Yamahas venner
  • Teobald
    Oversettelse med Google translate til Yamahas venner
    You could have built a mega DVerstärker. Or a fully digital amp with color display and hard drive. Or a multi-channel all-format streamer amplifier with its own website.
    But miraculously, Yamaha has made another decision. And revive an old tradition. Namely, the tradition that big Japanese hi-fi makers have a top-of-the-line amp combination in their program. An ultimate testament to the skills of the development department and a sonic statement.
    This is how it used to be, and usually a pre / final amp combination was chosen as a figurehead. In the late 1980s and into the 90s, real Japanese power hum got into a market in which preferences prevailed: what was his McIntosh or Krell was Stax, Pioneer, Yamaha or Luxman. In Japan, this tradition lasted longer or took the form of special models that left the homeland only in homeopathic doses. Economic constraints and a changed market finally put an end to most of these super equipment, which showed pure Japanese culture.
    "The C-5000 is one of the most spectacular preamps of its time."
    Further we observe a further diversification of the HiFi market: Although retro trend and full digitization plus network exist harmoniously side by side, but the technical development knows only one direction, namely the fully digital amplifier with streaming, although it is not foreseeable whether room correction systems in the future rather in (active) loudspeakers or in amplifiers.
    To decide in this environment for the development of a technically sophisticated, but conventionally built, purely analog pre / final stage combination, is courageous and revealed in its consequence, the unshakable love of (hi-fi) thing. Because what is it really all about? Right, to the sound. The last few inches on the long staircase into the seventh sound sky are still the domain of analog circuit technology, conventional power amplifiers and conventional power supply.
    A carefully designed phono stage, powerful line drivers and a battery of high-current output transistors plus a thick power transformer and a phalanx of energy-saving filter capacitors are unbeatable when it comes to pure fascination, the last bit of sound and the highest speaker control.
    Exactly this well-tried, still gold right principle also follows the Yamaha station wagon. The precursor C-5000 and the power amplifier M-5000 also pay homage to another proven recipe: their amplifier circuits are fully balanced, thus doubled and floating, which promises fundamentally ever extremely high noise immunity.
    C-5000: Discrete construction
    In the past, discrete design (ie the use of single semiconductors instead of integrated circuits) with the exception of special dual transistors was considered an effective measure for sound improvement. The extent to which the Yamaha developers were able to pull this principle through consistently is difficult to assess - the C-5000 should be discreet in the signal path and therefore still has a lot of conventional, "large" electronic components, while most of the used individual Transistors are tiny SMD types, which is not surprising given the current delivery situation of individual semiconductors.
    The C-5000 is also an old-style preamplifier in terms of features: It has a built-in MM and MC phono stage, flanked by high-level inputs that address a line and output driver stage. There is also a turn-off tone control (as was never as puristic in Asia as in Germany on the way) and a headphone jack with Vorpegelsteller, which is very convenient.
    The symmetrical circuitry also led to a mirror-symmetric design of the signal path on the boards, the patented electronic structure not only leads numerous voltage regulator directly to the associated consumers, but also allows short distances between the rich equipped terminal panel and a host of high-quality changeover relay. Immediately behind the front panel resides a double power supply: Two shielded with copper cups toroidal transformers are each responsible for the right and left channel, to the power of "management" (ie relay, potentiometer, remote control) takes care of a small extra power supply.
    And although the current requirements of a preamplifier (the way always works in A-mode, otherwise it is not) manageable, set the Japanese everywhere on the lowest possible contact resistance through thick cables, screwed contacts and last but not least, on a copper-plated Chassis, which has a shielding effect and quickly dissipates even the smallest interference voltages.
    The fact that the hip toggle switches have to click as full as a safe lock, goes without saying for a device of this caliber, but then a massive aluminum level control with ball bearings is completely worn down. A remote control is still available, but it is not that much fun.
    Power plant with bulletproof glass
    27 kilograms and 400 watts into two ohms are already a word; Both are also the responsibility of an official power transformer, which is not only quiet as a mouse, but also sits on a brass base plate. The turn is connected to a two-piece copper chassis, on which the heat sink and charging capacitors are rigidly bolted; The whole ensemble sits almost as a sub-chassis inside the housing of the power amplifier M-5000 and should give by its sheer mass vibration no chance. It works so well that you can confidently "lay on hands", nothing moves except the speedy hands of the gigantic VU meters, which shine behind seven millimeter thick Asahi glass, making it hard to look elsewhere.
    On the power amp boards, Yamaha recalls a deliberately simple circuit design and points to a short signal path as well as highly current-efficient MOSFETs in the output. Incidentally, our measurements prove the stability of the M-5000 in the most beautiful, after all, the amp produces iron-hard 400 watts on a two-ohm load, the low distortion level, an enormous damping factor (296) and the no less exemplary residual noise of absolutely rock solid, to witness perfect development work. Incidentally, the pampered music signal is passed out using a double set of speaker terminals. They would also look good on a welder, but here they are gilded with wide ribbed caps. Corresponding cable lugs can be tightened so well, a thick mounting plate carries the four-terminal set trustworthy stable.
    The silence is stronger than the storm
    How noise-free affects us, we have already often discussed: The possible dynamic range between the loudest and the quietest sounds is greater, the transparency increases because less noise is there. A very low-noise amplifier is also artifact-free, "pure" in the sound, since the superposition of the useful signal with noise is less.
    The Yamaha station wagon confirms this in the most beautiful, deeply impressive manner. And instead of testing out the already brutal power delivery capabilities of the power amp, the station wagon tempts experienced listeners to listen, to listen to the silence between the notes, all of their textures, colors, tone / quietness and meticulous precision against a pitch-black background formally be dissected out.
    What remains is usually the groove noise of the records, because a pickup - it may quiet be a very, very expensive specimen - feels on the C-5000 audibly well cared for, with the impedance settings of the phono input are practical.
    The wonderful, expressive tones to which the good old analog technique is capable, the Yamaha combo without any smear enough, with a gentleness that one would not have expected these amplifiers. An extra dimension of sound opens up here, soft, soft music plantlets treats the station wagon as carefully as if it were afraid to crush it. Quite amazing: Wherever you would expect raw torque - which can also be called up when needed - there is seldom meticulous care, where you might have to worry about thoughtless hyperanalysis, manifesting a perfectly balanced, unassailable tuning that is profoundly musical and completely intact leaves. Whoever was responsible for voicing these amplifiers had a golden ear.
    "The M-5000 convinces with its outstanding sound and enthusiastic musicianship."
    With self-evident (spatial representation, dynamics, openness, information content) we are no longer busy this time, everything is available at a level that is hardly debatable. Our conclusion is therefore drawn quickly: Who wants to have world class at home, does not have to spend more money.
    MusicBear
    Disse holder nok aller øverste klasse.
    Spennende, om Yamaha blir fremtidens high-end produsent ut over rådyre entusiastprodusenter. De er så store at de burde kunne levere slikt til relativt normale priser. Klart Yamaha kan, dersom de vil, spennende å følge de fremover. Og det MÅ det være fornuftige priser, skal de lykkes, hvis ikke kan man jo like gjerne kjøpe Accuphase og Luxman.
    Teobald
    Problemet er nok markedet. Nå har de utvilsomt laget noe knallbra med 5000-serien. Og de setter den i slags masseproduksjon.
    Den har liksom det som skal til for å klassifiseres som highend, men ikke så mye mer.
    Prisen er stort sett den samme over hele verden ser det ut til:
    Høyttalere: 140k kr, forsterkersett 140k kr, platespiller 50k kr.
    Det blir kr 330 000,- pluss kr for pickup og ledninger.
    Hvor mange slike anlegg vil de selge? Kommer de til å tjene inn utvikling og utgifter til produksjonsutstyr for rasjonell produksjon.
    Jeg tror det er tvilsomt at de kommer til å tjene mye penger på dette her. Men de trenger nok en slik "statement-serie" for å vise at de kan :confused:
    Teobald
    Store ord om Yamaha's 5000 serie forsterkersett fra Australske SoundStage
    "Over the first few minutes of listening and then on to many weeks of regular auditioning, the C-5000/M-5000 combo performed commensurate with its exalted stablemates. I seldom state this so early in the piece but I will this time: the Yamaha C-5000 and M-5000 preamplifier and power amplifier are world-class-level and can mix it with the very best in the high-end audio space. Just saying."
    "Make no mistake, the Yamaha C-5000 and M-5000 preamplifier and power amplifier duo, alongside its ‘perfect match’ GT-5000 turntable and NS-5000 loudspeakers, will provide the engineering excellence, the aesthetic splendour and the arresting communication of the musician’s intent, in its purest form, on a par with the best of the high-end. These excellent components are worthy of my unreserved highest recommendation. Pure pleasure."
    Espen R
    nesten rart ikke nye effektampen i 5000 serien ble en 200 watter selv om 100watt rekker langt, men er allerede bekrefta at nye NS-5000 talerne krever endel Current så rart yamaha er så ``beskjedne``med effekten i samme serie etter mitt syn , men ser ellers fantastisk flott ut da morro når slike merker går inn å lanserer nye ``retromodeller:)
    M-5000 gir bare 2x100 watt i 8 ohm. Virker litt smått etter min erfaring. Driver NS-5000 med to kjempe (50 kg stk.) monobokker (Accuphase m-8000). Jeg har inntrykk av at høyttalerne håndterer det meste disse kan gi. Jeg ser imidlertid at du kan brokoble to M-5000. Da gir de 2x400 watt i 8 ohm. Det er kanskje det Yamaha har tenkt for de som vil ha skikkelig trøkk (optimal lyd) :p
    Yamaha er konservativ når de oppgir data. Og takk for det. Viser bare at dem er seriøse. 100 watt og 100 watt fru blom....hvor dimensjonert strømforsyninga er har mye å si for hvor kraftig forsterkeren oppleves å spille. Og jeg vil nok tro at M-5000 oppleves som en kraftig 100-watter.
    Forresten, jeg fikk rett i mine antakelser at M-5000 spiller i klasse A et godt stykke før den går over i AB.(Var poengtert i en test) Så det er mer en A/AB-forsterker.
    Og 100 watt er sikkert det dem klarer å få til uten å gå på kompromiss med lydkvaliteten. Det jeg har lest av tester så langt taler for at det er akkurat denne forsterkeren som jeg har lett etter. En feinschmecker forsterker med ekstremt lavt støygulv, super-nøytral og sofistikert gjengivelse; et slags Master-verktøy for musikken. Og som i tillegg har et klassisk og dritlekkert utseende, Imo.
    Jeg er i gang med å spare :)
    Espen R
    70000kr pr enhet :)
    Er ikke det i meste laget - fra en (tross alt) "masseprodusent" ?
    Eller er de sensasjonelt gode - oppe på Accuphase/Luxman nivå?
    Ja, med 5000-serien er de er oppe på Accuphase/Luxman nivå, minst!
    Yamaha er et konsern av størrelse. Hvis dem bestemmer seg for noe, og går all in, har dem muskler og kompetanse til å gjennomføre.
    Odd J
    Det er litt vanskelig å få oversikt over ‘signaturen’ på disse komponentene; er de nøytrale i klangen eller heller de over mot det litt varme og tilgivende? Hvordan er komboen i forhold til Yamahas integrerte utgaver, først og fremst A-S3000? Og hvordan høres det ut i en direkte sammenligning med tilsvarende fra Luxman og Accuphase? Det er jo sånt vi lurer på, alle mann:)
    Subjektiv testing av hifiutstyr er jo en mye mer ‘flytende’ kunstform enn f.eks å teste kamerautstyr den man bare peiser på med all verdens målinger. Mye av testene av hiend blir derfor ‘ål i oljefat’ da det står mye pent, men resultatet likevel er vanskelig å få ordentlig tak på. Det som oftest hjelper mest er å teste opp mot andre apparater i stedet for mot en slags standard (nøytral lyd, om du vil) da denne ikke er absolutt, men varierer enormt, basert på alle de vante tingene som vi alle vet om.
    Men direkte sammenligning mellom komponent A og B i samme anlegg utført av samme person gir en ganske bra mulighet til å beskrive forskjeller mellom komponent A og B og dette vil kunne gi leseren en god oppfatning av både A og B. Og som regel mye bedre enn individuelle hurratester av hver komponent for seg, adskilt i tid, rom og alt mulig annet.
    Har lest alt jeg har kommer over om komponentene i 5000-serien, men vil overhode ikke si at jeg har en bra forestilling om hvordan dette lyder. Klok av skade, jeg har kjøpt utstyr basert på tester og gått så til de grader i veggen at det ikke var til å tro....
    Håkonlj
    Toten
    Ny Yamaha venn
    Er det lov å kalle seg Yamaha venn etter innkjøp og en ukes fornøyelig testing og bruk av aventage 3060?
    Selv er jeg ihvertfall storfornøyd og blitt en svært god venn med denne recieveren :D
    B&W og Yamaha Spiller som hånd i hanske her i huset :)
    fluefiskern
    Da får jeg ikke til noe bedre i den lille leiligheten min, neste prosjekt innen hjemmekino får bli ett hus og dedikert rom.
    Det man ser i fronten her er: ns-8hx front, ns-4hx atmos, ns-c7hx senter, yst-sw1500 sub, cx-a5100 prosessor og mx-a5000 forsterker. Bakrekka består av 4stk ns-8hx og 2stk ns-4hx atmos
    Den stygge lampa kan ikke fjernes, den henger fast i veggen og jeg leier bare, i en 5manns bolig :p
    Men klarer meg enn så lenge, selv om det medfører noen ulemper og ha hjemmekino som hobby i en 5mannsbolig (og ja, jeg bor faktisk i midten, 3 nede og 2 oppe). det beste med "kinoen" er faktisk å se ut av vinduet
    Bjørn.H
    Heftig. Men du har kanskje enda plass til større høyttalere... :cool:
    fluefiskern
    Vi får se, etter at neste hjemmekino prosjekt er fullført :) men er igrunn meget fornøyd nå, eneste er at jeg vil ha 2 subber med frontmontert element, enn de subbene jeg har nå som høres ut som en 70åring med astma og kols i en bratt trapp, når jeg drar på skikkelig
    Bjørn.H
    Og resten av naboene da, hvordan høres de ut? :cool:
    fluefiskern
    Naboene klaga litt i begynnelsen, men har invitert de en etter en for å se på film, alle er enige i at jeg skal få lov å bruke anlegget til film på høyt volume frem til 12 på kvelden. Men hvis jeg prøver meg på å ha fest, så tar de hovedsikringen til hele huset.
    Er en fordel med og være han som hjelper naboene med alt. Fiske, båtene, vedlikehold av bryggene, tunge løft, snømåking. Er litt smisksmisk fra min side, men det fungerer tydeligvis
    Graks
    Noen som har løsning på å koble iPad via USB til Yamaha CD-S2100? Har Apple Camera Connection adapteret, men CD-S2100 virker ikke med denne. Har ikke prøvd med USB hub, mulig det virker da? Eller støtter DACen kun PC/MAC med Yamaha drivere?
    kjetil200
    A-Sxxxx serien har ingen jord kontakt på strøm kontakten, er det mulig å bruke vanlig kabel med jord lpå disse?
    Eller må kabelen også vere ujordet?
    Lette litt, men fant ikke noe svar på dette. Jeg regner med at man kan bruke alle ettermarkeds strømkabler på denne. Noen som har formening om det er forskjell på hvilken vei stikket står i kontakten?
    SvenO
    Eydehavn/ Arendal
    Du kan bruke alle som passer i A-S’en. Når det gjelder retning i stikk kontakt, så pleier jeg å måle potensial ( spenning) forskjellen mellom gods(jording til platespiller inngangen) og jording i stikkontakten. Alle innganger plugget ut. Den retningen som gir lavest er den som er riktig.
    Sent from my iPhone using Tapatalk
    ThomasN
    Her var det ikke voldsomt til liv... Men synes nå at Yamaha har kommet med en kreasjon som oser kvalitet og eleganse. Hadde ikke sett for meg å ende opp med Yamaha som platespiller... Men dette er nydelig for ører og øyne :)
    For en herlig spiller Yamaha GT-5000 er
    cbarth1
    Arendal
    Gratulerer, den var fet!!!! Hvor handlet du den fra? Har ikke sett den i de vanlige norske butikkene?
    motoren
    Flekkefjord
    Grattis med super flott spiller :) en av dem vakreste som finnes der ute
    MalaAudio
    Asker
    A-S3200 kommer snarlig :)
    A-S1200 og A-S2200 er på vei inn om kort tid til demo. Gleder oss stort til å prøve dem ut!
    Graks
    GT-5000 ser virkelig flott ut. :)
    Odd J
    Jeg sliter litt med å se hva som er de reelle oppgraderingene på de nye forsterkerne i forhold til de gamle. Litt småtteri her og der, men siden det begynner å bli kostbare saker savner jeg litt mer bang for the buck, må være ærlig å si det. Toppmodellen kommer vel på rundt 57k nå hvis jeg har sett riktig. Utgående modell kostet rundt 35-37k. Det hadde gjort seg med Roon Ready og qobuz/Tidal snarveier innebygd. Veldig mange konkurrenter kommer med sånt nå.
    SvenO
    Eydehavn/ Arendal
    Her ser det ut som modell skifte for å dra opp prisen! Yamaha har vel heller ikke streamer/DAC som står til kvaliteten til A-S serien. CD spillerene har DAC inngang, men ikke stream mulighet. A-S serien er jo utrolig godt skjermet så streamer/Dac burde vel ikke ha degradert lyd noe vesentlig?
    ThomasN
    Hvis de skulle ha laget en innebygget streamer og DAC som står til kvaliteten på ampen, så hadde det blitt en kostbar affære. Jeg personlig synes det er meget fornuftig at dem har droppet dette. Eneste mulighet jeg ser er at de hadde laget en løsning for separate kort som kan settes inn. En god DAC og streamer koster omtrent det samme som hele ampen :)
