Lyngdorfs Venner!
  • Bjørn.H
    Ny integrert forsterker fra Lyndgdorf: TDAI-2210.
    Specifications
    Description: 2-channel integrated streaming amplifier
    Power rating: 2 x 210 W @ 4Ω / 2 x 105 W @ 8 Ω
    Idle power consumption: 18-26 W
    Standby power consumption: < 0.5W
    Max output current per channel:
    35A
    Audio specifications: Frequency Response: ±0,5dB from 20 – 20,000 Hz, Total Harmonic Distortion: 0.05% max from 20 – 20,000Hz, THD-N 1w/8ohm 0,04%, THD-N 1w/4ohm 0,04%
    Digital inputs: 3 x Coaxial digital (≤192kHz / 24 bit), 2 x optical digital (≤ 96kHz / 24 bit), 1 x USB C (≤192kHz / 24 bit), 1 x HDMI 2.1 (≤192kHz/24bit)
    Digital output: 1 x Coaxial digital (96kHz / 24 bit)
    Analog inputs: 2 x Single Ended RCA, 1 x Mic input (XLR) for RoomPerfect™
    Analog outputs: 1 x Single Ended RCA, 1 x XLR Balanced, 1 x 3.5mm headphone
    High-End analog module (optional): 1 x RIAA Phono MM, 2 x single ended RCA, 1 x XLR balanced
    HDMI 2.1 module (optional):
    1 x HDMI Output / 2 x HDMI Inputs (PCM ≤192kHz/24bit), eARC/ARC (PCM ≤192 kHz/24bit), CEC integration
    EQ: RoomPerfect™, voicings, Bass/Treble tone controls
    Media player: Internet Radio (airable), Spotify Connect, TIDAL Connect, Roon Ready, Google Chromecast, Apple AirPlay2, DLNA Support (UPnP/see DLNA formats), Local file playback (USB), Bluetooth (BLE), Plays with Audirvana
    Interfaces: Touchscreen, web-interface for setup and media player, remote application for IOS and Android, IP control, CEC (HDMI), 1 x trigger input, 1 x trigger output, 1 x RJ45 Ethernet LAN
    Remote control: Infrared or bluetooth
    Accessories included: RoomPerfect™ microphone with stand and cable, Remote control
    Dimensions (W x H x D): 325 x 102 x 300 mm (incl. connections) / 12.8 x 4 x 11.8 inches (incl. connections)
    Weight: 4,8 kg / 10,6 lb
    Finish: Matte black
    Available versions: TDAI-2210, TDAI-2210 + High-End Analog Module, TDAI-2210 + HDMI 2.1 Module
    Bjørn.H
    Modellene TADI-1120, TDAI-2210 og TDAI-3400 oppsummert:
    Reaksjoner: KMR
    Bjørn.H
    Radiant Acoustics Clarity 4.2 -ny modell og lillebror til Clarity 6.2. Riktignok ikke direkte Lyngdorf, men søstermerke som mest sannsynlig innen kort tid vil inkluderes i en software oppdatering til Lyngdorfs forsterkere.
    Bjørn.H
    Ny oppdatering til TDAI-3400:
    3.6.0 / May 2025:
    Streaming:
    - Qobuz connect
    - Airable hires channels stability improvement
    Bjørn.H
    Lyst til å se litt på funksjonaliteten til den nye TDAI-2210?
    MrGolden
    Skodje
    Fy faen for noen subber Steinway Lyngdorf model s210 er 😵💫😵💫😵💫! Elsker de rett og slett! Sinnsyk thight og kraftfull gjengivelse. De satte virkelig fyr på lyden i hula. Alt er bedre! Ikke bare i bassen men over hele spekteret .. Lows, mids and highs! Var heldig å få tak i disse lett brukt. De selges normalt sett ikke løst. Deler på 150hz nå med Room Perfect fra Lyngdorf MP-40 og litt smårydding med parametrisk eq i MP-40 etter REW måling i etterkant av Room Perfect kalibrering. Beste og mest naturlige lyden jeg noensinne har hatt. Har hatt ting som er langt dyrere gjennom hele kjede før, men det her tok kaka!
    Her er et lite lydklipp fra rommet mitt for den som måtte være interessert😎👌.
    fwrummel
    Risør
    Hei, savner loudness-funksjon siden jeg oftest spiller lavt, spesielt om morgenen før fruen står opp og jeg koser meg med en kaffekopp.
    Har sett på mulighetene TDAI 2170 gir med voicing eller lydprofiler, og legge inn en kurve med ekstra bass og diskant for lavt volum.
    Forsterkeren støtter dette forstår jeg.
    Har noen av dere gjort dette på en «eldre» forsterker som 2170?
    Og hvordan og hva var deres erfaringer?
    Nocturnal
    Sørnorge
    Kan ikke svare for 2170, men vil tro den er like tilgivende som 3400? Det fine med Lyngdorf er at jeg kan logge inn på forsterkeren fra PC'en as we speak - og justere bass, diskant og balanse. Sånn skal det være. Muligheter fratatt meg i mange år fordi alle forsterkere skulle bli så "rene" er tilbake med god smell. Tror du bør lese reklamen for 2170 først og fremst, og finne ut hva den kan.
    Harry Stoteles
    TDAI-2170 støtter ikke dette, men har en håndfull forhåndsinnstilte voicinger. Noen av dem har ekstra bass, men smilefjeskurve får du ikke.
    Hornlyd
    Musikkglad
    Joda. Smilefjes voicing curve på TDAI 2170 lar seg gjøre å lage:
    Flemming Smith hos Lyngdorf syntes ikke det var veldig morsomt 🤭 men han sa at de også kunne være behjelpelige med å å lage en voicing eller to til kunder.
    Prøv metoden over eller mail teknisk i Danmark og spør om de vil lage et partre filer 👍
    Men jeg tenker også at det er et rikholdig utvalg original voicinger i TDAI2170:
    Hornlyd
    Musikkglad
    @Hornlyd det var et bra innspill med originale voicinger.
    Prøver du ut nå 😀
    Nei det var for mange år siden.
    Men full rigg med 3400/dobbelt med 2400/cd2 blir montert opp ila juli :)
    Det blir altså fire etasjer med Lyngdorf komponenter hos meg.
    Men noen har hatt det værre:
    Reaksjoner: KMR
    charliefoxtrot
    Har lest og sett meg opp på Lyngdorfs forsterkerteknologi det siste døgnet. Det er fascinerende, både filosofi og implementering, og resonnerer godt hos meg.
    Samtidig biter jeg merke i at noen (les. Darko her) beskriver TDAI 1120 som ørlite "kraftløs" og "mager" i presentasjonen.
    Tenkte derfor å høre med Lyndorfs venner om dette er noe man kjenner seg igjen i og om det er litt gjengs for teknologien, eventuelt om det kun knytter seg til akkurat denne forsterkeren.
    Harry Stoteles
    Darko og mange andre hører vreng og tenker at det betyr at det er høyt. Lyngdorfen har "ICC" - Intersample clipping correction - som faktisk fjerner en veldig vanlig type forvrenging. Benchmark skriver om prinsippet her: https://benchmarkmedia.com/blogs/application_notes/intersample-overs-in-cd-recordings
    Fant også en tråd om saken her: https://www.hifisentralen.no/forume...om-intersample-overs-in-cd-recordings.101614/
    Lyngdorfen tilfører lite eller ingen egenlyd, og en kan jo tenke at Room Perfect fjerner litt drama i form av opptil 20 dB peaks og dips, men jeg liker det sånn, jeg. Så får de som liker å høre på vreng kjøpe annet utstyr.
    fry
    Lyngdorf har en utrolig fin og lettflytende lydkarakter, egentlig uten mangler. Hadde en 1120, som jeg savner, og den var alt annet enn mager. I tillegg har man RP og eq så kan ratte her og der hvis man ønsker litt mer kjøtt på beinet. Eneste mangler 1120 hadde var egentlig mangel på digital ut, og at jeg opplevde at analog ut støyet litt for mye på forsterkeren jeg hadde på den tiden. Ellers var den en fryd å bruke og et skoleeksempel på menneskevennlig forbrukerelektronikk.
    charliefoxtrot
    Er det noen som har rukket å lytte på TDAI-2210 ennå, og eventuelt kan si noe om hvordan den låter ift. 1120 og 3400?
    Reaksjoner: KMR
    Beretta67
    Nocturnal
    Sørnorge
    Den "gamle" appen er forferdelig. Scrolle gjennom foldere til man dauer av det. Når TDAI-3400 er så dyr som den er, burde den hatt en brukerapp a la Eversolo (som nå er min digitale Front End) og endelig er jeg tilbake til noe brukervennlig.
    Svene007
    Skedsmokorset
    Har en TDAI-1120 der jeg har koblet til en ekstern harddisk med masse FLAC filer fra CD. Spiller de filene fint ved å velge USB i menyen i appen. Men jeg får ikke tatt backup til harddisken, det funker kun til minnepinne. Er dette riktig? Ved enkel googling så ser det ut til at den skal støtte både harddisk og minnepenner. Så hvorfor er det kun backup som ikke funker?
    Hornlyd
    Musikkglad
    Noen som vet om vanlig 3,5 mm minijack stereo kabel kan brukes som triggerkabel på 3400 & 2400?
    Hornlyd
    Musikkglad
    TDAI3400
    1st og 2nd speaker setup
    Er det alternative profiler?
    Kan jeg f eks lage en profil for nærfelt og en for sofa lytting lenger unna?
    Det ser slik ut, men man kan nok ikke lagre to forskjellige Room Perfect innstillinger?
    Harry Stoteles
    Speaker setup viser til ulike crossover-settings eller høyttalerkomboer (dvs. med eller uten sub, f.eks.). Du kan lage forskjellige focus positions for Room Perfect, og det er noe annet. Jeg har begge deler på TDAI-2170 også.
    Sinsen
    Jeg mener det fungerer fint med to ulike sett målinger, for hver "speaker setup". Du kjører bare egen måling for første og andre sett. Altså, velger først setup 1 og måler, bytter til setup 2 og måler igjen.
