Mytek lanserer Brooklyn AMP
  • - 2 x 300 Watts @8 ohm
    - egenutviklede filtre!
    Prisantydning: 18500 NOK
    Moiz Audio
    epost: info@moiz.no / mobil: 93047149
    Lars™
    Spennende M,
    Låner gjerne et øre til denne når den kommer :)
    mteinum
    Øya
    Meget spennende! Burde kunne dra AE-bassene greit !? :)
    Moiz Audio
    When on a roll, why not push on, the "High-Res Specialists from New York" must have thought...
    Following the Munich announcement of the pre-ordering of the CLEF, their new mobile USB/DAC/AMP with MQA, Mytek has come up with a revolutionary Class D design for their newest amplifier, aptly called the Brooklyn AMP, which they will introduce during Munich HIGH END 2017.
    Like the name suggests, the Brooklyn AMP will join their renowned Brooklyn DAC and shares its visual design. Mytek engineers built the AMP after endlessly listening, soldering, substituting components, computing--and even more listening--before they gave their stamp of approval on the final version of the Brooklyn AMP.
    The name is aptly chosen because the Brooklyn AMP fits in the same housing as the DAC, albeit with an inch of extra depth. It will be available in the same silver and black finishes as the Brooklyn DAC.
    Apart from its elegant looks, the Brooklyn AMP produces 2 x 300 Watts of output power at 8 ohms and drives even the most difficult of loudspeakers with ease.
    Mytek claims to have created a "triode Class A-sounding Class D" design which will make the Brooklyn AMP relevant for audiophiles worldwide. The expected retail price of the Brooklyn AMP is 1,995 Euro/$, and delivery will start mid-summer 2017.
    mteinum
    Øya
    Har du planer om å ta inn Clef? Tenker jeg kunne kjøpt en slik for å ha på kontoret.
    Moiz Audio
    Tar imot forhåndsbestillinger; veiledene pris er 19750, men vi selger disse for 18500. Kombopris med Brooklyn DAC er også mulig.
    Lars™
    Denne kom rekende inn døra i dag for testing (takk Moiz)....spent :)
    Lars™
    Farlig å uttale seg så tidlig i løypa kanskje...kun 2-3 timer på baken.
    Aner ikke om denne endrer karakter ved innspilling, noen mener det....
    Men umiddelbart; det beste jeg har hørt av en digital amp så langt.
    Skal prøve å komme med en bedre beskrivelse etter hvert.
    Moiz Audio
    Mytek had their shoebox-d Class D Brooklyn amplifier (US$1995) hooked up to a pair of Wilson Audio loudspeakers, fronted by the recently-announced Brooklyn+ DAC-preamplifier (US$2195). And when I stopped by, the Warsaw-based manufacturer could be heard winding the wick on some dubstep.
    Ten highlights from the Warsaw AV Show 2017 | DAR__KO
    Moiz Audio
    Liten oppdatering. Ampen har 8 dip switch settinger, hva disse gjør er følgende
    8 dip switches:
    dip switch 1. On/off of all other dip switches
    dip switch 2. On/off power up trigger
    dip switch 3. not used at the moment
    dip switch 4. not used at the moment
    dip switch 5. AMP gain (0 up, +6 dB down)
    dip switch 6. AMP balanced up/unbalanced down mode (You should switch to balanced when using XLR, unbalanced for RCA)
    dip switches 7 and 8 work together
    when
    -7 is up - AMP works in a normal stereo mode
    -7 is down - mode depends on dip switch 8 setting:
    -8 is up - Biamp mode
    -8 is down - bridge mode.
    ved brokoblet modus vill ampene levere 600 watt i 4 ohm
    Distinctive
    Spennende saker dette :)
    Regner med at klasse D teknologi er proprietær Mytek og ikke basert på Hypex nc500?
    MusicBear
    Ingen som har fått Brooklyn Amp i huset og evt. har lyst til å uttale seg om den?
    Lurer på hva den klarer ned til 3 - 4 Ohm, som brokoblet, om den tåler det i det hele tatt?
    Denne manhatten DAC'en til tre ganger prisen av Brooklyn DAC'en, noen som har formening om disse to ved spilling i CD-kvalitet - også og ikke minst kvaliteten på forforsterkerdelen? Tre ganer forskjell i prisen er mye for to små bokser, men kan være det er forskjellen verdt for det jeg vet - og da tenker jeg utelukkende avspilling i CD-kvalitet.
    Moiz Audio
    du kan jo ringe meg ..så kan jeg forklare forskjellene
    Moiz Audio
    Fortsatt stor backlog på DAC+/AMP...må vente litt til
    BeetleBug
    Hyggelig å lese at butikken går bra!
    Jeg venter fortsatt på uttalelser fra kunder som har kjøpt Dac+ og AMP. Hvordan låter dette hjemme hos dere? Og hva spiller dere på? Så langt kan man lese om "analogt" lydbilde, nærmest rørlyd. Superdetaljert DAC med alt man kan ønske seg av muligheter.
    BB
    MusicBear
    Bytter mer enn gjerne til små klasse A amper den dagen de låter som gamle tradisjonelle forsterkerbeist. Antar importør lar erfarne hi-fi journalister mene noe om småtassene som en start på en mulig ny verden. Så langt; for godt til å være sant :)
    Moiz Audio
    flere omtaler er på vei...
    R.E.S.
    Vet ikke om jeg er erfaren nok, men har i hvert fall hatt den i hus til test. :)
    Testen blir vel publisert før sommeren regner jeg med. (Men ikke i det første nummeret som snart kommer)
    Roy
Moiz Audio
Moiz Audio sine annonser
SPL Phonos RIAA test i The Ear
  • 1
Link til test: https://the-ear.net/review-hardware/spl-phonos-mm-mc-accurate-vinyl-sound/ SPL Phonos RIAA leverer en dynamisk og livlig lydopplevelse preget av nøytralitet og presisjon. Teknisk...
Lab12 DAC1 Reference
  • 2
PÅ LAGER IGJEN! Lab12 DAC1 Reference er et imponerende produkt som er konstruert rundt 8 Philips multibit DAC-chips i en parallell konfigurasjon og 6922 trioderør på utgangen. DAC1 Reference...
Burson Audio Soloist Voyager
  • 3
Flaggskip Amp fra Burson Audio er nå tilgjengelig i Norge Dette er en en Klasse-A, symmetrisk Dual Mono design og Fullbalansert . En strømsterk forsterker som leverer 10 Watt i klasse A...
Burson Audio diskret OP-amper: Vivid V7 Pro vs Vivid V6 (forrige generasjon)
  • 6
Andy skifter Vivid V6 opampene i Burson Audio Playmate 2 til nyeste Vivid V7 PRO, og forklarer forskjellene han hører. V7 Vivid PRO op-amps er designet for å oppnå maksimal oppløsning og...
BURSON AUDIO V7 OP-AMPER ! ! ! ! ! !
  • 8
BURSON AUDIO PRODUKTER KAN NÅ OPPGRADERES! Burson Audio's nyeste generasjon av Diskre OP-amper er nå tilgjengelig! v7 serien kombinerer banebrytende kretsløp og overlegen lyd. Den kompakte...
Audiophile.fr tester LAB 12 Gordian
  • 3
Tidligere omtalt hos stereopluss https://viewer.joomag.com/stereo-7-2023/0397186001696598323/p58?short AB12 Gordian er en strømrenser som består både av passive og aktive filtre. Analysekretsen...
