Testvinneren Western Electric 91E - "BIG, BOLD AND BEAUTIFUL"
"STEREO+ MENER: En forsterker
laget av og for folk med lidenskapelig
forhold til lyd, musikk og
elektronikk."
"Konklusjon
Med de rette høyttalerne koblet til, er Western Electric 91E en formidabel
magi-maskin. At den er en ren nytelse for øyet og eiergleden,
bidrar bare til inntrykket av at dette er en integrert forsterker det er
vanskelig – for ikke å si umulig – å glemme. Har du råd, har du lov."
- Roy Ervin Solstad Stereo+
“This unit is groundbreaking…”
“The Western Electric 91E is a unique combination of ‘old and new.’ The heart of the unit is the WE 300B tube, which is made—right here in the U.S.A. by WE—to the same standards and specifications as the original WE 300B tube, with some enhancements to the manufacturing process that increase the tube’s longevity. The amplifier also blends an old circuit design (Class A2) for driving the grid of the tube with new innovative circuits like the patented SCCS (Steered Constant Current Source). Reviewer Rives Bird found the result to be nothing short of magical. Leading-edge designs like the 91E are not just hyperbole. They deliver real benefits, such as 20 watts of power from a 300B in single-ended triode (SET) mode. The 91E offers all the sonic benefits of the 300B without the shortcomings: well-controlled bass, a wonderful top end, and a five-year warranty on the pair of 300B tubes. It is refreshing to see tubes being made in the U.S. again. What’s even more impressive is the commitment Charles Whitener, WE’s CEO, has made to quality and execution. This unit is groundbreaking. It delivers an incredibly high standard at a relatively affordable price. [The reviewer] was so impressed he purchased the review sample and listens to it daily.”
- Excerpt from The Absolute Sound, Jan 2023
Stereophile:
“The 91E is not your traditional treble-and-midrange-champ SET amplifier. In delivering more strength and power without compromising the low end, it`s a classy machine that can frame music neutrally in a large soundstage. The 91E elicited consistent musical pleasure.
Western Electric is back.”
Ken Micallef - Stereophile
hifi-advice:
"The 91E has a remarkably solid and robust sound, not what you normally expect from a SET design. It’s also remarkably powerful for a SET design: 20 Watts instead of 7 Watts as normal for the 300B tube. This amplifier has the most powerful and impactful bass that I have heard yet from a SET amplifier using a single set of output tubes.
Dynamically, too, the 91E is rather surprising, sounding more like a big push-pull amp than a small triode. The difference is that, unlike many other push-pull tube amplifiers, and for all of its solidity and boldness, the 91E also has a seductive and gently-dosed warmth, a delightful smoothness, and an utter lack of hardness or edge even when pushed.
It’s arguably what the 300B’s are most famous for: that wondrously rich and deeply saturated midrange. The real beauty of the 91E in my view is that it blends robustness, solidity, and power with rich and deep tonal saturation and a smooth warm glow while remaining upbeat and dynamic."
- CHRISTIAAN PUNTER hifi-advice
Part-Time Audiophile:
"Yes, Western Electric is back, and in a big way"
whistler
Har ennå ikke klart å venne meg til utseendet på denne. Personlig synes jeg LM sine produkter ser mer ut som noe produsert av WE, enn denne "kreasjonen". For meg har den noe Alibaba over seg, men jeg vet at flere her på HFS synes den er "bæltøff". ;)
LMC
Drøbak
litt Consonance 211 håndtak, litt Kina CNC, etasjer etc
ikke my retro look nei
om 5 år er det en klassiker :)
kjellben
Den har nok kjempegod lyd i seg. Men etter min smak, er den ikke fin i det hele tatt. En Rolls Royce med utseende som en Skoda.:ROFLMAO:
Mvh Kjell
JMM
Slava Ukraini!
Fredrikstad
MOSFets og microkontrollere... Lite som minner om en 300B single-ended i denne her, patent pending eller ei. Heller det pureste humbug.
bambi
Sølvbyen
Jeg prøvde å legge inn en bestilling på 10 stk. i nettbutikken, men det var absolutt ingen rabatt å få.
Her er objektive målinger gjort av Stereophile.
Skal ikke kommentere noe angående produkt men at et magasin gir en forsterker til 200k på noen få watt med de store begrensningene det gir og dårlige objektiv ytelse, 10 (maks) poeng på ytelse/pris er noe underlig. Dvs. det kan ikke gjøres bedre faktisk.
Garantert en finfin musikkformidler likefullt og kult at det produseres fra det legendariske merket igjen.
Espen R
Stereophile skulle fått 3 eksemplarer tilgjengelig og sett om disse målte noenlunde identisk. Temmelig ofte gjør det ikke det fra disse småskala produsentene, store avvik registreres ofte. Ironisk nok, nettopp i dette prissegmentet burde forbruker forvente en konsistent og jamn kvalitet på produktene.
amason
Dvs nok et produkt folk synes lyder fantastisk tross målinger! Verden er vel full av slike produkter nå 👍
Terje-A
Jeg synes den er tøff jeg. Artig med produkter som skiller seg ut med særegen design.
HAREPUSEN
avtrådt 010924
telemark
Det er så sinnsykt enkelt at den er en current sourced singel end . )
En gammel teknikk som mest er brukt rør i drivere /outputs . mosfet og fet .Den vil være like mye elller ofte mer klA for det vanlig vis spolen som begrenser strømmen i SE out put stage . Fordelen er mye lavere forvrengning enn spolen " evt eller resistor last en "
En annen fordel er at spolen ikke lenger bærer tomgangs strømmen,,, som nå kan bestemmes av rørets max rating og current sourcen
Ny tenking og velkommen sier jeg og litt uvanlig og litt om snakking av en real current sourced out put " Det er ingen tvil om at den vil lyde godt til tross for at den ser ut som en push pull og ikke har en spole som er glo heit
HAREPUSEN
avtrådt 010924
telemark
Ja det glemte jeg Western Eletric ,,,Ett erhverdig gammelt foretak , ett produkt made in amerika , garantert laget for å vare lenge .
MalaAudio
MalaAudio sine annonser
Bruktmarkedet på Mala Audio
Hos Mala Audio i Asker finner du nordens største bruktmarked av hifi. Dette er både innbytte som vi har kjøpt av kunden når noen har kjøpt noe nytt, eller utstillingsprodukter og ting som har...
Ø Audio — Verdande
Ø Audio — Verdande
Verdande står klar i vårt minste rom — for å vise hva den kan. Disse står normalt i det store rommet, men spiller også veldig bra i mindre rom. Man kan modifisere bassgjengivelse i disse ved å...
Bli med på lanseringen av Ø Audio YMIR den 26. Mai
Ø Audio - YMIR - Lansering hos Mala Audio. Den 26. Mai klokken 18:00 hos Mala Audio kan du være med på et lanserings-event for Ø Audio sitt nye flaggskip: YMIR. Meld deg på...
Ø Audio bygger fotfeste internasjonalt | Verdande imponerer
  • 6
Ø Audio Verdande imponerer internasjonalt Den fysisk største høyttaleren fra Ø Audio har den senere tiden fått stor oppmerksomhet i utlandet. Først kom den strålende omtalen fra veteranen Michael...
Lyttekveld og eventer hos Mala Audio
Hos Mala Audio ser vi ikke bare på hvordan utstyret ble laget, men også musikken. Vi arrangerer jevnlig eventer i våre lokaler i Asker, alt fra produktlanseringer med leverandører som...
Hvilken Streamer/DAC er best?
  • 1
Hvilken Streamer/DAC er best? Hvordan kan et eksternt klokkesignal ta deg enda dypere inn i lydbildet? Vi har rigget til butikken med utvalgte dCS produkter — som står klar for demonstrasjon...
