Bergmann nyhet. Galder/Odin Signature!
Bergmann har gjort det igjen. Forbedret en analog spiller som har blitt kåret til en av verdens beste analog spiller av mange av verdens ledene analog og HiFi magasiner og til en pris som ligger langt under konkurrentene!
Etter å ha levert etter kundeoppfordringer platetallerken med i div Bronse legeringer mm. Så har det aldri vært en stor nok oppgradering til at ville ble en ny (signatur) modell.
Men etter å ha testet ut div andre metaller og legeringer. Så var det rustfritt stål som utmerket seg som en god oppgradering med tanke på lyd!
Det var nok til å lansere Galder/Odin Signature.
Prisen forventes å havne på NOK. 435.000.- komplett.
Les mer her:
We are very proud to launch the new Galder-Odin Signature.
It is 5 years since we launched the well-known classic Galder & Odin, which, from the beginning, has won great acclaim - for design, technology, craftsmanship, ease of use, and not least the sonic qualities.
The classic Galder and Odin will continue in the Bergmann product line for many years. But we decided to follow up on this success with the new Galder-Odin Signature, to push the performance even further.
With the new Galder-Odin Signature, we have taken this system to a new sonic level.
Vital parts are made of solid stainless steel. Such as the 36kg platter, the clamp, and the unique adjustable Galder feet (further developed).
We have improved the Odin tonearm for additional strength and stiffness, as well as even easier adjustment of the VTA and overhang. We have developed a libelle tool that makes it quit easy to adjust the air pipe levelling.
Galder-Odin Signature comes with a more powerful airsupply, to lift the dramatically heavier platter. And the easy operated vacuum hold down is integrated as usual, on the turntable.
With the new Galder-Odin Signature, we achieve more depth and weight in the low frequencies. The transparency is dramatically improved, and the full sound image has become even more vivid.
To complete the design, we have added additional items in steel, such as push buttons, Bergmann logo plate.
The plinth is painted in Black Velvet finish which matches the semi-shiny honed stainless steel parts perfectly.
Galder-Odin Signature. A performer. Forever.
Danish design - produced in Denmark
I know we will have the question: - can the classic Galder or Odin be “upgraded”? And the answer is that only the classic Odin tonearm can be upgraded with the features from Odin Signature.
Norsk AudioTeknikk AS
Ullevålsveien 13
0165 Oslo
Tlf: 22200095
Mail: morten@norskaudioteknikk.no
Web: www.norskaudioteknikk.no
Facebook: https://www.facebook.com/NorskAudioTeknikk/
Facebook PMC: https://www.facebook.com/groups/384770248991790/
Hønndjevelen
Sier meg enig med motoren, her;). Prisen derimot.......
Som med alt jeg har lyst på: flott villa, rå bil, high-end eller damer med high maintenance...
Må du spørre om prisen, da har du ikke råd!
Reaksjoner: nat
Motorhome
Sunndalsøra
Synes denne er penere enn Magne. Ser ut til at armbase og motor er helt adskillt fra selve basen for å få ennå mindre vibrasjon. Er man seriøs vinyl og musikkelsker, så er man villig til å betale det det koster og samtidig er ungkar. Kjenner til sorten:)
Reaksjoner: nat
nat
Synes denne er penere enn Magne. Ser ut til at armbase og motor er helt adskillt fra selve basen for å få ennå mindre vibrasjon. er man seriøs vinyl og musikkelsker, så er man villig til å betale det det koster og samtidig er ungkar. Kjenner til sorten:)
Det er helt riktig oppservert 👍
nat
nat sine annonser
Kommer snart. Norse Audio By Bladelius.
  • 1
Om noen uker så presenterer vi nyheter ifra broderfolket. Norse Audio by Bladelius. Bildet viser Norse Audio effektforsterker som er en del av et modulært konsept. Mer info kommer ved lansering.
Godlyd på farten, hjemme, eller på kontoret?
Norsk Audio Teknikk AS kjører pakkepris på Meze 105 Silva hodetelefoner og Cayin RU7 dongle DAC/Forsterker. Pakkepris Kr 9.195.- (veilpris Kr 10.680.-) Norsk AudioTeknikk AS Sofiemyrveien 12...
Vi fortsetter introduksjons tilbudet på den nye Cayin Jazz90! Kr 25.000.-
Nyutviklede Cayin Jazz 90 integrert rørforsterker med masse funksjonalitet til 31 lapper – det skulle nesten ikke være mulig. Den nye Cayin Jazz90 ble umiddelbart en suksess verden over. Også...
“The prophecy9 delivers higher fidelity to the source than most speakers." hi-fi+ magazine.
  • 1
PMC sin nye Prophecy serie som ble lansert nå i 2025. Går sin seiersgang rundt om i Europas mest kjente hifi magasiner! Dette er den seneste testen av toppmodellen Prophecy 9 i HiFi + Sitat om...
NYHET! Cayin Jazz 90 integrert rørforsterker er på plass i butikken og på lager.
Nyutviklede Cayin Jazz 90 integrert rørforsterker med masse funksjonalitet til 31 lapper – det skulle nesten ikke være mulig. Cayin Jazz 90 lanseres i disse dager. Dette er en håndbygget...
Spinnvilt introtilbud!
  • 27
Nyutviklede Cayin Jazz 90 integrert rørforsterker med masse funksjonalitet til 25 lapper – det skulle nesten ikke være mulig. Cayin Jazz 90 lanseres i disse dager. Dette er en håndbygget...
