Streaming - Hva gjør jeg feil?
  • Asbjørn
    Jeg ville forøvrig ikke kjørt uten pre med så godt som noen andre DACer på markedet, med noen ytterst få unntak. Ikke fordi jeg innbiller meg at jeg nødvendigvis hører forskjell, men fordi det beviselig er en suboptimal måte å løse problemet på teknisk, noe som aldri i verdien hadde gitt meg fred i sjela, og jeg har økonomi til å gjøre det optimalt om jeg vil. RMEn er et unntak fordi dette har fått ekstra oppmerksomhet i den spesifikke implementasjonen.
    Benchmark har en bra gjennomgang:
    DSP-BASED VOLUME CONTROL CAN WORK WELL PROVIDED THAT THE FOLLOWING CONDITIONS ARE MET:
    1. The digital volume control must be properly designed. The DSP calculations must internally use word-lengths of at least 24-bits. If the output word length is less than 24-bits it must be dithered. either be dithered or long word-lengths (24 or more bits ) must be delivered to the D/A converter. Many media players, computers, and digital devices use 16-bit undithered volume controls. In most cases, these 16-bit volume controls can bypassed by setting the volume to maximum. When this is done, an external D/A converter can be used to control the playback level.
    2. The D/A converter must have a spectacular dynamic range. It is not uncommon to require 20-30 dB of attenuation for normal listening levels. In those cases, the dynamic range of the D/A will be reduced by 20-30 dB. If your D/A converter only has a 110-dB dynamic range, the output will have a dynamic range of 80-90 dB – a dynamic range that is less than that of a 16-bit CD.
    3. The peak level of the D/A converter’s output should match the maximum input level of the next device in the signal path (amplifier, pre-amplifier, etc). This is a fundamental part of proper gain-staging, as it fully utilizes the headroom of both devices. This is the reason that professional audio facilities will standardize the operating signal level between audio devices (usually at +4 dBu at -20 dBFS). With this type of configuration, the dynamic range of the amplifier will usually be the dominate noise factor.
    Med 32 bits oppløsning, 120 dB SNR og inntil +24 dBu (12,3 V rms) output er jeg enig i at eventuelle hifi-nevroser trygt kan legges til side. Spesielt hvis man ikke har stenkoll på gain-strukturen gjennom kjeden. For de fleste av oss er det et langt større problem enn teknologien for volumkontroll.
    Min RME er forøvrig en ADI2 Pro FS, dvs også med analoge innganger (for å plugge inn sånt som elgitar via Line6 Pod). Da vil jeg påstå at den funksjonelt er en (hifi) pre, med analoge og digitale innganger, volumkontroll, eq, hodetelefonutganger, balanserte utganger, og til og med en fjernkontroll.
    I RME’s verden er en preamp noe som tar mikrofonsignal inn og leverer linjesignal ut, ofte kombinert med A/D-converter for å gi digitalt signal ut. I hifi tilsvarer det et RIAA-trinn.
    Jeg hadde forøvrig også en EC 4.8 pre en gang. Den fikk et veldig kort opphold hos meg, forsvant ut etter noen få måneder. Ser at den er erstattet av en forbedret «Mk II» hos EC nå.
    tkr
    Nede i fjæresteinene
    Vis vedlegget 884733
    .......Eller en platespiller........ :D
    Ask4me22
    Eneste veien til god lyd ja... Hvordan vet man forresten om man er havnet i placebo-fella?
    Absolutt, men i mitt tilfelle er det nettopp for Pod’en. Etter RME’en står en Miles Tri-Sonic analog matrisemikser (to kanaler inn, tre ut), en liten stabel Hypex UcD-forsterkere og så tre JBL 9350 på langsiden av rommet. Det er litt morsomt å la Pod’en emulere et Leslie-kabinett eller stereo delay og servere det i widescreen. Men streaming er det jo ikke.
    Gainstukturen i den kjeden er forøvrig helt vindskjev, med 26 dB gain i effektforsterkerne og 99 dB følsomhet i høyttalerne. Det er et godt stykke fra å behøve bekymre seg for fordeler og ulemper med digital vs analog volumkontroll.
    Reaksjoner: tkr
    bia
    Hvordan målte middagen i dag?
    Nå føler jeg snart at vi har pisket den døde hesten lenge nok, men før det har jeg ett siste spørsmål...
    Gir det mening at jeg mener at jeg opplever at telefon via lightning til usbc gir bedre lyd enn streameren, og nesten like bra som CD?
    Jeg trenger en bedre beskrivelse av signalveiene.
    bia
    Streaming fra telefon med kabel til dac til pre lyder bedre enn internet streaming fra wiim via optisk til dac.
    Samme materiale jeg har hørt på.
    1/2 Tam
    Det har jeg testet og hos meg er det lik lyd via Iphone sammenlignet mot Wiim Mini.
    Det kan jo være at din DAC er bedre via USB, men hos meg ingen forskjell.
    1/2 Tam
    @bia kan du dobbeltsjekke at ikke din Wiim Mini har hoppet over på bluetooth, det har skjedd hos meg ved minst en anledning.
    Sigma62
    Jeg kender ikke wiim. Men en simpel squeezebox duet med coax overførsel, vil være så tæt på cdafspilning, at jeg ikke tror, du kan høre forskel. Jeg tror problemer er din Wiim.
    Reaksjoner: bia
    bia
    Har sjekket. Den står på wifi. Siste ting jeg kan komme på nå er å se om jeg kan flytte litt på den og se om det er problemer med signalet.
    Powercon
    Horten
    Og CD spiller på Otisk vs USB fra telefonen inn på Denafrips er likt eller nærme? -Kjapt å bytte kilde og sammeligne.
    bia
    Cd er bedre uansett, men marginalt og så må vi ta med uvissheten om utgivelser igjen - og det er vel relativt utdebbatert nå :)
    Powercon
    Horten
    Ja, men jeg vil uansett si at du har komme et stykke videre. Streaming er ikke så ute på viddene som først opplevd.
    Om du streamer med telefonen via USB så opplever du det bedre enn via den optiske inngangen i ditt anlegg med Wiim streamer.
    Finnes jo andre streamers. :cool:
    Reaksjoner: bia
    bia
    En stor iphone lader.
    Powercon
    Horten
    Prøvde trådstarter å strømme fra eks Quboz for å se om det er forskjell imot Tidal?
    Dette for å ev prøve ut om Denafrips krangler med formatet fra Tidal. 🤔
    bia
    Nei, så langt har jeg ikke kommet.
    Powercon
    Horten
    1 måned gratis test på Qobuz. Har jo vært en innholdsrik vei hittil, enkel sjekk for å verifisere om det blir bedre/værre/likt. :cool:
    Edit: Med Qobuz så må man bruke WiiM appen. Fungere fint den.
    Flageborg
    Det ser ut som Denafrips er et godt valg blant de beste...... (y)
    Reaksjoner: bia
    Bart
    Bruker trådstarter optisk/TosLink?
    TosLink bruker protokollen S/PDIF. Det endrer seg ikke om man går fra Tidal til Quboz.
    Hvis det blir bedre med Quboz er det i så fall Wiim som gjør noe "feil" ifm. dekoding av Tidal.
    Bart
    Dekoder Wiim Tidals MQA da?
    (Tidal/MQA skyr jeg forøvrig som pesten, men den diskusjonen føres annetsteds.)
    Ser ikke ut som MQA er støttet, ennå.
    1/2 Tam
    Fra Wiim Mini sine sider:
    1. Hi-Res, 44.1kHz or 48kHz, 24-bit lossless FLAC that is higher than 44.1k/16-bit CD quality
    2. MQA, FLAC + MQA first unfold, usually 88.2kHz or 96kHz, 24-bit lossless audio (it hasn't been supported yet)
    3. Dolby Atmos, Dolby master (it hasn't been supported yet)
    Powercon
    Horten
    Ser det er en mqa-refeneranse i WiiM-app som står som Beta..... Er dette kanskje den første unfold? 🤔
    Men jeg lurte på hvordan Denafrips takler at hele greia er pakket inn i mqa-teppe. (om den er det da. Husker bare at min dac over natten plutselig sa at alt fra Tidal var mqa.....)
    Powercon
    Horten
    Trådstarter kan jo teste å slå den MQA Core Decoder Beta i WiiM-appen.
    Da skal det kanskje være nærmere samme situasjon som med test fra mobilen, der mobilen jo gjør første unfold.
    Bart
    Yess. Tenkte at det var en enklere/billigere test for trådstarter å verifisere, enn å direkte gå veien om dyr streamer og DDC-enheter++. 🤔
    Jeg ville testet med å bruke en laptop/pc som "streamer" i stedet for Wiim. En enkel måte å sjekke om Wiim er problemet.
    Powercon
    Horten
    Trådstarter har testet med usb fra telefonen.
    USB fra pc vil jo være samme sak skulle man tro. 🤔
