Venner af Bang & Olufsen
  • Valentino
    ...men det anlegget er et slikt livsstilsanlegg. Beolab 90 er ikke det. Blir spennende å lese Atkinsons målinger, haha!
    Bare å gi beng i den traktoren, Hardingfele.
    E. Largo
    Disco Volante
    Spennende høyttaler dette. Men jeg stusser litt på at B&O som alltid har laget design hi-fi, nå lager så stygge høyttalere at de må ikles en burka :confused:
    tommykh
    Jeg er selv eier av BL5.
    Hva angår design hadde jeg byttet over til BL90 på dagen.
    B&O var et tiår foran på BL5, de står seg like godt i dag. Antar vi vil se det samme med BL90.
    Synd de blir hinnsides dyre i innkjøp.
    erato
    Men du sparer et par hundre tusen i høyttalerkabler og strømrensing.
    tommykh
    Nja, ikke når man allerede har BL5, finnes ikke en meter med ht kabel her ;)
    H
    Hardingfele
    Tonemester Geoff Martin fikk et spørsmål. Han svarte slik:
    Interesting Q and A from one of Geoff Martin's articles on his blogsite:
    B&O Tech: BeoLab 90 – Behind the scenes ? earfluff and eyecandy
    Question:
    'Do you belive this is the best sounding speaker in the world and can you describe their sound characteristics, and how do you feel their sound comparing to conventional passive High-End speakers like Wilson Audio , MBL Reference 101 , Focal Utopia Grande ?'
    Answer:
    'It’s unfair of me to comment on the loudspeakers of our direct competitors and how they compare to B&O loudspeakers – so I almost never do.
    I will say, however, that as part of the development process of the BeoLab 90’s, we auditioned a wide range of high-end loudspeakers. Each of them had some good aspect – for one it was imaging, for another it was midrange, for another it was temporal precision, for yet another it was a weird ability to sound like itself regardless of the room it was in, and so on… Our goal with BeoLab 90 was to take the attributes we liked from each loudspeaker we listened to, and assemble those into one product. In my (admittedly biased) opinion, we succeeded.'
    EvoBatman
    Fersking
    Jeg bør vel vise fram bilde av rotet mitt:
    Beosystem 7000, Beovision MX4000, Beovox Redline 60.2. Ikke med på bildet er Redline høyttalerkabler og en MCL2P ekstra forsterker for slaverom. Beo4 og Beolink 1000 fjernkontroller.
    En Apple PowerCD er med for ekstra udda-faktor.
    teafortwo
    "Oppshining" av aluminiumskabinettet på CX100.
    Prøver denne vennetråden først. Har noen tips til remedier mm som kan brukes til en utvending oppfrisking av kabinettet på disse høyttalerene. De ser noe "skjoldet ut" histen og pisten i det rette lyset. Tanken var å gjøre det så enkelt og skånsomt som mulig.
    soundscape
    Nordre Follo
    Ser interessant ut den boka der. Kan vel kalle meg B&O venn med en Beogram 4000 og en 4002. Begge trenger litt stell , men er kosmetisk veldig bra.
    H
    Hardingfele
    Blir like fascinert av at dette er laget i 1967 hver gang jeg spiller plater på dette fantastiske systemet :)
    Vis vedlegget 412314
    Der har du fullt oppsett!
    Har du kjøpt gjennom Frede eller hatt det gjennom årene? Så et komplett sett til salgs her i Norge en tid tilbake og var fristet.
    Har platespiller og radio forsterker/fra før, likevel fristet.
    De høyttalerne er perfekte til jazz, har sittet i Fredes lytterom og kjent veldig godfot.
    Male
    Har faktisk senterhøyttaler og Beocord'en på stativ til dette oppsettet også :)
    Samlet del for del i løpet av noen år. Ebay og finn.no, høyttalerne kjøpte jeg faktisk her inne :) Tenkte å ta det med en tur til Frede for en sjekk nå snart da jeg har en god del annet som trenger en fix.
    Hvilken tilhørende Beogram er det du har? Thorens?
    Det er sjelden jeg ser dette til salgs her i landet, så jeg hadde nok trykket på kjøp knappen hvis jeg hadde sett det...
    liern
    Digitaldel på Beolab 5
    Beolab 5 står oppgitt til maks å håndtere 88.2 kHz samplingfrekvens på digitalinngangen. Er det noen som har testet om den klarer å spille av høyere samplingfrekvens, f. eks 96 kHz eller 192 kHz? Aktuelt nå som MQA og andre high-resformater begynner å spre om seg..
    Fenalaar
    Du glemmer at Beolab 5 har innebygget DSP og digital signalbehandling. Det hele blir omsamplet til DSPens interne arbeidsfrekvens, uansett.
    Johan-Kr
    liern
    Johan-Kr
    Ok, det har du helt sikkert rett i. Men spørsmålet er likevel relevant: Kommer det lyd dersom man sender høyere samplingfrekvens inn på digitalinngangen? (uavhengig av hva den måtte resample til internt)...
    Fra Beosound 5 - Support for FLAC 192khz/24-bit -
    Hi Martin,
    Thank you for contacting Bang & Olufsen Customer Service. Please excuse the very late reply.
    The BeoSound 5 supports the following formats:
    M3U, M4A,WMA (including lossless),FLAC,MP3, MP2, WAV, ASF and AAC (MAC format)
    BeoSound 5 can play FLAC formats up to 24 bit / 192 KHz but formats above 44.1 kHz will be downsampled to 44.1 kHz.
    Please observe that the WAV formatcannotcontain metadata/tag information resulting in albums being listed as”Unknown album”
    Support for MP3 tag information ID3v2 up to and including version 2.3
    We recommend using WMA lossless when ripping from Windows
    BeoSound 5 will output the same as the input.
    It does not support Spotify Connect but has a built-in Spotify player which cannot be controlled by an iPhone. unfortunately. A solution could be to add a BeoSound Essence to your setup.
    http://www.bang-olufsen.com/en/beosound-essence as we currently have no plans of introducing Spotify Connect for the BeoSound 5,
    Please contact your Bang & Olufsen retailer for information about your possibilities with adding a BeoSound Essence to your setup.
    Kind regards,
    Ina Bang Andersen (Ms) | Customer Service
    liern
    Hi Martin,
    Kind regards,
    Takk for svar Bambadoo, men mitt spørsmål er ikke nyttet til mediaspilleren Beosound 5, men de aktive høyttalerne Beolab 5.
    Dæven bomma jeg slik? :) Jaja - godt det snart er helg..
    Jaja - tar til meg den :) Men for de som lurer på Beosound 5 så er svaret gjengitt over ;)
    Ulf-B
    Og for dem som lurer på Beolab 5, gjengir jeg det svaret jeg fikk fra Bang & Olufsen da jeg var i kjøpsmodus for disse i 2010. Et par 2009-modell som lå ute på bruktbørsen, og som jeg kjøpte, og som jeg fortsatt har stående her hjemme:
    Det glæder os at se, at du har planer om at købe BeoLab 5.
    Vi kan sige at DSP i BeoLab 5 er et avanceret system, med 32 bit "floating-point" forarbejdning. SPDIF outputs fra enhver ekstern kilde, med sampling frekvenser på op til 96 kHz og 24 bit signaler kan sendes direkte til højttalerne. Alle signaler samples op til 192 kHz/24 bit, før de konverteres til analog for effektforstærkerne.
    Hvis højttalerne modtager signaler over 96 kHz, får du formodentlig ingen lyd. Dette er ikke noget vi har testet.
    Vi kan ikke hjælpe med specifikationerne omkring jitter o.a., da dette ikke noget vi opgiver.
    Jeg håber ovenstående information vil være dig til hjælp.
    Med venlig hilsen
    Bang & Olufsen a/s
    Brosjyren sier maks 88,2 kHz, men i svaret til meg sier Bang & Olufsen 96 kHz. Litt uklart altså, men mine fungerer i hvert fall på 192 kHz via Squeezebox - som etter det som står å lese om Squeezebox'en, betyr at signaler over 96 kHz nedskaleres til 96 kHz av Logitech Media Server programmet. Men sikkert lurt å sjekke ut nærmere.
    liern
    Med venlig hilsen
    Bang & Olufsen a/s
    Ok, takk så mye for svar. Da høres det iallefall ut som 96 kHz burde fungere greit :)
    Ulf-B
    Med venlig hilsen
    Bang & Olufsen a/s
    Da har jeg sjekket. Spilte en 24 bit/192 kHz-fil via min Squeezebox Touch på arbeidsrommet mitt, og Benchmark-DACen registrerte 24 bit/96 kHz-signal inn fra Touch. Spilte deretter samme musikken fra Squeezebox Touch i stuen, inn på Beolab 5 - og det fungerte helt feilfritt. Så 24 bit/96 kHz inn på Beolab 5 er OK.
    liern
    Med venlig hilsen
    Bang & Olufsen a/s
    Takk for at du tok deg tid til å sjekke, og flott at 96 kHz fungerer. Kanskje ikke høyttaleren er så utdatert (i dac-delen) som man kan være fristet til å tro ut i fra alderen på konstruksjonen. Mon tro om den ville klart 192 kHz direkte inn også? Dersom jeg klarer å skaffe meg et par skal jeg selvfølgelig teste, og dele resultatet. Ser for meg at Beolab 5 sammen med Bluesound Node2 kunne vært en spennende løsning.
    NLS
    Drammen
    Var idag indenom B&O Bergen da jeg alligevel er i byen. Sidste år havde de Beolab 5 stående, og havde egentligt ønsket mig at høre disse (lidt sån hemmelig drøm hehe). Den eldre vældig hyggelige kar fortalte at de er blevet discontinued, de kan fortsat skaffes fra lager, og han antydede endda muligheden for rabat :) Overvejede det 1/10 sekund menmen..
    Videre fortalte han at en afløser vistnok er på trapperne, en "lillebror" (hans udtryk) til Beolab 90. Softwareproblemerne til Beolab 90 skulle være løst efter at udviklingen er flyttet fra Indien til Ålborg.
    NLS
    Drammen
    Det ved jeg faktisk ikke min ven. Var i butikken for at høre Beolab 5, som altså ikke var der mere. Jeg er ikke "seriøst" interesseret i Beolab 90 + jeg havde flere bekendte på slæb der ikke er specielt HiFi interesseret. Så jeg havde min lille snak, og sagde pænt farvel..
    Men er helt sikker på en henvendelse til butikken vil gi svaret - og mulighed for at booke en time, så ingen står og tripper utålmodigt i baggrunden :)
    baluba
    Kopervik og Bergen
    I see. Greit å ta med noen CD-er i bagen som jeg likevel bærer på da for sikkerhet skyld.
    Lurer forresten på noe B&O-relatert. Har forleden kjøpt en Beocord 4500 som er terminert om fra DIN til RCA. Tilkoblet en ganske ordinær Pioneer transistorforsterker i kryptens aller helligste låt det helt greit, men når jeg koblet den til Audio Innovations rørpre hos min bror forsvant lydnivået helt i bunn. Kan det være en impedansforskjell som lager krøll?
    Ulf-B
    Hvis du er interessert i Beolab 5, kan jeg bekrefte at de hadde et par av disse stående i lokalene på Skøyen i Oslo for et par dager siden.
    NLS
    Drammen
    Godt at vide, takker! :)
    Er rimelig standfast her i Drammen til daglig, får se hvad jeg kan gøre..
    Heimdall
    Er det den som kalles Oslo sentrum? Jeg skal til Oslo i juni, kunne tenke meg å høre dem. De har vel Beolab 90 også?
    Bør man ta kontakt på forhånd eller er det alltid mulig å få demo?
    Ulf-B
    Det er snakk om to forskjellige butikker:
    Bang & Olufsen Oslo Vest: Bang & Olufsen Oslo Vest
    Bang & Olufsen Oslo Sentrum: Bang & Olufsen Oslo Sentrum
    Det er mulig at begge butikkene har Beolab 5 inne - men jeg var tilfeldigvis på Skøyen, og der sto det et par klare til lytting.
    Han i butikken på Skøyen anbefalte å ringe og avtale tid for demo. Det var det jeg gjorde i 2010 da jeg vurderte Beolab 5 - og da fikk broren min og jeg halvannen time eksklusiv audiens for å lytte til høyttalerne.
