Refoaming av Lowther
Griffenfeldt
I en blokk
Har et par Lowther dx3 elementer hvorav den ene lager en skurrelyd i perioder. Den blir gjerne fremprovosert av pianomusikk av alle ting.
Jeg klarer å gjenskape lyden ved å dytte lett på elementet og hører at den kommer fra skumringen rundt elementet.
Jeg vil nødig sende inn elementene til Lowther eller hive meg på en bytteordning.
Får man kjøpt reconingssett fra Lowther og vil jeg klare det selv?
Har funnet en video på Youtube som viser en som utfører det selv, men det ser faktisk ut som han bytter skumringen med gummi og da ser det jo ikke vanskelig ut strengt talt.
fraiser
Ser kantringen morken ut.?
Det vanligste på lowther er dette.:
Lowther Maintenance
Do you have problems with your Lowther driver? Here is how we maintain them. Make sure that you have a clean work environment. Do not have steel tools or metal dust lying around. Always keep the very large magnetic force in mind. The magnet can pull a tool from your hand and into the cone, or any small metal shavings into the voice coilgap. The most common problem with Lowther drivers is voice coil rubbing. This can be caused by any of the following:
The diaphragm assembly does not sit square on the magnet and the coil rubs inside the magnet cap.
The driver could have been jogged in transport or maybe the coil is not quite round. The air gap width of the magnet is less than 1mm so small misalignments are critical.
Foreign matter has entered the gap and is causing the cone to rub.
Your driver may be so old that the foam surround has perished. The required tools for maintenance are:
A 5/16mm wrench, it should be as "thin" as possible. Stainless steel is preferred, but not necessary.
A roll of aluminum foil tape with an acrylic glue on one side. You can also use a business card with tape wrapped around the outside, sticky side out. This is what you need for those iron filings stuck in the air gap.
1.5” diameter pipe will be required if the former is not round.
A test CD or frequency generator for 20-50Hz notes. Connect the driver to an amplifier which is being fed a 20 hz. note. Raise the volume very slowly until the cone moves about 1/8”. There is often a slight clicking noise from the flexible wires connecting the post to the cone, ignore this. If you do not hear any scraping noises the cone is properly centered & the voice coil gap is clean. If there is a scraping noise then continue on. At times something gets caught in the voice coil so that sometimes it rubs, and sometimes it does not. If you have this problem you must go disassemble the driver and clean out the voice coil gap. If you can see that the voice coil is not properly centered, you probably just need to realign the cone. Place the driver onto a table and connect to your test system. Loosen the bolts holding the cone basket to the magnet. “DX” drivers have four bolts, “A” drivers have 3. You want these mildly tight to prevent easy movement of the cone, but not so tight that you cannot adjust the cone position.
Griffenfeldt
I en blokk
Takker for svar.
Nei, kantringen ser ikke morken ut.
Det høres mest sannsynlig ut som skraping mellom magnet og voice coil siden den bare kommer i perioder.
Mulig jeg bare skrur ut elementet og vrir det rundt en halv runde for å endre belastningen på elementet?
Hvis jeg skal prøve å fikse den:
Sentertappen skrus bare rett ut?
Sitter de 4 skruene under lokket over magneten?
Griffenfeldt
I en blokk
Skrudde ut støvhetten og så at det er en skjevhet mellom spolegap og magnet. Det er det som lager skurrelyden.
Jeg tviler vel litt på om jeg klarer å fikse dette selv for å være helt ærlig.
Hvorfor vil du ikke bruke Lowther? Hadde samme problem og valgte da nye elementer. Lang tid å spille inn, men verdt det.
Lowther har glimrende bytte/oppgraderingssystem. Bruk de!
Fenalaar
Skjevheten vil antageligvis være slik at det er trangest på den siden som er ned. Prøv å snu elementet 180 grader og se om det hjelper.
Johan-Kr
Griffenfeldt
I en blokk
Jeg var inne på tanken på å sende de inn til rep, men det vil koste roughly 500 pund + shipping og mva.
Mulig jeg gjør det en gang, men ikke i denne omgang. Nå går de inn i boden til lagring. Jeg vet man ikke skal lagre slike elementer for lenge, men nå spiller det forsåvidt ingen rolle.
Fenalaar: jeg har førsøkt men det hjalp ingenting desverre.
svendatle
Skien
Hei.
Dette fikser du ganske greit selv, litt plundrete er det. Har hatt samme problem som deg, tok ut elementene, løsnet de fire 8mm skruene på baksiden, la elementene på bordet med magnetene ned på bordplaten, så er det bare å forsiktig flytte membranet rundt til du har sentrert det.
Svend Atle.
Griffenfeldt
I en blokk
Du løsnet på mutterene bare? Du skrudde de ikke helt ut?
Ser at toloransene i gapet er nokså små!
Spolegapet på de elementene er mindre enn myggekukken - det lønner seg å bruke en tonegenerator når du skal sentrere, 100 Hz f.eks. - og dra til skruene diagonalt og forsiktig.
Griffenfeldt
I en blokk
takker for tips! Det hadde vært artig å prøvd selv! Jeg skulle muligens prøvd på billige elementer først og ikke på relativt kostbare Lowthere.
Jeg ser for meg da å koble telefonen på reserveforsterkeren min med en kabel, laste ned en tonegenerator app og koble på elemenet.
Ja det kan jo virke selvsagt.
Laban MK3
Plankebyen
Johan-Kr
Tenkte tanken selv snu de 180 grader , kanskje man slipper med skrekken ( lov å håpe på det enkleste noen ganger )
michell
Prøv å blåse forsiktig med trykkluft. Det er supertrangt mellom spole og kjerne.
Trengs ikke veldig mange støvkorn før det skraper.
svendatle
Skien
Jeg skrudde de helt ut, for guttungen hadde klart å klisse noe seigt innimellom og rundtforbi,så keg vasket og renset, når jeg satte de sammen så skrudde jeg skruene løselig til og prøvde etter beste evne å sentere de så godt jeg kunne, skrapelydene forsvant hvertfall, men om de ble sentrert sentrert kan nok se lærde diskutere.
Kabeldragern
Kristiansund
Jeg hadde Lowther PM7A med store, tunge alnico-magneter og måtte rette opp magneten sånn ca 1 gang pr år.
Jeg brukte musikk på lavt volum og når lyden endret seg fra «telefonlyd» til normal fullrange lyd så var jeg i mål. Brukte tonegenerator som kontroll og framprovoserte større membranutsving. Når det da ikke var scratch lengre så holdt de et år til.
Griffenfeldt
I en blokk
Her står høyttaleren på båren postoperativ.
Foreløpig virker inngrepet vellykket, men den trenger litt rekonvalesens.
