Politikk, religion og samfunn Nok et genialt trekk av de rødgrønne
  • Trane
    "Vi skal videreutvikle velferdsteknologi til bruk i ordinære helsetjenester."
    - Mens de i fullt alvor og med stor interesse studerer et stort puslespill hvis eneste formål er å fordrive tid.
    Man skal være godt oppslukt av sin egen boble for ikke å se ironien.
    morbid
    Kan man argumentere for den ekstra gassen man får på melkøya ved å bygge om til fornybar strøm erstatter kull og således får en noe bedre uttelling i klimaregnskapet?
    Jeg tror det er i seneste laget for det. Kull er allerede på vei ut. Tyskland står fast på at de siste kullkraftverkene skal stenge innen 2030. Det som skjer nå er snarereat gasskraft også fases ut. På marginen kan man like gjerne argumentere for at mer tilgjengelig gass fra Melkøya bare vil bidra til å utsette skiftet fra gass til fornybart.
    According to Ember, the smaller-than-expected coal rebound in 2022 shows the EU is committed to transitioning to renewables and phasing out coal. Instead of doubling down on fossil fuels, governments are turning to renewables to ensure energy security. Germany is still standing firm on a coal exit in 2030, the Netherlands still plans a coal phase-out by 2029 and Romania has moved forward its coal exit from 2032 to 2030.
    “Europe’s clean power transition emerges from this crisis stronger than ever,” said Jones. “Not only are European countries still committed to phasing out coal, they are now striving to phase out gas as well. The energy crisis has undoubtedly sped up Europe’s electricity transition.”
    As a result, Ember analysts predict that fossil fuel power generation will plummet in 2023, while renewables are set to rise further. The think tank estimates that fossil fuel generation could fall by as much as 20% in Europe this year, which would be the biggest annual decline in fossil fuel generation so far. As gas remains the most expensive fossil fuel, it seems likely that this fuel will decline the fastest. New fossil fuel infrastructure construction, like the liquefied natural gas terminals in Germany, will not change this, suggests Jones.
    “The speed of the fall in gas-fired power generation in 2023 will catch many people by surprise,” he told Energy Monitor. “EU gas demand fell by 12% last year, even though gas generation was unchanged. If gas generation falls by 20% this year, that is 5% off total EU gas demand by itself, before looking at other sectors.
    “Already, in the first 25 days of 2023, the EU’s gas-fired power generation was 37% below the same time in 2022. I think this will give more confidence in Europe of how quickly it can phase down gas use. Coal’s fate was already sealed; now it is gas that is in the headlights.”
    Disqutabel
    Jadda!! Dette er gennialt, Egon!!
    Av og til må man jo lure på om det er selvskading, selvironi, eller genuin dumskap som driver prosessene. Vet ikke om jeg skal le eller grine, men velger vel helst det første. La meg sitere en gammel kollega (han er dau nå, da) fra den samme landsdel som det her er tale om, med hans blomstrende vending: - De er fitten drage!
    BT
    Har de brukt Svadagenerator ?
    Hønndjevelen
    Tja.... er det strengt tatt såå mye verre enn den svadaen av intetsigende pjatt som serveres av alle partier?
    Det er jo stort sett slik næringslivet uttrykker seg.
    "Det er viktig med en prosess og løsningsorientert måte å møte dagens og fremtidens dillemmaer, slik at våre medarbeidere og kunder kan ta del i vår internaliserte verdiutvikling "
    weld77
    Burde kanskje ringe en bjelle for det lokale AP-laget når plakatene deres hadde funker fint som en rute i Lunch
    Dr_BASS
    Rælingen
    Utydelig retning fra regjeringen gjør at investeringen i det grønne skifte går saktere...
    Reaksjoner: SAL
    Nei, det er jo ikke det. Der jeg har jobbet blir svada møtt med direkte spørsmål av typen "Tjener dere penger, eller tjener dere ikke penger?! Hvordan ser resultatet ut dette kvartalet sammenlignet med samme kvartal i fjor? Bruttomargin, nettomargin, markedsandel? Opp eller ned?" HR og lignende tillates et visst slingringsrom for svada, men for de som har forretningsansvar er det mindre toleranse. Bullshit betyr gjerne exit etter ganske kort tid.
    Voff
    Det er kanskje derfor stilling ledig annonsene er fulle av svada og synonymet buzzwords. Tipper at jo mer svada du kan lire av deg jo lettere er det å få jobb.
    Er det udugelig nok (og det er ofte en korrelasjon), får du fallskjerm i tillegg...
    skranglefant
    Bartistan
    Jo, det er jo det. Også. Du ser det fra toppen, jeg ser det nedenfra.
    For oss 'fotfolket' som er mer interessert i å make shit work enn å sitte i møter og svelge floskler hele dagen (o'skræk :eek:) er dette usedvanlig vanlig. Og særlig etter at enellerannen gjerdepisser av en leder har besluttet noe ubegripelig evneveikt for å markere revir og dermed påtvinge alle berørte parter den aller nyeste prestisjekjepphesten.
    Det grelleste eksemplet i min verden var da en høvding hadde bestemt seg for at én spesifikk lokasjon SKULLE fjernes fra denne delen av virksomheten. Dermed sagde vi av oss drøyt 80% av sårt tiltrengt kompetanse som det allerede var skrikende mangel på.
    Gjett hvordan slikt pakkes inn når det skal forsvares og forklares.
    Nå bestemte ikke denne krabaten så veldig mye etter dette, meg bekjent, men da var skaden allerede skjedd.
    Synd men sant.
    EDIT: Jeg innbiller meg at dette er ganske gjengs i mange organisasjoner bare de blir store nok, offentlige som private.
    Hønndjevelen
    Tegneserien Lunch hadde aldri eksistert om ikke forfatteren hadde sett noe som vi som lesere kjenner oss alt for godt igjen i.
    Alt for mange av oss har vært utsatt for konsulenter med litt for mye gabba gabba go go språk.
    tjua
    Interresant kronikk fra en som har fått føle folkets vrede mht «gale» politikeres beslutninger uten konsekvensutredninger Desverre bak betaling
    Kort versjon; Melkøya beslutning drevet frem av olje og gass selskap. Vil medføre samme kraftsituasjon i Nord som man har hatt etter elektrifiseringen av Ormen Lange (150 MW) i Trøndelag. Det er den direkte årsaken til at trønderne måtte få inn vindkraft siden kraftprisen gikk til himmels, og nett/kraftselskap får svi for en påtvunget situasjon de ikke kan kontrollere
    Med Støre og Vedum i par skjer sjølsagt ikke det. Derigården sitter man for å lære
    Alt tyder desverre på at så ikke skjer.. gratulerer til nord No får dokker heldigvis lik strømpris som i sør
    Det viktigste er at ikke noen har det fortreffelig, det viktigste er at alle har det like dårlig (sett ift norske forhold, og ikke Afghanistan Afrika osv osv)
    Inkompetente folk finnes jo, og noen av dem pakker inn inkompetansen sin i floskler, men en effektiv organisasjon har mekanismer for å sile dem bort før de gjør altfor mye skade. Det gjelder både de innholdsløse svadageneratorene og psykopatene.
    En mekanisme som brukes der jeg jobber er ukentlige temperatursurveys av ansatte, hvor de svarer anonymt på et batteri spørsmål (ulike hver gang) og gir scores + mulighet til å gi anonyme kommentarer. Poenget med det er å avdekke «ledersolsikkene» som ser pene ut ovenfra, men sjuskete nedenfra. De resultatene leses ganske nøye både av HR og toppledelsen. Eksempel:
    Aurora
    Ytterst i havgapet...
    For meg er dette bare en trinn i utviklingen av et politikerspråk som går ut på å lire av seg flest mulig ord uten å egentlig å si noen ting...
    man kan jo fort bli konfrontert med lovnadene om de inneholder konkrete lovnader....
    weld77
    Husk på at det har sittet flere voksne personer i et rom og diskutert dette frem og tibake og dette er hva de har kommet frem til. Om noen protesterte vet jeg rimelig nok ikke noe om, men at dette i det hele ble valgt og trykket opp og publisert er smått fascinerende.
    lars_erik
    Hades
    Når politikk har blitt en karrierevei, hvor stadig flere mangler erfaring fra arbeidslivet, blir politikk stadig mindre preget av ideologi og instinktiv magefølelse. I stedet blir politikk et virkemiddel for egen karriere, hvor det er mer og mer viktig å dekke seg på alle bauer og kanter. I dette ligger også den stadig økende avstand mellom velgere og de valgte, hvor de valgte blir mindre og mindre i stand til å treffe med sine budskap. Karrierepolitikere tenderer til å opptre som forvaltere og byråkrater, ikke som det de er ment til å gjøre; styre samfunnsutviklingen etter sin ideologi. Derfor er det i dag også langt større vandring av velgeremassen, der de er på stadig søken etter noe som treffer de.
    Hønndjevelen
    Dette må jo være en prank!
    Bare vent, til uka er de tilbake med folkelige:
    Alle skal med.
    For velstand og velferd
    Nå er det Bodø Glimts tur,
    og
    Ta hele landet i handa.
    tjua
    ^med verdens største forbehold, sjølsagt
    Tweedjakke
    Market Snodsbury
    Den siste der var jo litt artig. Om spøken slår an, tviler eg på.
    Men eg lurer verkeleg på kva som har gått gale her. Heilt ærleg. Om det var ein dårleg spøk heile tida?
    Ap plar ha inkjeseiande, men likevel tilsynelatande forståelege slagord. «Alle skal med» og sånn.
    weld77
    Neppe, de har vel vært ute og kommentert at de ikke hadde truffet helt med dette.
    – Når vi har gått gjennom en del av disse innleggene ser vi at vi kunne brukt andre formuleringer.
    Det sier Arbeiderpartiets ordførerkandidat i Bodø, Ann-Kristin Moldjord, til NRK.
    Der ble hele kvoten av «understatement of the day»-priser brukt opp for resten av måneden.
    Hønndjevelen
    Jeg skal spise kablene mine om dette ikke er en del av markedsføringen.
    Om litt kommer en " vi skal snakke folkelig til folket" kampanje der de kritiserer uforståelig byråkrat og politker prat.
    I mellomtiden har de fått markedsførings og retorikk professorer og alle landets presse organer med på kjøret.
    Om dette snur skuta, eller bare er som Titanic's orkester som spilte mens skuta gikk ned.....?
    Hadde jeg jobba i pressa, ville jeg gitt faen i å dekke denne eventuelle akt 2.
    tjua
    Forøvrig på CNN akkurat nå; Talibans seire over kvinners makt går sin seiersdans over verden. Sitert fra Afghan kvinne «Taliban are flown in private jets to High level meetings with the red carpet rolled out so governments around the world are accepting Taliban rule”
    Endelig viser Norge way to go. Vi var som kjent de første som startet dette og vi har senere fulgt opp
    Gooooodt jobba
    Hønndjevelen
    Nå har jeg en del standard svarte "lakris lisser" så det går nok bra.
    Men om noen er up for it, jeg setter mine lakris lisser på at dette er et marketing trick, om noen setter sine "high-end kabler" imot
