kaeksen's high end & annet.
  • kaeksen
    Tromsø.
    Specification Sonus Faber Electa Amator II: 14 liter two-way with passive radiator. Tweeter, 20mm silk dome high-resolution type. Mid-Woofer, 180mm high-performance, low distortion driver. Copper ring system voice coil. Paper carbonium cone. Low Bass, 35Hz tuned, passive radiator with special high density paper cone. Crossover, 2.5kHz first order attenuated. Sensitivity, 88 dB/m/W. Impedance, 8 ohms nominal. Power Consumption, 30 to 200 W. Frequency Response, 35Hz to 20kHz. Cabinet, 23 individual struts of solid walnut for resonance control. Dimensions(w x d x h), 22.5 x 38.5 x 38 cm. Weight, 13kg per side. Stand weight 22.5kg per side.
    Review Sonus Faber Electa Amator II: The Sonus Faber Electa Amator 2 is a pair of award winning speakers for the European High-End Audio of the year '98-'99. The combination of walnut and leather won over as the choice of many audiophiles. The standard of craftsmanship of hand made units cannot be undervalued in the days of mass production. The look and build quality of the Sonus Faber Electa Amator 2 are first-rate, especially when supported with the compatible stands. The pleasing aesthetics of fit and finish of the woodwork is an excellent piece of a conversation starter. The quality of sound matches well with its attractive appearance to become one of the most sought after speakers in the market.
    One thing great about these Italian Sonus Faber speakers are their ability to portray music with a sensual airy ambience. Sonus Faber speakers may not have the best treble, may not have the best midrange, may not have the best bass and may not even be the most detailed. But it is its ability to create music with heart and soul that sets itself apart. In general, American speakers perform with focus of rhythm, punch and dynamics. British speakers usually have a more pronounced fuller midrange which makes them especially good in vocals and jazz. For Italian speakers, they focus on the highs which brings out the heart and soul of string instruments. Most Sonus Faber users spend alot of their time listening to instrumental and orchestral music. Violin and string instruments sound exceptionally pleasing on Sonus Faber speakers. In fact, some of the Sonus Faber products are named after some of the greatest violinmakers of the past - Guarnieri, Amati and Stradivari.
    The Sonus Faber Electa Amator 2 is astonishingly musical and detailed, bold yet refined. The Amator 2 has a more open nature than the Amator 1 which can be even more of an asset if matched right. The sound is also very natural with total transparency and outstanding resolution, even when playing demanding music. It gives life when listening to every kind of music, and absolutely shine with string instruments, piano as well as vocals. Even more impressive is the peerless conveyance of massed strings of violins, which most expensive speakers fail to deliver. It has deep bass, great control and without distortion. The midrange is rich, palpable and articulate. The higher treble is as clean as a whistle, and do not sound shrill or overly bright but controlled and smooth. The soundstage is wide and deep with excellent 3D imaging. They are transparent across the range, sounding real and not synthetic. The Sonus Faber Electa Amator 2 is an example of excellence in the world of hifi sound reproduction. Source: listeninn.
    Utfyllende review om min Burmester 082.
    Hvis jeg trenger sub i fremtiden, blir det noe fra de mange tips som kom inn via det lille eksperimentet.
    UNNSKYLD, fra hele mitt hjerte. Spøken om sub gikk litt vel langt.
    *Off-Topic i tråden min er tillatt*
    thohaug
    Fetsund
    https://en.wikipedia.org/wiki/Audio_power#Continuous_power_and_.22RMS_power.22
    Les her. Spesielt seksjonen som heter: Power and loudness in the real world.
    Da får du litt innblikk i hvorfor det blir rart å se på kun hvor mye watt det tåler etc.
    Et eksempel sånn litt kjapt for å vise. Si man har et par stativhøyttalere som tåler 100w og har en følsomhet på 90db/1watt. Denne kan da spille omtrent 110db ved 100watt kontinuerlig inn.
    Så skal man supplere dette med en subwoofer, men siden det er så lave frekvenser som skal gjengis så er følsomheten kun 80db/1w. Om denne da får 100w kontinuerlig inn så vil den ikke spille høyere enn 100db. Altså hele 10db lavere enn stativhøyttalerne. Skal du ha den til å spille likt som stativhøyttalerne så må du fore den med 1024watt kontinuerlig inn for å oppnå samme lydnivå. Dobbel effekt for hver 3db opp.
    Derfor blir det litt søkt å se på kun watt tall, siden du må ta følsomheten med i beregningen også.
    Dette er kun eksempler, men det illustrer poenget ganske godt. :)
    Lekre høyttalere forresten!:)
    kaeksen
    Tromsø.
    Såpass kraftig, jaja, må vel venne meg med tanken, men 100db er jo høyt!!. Tror det ville vært perfekt for meg 100db, mener jeg testa og spille på 100db og det var passe. Liker ikke hvis det blir for høyt i db. Hadde 100db ca 2 meter fra ht i sofaen, der sweetspot er. Takk for kompliment. Skal lese igjennom dette, ser ut som æ treng det bigtime!
    Vi trenger bilder i tråden :) (Siden den er plassert i billedavdelingen) :)
    kaeksen
    Tromsø.
    Ok skal se ka æ får til. Det e forøvrig ikke de mest vanlige stativene til disse, men det stativet som har svart metal remse i midten, med heiltre på begge sidene. Mangler dessverre rackbord, da forsterker står på gulvet. Synd jeg ikke hadde penger da til de som gikk på sentralen for 11k fra burmester.
    kaeksen
    Tromsø.
    Update: For ordens skyld, denne faller helt ut!
    Ok fant en sub som deler på 40hz som nedre på lowpass phuh, og som går til 25hz. Her
    kaeksen
    Tromsø.
    Den er ikke 100watt :rolleyes:
    Close call..150watt er godtatt :p Edit: NEI ser den er utskiftet med en annen model :( Men får godta den er 250w da. Men har ikke bestemt meg skal finne flere alternativ først. Må ha litt og velge mellom.
    kaeksen
    Tromsø.
    Frekvensområde 40-150 hz....
    Det er high-pass filteret som er på 25hz.
    Det står frequency range 25hz - 200hz med deling på 40hz-200hz på low pass, så da trenger jeg bare stille den på 40hz på low pass filteret for og ikke spille 40hz og oppover, men 40hz og nedover til 25hz.
    Er ikke high pass filteret der bare for og kutte vekk 0hz opp mot 25hz?
    yosh81
    Flisa
    Ja, når man gikk inn på den oppdaterte modellen 8.2 ja. Men du hadde linket til den gamle modellen.8.
    Du får prøve deg frem når du eventuelt har kjøpt den sub.
    Den deler jo ikke rett av på 40 hz, man har en dalende kurve. Så man må justere og prøve seg frem hvor det kan bli best. Om det er på 35, 40,45, 50 hz osv...
    Dette er det samme som på de aller fleste slike subwoofere.
    Justering av delefrekvens, plassering og fase er noe man bør eksperimentere med for å oppnå best mulig resultat. Lykke til. :)
    gismo
    Finnskogen❤️
    Væssia i Grue.
    Flotte høytalere, er stativ SF fan selv, har fått til dette mega bra med REL- sub, meget samsvarende lydsignatur i nedre frekvenser som SF;)
    Leste noe av dine innlegg i annen tråd, syns du kanskje har mye å hente med å lese deg opp på sub, prinsipper, virkning, sømløs integrering, begrepet watt osv. osv.... Lykke til;)
    gismo
    kaeksen
    Tromsø.
    Update: Tror denne også faller utenfor, fordi den måtte ha egen amp, og klarte ikke overbevise meg helt om at jeg skulle investere i en ekstra amp bare til subben. Siden den kostet endel bare subben uten amp. Ble i hardeste laget for meg prismessig, sub+amp.
    Var jo bare skit uannsett det dem presenterte :cool: Forutenom Bass Clef active subwoofer.
    Skal skjekke den litt mere ut.
    yosh81
    Flisa
    Ja, hyggelig å lese at du synes det var skit da jeg og flere til faktisk gjorde et forsøk på å forstå og hjelpe deg.
    God kveld, og lykke til videre. :)
    Du kan forsøke, men all sannsynlighet tilsier at slavebassen på hovedhøyttalerne dine gir en nokså heftig fasedreining. Lowpass-filteret på suben også. Det hjelper ikke så veldig mye å stille inn lavpassfilteret til frekvensen for høyttalernes -3 dB-punkt hvis de er i motfase ved den frekvensen.
    Som flere av oss har rådet deg til allerede: Bruk et delefilter og prøv deg frem til riktig delefrekvens. Sannsynligvis vil den ligge en god del høyere enn du tror.
    Dette høypassfilteret er nok der for å beskytte subwooferen mot de aller dypeste frekvensene, ja. Men høypass ved 25 Hz, jeeez. 16 Hz ville vært mer normalt hvis du først skal ha en subwoofer.
    kaeksen
    Tromsø.
    Derfor jeg startet egen tråd. Den gikk litt skjeis den forrige der hehe. Min feil. Blir lettere i egen tråd. Tar det litt mere bakoverlent her.
    kaeksen
    Tromsø.
    Det var no sykt kor digg musikk propellerheads hadde. Litt spacet, men kult som fy!
    kvasi
    Når preferansene er Eltax og Logitech tror jeg du blir fornøyd uansett hvordan sub du kjøper så lenge den er fra en anerkjent produsent.
    Mitt råd er å kjøpe en med DSP og automatisk kalibrering, eller evt en Antimode i tillegg hvis du har pre-out på forsterkeren din.
    LilleFetirLutemann
    Greia er kaeksen....at vi vil deg bare godt! Alle rådene du fikk i den andre tråden var gitt med ditt beste i tankene. Det eneste "vi" ber om er at du ser bort i fra det kravet om 100w, så ligger lydnirvana tilgjengelig for dine føtter. Med det budsjettet så er det omtrent ikke grenser for godlyd du kan få.
    En ting til: Med din musikksmak burde du ha en sub med vesentlig mer kapasitet enn den flate dingsen. Den er ikke i nærheten av samme kvalitetsklasse som hovedhøyttalerne dine og går ikke på langt nær dypt nok for den musikksmaken du beskriver. F eks et par SVS SB-13 Ultra eller Velodyne SPL-1200 Ultra ligger fint innenfor budsjettrammen din og har innstillingsmuligheter som gir mye større sjanse for vellykket integrasjon med hovedhøyttalerne.
    kaeksen
    Tromsø.
    Ja det var navnet på de. Eltax Atomic A-15. Når jeg hadde den kjørte jeg den med patos basic 500 ht m/aw250 fra electrocompaniet. Den gamle fra 90 tallet. Men den vil ikke fungere her med dette oppsettet. Til det er den for dårlige. Må nok finne noe med bedre bassgjengivelse enn de billige der. Bassen var ganske så sløret.
    kvasi
    Dra bort på spacegarden og deponer på denne så kommer du til å få et helt nytt inntrykk av hva det faktisk er du er på utkikk etter.
    kaeksen
    Tromsø.
    Ser grei ut. Ser litt på noen av de andre også. Men skal ikke kjøpe noe enda, har god tid. Takk for tips!
    Update: Ok, leste en gang til igjenom tråden, og hadde misset, og ikke fått med meg helt at soundgarden tok dem inn. Velodyne er fortsatt på banen.
    kaeksen
    Tromsø.
    Fant Velodyne DD18+ Subwoofer 18" - Sort ebony med auto-eq funksjon, som fikser rom korrigering. Bare velstand. Artig dette å leite rundt ka som finnes. Noen av de mindre modellene har sikkert auto-eq også, har ikke lest igjennom alt helt ennå.
    kvasi
    DD-serien er egentlig "overkill og unødvendig" til bruken du beskriver men så finnes det jo eiergelede da..
    Alle Velodyne fra EQ-Max serien og opp har auto-eq men du vil ha SPL eller bedre.
    kaeksen
    Tromsø.
    Ombestemte meg iht overkill også. Ser helt bort fra underkills nå. :p
    Nå er det bare og vente til man får råd, som sikkert er i neste århundret.
    E æ heldig så finner jeg den største velodyne på brukten eller finn. Og den planlagte dac som ikke er bestemt. Til 60k eller noe i den duren. Begge brukt. Må ha en bra dac også så.
    Gjennstår og finne ut om den kan kobles på pre out på burre, der det står i bruksanvisningen:
    For additional connection of power amps or active loudspeakers the 082 provides two pairs of output jacks: For balanced connection you have to use the SYM-OUT, and for unbalanced connection you have to use the ASYM-OUT
    Og det er xlr på velodyne. (L+R) Input. Hvis subben regnes som aktiv høytaler da. Hvis ikke så trenger den vel en active sub out. Vet ikke om det er det samme pre out og sub out. Mangler sub out da, så håper det ikke krever sub out på forsterker.
    Så mange benevnelser, er ikke lett og komme i mål.
    kaeksen
    Tromsø.
    Til alle natteravner:
    Ser på dokumentar om wormholes. Utrolig flink han Isaac Arthur som har kanalen på youtuben, og masse interesant. Med skikkelig fin grafikk/renderinger. Han har litt uvant dialekt, så greit og sette på cc-text. De store dokumentmakerne kan ta seg en bolle, for han knuser de syns jeg. Håper han laster opp nye episoder så ofte som mulig. Eneste til nå jeg har subba til på YT. Hvis noen vet om flere "uavhengige" dokumentmakere som er bra med masse grafikk, si ifra.
    X-Cell
    King of the North!
    Ville heller gått ned noen hakk og kjøpt 2 subwoofere kontra en stor.. bedre stereo perspektiv :)
    Her er et tidligere oppsett jeg hadde:
    kaeksen
    Tromsø.
    1: Velodyne DD18+, 20–200Hz, AutoEQ, in-room response with the 80Hz high-pass filter on the Quads (25dB vertical range). Note that the peaks at 45 and 65Hz have been lowered.
    2: Velodyne DD18+, Manual Room EQ, in-room response without the 80Hz high-pass filter on the Quads (25dB vertical range).
    Skjekk den har hele spekteret...Og steike jevnt også..Nærmeste jeg kommer fullkommet.
    kaeksen
    Tromsø.
    Prøvde refinansiere til gjeldsbrev via Santander, men selv med romslig økonomi så fikk æ ikke innvilga. Jaja, da får man bare vente ca ett år. :( Skulle ikke forundre meg om minsten er 300k i året nå. Hatt lån før hos dem, uten bet.anm i alle år. Veit no at det e siste gang æ skal benytte meg av dem. Kjiipingan. Eller så e søndags automatikken på online ute av styring, og klarer ingenting. Pissed.
    Artanis
    Har jeg tolket deg riktig at det du ønsker er mer bass på lave volum? For å foreslå en enkel løsning, har du forsøkt å skru opp bassen med tonekontrollen på forsterkeren din.
    kaeksen
    Tromsø.
    Testa det, men fant ut at jeg ikke trengte høyere bass generelt fra ht via tone kontrollen, men lavere hz fra en sub eller to, for og dekke fra 40hz og ned. Fant noen subber som jeg blir og tenke over nå, fra velodyne og elac. Prøver og holde første posten oppdatert i fremtiden, ifm ka jeg finner ut. Så ble jeg også enig med meg selv om og tørre av og til spille over halv styrke. Har bare vært litt skeptisk til subber som er så kraftige.
    oes
    Anbefaler virkelig ikke en dyr subwoofer kjøpt med forbrukslån. Når du f.eks. oppdager at den er for stor for stua di, eller på annen måte går lei, så må du trolig selge for halv pris eller lavere.
    Jeg tror du kommer veldig langt (og kanskje lengre) med 1 eller 2 subwoofere fra BK Electronics. Disse holder samme nivå som REL. Jeg vet at noen her på forumet har fått to slike (xxls400) til å spille veldig bra sammen med Harbeth M30.1 monitorer (blant verdens beste). Sjekk evt Harbeth-tråden.
    Koster 424 pund per stk for xxls400, men husk at frakt og norsk m.v.a. kommer i tillegg (tror du kan be om å slippe å betale engelsk v.a.t. når de sender til Norge).
    Sub Woofers - Sub Bass - Subwoofer
    Du kan også betale 259 pund ekstra for dsp antimode, de slår av 30 pund om du kjøper sammen med sub, og da får du samme funksjonalitet som på Velodyne: Anti Mode 8033SII
    Lykke til!
