Finnes det noen "tweaks" som er så "over the top" at ingen går på de?
  • Drossel
    Mint grøn only. Har eksperimenteret med det. Næstbedst er pink. Med sort bliver lyden alt for flad.
    Her skal man spare bensin og diesel.
    Se gjerne hele. De selges av norske firmaer via finn.no bl.a.
    Her sammenlignes også med audio bransjen etter ca 12min.
    Hva med noen nye "cover" til vegguttakene dine? Kun noen tusenlapper pr. stk.
    Aner vi konturene av audiofile covre til telefonen din snart?
    https://www.alanmaherdesigns.net/pr...Bw_lZVO2hpByxEFjuYC4gngoAavf4ltWGbfjM3nvfa2lo
    CEF Radio Frequency / Electromagnetic Interference Suppression:
    Typical Properties: Not for specifications. Values are typical, not to be considered minimum or maximum. Properties measured at room temperature 73°F (~23°C) unless otherwise stated.
    >10Hz-100KHz: 84dB to 94dB
    >100KHz to 1MHz: 82dB to 93dB
    >1MHz to 2GHz: 85dB to 100dB
    >2GHz to 10GHz: 100dB to 130dB
    >10GHz to 18GHz: 130dB to 150dB
    1. Mil-STD-202 Method 303 maintained at 5 psi (3.4N/cm2) measured over 1 in2 surface area. Conductive particles in the adhesive provide the electrical path between the application substrate and the foil backing.
    2. UL Recognized for flame retardancy per UL 510, Product Category OANZ2, File E17385
    3. ASTMD-4935 Test Method
    How do they work?
    Out-of-the-box the QUADcell Outlet Cover will require 225-250 hours for a complete break-in. When CEF is applied to a circuit, all appliances and electronics installed throughout the circuit will be conditioned to our noise specifications. No other product that we are aware of can deliver this level of power conditioning.
    Alan Maher Designs turns a standard outlet cover into a true, non-limiting power conditioner. Our Outlet Cover reduces Extreme Low Magnetic Fields, Electromagnetic Radiation, and Electromagnetic Fields by using a combination of the Third Law of Thermodynamics and negative radiation cancellation. Our design attaches a small negative ionic charge to the electrical positive ionic energy field passing through the in-wall circuit. By regulating the temperature and manipulating the frequency suppression, we are able to produce a one-for-one ionic cancellation. In electrical design, harmonics, radio frequency, and static noise are all combinations of a positive ionization field associated with electromagnetic radiation. By cancelling the field, we can significantly lower EMR’s effect on the circuit and all electronics plugged in to the circuit.
    For prisen av en helt ok hjemmekino receiver med 8 kanaler får man en stk audiofil sikring. Nå endelig med bivoks.
    https://highend-electronics.com/pro...qEpllWrqvwXN9hHvIy8u6c4&variant=2513609785373
    NOW NEW! Ultimate Beeswax SHD - Super High Definition!
    Introducing Audio Magic's new Ultimate SHD Beeswax Fuse. We didn't think it could be any better but the new "Ultimate" is world class and then some! Now using a push-pull I-Core design instead of the single Core and Audio Magic upgraded the Black Out powder mixture for a broader noise absorption parameter. The new Ultimate is extremely difficult to build considering Audio Magic is drilling into both sides of the fuse now, sometimes it takes up to 3 tries to get one good fuse - lots of labor involved. This fuse will give you tighter bass and yet sound relaxed - very natural sounding. The sound stage will become bigger and deeper, more detailed, better layering, better micro detail but with a relaxed musical presentation. This is not a subtle upgrade from the original Beeswax SHD fuse which will stay in the line up. For people that have to have the best this is it! Global retail price is $225.00 each.
    The new Beeswax SHD fuse incorporates a triple layer design with 2 new proprietary components to make the fuse even quieter with a better transfer of current and re location of the Beeswax inside of the fuse for better stability.
    Ultimate Beeswax fuses are made-to-order. Please allow a 7-10 days factory lead time.
    Audio Magic Premiere SUPER fuse:
    The Audio Magic Premiere SUPER fuse incorporates Audio Magic's anti vibration fluid to stop the element from vibrating at 50/60 hz and then the blackout powder super mix to absorb all EMI and RFI riding the element as well as ambient sources and insert a new HRC core which allows the signal to travel through the fuse in a more cohesive and linear manner. The Premier SUPER fuse is 30% better than the Audio Magic's original SUPER fuse in every way!
    Much more detail top to bottom, wider and deeper soundstage, much better inner detail, layering, and a lot more air around instruments and voices.
    X
    X186841
    Ser ut til å være nok av remedier der ute til å holde en slik tråd i live til tidenes ende.
    Aurora
    Ytterst i havgapet...
    How do they work?
    Skrekk og gru!! DIsse passer jo bare til amerikanske standardbokser! Hva skal folket gjøre???
    Trondmeg
    Miltesten de refererer til gjelder likestømsmotstand. Jeg sliter litt med relevansen til et deksel hvis det ikke er noe jeg har oversett.
    Nå snakker vi hitech
    Audio bransjen leder den neste industrielle revolusjon.
    QUANTUM NOISE RESONATOR
    Mye quantum tech til ørene våre.
    Telos audio -
    https://telos-audio.com.tw/quantum-...71ewMdQWdqBdbPUd20k9thkxJ61ViFTxaYhyuE4TzuPFU
    For the version 3.1 upgrade, We are doing parts specially selection, By a high accurate way(similar to what FM acoustic does) And this takes effort by only two engineers with such ability.And by this way, we can only have 1 part being approved out of 16 parts (1/16 chance) This takes many times and we will drop all the unselected parts.Which is where the costs from. Until now, we have purchased more than 10,000 parts and select one by one. only hundreds of parts are been selected.
    In Taiwan market trial run, We have more than 20 customers made the upgrade(and it is growing), In our average feedback, from these customers, They mentioned the upgrade is like 300%~500% improvement. We even have customer said that the upgrade range, Is like adding USD30,000 audio tuning accessories to the system.
    Introduction
    This is the very first time a circuit design which is a combination of resonance and Noise and transform into light!
    Drossel
    Jeg tror simpelthen ikke på det skulle have nogen betydning med selekterede komponenter i det der kredsløb.
    ^^ Det er jo glassklart hva den kretsen gjør:
    The Internal quantum modules is combined with eight resonate channel and a core processor, the engineer detect the power outlet wave type by internal IC, and generates instant synchronous phase distortion compensation which is made for the beautification waveform through precise resonance and reduce phase distortion.
    Thus a whole new audio processing technology-QNR has been released, The actual listening experience to the sound system make more sense and focus on, more precise audio clarity, the whole background is black and silence, music is enhanced with more charm and smoothness.
    Låter kort sagt som ethvert annet placebo. :rolleyes:
    JENO
    Saksvik - Trøndelag
    Pussig at alle tweaks gjør samme type forbedring med lyden.
    ...more precise audio clarity, the whole background is black and silence, music is enhanced with more charm and smoothness.
    ...will give you tighter bass and yet sound relaxed - very natural sounding. The sound stage will become bigger and deeper, more detailed, better layering, better micro detail but with a relaxed musical presentation.
    Kanskje ikke så pussig likevel hvis man innser at endringen skjer mellom ørene og ikke i anlegget.
    Zerostat
    Strømmen
    Litt OT , eller…
    Da min sønn var 7år gammel fikk han plutselig en pågående hikke. Det startet rett etter frokost og han holdt fortsatt på med dette ved lunchtider. Han var spesielt affektert av dette, men klaget noe over det. Jeg ba han komme bort til meg og brette opp genseren sin. Jeg la hånden min over magen hans og sa at kan skulle legge merke til at hikkingen forsvant nå, og det gjorde den faktisk. Jeg er glad han ikke spurte meg hvorfor den forsvant. Så da kunne jeg ha det til gode også en annen gang og kanskje også i andre sammenhenger.
    _RoDa_
    Dette er lett å montere, og det er også mulig å få gratisprøver.
    Black Discus
    Testing Your BlackDiscus
    We strongly encourage you to test the BlackDiscus. However please observe the following point, or you may get invalid results.
    Because of the way BlackDiscus work, they can have an effect even if they are not attached to your system. The effect is weaker, of course, but to ensure a proper test, please put the BlackDiscus inside a metal tin (or can, fridge, safe, - something metallic. Tinfoil even..) when you want to listen to your system without the BlackDiscus' influence, otherwise you will not hear the full difference. If you do not have anything metal to hand, try putting them in the next room.
    Verdens navle
    Det er veier for å omgå det?!
    Sent from my iPhone using Tapatalk Pro
    funbunny
    Ved Mjøsa
