Uansett, husk at jeg ønsker å få dette til å låte like eller bedre enn et tradisjonelt drivverk så jeg er utrolig takknemlig for alle tilbakemeldinger.
Kan du ikke også prøve foobar-digitalkabel-dac1?
Hadde vært UTROLIG INTERESANT å høre hva du synes om Foobar vs Squeezebox vs Drivverk når alt virker som det skal..
Recommended Player and Ripper software:
PC-driven audio is better than ever. The Foobar2000 player and Exact Audio
Copy (EAC) ripper make it practically foolproof to make exact error-free CD
copies on hard-disk and play them back. The quality of playback is superb
using Peter Pawlowski's Foobar2000 and there are lots of features and
plug-ins available for formatting, data-base use and look-and-feel. Here are
the links to download the basic tools for free:
Foobar2000 player Download can be found here:
http://www.foobar2000.org/
Read this FAQ after downloading:
http://www.foobar2000.org/FAQ.html#FAQ_o2
Output settings for Foobar2000 (preferences):
Windows 9x WaveOut is the best
Windows XP, 2000; later, Directsound is the best
Foobar2000 forum:
http://www.hydrogenaudio.org/forums/index.php?showforum=28
EAC ripper Download can be found here:
http://www.exactaudiocopy.de/
Driver Plug-ins
If you are using Windows XP, then the audio is routed through a DSP software
called "Windows Kmixer". This mucks-up the sound, so it is best to bypass this
mixer. To accomplish this, use plug-ins called ASIO or ASIO4ALL. These can
be downloaded for free from:
ASIO4ALL plug-in download site:
http://michael.tippach.bei.t-online.de/asio4all/
or
ASIO plug-in downloads:
Control:
foo_ddecontrol_029.zip Ver. 0.29 for foobar2000 Ver. 0.8.2 (52KB)
DLL:
foo_output_asio(dll)_041.zip (dll version) Ver. 0.41 for foobar2000 Ver. 0.8.2 (404KB)
EXE:
foo_output_asio(exe)_044.zip (exe version) Ver. 0.44 for foobar2000 Ver. 0.8.2 (526KB)
ASIO master page (Japanese):
http://www3.cypress.ne.jp/otachan/
ASIO files must be download and unzipped. Then put the .dll file (and exe if you got
that version) into your Foobar2000 plugin folder and re-start Foobar2000. Then go to
preferences, output and select ASIO. Then go to ASIO panel and select the right
hardware driver. If your hardware prefers the data to be INT32SB, then select 24 bit
in Foobar2000 preferences, playback, padded to 32 bits and turn off the dithering.
Buffering
ASIO, Foobar2000 and the control panel for the Transport driver all have buffering
size and number options. We have not determined the best configuration for these
in 16 and 24-bit modes yet, but we will update this section when we do. We have
noticed that the wrong buffer settings for 16-bit can delay the start of a track and
you loose that music, or in 24-bit mode, a long playlist will start to have ticks and
pops in the later tracks.
