeg i dag et Sylvania Gold Brand 5687. Det fungerer helt fint. Som backup har jeg noen steingamle Tungsol 5687. De er veldig gode, men etterhvert like sjeldne som hønsetenner...
    Da jeg kjøpte dacen i hine hårde, satt det et Telefunken 802S i 12AU7-posisjonen. Telefunkerøret var litt for klinisk etter min smak, så jeg testet en del rør i denne posisjonen og har endt opp med et RCA5963 rør som jeg har vært fornøyd med. Men, nå ser jeg at Qvortrup & Co har byttet til 5814a (Amerikansk militærspekket 12AU7) i denne posisjonen. Jeg lurer litt på om det er noen her inne som har gjort seg noen tanker om hvilket ecc82/12AU7/5814A som fungerer bra i Audio Note dacene som benytter seg av 12AU7 i en av posisjonene.
    Det skal også nevnes at jeg sitter med horn som har følsomhet på 108db så det skal ikke store endringen til før det er hørbart.
    Jeg har noen 5687 hensetenner (tung sol black ribbed plate såvidt jeg husker) liggende foresten. Kjøpt dyrt hos motron for kanskje 15-20 år siden
    ..Min rørtid er nok over.
    Poenget er å ikke være for redd å bruke dine favoritter. De holder lenge og det finnes i diverse kjellere
    AN bygger gjerne kretser rundt sin egen lagerbeholdning, det de "støvsuger" markedet og kan kreve heftige priser for rør.
    rca45
    Når jeg nevnte TungSol og hønsetenner så er det disse jeg tenker på:
    Har et par av disse liggende (TungSol vertical getter ribbed flat plate) og de er outstanding når det gjelder lydgjengivelse i dacen min.
    Iflg. Peter Qvotrup er dette første generasjon av TungSol 5687 produsert sent 1940-tall...
    Har også et par TungSol 5687 D-getter med flat ribbed plate. De er på en god 2. plass hos meg.
    (Mulig dette er 2. generasjon).
    Så joda jeg har nok i lang tid da de er seiglivede i dacen. +5 år på et rør bør være innafor.
    Har forresten bestilt meg et 5814a rør hos Audomix, så får vi se hvordan det oppfører seg opp mot RCA5963.
    Atlerovik
    Konvertitt
    Apropos hønsetenner og tips til 12au7-posisjonen. Jeg var heldig og fikk tak i noen Amperex 7316 Long Plate. Jeg har prøvd mye etter hvert, men disse er nok det beste jeg har opplevd i den posisjonen.
    Edit: samme Tung-Sol rør som over i 5687-posisjon. Også magi.
