Hvorfor skal vi ikke stille spørsmål?
  • 1/2 Tam
    Og alle var vi enige om at kjøttkakene var god.
    Write a Review and share your opinions!
    Rating:
    Good for the price
    Wednesday, 25 August 2021 | Rafi
    Tried it in PS Audio Stellar P3. Better than stock. Needs a few days to settle. Lower end and mid bass emphasis but upper end a bit down.
    Was this helpful to you? Yes / No
    This review has not been appraised.
    Rating:
    HIFI TUNING SUPREME 3
    Sunday, 13 December 2020 | Franco
    Fantastic fuses
    Rating:
    Best upgrade ROI ever
    Sunday, 25 October 2020 | Ankur
    Loving these fuses in my DAC!!! It’s incredible how much of an improvement they make for less than the price of an entry level power cable upgrade.
    Rating:
    Cheap upgrade for your system
    Friday, 2 October 2020 | Kah
    The fuses took a while to run in, when first installed ('upgrade' from Supreme silver-gold) the sound was a bit 'splashy' in the treble region. After about a 100 hours the sound has richer bass and increased detail in the treble. Only issue I have is on some CDs the treble is still a little bright, hopefully with a few more hours of run-in this will disappear.
    Also surprising is the fact these fuses appear to be a significant upgrade from the silver-gold supremes, it could be that age has caught up with my silver-gold supremes(more than 5 years old).
    I still have not installed the fuses for my power amp, only upgraded my disk player, subby and power regenerator.
    3 of 4 people found this review helpful.
    Rating:
    Audiomix
    Hvorfor ikke fjerne sikringene? Alt degraderer jo lyden.
    Hvis du mener å sette inn en spiker (kortslutte) så kan du komme dårlig ut om det oppstår en feil.
    Sikringer gjør ikke at feil ikke oppstår, men at feil ikke fører til katastrofe.
    Hvis du mener å ta den bort............
    Armand
    Angående overprisede tullesikringer og innbilte effekter
    Jeg har jo noen low noise power supply på samvittigheten også.
    F.eks et RIAA power med helt idiotisk overkill mye filtrering og skjerming og regulering
    Det hele starter med en av/på bryter og en sikring.
    Så må strømmen passere 6 trinn der hvert av disse trinnene har som mål å fjerne støy og senke og regulere spenning.
    1. Skilletrafo 230 -> 110V
    2. Skilletrafo 110V -> 24V
    3. Likeretting og glatting med pi-filter og spoler i en C-L-C-L-C configurasjon med 30000uF kapasitet.
    4. Regulator 1 som fjerner støy
    5. Mer spole og filter
    6. Regulator 2 med 0,3uV støygulv
    Støyreduksjonen fra strømnettet (der sikringen sitter) til utgangen på power supplyet ble målt til minimum 155dB opp til 80kHz
    ALLIKEVEL satte kunden sette inn en "bedre" sikring og mener at man kan merke det.
    Han mener altså at man kan høre en bedre sikring selv etter over 150dB med filtrering !!!!
    Det er bare ikke mulig. Det er faktisk det samme som å påstå at man kan høre en mygg på 167000km avstand.
    Prospect
    Ute i det friere landskap (heldigvis)
    Weeelll, alt farger lyden.
    Masteren er et råprodukt de fleste ikke besitter og som blir mikset etter smaken til den som utfører jobben.
    Forsterker velges etter egne preferanser, det samme gjør HT og jeg vil påstå at det ikke finnes en fasit på hva som er «riktig» lyd.
    Preamp som jo er en nødvendig del av kjeden likeså.
    Vi er vel enige om at de låter forskjellig eller?
    Min erfaring på mitt tilårskomne oppsett er at strømkvalitet faktisk endrer lyden selv på en god strømdag.
    For den som spiller vinyl (utenfor mitt område) så har jeg forstått at mulighetene for tweeks er nærmest uendelige i absolutt alle ledd.
    Men, jeg har jo bla sett litt på Pass sine enklere forsterkere og ser jo med nysgjerrighet på så enkle oppsett som mulig.
    Så som høyeffektive fulltonere med rør eller feks Pass sine enkle konstruksjoner, men jeg står fast på at det alltid vil måtte
    bli et kompromiss etter egen smak.
    coolio
    Erstatte alle sikringer med ren gulltråd. Har man kontroll på ting går det ikke til helvete. Risikoen for katastrofe er noe man bør akseptere i den gode lydens navn 😀
    kjellbjarne
    Sånn ca fordeling mener dere 2021? 80 høyt 15 forsterker 4 kilde 1 kabler
    kjellbjarne
    Glemte akustikk ja, har det virkelig så mye å si
    ymir
    Vis vedlegget 754315
    Hmm, rart att det trengs så mye mikk makk for å lage en upåvirkelig strømforsyning.
    Tidligere år er det hevdet at en upåvirkelig strømforsyning koster småpenger, så egentlig blir dette vel litt som keiserens nye klær og unødvendig dyrt?
    Er det skilletrafo eller støydempingstrafo..
    Prospect
    I et anfall av sterk utolmodighet etter et års jobbing med å lage meg et hobbyrom i kjelleren satte jeg opp HT og anlegg i tomt rom.
    Måtte bare bare ha en test av mitt «fantastiske» lyd og filmrom.
    Ble skuffet så det holdt, nesten deprimert må en vel si av den elendige lyden jeg fikk.
    Ordnet nå selvfølgelig med både møbler og diverse tiltak, men akustikk og rom er i aller høyeste grad viktig JA.
    Audiomix
    De aller fleste smeltesikringer har vel sølvtråd, så det er vel allerede high end?
    Og så lenge sikringen slipper igjennom 220v til forsterkeren så er det godt nok.
    Et lite utvalg.
    Den til høyre er til DMM.
    Ekstra sikker. Aldri godt å vite hva måletullinger finner på.
    HasseBasse
    Hjortshøj, Danmark.
    Precis det jeg mente med "tegne og fortælle bedre enn jeg".
    Takk @Armand (y)
    MakkinTosken
    Godseier
    Me? Just hanging around!
    Ikke alle high end merker er kokt sammen av interiørarkitekter og frisører. Noen av dem har reelt ingeniørskap i bunnen og til tross for tilsynelatende overpris forholder seg nøktern til tilbehør.
    Men også de tilbyr "lifestyle" for oss fanboys
    Kaffen smaker selvfølgelig bedre i disse. Bare spør @Stalewinter Synes han kunne kommet med en karakter.
    oks81
    Hjemme
    Stiller mer spørsmål med hvorfor ikke folk ikke er mer opptatt av ting som betyr noe.
    En vanlig mellomtone så er det faktisk under 1% av tilført effekt som blir til lyd.
    På en kompresjonsdriver med tilhørende horn er en gjerne oppe i 110dB følsomhet, da er det godt over 50% av tilført effekt som bli til lyd.
    Sikringer er til for at de skal ryke om noe er galt så en slipper at ting eksploderer og/eller tar fyr.
    Intet annet.
    Vis vedlegget 754347
    Intet annet.
    Indeed. I avdelingen for ting som betyr ganske mye, men som knapt noen selverklært audiofile ofrer en tanke: Gainstruktur.
    Syncrolux
    Intet annet.
    Har Magnepan. Blir krenka ! ;)
    oks81
    Hjemme
    Enig med dette med gainstruktur.
    Jeg var ikke ute etter å krenke Magnepanere, lærer nok en dag...... 😇
    Det jeg var ute etter er jo mer strøm en dytter gjennom spole i en drivermotor så skjer der saker og ting.
    Og det vil jeg mene er mye mer interressant en materiale på sikringer, AMS målere og alt annet som blir nevnt her.
    Reiner med det går tre innlegg så er likevel dette innlegget jeg skriver nå glemt og historie i en slik tråd som dette.
    Armand
    Helt klart unødvendig dyrt ja. 155dB demping er også som nevnt i posten min "idiotisk overkill", men så var det var litt av poenget også. Det skulle være overkill. Allikevel kostet ikke dette poweret mer enn en liten håndfull "gull"-sikringer.
    Trafoene som ble brukt er av typen med fysisk separerte primær og sekundærviklinger. Det eneste fornuftige valget i laveffekt power supply.
    ymir
    Men da helt uten noen lydforbedring?
    Og i såfall hva selges konstruksjonen som?
    MusicBear
    Godtfolk, siden Snickers-Is trolig har kastet seg foran toget for lengst, i ergrelse over sin tråds utvikling. Tillater jeg meg å spørre om en av klodens mer aktive høyttalerbyggere - Troels Gravesen - ville hatt som motiv for å fronte måleresultater av sitt levebrød…
    …Mens han imidlertid hevder/advarer med dette her (ved inngangen til sine egne måledata):
    A few comments on MEASUREMENTS before you start interpreting the readings below.
    First of all, if we think measurements will tell us how a speaker sounds, we're wrong. The perception of sound is way too subjective to be reflected in any measurements we can perform. A loudspeaker system is meant to give us a satisfying idea of an acoustic event and for some people a pair of 5 USD ear-plugs are enough, others spend 200 kUSD on a truly full-range pair of speakers - and the latter may not be happier than the former.
    Measurements may give us an idea of tonal balance of a system, i.e. too much or too little energy in certain areas, although dispersion characteristics play a vital role here. A two-way 7+1 and a three-way 7+4+1 may display similar horizontal dispersion, yet sound very different. Measurements may tell us about bass extension if far-field measurements are merged with near-field measurements. In addition to this, ports may contribute to bass extension. Most of we diy'ers do not have access to an anechoic room for full-range measurements from 20-20000 Hz.
    Er Troels fullstendig på jordet der nede ved Aarhus?
    Armand
    RIAA power må være støysvake. Man ønsker også god isolasjon mot kapasitive jordstrømmer og man ønsker god demping av støy fra strømnettet. Kunden ønsket seg et med bedre data på disse områdene enn det som fulgte med originalt. Han ville ha overkill og jeg lagde det. Kunne sikkert klart seg med mindre støyreduksjon uten at det hadde hatt noe å si. Du som er en forkjemper for ren strøm kan da veil ikke ha så mye å utsette på dette Ymir? Vil du ha ytterligere detaljer kan du sende meg en PM.
    Armand
    Når Gravesen sier "First of all, if we think measurements will tell us how a speaker sounds, we're wrong."
    Så tror jeg kanskje disse gutta ville vært uenige..
    Når det gjelder amatører som oss som sveiper litt med en mikrofon til en tusenlapp så er jeg langt på vei enig. Men tross alt mye bedre enn ingenting.
    Bergfinn
    Det er vel ikke på jordet?
    Målinger forteller ikke alt, eller hvordan det høres ut.
    Det vet da iallefall alle som holder på med DIY.
    Er vel ikke noe kontroversielt med det?
    Reaksjoner: erk
    Audiomix
    Forstå hva Armand driver med!
    Det han har gjort her skal ikke (?) bli noe kommersielt produkt til HiFi.
    Noen ganger kan det være utfordrene å se hva som er mulig å lage i forhold til hva som er mulig å måle.
    Ikke hva som er mulig (eller umulig) å høre.
    Stalewinter
    Vis vedlegget 754342
    Vis vedlegget 754346
    Et klart terningkast 6 🥳 Gøy med slike kopper som får kaffen til å smake bedre.
    ymir
    Synes bare det er litt merkelig, når du latterliggjør de som kjøper støydempingstrafo og filter i løs vekt.
    Kunne brukt pengene på en flaske Guatemala rom eller annet godt eller en Teddypardo strømforsyning,(som fungerer like dårlig som andre)
    Audiomix
    Forskjellen mellom hva du viser til her (støydempingstrafo etc.) og det Armand gjør er som et lysår.
    Som en redaktør av fidelity ville uttrykt det.
