Originally Posted by tkr View Post
But the learning curve with the 3d is really challenging for someone like me. For two days now I been trying to get my monitor controller to work. I simply want to be able to have playback from one analog and one digital source into 4 channels of sound, but as of now I haven`t been able to accomplish that. I have had several crashes, and I haven`t the faintest idea why they happened.
Sorry you're having problems. Have you filed the bugs with the bug reporter when it popped up? If not, please start doing so, as it will help us help you.
Short answer to your question:
Use the Monitor > Add Monitor Source… menu command twice to add two sources; one for your analog and one for your digital; as you do that, choose the input channel for the source, and name the source.
If you want a 4 channel output, it would seem that you want to do something like crossover or bass management. If that's the case, you'll want to do Monitor > Edit Current Monitor Output… and then change the monitor output to a 4 channel path (either LCRS or Quad - it doesn't really matter).
To do your crossover or bass management you'll need to Edit the Current Output Graph and add the signal processing you need to route from the L/R input of the graph to your 4 outputs.
If you need more help with this, open a support ticket and we'll work through it with you.
Obviously, i couldn`t care less about low latency, mic preamps and the like, but I would really like to know:
1)Am I the only one struggling with the update and new interface?
2)Is there any kind of manual online somewhere??
3)Is there any use in trying to extrapolate anything from the online manual for the ULN 8 2d manual?
1) People seem to be doing OK, but some things are different enough that it can be an adjustment
2) This is what we have for now:
https://mhsecure.com/3d_public_beta/3dQuickStart.html
We are working on an updated and consolidated manual and will post it as soon as it will help more than hurt.
3) A lot of 3d is similar to 2d; so yeah, the 2d manual is potentially helpful, but there are differences.
I am extremely frustrated and out of my element. Whom can I turn to for help?
The first thing to do is open a support ticket with our support team; they can help you via email or you can schedule a call.
https://mhsecure.com/support
We can definitely talk you through the process of getting things set up, and you can definitely do what you want.
__________________
B.J. Buchalter
Metric Halo
