  • PowerMetal
    erato
    Så får man se om Ukrainerne angriper rett på, eller om styrkene som bygger seg opp ved Vuhledar går ned mot Mariupol og angriper dem videre fra øst
    Lite behov for å gå rett på. Slik idioti er det russerne som driver med. Russerne der nede er i ferd med å bli ganske isolert. Å
    BT
    Problemet med russerne er at når det går dårlig i krig så finner de alltids noen millioner menn et eller annet sted som de kan uniformere og sende til fronten.
    Terje-A
    Nå slippes katta ut av sekken i Russland;
    Influential military bloggers in Russia have been even more blunt. Zakhar Prilepin, whose Telegram channel has more than 250,000 subscribers, reposted a commentary that described events in Kharkiv as a "catastrophe" and a wholesale failure of intelligence.
    "Now we can observe the result of the criminal irresponsibility of those who were responsible for this direction," the post reads, before concluding: "The special military operation is long over. There is a war going on."
    Another pro-Putin blogger who goes by the name Kholmogorov reposted an equally scathing account by the Partizan Telegram channel from the front lines, which that essentially accused the Russian authorities of abandoning the troops.
    "The soldiers were on foot with one machine gun and a sack. Abandoned by the command, not knowing the way, they walked at random," the post said.
    The poster, who describes himself as a Russian Orthodox nationalist, says that while hatred of the enemy grows, "hatred of the government and command is growing even more."
    Adding his own thoughts, Kholmogorov said: "Lord, save the Russian soldiers from blows from the front and even more from blows in the back."
    A similar analysis came from the Telegram channel of Pyotr Lundstrem.
    "There are NO thermal imagers, NO bulletproof vests, NO reconnaissance equipment, NO secure communications, NOT enough copters, NO first aid kits in the army."
    Referring to commemorations in Russia this weekend for the Day of Moscow, the city's birthday, he added: "You are celebrating a billionth holiday. What's wrong with you?"
    OMF
    • Nå er det vel fortsatt 7 millioner menn i mobiliseringsalder i Ukraina.
    • Jeg har ikke oversikt over alt, men det foregår vel en ganske omfattende opptrening av Ukrainere utenfor landets grenser, og de bygger opp et omfattende underoffiserskorps.
    • Nå som Ukraina har vist at de kan slå russerne tilbake, vil jeg tro støtten fra vesten øker. Risikoen for å bli involvert i en årelang hengemyr er betydelig redusert.
    • Selv om mange av disse litt morsomme enkeltsakene ikke representerer helheten, så sier det en god del om hvor dårlig det står til - da tenker jeg på ting som:
      • Kanoner fra WW2" som brukes til å utløse snøskred er mobilsert til fronten.
      • Små kanoner med 12km rekkevidde fra WW2 er mobilsiert
      • Et uttall videor hvor de kjører i elver, i trær, over hverandre, osv
      • Mannskap i stridsvogner som ikke kan skyte
      • Generellt ser jo alle russerne ut som uteligger.
    Ukrainerne ser generelt veldig proffe ut - uniformert, godt utstyrt med hjelm, GRU, uniform osv.
    Jeg vil anta at Ukrainerne ikke stoler en dritt på Russland, og nå vil befeste de områdene de har tatt tilbake med styrker fra TDF - som er lokale og spredt utover hele landet.
    Odd J
    Ganske betegnende at det på russisk side overhode ikke gjøres noe forsøk på å realitetsorintere seg. Full mobilisering er nytteløst nå, ikke er det trente folk å oppdrive og lite brukbart materiell. Likefullt snakkes det bare om å ´komme ordentlig i gang‘ med en krig i stedet for å leke Spesialoperasjon så skal Ukraina og verden få se. Det grandiose selvbildet er langt fra å få seg en sårt tiltrengt kalibrering enda. Ukraina må nok la kjøttkverna gå noen måneder til.
    E. Largo
    Disco Volante
    Det pågår også harde kamper rundt Bakhmut med store tap på begge sider.
    What do Russian generals want? A win. Where do they want it? Bakhmut. And to get it, they are staging near continuous attacks in which artillery bounds Ukrainian positions while “zerg waves” of Russian infantry attempt to storm Ukrainian positions. The fighting may be the most intense of the entire invasion. So intense that at one point on Saturday, Russia reportedly agreed to a brief armistice in order to remove mounds of bodies along a slope leading up to Ukrainian positions.
    Casualties for Russian troops in this assault are insanely high. But they are also extremely high for Ukrainian forces. As nimble as Ukraine has proven in its high-speed run across Kharkiv Oblast, the people fighting at Bakhmut are still in a position of being under a heavy artillery barrage, including regular strikes from MLRS and even thermobaric weapons. Their losses are also tremendous.
    So much so that on Sunday morning there were concerns about whether sufficient Ukrainian forces remained at some locations to simply shoot the Russians who were coming at them across fields that had been stripped of any cover by days of continuous fire. Russian forces, including Wagner Group mercenaries, had reportedly captured a large factory at the edge of Soledar and were pushing into the streets of that town.
    As of the time of this writing (7PM ET, 3AM in Kyiv), Ukrainian forces were reportedly still holding positions in Bakhmut and Soledar, but they continue to be under what is described as unrelenting assault. Mercenaries from the Wagner Group had reportedly reached an industrial area on the edge of Bakhmut, and were exchanging withering fire with Ukrainian troops, all while Russian artillery continues to pound Ukrainian positions near the center of town.
    Across Kharkiv Oblast, Ukrainian troops, and liberated civilians, are celebrating one of the great military victories of recent history. And they deserve to celebrate.
    But down the road at Bakhmut, Ukrainian forces are still fighting a desperate pitched battle with Russian forces—and with Russian commanders determined to give Vladimir Putin something he can call a win after a week of devastating defeats.
    Getting these guys the supplies and reinforcements they need keep fighting in this location is going to be tough, because Russia is all in on taking Bakhmut. Just remember, if Russia does take this location: it’s one small city. It won’t heal any of the damage that’s been done to the Russian military, and it’s still a long way to Slovyansk. At least it is for Russia, who doesn’t seem to know any other way to fight.
    Make no mistake, the men and women fighting around Soledar and Bakhmut are GD heroes, who are holding out in the toughest situation even while many of their compatriots get to take a victory lap. These guys, and this place, are a win for Ukraine. No matter what Putin claims.
    For Russia, this battle is what desperation looks like. For Ukraine, holding ground in the face of an all on assault … it’s just what they do.
    Polka
    Pipene som advarte om å sende våpen og utstyr til Ukraina, har de stilnet? Jeg vil tro at hjelpen har vært avgjørende for Ukraina. Nå skal man ikke selge skinnet osv men nå ser ut som det er en reell sjanse for at dette faktisk kan gå veien. Russland har oppnådd å miste omtrent alle venner, idrettsutøvere i kulden, store tap av liv og å befeste sin posisjon som storskurk. Godt jobbet Putin. Åja, NATO har krøpet nærmere også.
    BT
    Tror den største pipen ble utestengt fra denne tråden.
    BT
    Ikke rart Rødt har steget kraftig på meningsmålingene i det siste.
    BT
    Museumsvokterne i Rødt har nok fortsatt en solid posisjon i partiet, og båndene deres til de gamle kommunistene i Moskva er urokkelige.
    Wishmaster
    Liker den konstante humoren, ordvalgene og latterliggjøringen som kommer fra offisielle Ukrainske kanaler. 🥳
    noruego
    For russkiene har public messaging bare gått nedenom helt siden Medvedev inviterte Deep Purple hjem på te.
    Deputy Chairman of the Security Council of the Russian Federation Dmitry Medvedev said that Russia still demands "total surrender of Ukraine on its own terms", commenting on President Volodymyr Zelenskyy's statement about the impossibility of negotiations with the Russian Federation until the end of the war.
    Wishmaster
    Tror det like gjerne blir dommedag i Moskva hvis Ukraina tar tilbake Krim. ;)
    Terje-A
    For noe piss Medvedev lirer av seg, prøver å skremme Ukraina (og Vesten) til å overgi seg. Skjer aldri.
    Send flere sånne i retning Krim umiddelbart, kjør på.
    NSM cruise missile. Sannsynligvis en slik som senket krysseren Moskva.
    otare
    Ja, hva skal de gjøre? Ingen forsyninger. Ingen ammunisjon, ingen mat, ingen medisiner. Oppvåknende forståelse av at det de holder på med er meningsløst. Elendig kampmoral. Blir de såret får de ingen hjelp. Overgir de seg blir skader de evt har behandlet. Er det egentlig noe å lure på?
    Om noen skulle være i tvil om hvem som lønner Tucker Carlson:
    Sør for Kharkiv ~ Izyum. Jaja, hvis Tucker og hans «ekspert» sier det, så…
    Men det er jo ikke det bildet noen andre ser. Selv offisielle russiske TV-kanaler gir et mer realistisk bilde enn slik propaganda, og russiske milbloggere er fortsatt i full panikk.
    Rimelig oppdatert kart fra offentlig tilgjengelig informasjon:
    noruego
    Noterer meg ellers at noen hundre dager ut i denne tredagerskrigen så har vel russerne bare tre dager igjen til å ta hele Donetsk fylke innen den nye fristen de satt.
    Men det er nok også bare en av deres mange «cunning plans» i denne krigen.
