VPI-tråden
  • lomt
    rico skrev:
    Her ett sitat fra VPI sin set up manual ang. antiscating....
    E. ANTI-SKATING:
    • A pivoted arm without an offset head would not be subject to skating force.
    However, it will also have no correction for tracking error and the resulting
    distortion is unacceptable. As soon as the arm's head is offset to lower tracing
    distortion, skating force arises. Greater offsets result in greater skating force.
    The 12” arm has a very small offset angle and therefore a very low skating
    force to deal with.
    • After very careful listening tests we have determined that every tonearm we
    tried sounded better with their mechanical anti-skating disabled and the tracking
    force very slightly increased. All mechanical anti-skate devices add a negative
    sound to the music because they are made of parts that can vibrate. We solve
    the problem in a unique way:
    • As mentioned earlier, the arm wire applies the anti-skating force. The degree of
    force applied can be adjusted as explained below.
    • To increase or decrease the amount of anti-skating force applied, simply unplug
    the Lemo connector and twist it in the direction you want the force applied.
    • For example, to increase anti-skating force give the connector a
    counterclockwise twist, unwinding the coiled wire. Likewise, to decrease the
    force, give the connector a clockwise twist. Remember, the Lemo connector
    can only be "adjusted" in increments of whole turns. If it is not, its key will not
    line up with the groove in the receptacle.
    • We could go on discussing the pros and cons of how much anti-skate is correct,
    but the sonic answer is very simple. Adjust the wire as mentioned above until
    the tonearm drifts outward when set to neutral balance. When you push the
    neutral balance floating tonearm towards the center of the record, it should push
    back out towards the rim of the record. Very little force is needed to do this,
    and the wire acts like a spring to supply this force.
    • If you try adjusting the anti-skate with a groove less record or a test record
    you will ruin the twist in the wire and void your warrantee
    • Double check the horizontal balance, lateral balance, and tracking force and
    adjust as needed. Increase the tracking force by 1/10 of a gram above the
    cartridge manufacturers highest recommended force.
    Det stemmer og korrsponderer med mine uttalelser
    bortsett fra på ett punkt
    Jeg tenkte feil i forhold til lange armer. Feil i form av at jeg ikke tok med i beregningen at en lengre arm festes lengre fra platetallerken (har ikke hatt en slik selv og antok at man brukte samme innfestningspunkt som originalen). Men det jo selvsagt slik at pickupnålen settes ned på samme punkt på vinylen, og tangent-feilen vil da bli mindre, og anti-skating krefter også mindre.
    Birdman
    Fikk min digitale pu-vekt i dag. Har justert nåletrykk, jobbet litt med plassering av høyttalerne, samt flyttet lytteposisjon, og nå føler jeg at jeg virkelig er i nærheten av noe stort :D. Under "Byssan lull" ,med Kari Bremnes, måtte jeg åpne øynene for å sjekke om hun sto foran meg ;). Herlig! VPI ruler 8).
    Frank
    ssm
    Bra..Høres jo deilig ut,er ikke lyd flott på gode anlegg,og ødeleggende på kipe boomblastere uten bass!???
    Her er jeg selv nær nirvana når jeg kan spille av Ole Petter Antonsens Tour de force på høyt volum..Desverre eies kun eksemlaret kun på cd,men dersom noen vet on noen som skulle ha OPA på vinyl,vær snill å gi et vink...da blir jeg gla da!
    Nå er det helg,å mulighet for å være hjemme med musikken igjen...go helg folkens. ;)
    emotikon
    Gøy at du blander brødrene Antonsens fornavn...gjort det selv mange ganger. ;)
    Har aldri sett denne på vinyl :(
    Denne cdn låter ikke særlig i mitt oppsett, men har hørt den i noen andre med ok resultat.
    Ha en strålende musikkhelg!
    Det skal jeg ha ;)
    B
    break_out
    Snedig løsning den der antiscatingen til VPI, snurrer en til det høres riktig ut eller er det en verdi pr snurr?
    Denne er kopi fra setupmanualen listet over:
    "• If you try adjusting the anti-skate with a groove less record or a test record
    you will ruin the twist in the wire and void your warrantee"
    Hvordan kan en ødelegge tvisten på denne måten?
    Birdman
    Dette har jeg også lurt på.
    Det gjelder forøvrig ikke for signaturarmen som har eget antiskatingsystem (Valhallakablingen må ikke tvinnes!).
    Synes i det hele tatt at dette med antiskating er vanskelig! :-\
    Frank
    emotikon
    Jeg kan ta meg en tur i løpet av helga Frank, med en antiskatingsplate om du ikke har, så skal vi få orden på dette :)
    P
    Parelius
    lomt skrev:
    Plutselig bestilte jeg en slik en...
    VPI HW-16.5 Record Vacuum Cleaner
    ..og da måtte jeg jo lese VPI tråden, men det gikk bare i platespillere
    Er det noen som har erfaring med den?
    Med det samme la jeg merke til at Parelius har kuttet ut anti-skating
    Er det lurt?
    Tror ikke det
    Innerveggen på vinyl rillene vil fort bli uforholdsmessig slitt
    eller har du gått over til tangentsial arm? ti tommer lang??
    Veldig lurt! Intet problem! Fremdeles med 9". Så får andre gjøre som de finner ut.
    P
    Parelius
    Det forstår ikke jeg heller. Og ikke greier du å "twiste" kablingen på Signaturearmen heller. Hvis du prøver så går armen rett øst eller vest eller nord eller syd, alt etter som den står i utgangspunktet. Det er som å sette hele saken i en katapult! (Utifra det jeg forstår med "twist" da.)
    Birdman
    Har lest litt mer i vpi-papirene. Vpi anbefaler jo faktisk å ikke bruke antiskatingen og heller øke nåletrykket. Spilleren har uansett naturlig antiskating, da armen svinger utover uten at noe er gjort. Tror jeg gjør som Parelius, enn så lenge.
    Frank
    ssm
    Litt off topic...men jeg retter selvfølgelig navnet jeg greide å skrive feil...Ole Edvard Antonsen skal det selvfølgelig være.. :D
    terryboy
    Parelius skrev:
    Hoochi, nå har jeg bestilt en VPI 10.5i til SuperScoutmasteren. Dette blir spennende!
    Er det åpnet for at man nå også kan montere JMW-10.5i "direkte" på VPI Super Scoutmaster, eller er det gjort spesialtilpasning av din spiller Parelius?! Mente jeg har lest at SSM KUN vil kunne bli levert med JMW-9 Signature (den med Valhalla kabling og VTA justering)
    P
    Parelius
    ad terryboys spørsmål.
    En får nå faktisk kjøpt SuperScoutMaster med 10.5i arm, så jeg tror ikke monteringen skal by på store problemer. (Prisen er ikke akkurat en busstur (USD 7.700))
    Jeg har ennå ikke mottatt min, og begynner egentlig å gå litt sur av all denne sendrektighet fra VPIs side (skulle vært her lenge før sommeren ankom, skjønt den har vært litt fraværende den også). Betalt og alt er den! Så snart den ankommer, så vil jeg legge ut noen bilder vedr. hvordan det hele gjøres.
    Gunnar_Brekke
    Hei :)
    Prater litt med Mike Randell ved VPI innimellom. Han fortalte at det kommer
    test av den blodtrimmede SuperScoutMasteren i TAS snart. Dette er altså
    Super Scout Masteren med 10,5i tonarm, tung sandwich platetallerken og
    Mini Feet. Harry Pearson tok visst helt av på denne spilleren og uttalte at den
    "i hvert fall ikke var dårligere" enn toppmodellen fra Rockport til 10 ggr prisen
    og med over et års ventetid på leveranse.
    Dette må selvfølgelig taes med en klype salt siden infoen kommer fra
    produsenten - og siden Pearson tross alt er "faren" til SSMen - men dette blir
    uansett spennede lesing. Interessant om HP kommer med samme konklusjon
    på trykk.
    Randell var ellers rimelig imponert over oppsettet til HP. Dette var i hvert fall
    det beste stereoanlegget han hadde hørt.
    Ellers er det værdt å merke seg at de forskjellige VPIene har forskjellig klang-
    karakter. Scoutfamilien som benytter MDF i chassiset har en varmere klang
    og mer basstrykk - enn spillerne med akryl i chassiset (Aries, TNT og HRX).
    Sistnevnte er kanskje mer nøytrale og riktige - men ikke nødvendigvis like
    morsomme. Det er vistnok også forskjell på klangen i de forskjellige typene
    akryl de bruker i platetallerkene. Svart akryl låter vistnok mørkere enn klar
    akryl.
    mvh :)
    Gunnar Brekke
    P
    Parelius
    Dette var da herlig nyhende.
    Kjenner du til noen erfaringer med Gingko platting til SSM, Gunnar_Brekke?
    argh
    Vurderer en Ginko platting til min Michell gyro, men er noe usikker da den blir
    linket til VPI platespillere hele tiden.
    Jeg kan egentlig ikke forstille meg at den bare fungerer godt på VPI og ingen andre, det er da ikke så stor forskjell på drivverkene.
    Eller hva mener dere?
    Mvh,
    Terje
    P
    Parelius
    Tja, Gyroen har jo "innebyggget" oppheng, har den ikke? I så fall ville jeg ikke bare tatt det for gitt at det hele fungerer. Setter en inn flere resonanskontroller som ikke er avstemt i forhold til hverandre, så kan det like godt bli verre. VPI-ene (Scout) har liksom ikke noe særlig til oppheng fra før av.
    Jeg vet altså ikke med sikkerhet, men jeg ville ha forhørt meg før jeg blåste kronasje her. Hva med å kontakte Gingko?
    argh
    Ser poenget ditt
    ssm
    Da kan jeg meddele at til Mandagen kommer dynavector pickupen DV-20x low i hus,og på spillern (scout) og jeg er jo ikke lite nysgjerrig på hva dette kan by på,spesiellt etter innspillingen ;)
    jeg bytter nå fra en audionote iq2 mm,og over til denne mc pu en,så da er det bare å håpe det blir bra til sigende..
    dustkover fra gingko fikk jeg pris på nå: 3500 NOK fra Sverige,nesten fristet til å sjekke samme i USA,tror Svensken tar seg greit betalt for dette,men m¨å jo da sjekke nærmere somsagt,det tilkommer jo tull,og annet tøys over grensa ;D
    for gitte pris,kommer en langt hos Kreativ plast i Tønsberg...men må vel her godta 90 graders hjørner og slikt VIL JEG TRO?..
    Hva syntes dere om den Monterprisen? Monteret er av typen som står over hele spillern dvs helt ned på underlaget,det ser forøvrig forseggjort ut,og kan brukes på andre feks sm & ssm etter hva jeg skjønte...
    Mvh Espen
    terryboy
    Er det noen av dere VPI eiere som har prøvd ut og har erfaringer med bruk av Ginko Audio Cloud 11 Base under deres kjære VPI spillere??!! Denne basen fikk såpass mye skryt i test (CriticalEar.com) for hva den gjorde med lyden når den var plassert under en VPI Super Scoutmaster/SSM, at jeg seriøst vurder å anskaffe denne. Avventer hva dere hifi-sentralvenner eventuelt har erfart før endelig beslutning om Ginko kjøp eller ikke tas...
    P
    Parelius
    @ ixos_76: Tviler på at det er samme monter til Scout og SuperScoutmaster (SSM). Den siste har et større fotavtrykk grunnet motoroppsettet. Prislisten viser også to forskjellig for disse, med forskjellige mål (og priser) for Scout, Scoutmaster og SSM. Også litt usikker hvordan dette går hvis du oppgraderer Scout med ny motor/svinghjul, da dette stikker utenfor plinten. Her er ingen one size fits all.
    Prising: USD 279 + 70 (frakt?) + moms skulle vel gi noe slikt som NOK 2.600 (sjekk opp utregningen for sikkerhets skyld)
    Hvis du i tillegg må betale moms og event. frakt på den svenskeprisen (NOK 3.500), så begynner det å bli kabeldyrt-dyrt, må jeg si - meningsløst i min bok.
    @ terryboy: Jeg la inn en bestilling på Acoustic Sounds på Cloud 11, men ingenting skjer. Orderen er på "hold". Tror jeg gir f. og bestiller direkte fra Ginko. Har du kjøpt deg en SSM?
    ssm
    Prisen via søta bror er med alt,frakt,tull,og hele sulamitten....ikke gratis men...får vurdere litt....denne kommer det som sagt ikke lyd ut av... ;D
    ssm
    Da har snapa vært her å hjulpet meg med rett innstillig/opplæring av oppsetting av ny moving coil på min vpi scout...rett ut av eske,låter det helt fortreffelig,helt utrolig,Dynavector er flotte saker,gain ble skikkelig bra med Torhauge mc forsterker...nå blir det mye vinylspilling fremover ;)
    Med denne komboen,kommer cd spillern min til kort,gleder meg til å ta fatt på laange lyttekvelder utover høsten..
    Da var Dynavector dv-20x,low i jmw armen....og den blir der leenge ;D ;D ;D
    (bilde er klippet fra et annet innlegg i vpi tråden)
    Mvh Espen
    ssm
    Mvh Espen
    Det er forøvrig gjort en endring på denne,kontra tideligere modeller,med annen sliping(bedre?)og mutterne til pu skruer er erstattet med gjngede hull i pu hus på de nye.
    Nå har ikke jeg hørt den forrige varianten,men dette spiller sykt bra rett ut fra esken...Mitt første møte med mr.snapa var meget positivt..skikkelig seriøs mann,hyggelig og hjelpsom..Handler mer enn gjerne med han på en senere anledning ;)
    emotikon
    Grattis med riktig god PU! :)
    Da kan jeg fortelle deg at DV-20x blir enda bedre etter ca 40 timer ;D :-*
    Bruk gjerne 2.2g vekt på i disse timene.
    ENJOY!!
    ssm
    Ok,vekten er nå innstillt på 2,04....med shanghaivekta...digital...funker som fy,nykalibrert for anledningen..
    Etter få spillte plater,oppleves dette som et langt mer livlig lydbilde enn med innspillt mm...mer snert i bassen,og annen klang,til det positive...gleder meg etter 40 timer som du sier. ;D
    P
    Parelius
    VPI-en og en liten Luxman 444. VPI-en skal opp på veggen. Nå blir det litt artig etter hvert …
    Fosse
    Fått reoler? Hmmmm... må vi ha flere bilder av.
    Er det Cardas Golden Reference jeg spotter øverst til høyre?
    P
    Parelius
    Var på IKEA og kjøpte Bestå-reoler (2 stk - 120x64x40). Det får gjøre nytten til banken frigjør Montanasakene.
    Det er Cardasene dine, ja. Får vel duge så lenge til jeg kommer meg til Clas Ohlson!
    Får jeg nå bare vegghylla på plass, og kappet kabler i passende lengder, så går det nok bra.
    Fosse
    Dette ser da virkelig pent ut Parelius. Er du vennlig å ikke klippe Cardasene mine?
    For de som ser etter reoler kan Naver være et alternativ til Montana.
    argh
    Savner litt lytterintrykk av den ny fine Herronen din, et veldig intresangt produkt.
    Mvh,
    Terje
    Fosse
    Mener at Parelius og undertegnede laget en kort beskrivelse av denne opp mot Klyne den gang den var ny. Husker forskjellen mellom de to var langt mindre enn noen av oss hadde regnet med. Flotte produkter Herron, men det er jo Klyne også.
    Hagto
    Spennende saker Parelius!
    Bestå er en grei reserve, hyllene passer ihvertfall greit på mål til LP'er :)
    gut_man
    Lytteinntrykk Parelius? Eller var det målløshet som var effekten av tweaket :eek:
    terryboy
    Hvis du nå skulle finne på å hoste opp noen nye lytteintrykk Parelius, håper jeg at du kan beskrive forskjellene i to etapper:
    1) Forskjell med Super Platter (for det er vel den jeg ser på et av bildene litt lengre opp??!) kontra standard akryl tallerken fra VPI
    2) Forskjell med bruk av Ginko og ikke
    gut_man
    Fin oppfordring terryboy. Jeg er også svært interessert i å høre erfaringene til Parelius med superplatter og med Ginko! Jeg har bestilt meg et "ball suspension upgrade kit" til min TNT. Forestiller meg at det vil gi noe av den samme effekt siden det også er basert på luftfylte "squash" baller. Superplatteren er også noe jeg vurderer som fremtidig oppgradering, så erfaringene med denne tas i mot med glede!
    Audiophile-Arve
    Eg også er veldig interessert.
    Har skrive ein forferdeleg lang artikkel om SSM med superplatter no, men har ikkje fått gjort unna direkte samanlikning av denne saken. Reknar med å få prøvd AB-testing den 10/11 november. Artikkel kjem etterpå...
