Side 2 av 16 FørsteFørste 123412 ... SisteSiste
Resultater 21 til 40 av 313
Abonnér på denne tråden
  1. #21
    Hifi Freak CDWMcInSpots's Avatar
    Sep 2010
    Bergensregionen
    Tagget i
    0 Innlegg
    Utviklingskostnader og -tid samt en god del annet vi nylig har diskutert
    Apropos utviklingskostnader og -tid (som også ofte er penger) samt en god del annet vi nylig har diskutert:
    Stort utdrag fra et innlegg konstruktøren/designeren J. Gordon Rankin fra Wavelength Audio skrev i tråden "AudioQuest DragonFly 24/96 Asynchronous USB DAC / Headphone Amp" på Computer Audiophile om utviklingen av Audioquest DragonFly som er en meget liten asynkron USB-DAK + hodetelefonforsterker med samme størrelse som en USB-minnepinne. Han er innom og belyser flere av momentene vi nylig har diskutert.
    Legg merke til at det koster ca. $ 10.000 å lage hvert forslagseksemplar/hver prototype.
    06-20-2012, 03:26 PM #131
    Development on this was done over about 8 to 10 months. Kind of a funny story... I said lets do this and AQ wanted a dac with minimum phase filters. So we made a couple of dacs with the Wolfson 8741 and cap coupled and direct coupled and differential and single ended and if you don't know this every example costs about $10K to do. So we made up five different samples and they all were evaluated by the team and we were getting closer. I said look let me make what I originally suggested and I will pay for it if you don't like it. Well that is what is shipping! There are 107 components on a 0.6"x1.7" four layer board including a ton of regulators and expensive custom capacitors.
    3.5mm Do understand that at AudioQuest it's all about the metal. Both the USB connector and the 3.5mm connector are custom one off pieces made with high audio grade silver contacts. If we would have put RCA connectors on these it would have been on wire and what kind of an upgrade path would that have had? nothing!!!!! If we would have put RCA connectors on the unit then it would have been bigger you have to put them at least 0.75" apart and nothing would have fit the model AudioQeust wanted.
    I did a ton of work on the output stage to make it compatible with both line and headphone. I think it works really well with both as it has more drive than required for line and easily 2x more drive for headphones.
    Flavors...
    Look there are a lot of flavors of dacs out there. Everyone seems to be an expert but none of you have listened to all of them so really keep your mouth or fingers off the keyboard. None of us listen the same way or for the same purpose. It's like guitars... you don't hear musicians calling foul on guitars they just don't buy them. Audiophiles should be more like that and really go out an listen before you purchase or make comments.
    Thanks
    Gordon
    J. Gordon Rankin
    Wavelength Audio
    Løsøreoversikt. Jeg lytter med høyst moderate lydstyrkenivåer.
    Subjektiv observasjon vs. forsøk etter anerkjente vitenskapelige prinsipper.
    Standardforbehold: Meg, mine ører, min smak, på den aktuelle dag, i det aktuelle system, med den aktuelle musikk, ...
  2. #22
    Tittentei
    Guest
    NwAvGuy skal ha blitt bannet fra Head-Fi etter at han adresserte problemer med forumsponsoren Schiit Audios hodetelefonforsterker, Aasgard. NwAvGuy: Banned at Head-Fi!
  3. #23
    Jul 2012
    Tagget i
    0 Innlegg
    hmpf, jeg som vurderte Schiit Lyr! Tror kanskje jeg holder meg unna vist det er slikt
  4. #24
    Hifi Freak Loevhagen's Avatar
    Aug 2005
    L -> her <- H
    Tagget i
    0 Innlegg
    Album
    Jeg mener å huske at det var et problem med Lyr og Asgard, men at dette er utbedret for en god stund siden.
    I enden av regnbuen http://loevhagen.blogspot.com/
  5. #25
    Tittentei
    Guest
    Sitat Sitat fra Loevhagen Se Innlegg
    Mulig det, men å handle med et selskap som bagateliserer problemer som dette ovenfor kundene sine?
    Nei takk.
  6. #26
    Sep 2010
    Bergensregionen
    Tagget i
    0 Innlegg
    Manglende relé
    Schiit Audio drøyde en god stund før de krøp til korset og tok i bruk relé(er). De skrev t.o.m. en form for åpent brev om det. Det svever for meg at du kan ha skrevet om dette dengang da.
    Sitat Sitat fra tittentei1000 Se Innlegg
    [Video]
    Nei takk.
    tittentei1000 har rett i at Schiit Audio ikke akkurat gav noe godt inntrykk under prosessen. De kan vel knapt sies å ha vært ballen(?)
  7. #27
    Tittentei
    Guest
    YES! Endelig har jeg også rett i noe!!!
  8. #28
    Hifi Freak rumath's Avatar
    Mar 2004
    Tagget i
    0 Innlegg
    Pst! Folkens... dere har kapret tråden min. Tråden heter Schiit erfaringer, da jeg synes produktene så spennende ut, ville jeg sondere om det var noen som kunne anbefale, eller evnt. ikke.
    Noen flere som kan fortelle om Schiit produkter i tråden?
    Kjellerstue: Hegel Røst, Montana SP3, 65" samsung 4K. Stueanlegg: Klipsch Heresy III, Onkyo TX8270, Schiit audio headphone amp, AKG K242HD headphones ++
  9. #29
    Sep 2010
    Bergensregionen
    Tagget i
    0 Innlegg
  10. #30
    Sep 2010
    Bergensregionen
    Tagget i
    0 Innlegg
    Trådens emne
    Sitat Sitat fra rumath Se Innlegg
    Jeg tror nok at vi har oppfattet dette som tråden om hodetelefonrelaterte produkter fra Schiit Audio og dermed en parallell til:
    De siste innleggene om bl.a. Schiit Audios håndverksstandard og produktkvalitet angår direkte deres produkter. De er altså i samsvar med ditt ønske.
  11. #31
    Mar 2004
    Tagget i
    0 Innlegg
    Hmmm, når jeg skrev innlegget, så var det i alle fall 5 av de siste postingene som ikke dukket opp for meg. (Har selvsagt frisket opp browseren) Så ja, enig i at det er en del relevante tilbakemeldinger nå.
  12. #32
    Aug 2005
    L -> her <- H
    Tagget i
    0 Innlegg
    Album
    Jeg lar nå ikke en feil på et produkt fra en produsent overskygge hele sortimentet til samme produsent. Det blir for enkelt. Andre vurderer nok dette anderledes, men jeg har vel evnen til å tilgi. Ikke så dum egenskap det - og så kan det jo være at man vinner på det selv - og kanskje synes at Schiits produkter spiller flott til prisen. Skal ike se bort fra at Schiit lærte en lekse den gangen...
    Nå skal det legges til at NwAVGuy, som kritisk bruker skal ha æren for at han fikk Schiit til å oppdatere produktet. Så, skal man videre legge til at NwAVGuy ikke er like imøtekommende for andres "kritikk" av hans design av O2. Det hevdes at kritikerne er sensurert på hans egen blogg, som jeg ikke har lest kommentarene på i detalj. Headfonias review av O2 er ett eksempel.
    Det koker kanskje ned til at det å gi - og motta - kritkk er en kunst.
  13. #33
    Sep 2010
    Bergensregionen
    Tagget i
    0 Innlegg
    Leverandørers åpenhet, NwAvGuy og O2
    Jeg er enig i at alle kan gjøre feil, og at hvis man lærer av det, så er det bra.
    Det er dog en forskjell på produsenter som straks sier "Vi skal straks sjekke om det er et problem, og i så fall utbedre det" vs. de som må dras strittende og baklengs inn i det etter først å ha forsøkt å kneble (og gjerne også skyte) budbringeren. F.eks. kan de produsentene som ordner utestengelse av mennesker fra Head-Fi.org, neppe sies for å være tilhengere av åpenhet, transparens og fri informasjons- og meningsutveksling.
    NwAvGuy og O2
    Evt. kommentarsensur på NwAvGuy vet jeg intet om. Kan dette i så fall være forbundet med at noen administratorer el.l. fra Head-Fi.org ikke nødvendigvis fremmet saklig og høflig diskusjon?
    Jeg har lest en del av kommentarene til Headfonias "NwAvGuy’s Objective 2 by JDSLabs and Epiphany Acoustics". Noen av dem ser for meg ut til å være både saklige og balanserte. Slik jeg forstod og husker er årsaken til uenigheten omtrent slik: NwAvGuy har forsøkt å konstruere en (transparent/nøytral) "DIY wire-with-gain", og har så langt jeg har forstått lyktes meget bra. Headfonias forfatter og ganske mange andre hifimennesker ønsker egentlig komponenter som gjør noe med signalet (legger til og/eller trekker fra), men de er ofte ikke (helt) klare for å innrømme det hverken for seg selv eller andre (hvilket jeg har sett mange ganger).
    The Objective2 is neutral and transparent and, as opinions on the O2 show, when we are confronted with true neutrality, it might not be as satisfying to our ears as we thought it was.
    InnerFidelitys Tyll Hertsens har skrevet både om O2, mistroen til NwAvGuy og hans tall og egen vs. NwAvGuy's måte å møte verden på.
    Om O2s kvaliteter
    Sitat Sitat fra CDWMcInSpots Se Innlegg
    InnerFidelitys Tyll Hertsens om O2:
    If you've not heard of the O2 amplifier, it is NwAvGuy's attempt to design a very inexpensive amp that performs very well and can be built by DIYers. My experience with this amp so far is that it's very clean sounding, and does indeed measure very well. You can find out about it here.
    Sitatet er hentet fra "InnerFidelity Headphone Amp Measurement Program Update July 2012" der de benytter O2 under utviklingen.
    Om mistroen overfor NwAvGuy, hans tall og hans innstilling
    Det er stadig en del skriving om hvorfor de fleste hifitestomtaler er (rimelig) positive. Svarene varierer fra konspirasjonsteorier til at det ikke er noen vits å spandere arbeid og spalteplass på dårlige produkter.
    I kommentarene til den interessante artikkelen "InnerFidelity Headphone Amp Measurement Program Update July 2012" skriver Tyll Hertsens litt som tangerer dette:
    ^^^This!
    Submitted by Tyll Hertsens on July 18, 2012 - 10:21am.
    "I hope this will make people understand the hobby better, and by consequence make the offering from the manufacturers better too."
    My motives are more along those lines. Take data > publish data > everybody learns something new > cross fingers > write about good product (mostly) > products get better. That's what I hope anyway.
    Really? People thought he was
    Submitted by Tyll Hertsens on July 18, 2012 - 10:30am.
    Really? People thought [NwAvGuy] was faking his measurements? Got a linky?
    It's patently obvious to me that the guy knew what he was doing with the measurements. His "crusade" attitude might have been a bit touch and go, but I never doubted his numbers.
    FWIW, that's the tricky thing as an audio journalist/critic: How to report such that what you do is more constructive than destructive of the things that are good. Focusing on the poor performers doesn't do much for the good ones. I try to applaud the good stuff loudly, and let the measurements and little note in updates speak about the poor ones.
    I'll pen bad reviews on things that might be wildly popular though. To bad that happens so often.
  14. #34
    Aug 2005
    L -> her <- H
    Tagget i
    0 Innlegg
    Album
    Hvis Schiit hadde sagt "Vi skal straks sjekke om det er et problem, og i så fall utbedre det", så hadde de ikke hatt noe å lære.
    I den perioden Asgard ble diskutert, så var jeg i markedet etter en hodetelefonforsterker - og Lyr var en av dem som var på shortlista. Etter å ha hørt den i mai i fjor, sammen med Burson HA-160D, så var forskjellene mellom dem insignifikante (Lyr med originalrørene den gang). Jeg valgte Burson, blant annet på grunn av de diskusjonene som gikk den gang på Head-Fi.org. I dag, så hadde jeg ikke hatt noen kvaler om å ha kjøpt Lyr.
    Jeg tviler ikke ett sekund på at North West AV Guy (NwAvGuy) sin krets låter bra. Overhodet ikke. Spesielt etter å ha hørt Solderdudes sin Project Sunrise II, så innser jeg at ting ikke må koste mye for å låte bra - og at det finnes mange kompetente "DIY" der ute som ikke har komersialisert sine design / itereringer i stor skala. Jeg vil videre anta at NwAvGuys lite ydmyke innstilling til andres syn på hans forsterkerkrets, kan skyldes flere ting enn bare det tekniske. Ser den.
    Det jeg vet - eller antar svært sterkt - er at mitt første Schiitprodukt blir en Mjolnir.
  15. #35
    Aug 2005
    L -> her <- H
    Tagget i
    0 Innlegg
    Album
    Jason Stoddard sa nylig bl.a. "...Mjolnir has time-delay relay mute on turn-on and fast relay mute at shut-off, but it goes way beyond that. It also an analog computer section that constantly monitors both DC level and output current, and activates the relays to mute the outputs in case of either excessive DC or over current..."
  16. #36
  17. #37
    Hifi Freak ardilla's Avatar
    Dec 2009
    OSLO
    Tagget i
    1 Innlegg
    Album
    Hvorfor heter de Schiit
  18. #38
    Hifi Freak mteinum's Avatar
    May 2007
    Øya
    Tagget i
    0 Innlegg
    Album
    Sitat Sitat fra ardilla Se Innlegg
    Det er sikkert fordi de er så kule
    So, why don’t you check out our Schiit?
    About Schiit Schiit Audio — Headphone amps and DACs, made in USA.
    TIDAL|> Mac Mini / Roon |> SOtM sMS-200ultra |> Mytek Manhattan II |> FirstWatt B5 |> Trafomatic Audio |> Fostex T500mkII, FE203En-S / Acoustic Elegance OB.
  19. #39
    Mar 2004
    Tagget i
    0 Innlegg
    Nei nei! De er amerikanske, og navnet kommer fra serien "The wire" og senator Clay Davis. (Verdens lengste shiiiiiiiiit!)
    Senator Clay Davis - YouTube
  20. #40
    Jul 2012
    Tagget i
    0 Innlegg
    Sheeeeeeeeeeeeeeeeeeeeeeeet audio xD no thanks
    Ble tatt av når æ leste den tråden,
    What causes this (amp related)?
    Sponsored by headfi = Special treatment. We gotta sweep it under the rug and pretend its no big deal
    Det var et helt vanlig problem som ikke var et problem i følge dem.
    Siste redigert av Nipton; 14.08.2012 kl. 15:40.
Tags for denne Tråden
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
