J.Finvaag skrev:
mls skrev:
En ting er sikkert og det er at Bybee i signalveien endrer lyden. Men ikke nødvendigvis til det bedre.
dette er en av de tingene som gjør meg skeptisk spessielt til dette produktet, hvordan i allverden kan du pakke en ekstra dippedutt i kjeden uten at den påvirker signalet og det kun i positiv retning?
Jo, altså (and I am not making this up, som Dave Barry ville sagt):
_________________________________________________
Bybee Quantum Purifiers operate on the quantum mechanical level to regulate the flow of electrons that make up the signal (picture a metering light regulating freeway traffic flow). Current flow within the Quantum Purifier is unimpeded and ideal (think of the unencumbered flow of traffic on a lightly traveled expressway). During transit through the Quantum Purifier, quantum noise energy is stripped off the electrons, streamlining their flow through ensuing conductors. Unwanted quantum noise energy dissipates as heat within the Quantum Purifier rather than emerging as a layer of contamination residue over the audio/video information.
The benefits of this process extend beyond the physical length of the Quantum Purifier. As electrons speed through the purifier, a "slipstream" effect is formed which facilitates current flow in the surrounding conductors of the playback system. Introducing Bybee Quantum Purification into the electron path reduces quantum noise and increases signal velocity, resulting in performance improvement beyond what is attainable by any cable alone, no matter how well designed.
The new Bybee Slipstream Golden Goddess products are the culmination of decades of research and development by Jack Bybee. Over the past couple of years, the new-millennium Slipstream purifier based on carbon fiber and nanotechnology has taken the elimination of quantum mechanical noise to unprecedented levels. Eichmann RCA plugs, banana plugs and 5-way binding posts, and ERS Stealth carbon fiber damping and shielding material, ensure sonically superior connectivity. A new, ultra-flexible expanded Teflon (ePTFE) functions essentially as an air dielectric for the conductors, virtually eliminating capacitance. Those elements combined to make the sonics of the original Bybee Slipstream accessories and cables dramatically open, spacious and tonally pure.
Jack Bybee has now added to those materials and construction techniques the uniquely natural sonic properties of 14 K gold for the signal (+) legs of all these new products. After extensive measurements and listening tests, he has chosen to complement the gold (+) conductors with high-purity silver ribbon for the (-) conductors. This silver ribbon has lower measurable resistance than either gold or copper wire, and the gold (+)/silver (-) combination has proven to deliver the most balanced, neutral and harmonically complete performance.
Klarere nå, ikke sant? Mr Bybee har selv satt dette på web-siden sin, så da må det jo være sant.
Det interessante her er at han (muligens utilsiktet) påstår ting som er målbare: Den vanlige betydningen av "quantum noise" er "shot noise", som skyldes at signalet overføres med enkeltelektroner (eller fotoner i et optisk system), og hvert elektron har en bestemt ladning. Et kontinuerlig signal består derfor av en stokastisk serie av enkeltpartikler hvis man forstørrer det hele tilstrekkelig mye. Dermed er "quantum noise" en grense for den lavest mulige støyen i et system - det er ikke fysisk mulig å redusere den videre, uten å oppfinne
mindre elektroner eller (som han faktisk påstår!) å få elektronene til å stille seg i en velordnet kø i stedet for å ankomme stokastisk. En definisjon fra
ATIS:
quantum noise: Noise attributable to the discrete and probabilistic nature of physical phenomena and their interactions. Note 1: Quantum noise represents the fundamental limit of the achievable signal-to-noise ratio of an optical communication system. This limit is never achieved in practice. [After FAA] Note 2: Examples of quantum noise are photon noise in an optical signal and shot noise in an electrical conductor or semiconductor._________________________________________________
Andre tar også med termisk støy i definisjonen av "quantum noise". I begge tilfeller er det ganske knallharde fysiske lover som er ute og går, type Heisenbergs usikkerhetsrelasjon og termodynamikkens andre lov. Målbart er det, åkkesom.
Derfor, oppfinneren av en dippedutt som får elektroner til å stille seg opp i velordnede køer i stedet for å oppføre seg stokastisk og/eller å redusere termisk støy uten å kjøle ned komponenten, kan ganske enkelt dokumentere dette på reproduserbart vis hvoretter han ganske sikkert kan avhente 10 mill svenske kroner, et pent diplom og en diger gullmedalje fra Kungens hånd i Stockholm påfølgende høst.
Men i stedet velger han å vederkvege våre lengtende ører med stadig lifligere musikk i stedet, og det nesten til en veldedig pris sammenlignet med den Nobel-prisen han så tydelig gir avkall på. Jeg blir nesten rørt til tårer over slik altruisme. [Snufs.]
