- Ble medlem
- 13.05.2006
- Innlegg
- 2.526
- Antall liker
- 2.197
På tide at den fyren bytter medisin.
Ser ut til at den er tatt ned..
Ligger her:Ser ut til at den er tatt ned..
Kan serveren ha fått for mye ketamin?Men, med dagens DDOS så er x litt ustabil
Det er vel ingen som sier det er legetimt eller hyller. Det er heller et forsøk på å forklare hvor man ender når lovverket er frakoblet vanlige sosiale normer og folk føler seg maktesløse. Og det er vel ingen som tror at dem som utfører disse handlingene vil slippe ustraffet?Helt enig i det du prøver å få frem her.
Om vi aksepterer og «hyller» at det gjøres skadeverk på annen persons private eiendom, så er vi helt på villspor og utur - uansett bakenforliggende årsak.
Jeg er direkte forundret over medforumister’s litt flåsete kommentarer til dette - og som indirekte og direkte mener at det er helt legitimt.
Fotnote:Scott enters the chat
Mark Edward Kelly (born February 21, 1964) is an American politician, retired astronaut, and United States Navy captain serving as the senior United States senator from Arizona, a seat he has held since 2020. He is a member of the Democratic Party.
Kelly flew combat missions during the Gulf War as a naval aviatorbefore being selected as a NASA Space Shuttle pilot in 1996. He flew his first space mission in 2001 as pilot of STS-108, then piloted STS-121 in 2006, and commanded STS-124 in 2008 and STS-134(the final mission of Space Shuttle Endeavour) in 2011. In January 2011, Kelly's wife, then-Arizona Representative Gabby Giffords, was shot and nearly killed in an assassination attempt in Arizona. Kelly retired from the Navy and NASA that October.
Scott Joseph Kelly (born February 21, 1964) is an American engineer, retired astronaut, and naval aviator. A veteran of four space flights, Kelly commanded the International Space Station(ISS) on Expeditions 26, 44, 45, and 46.
Kelly's first spaceflight was as pilot of Space Shuttle Discoveryduring STS-103 in December 1999. This was the third servicing mission to the Hubble Space Telescope, and lasted for just under eight days.[3] Kelly's second spaceflight was as mission commander of STS-118, a 12-day Space Shuttle mission to the ISS in August 2007.[4] Kelly's third spaceflight was as a crewmember on Expedition 25/26 on the ISS. He arrived at the ISS aboard Soyuz TMA-01M on October 9, 2010, and served as a flight engineer until he took over command of the station on November 25, 2010, at the start of Expedition 26.[5][6][7] Expedition 26 ended on March 16, 2011, with the departure of Soyuz TMA-01M.[8]
In November 2012, Kelly and Russian cosmonaut Mikhail Kornienkowere selected for a year-long mission to the ISS.[9][10] Their year in space began with the launch of Soyuz TMA-16M on March 27, 2015, and they remained on the station for Expeditions 43, 44, 45, and 46. The mission ended on March 1, 2016, with the departure of Soyuz TMA-18M from the station.[11][12]
Kelly retired from NASA on April 1, 2016.[13] His identical twinbrother, Mark Kelly, is also a retired astronaut, and the senior U.S. senator from Arizona.[14][15]
Som om ip-adressene i et DDOS-angrep har noe som helst med organisatoren å gjøre. Er han virkelig så dum, eller later han som han er det?er alltid like fascinerende når man mener at ip adressen angrepet kom fra eller nasjonaliteten til personen/gruppen bak skal bety at selve landet står bak..
Hvis det virkelig var Dark Storm (som påstår at de sto bak) er det hactivister med pro-palestinsk/anti-israelsk agenda. Har ingen ting med Ukraina å gjøre.Så det kommer fra Starlink (siden Ukraina benytter seg av den tjenesten?)
Musk er nok ikke så dum og vet bedre
Bonus: Impulskontroll som en fjortenåring.Starship was meant to be able to take 100 tonnes to Low Earth Orbit (LEO) and be fully reusable afterwards. That is 41.5 tonnes less than Saturn V, but the reusability should have made it significantly cheaper. Unfortunately, it seems Musk overestimated how much thrust their engines can produce, and as such, he has had to admit that the current design can only take “40–50 tons to orbit,” with no obvious way to correct this.
This means that, even if SpaceX can get their Starship to work, their Falcon Heavy rocket will actually be cheaper per kilogram to orbit!
What’s more, if you actually look at how expensive Starship launches actually are, its kilogram-to-orbit cost is the same as Saturn V! (read more here).
So, basically, the NASA of over 50 years ago is beating SpaceX at their own game.
Får håpe Musk har vett til å ta seg betalt før levering da, hvis ikke ser han aldri de pengene.
Den ultimate post-moderne verkelegheita.^det er ulovlig å være uenig med trump, det er all jus som er nødvendig.
....radikale venstregærninger som han mener på ulovlig vis sammen forsøker å boikotte Tesla.Trump slenger rundt seg med ord han ikke forstår.
Han sier det er ulovlig å boykotte Tesla, noe det selvfølgelig ikke er.
For en hver diktator er det jo selvsagt at forbrukermakt må forbys. Så lenge alle gjør som diktatoren sier, går alt så meget bedre. For diktatoren.....radikale venstregærninger som han mener på ulovlig vis sammen forsøker å boikotte Tesla.
Ja han sier mye rart som er langt f..utpå viddene.
Whatever makes you feel better. Kos deg med godfølelsen din.Tesla økte salget med 20% i UK i februar:
Vis vedlegget 1104641
Utgående(!) Tesla Y er mest solgte bilmodell i Europa sålangt iår:
Vis vedlegget 1104642
Det er tiltider helt utrolig her inne.Whatever makes you feel better. Kos deg med godfølelsen din.
Som propagandist må du tåle såpass.Det er tiltider helt utrolig her inne.
Pass.
Følger du sida? https://doge.gov/savings"Gigantic scam" - Null niks fakta, bare hearsay og konspiratorisk vinkling on repeat.
Det er pinlig å lese slike innlegg så står over.Som propagandist må du tåle såpass.
Så ofte som de blir tatt i feil så er ikke den sida mye verd.Følger du sida? https://doge.gov/savings
Kritiske spørsmål, 2 skritt tilbake for ett bredere perspektiv, og andre måter å tilegne seg kunskap på er fremmed for enkelte.Det er pinlig å lese slike innlegg så står over.
