Welcome to the Leisuredome
  • bluesbreaker
    Hundeeier
    Blåskogen
    Presanger skal jo være overraskelser, men siden det er vanskelig å få katta til å hoppe oppi sekken igjen.
    -gismo har ordna en sånn en. Fra oss to. I bestefar-farge.
    Vi tenkte det fikk greie seg at vi to spleisa.
    :cool:
    sense
    Rørvik i Nord-Trøndelag
    Seriøst fin den Denon-kladden der sense... Sikkert et utrolig drivverk... Men har ikke helt trua på dac-chip i den.. Har du klådd litt på den, eller er den orginal sense ? Vakker okkesom.. :)
    De bygger ikke "slik" kvalitet lengre..hvor ser man idag at de støper chassis i støpejern? Den er ikke klådd på nei... vel jo..Neutric powercon er montert... Burr brown dacer..
    Denon: Alpha Processing
    The Denon engineers follow a completely different path. After analyzing the complex algorithms of the CD they find a way to extract and use data from the lower, least significant bit, well before the actual conversion takes place. These data represent pulses of sounds with high dynamics occurring mostly at the beginning of a sound. These data are processed in such a way that they are added to the actual converted wave form. In popular terms, the steep filtering around 20.000 Hz. is disabled for a few milliseconds every time the data give a specific value. The disabling can be just once in a while or can occur repeatedly. During these instances the width of the frequency band is not limited by the conventional process of conversion and its brick wall filter. No, it extends beyond 20.000 Hz. In this way upper harmonics can be generated. The result is that all acoustic instruments do sound more natural, have an analog quality. The Denon engineers call it "Alpha Processing" and introduce this conversion type in 1993. In designing their flagship DP-S1/DA-S1, they also pay the utmost attention to the construction and functioning of the CD-turntable.
    The benefits of Alpha Processing are not only heard, but can also be measured. Look at the four wave forms at the left:
    a = An original 1 kHz. sinus wave.
    b = The sound is digitally recorded at minus 90 dB and after being treated by a multi bit D/A converter, the sinus is more like a small number of stairs. The level of -90 dB is of course an extreme low recording level, chosen to demonstrate the workings and benefits of Alpha processing.
    c = The signal is converted by means of a low bit or single bit D/A converter. The sinus looks like a woolen thread still showing the rudiment of the steps of a staircase. The oversampling of 256 times also multiplies the smallest inaccuracy and distortion 256 times, hence the thicknes of the sinus wave. The multiplied noise is audible in a low bit CD converter and in the SACD (Direct Stream Digital) conversion. This distortion has to be filtered out by means of a noise shaping filter.
    d = If the signal in the Pulse Code Modulation used in the Compact Disc format and is retrieved and converted using alpha processing, the sinus is as the original.
    sense..
    Karmana
    Kjekt å se det er aktivitet i tråden etter at de unge er sendt til sengs :)
    Ikke tenk på gave til meg, gutter! Jeg skal ha inngangsbillett som i fjor, en rippet cd med spennende musikk. Viktigere at vi har noe fornuftig med til Rhapsody og MA. Flott at du har ordnet musikk til dem, HC!!! Jeg skal en tur til sørlandet i Nederlandene før dere kommer, og satser på å få nappet med meg en flaske akevitt der nede. Den sammen med en norsk kvalitetsinnspilling bør være greit for besøket hos MA.
    Snakket med Harry hos Rhapsody i helgen. Ble enige om å spikre opplegget en uke før dere kommer slik at han husket det. Han var klar for å åpne dørene for oss før vanlig åpningstid, og deretter gi oss en alternativ seanse i andre etasje. Bra med en musikkgave, men hadde vært kjekt med noe annet i tillegg. Er ikke i det kreative hjørnet på morgenen, men skal tenke litt, hjelp meg gjerne å tenke.....
    Karmana
    :cool:
    Dæven den var smekker! Drit oppi det jeg skrev om gaver og ripping, kjør gaver ;)
    Karmana
    Tenkte jeg skulle forsøke å gjøre noe med førsterefleksjonen på siden av høyttalerne. Aner ikke om jeg har et problem eller om det vil gjøre noen forskjeller her hos meg, men det hadde vært gøyalt å få testet ut. By the way, er for lat til å sette meg inn i måleverktøy og gå systematisk til verks.....
    Har ikke fnugg av peiling på dette annet enn hva jeg får med meg innimellom på HFS. Dessverre treffer denne informasjonen teflonsiden av pappskallen min. Det eneste jeg har skjønt er at jeg skal få kona til å vandre rundt med et speil slik at jeg finner riktig plassering :)
    Første spørsmål, er det diffusjon eller absorbsjon jeg bør gå etter? Intuitivt tenker jeg diffusjon, men å dempe i de øvre frekvensene kan vel kanskje også gjøre nytten og dermed slippe unna uten å ha noe på størrelse med en saccosekk ved siden av høyttalerne?
    Det neste er at jeg ser for meg noe mobilt og gulvstående. Kanskje på et eller annet stativ som jeg kan skyve frem og tilbake. Hadde vært fint om det så litt ålreit ut siden jeg har oppsettet i stuen. Forslag?
    Håper noen som er innom tråden tar seg bryet med noen gode råd og forslag.....
    gismo
    Finnskogen❤️
    Væssia i Grue.
    Har jo vært hos deg å hørt oppsettet ditt som var meget bra, selv med Miles3;)
    Med fuglene og dac, nå sikkert ennå bedre:):)
    På vindussiden din kunne jeg merke refleksjoner, blankt vind er liksom ingen akustikk venn:rolleyes: Du hadde tynne gardiner, men selv de hjalp litt den gangen. Så om din kjære tillater litt tykke gode og brede gardiner, sånn at du ikke må dra de helt slette for å trekke for så er nok mye gjort på den siden! Bakdelen blir vel at naboer tror du driver med litt lysskye affærer hver gang du spiller musikk:cool:;)
    Mot skap/bokhylle var det ikke så merkbart syns jeg, men her er det kanskje mulig med en flyttbar sak på stativ, der finnes jo hundrevis av alternativer av sånne.
    Sånn kan jo brukes på begge sider også da TOMZ, om du ikke gjennomslag for nye gardiner:cool:
    gismo
    Edit: Når hun skal gå rundt med speil, liker jeg best tanga her hjemme:cool:
    Karmana
    gismo
    Ikke optimalt det vinduet, nei, selv om det er sjeldent det blir særlig plagsomt. Har alltid nå en liten glipe trukket for. Pussig at så tynne gardiner gir en liten forskjell, noe jeg mener bestemt det gir. Hadde trodd det måtte tung velur til, men det kan jo være ørene mine bare spiller meg et puss. Ikke uvanlig det :)
    Kona er spent klar for både sying og kjøp av gardiner, det er meg som ikke vil bytte dem :) Strukturfasist som jeg er vil jeg ha det samme på begge sider av høyttalerne. Kom gjerne med en link til en side som har litt flyttbare greier på stativ :)
    Fikk forresten et ubehagelig bilde på netthinnen av Helene i hverdagsklær og speil, og du i sofaen med en litt kommanderende og myndig mine, kun antrukket en frekk Borat-tanga ;)
    Karmana
    Karmana
    Var egentlig veldig fornøyd med meg selv når jeg droppet dette bildet inn i en av kabeldebattene. Ble møtt med rungende taushet ;) Selv har jeg problemer med å skjønne alt dette alvoret rundt hobbyen vår. Hadde det ikke vært mulig å diskutere musikk og haifai uten et smil i øyenkroken hadde jeg holdt meg langt unna steder som HFS. På den annen side, hadde jeg selv vært langt nedi skyttergravskrigen hadde sikkert ikke jeg heller syntes innspill fra siden hadde vært særlig morsomt :) Eller kanskje ikke ;)
    Det er hobby som glede, det er hobby som livsstil, og hobby som totalt konsumerer en... Tja, tror det er mange fasetter i utøvelsen av hobbyen. Dessto mer tid en bruker, for noen hvor mye penger en bruker, joa, skal ikke være lett. Men vissheten om alt dette får iallefall meg til å smile..
    Karmana
    Du er ikke så lam mellom ørene, selv om du går rundt med flyttehode :)
    Får du flyttet inn før du kommer nedover til Hilverstaden?
    _RoDa_
    Blir det alvorlig så blir det sårt, blir et angrep på anlegget et angrep på jeg-et så blir det temperatur.
    Jeg har ærlig talt problemer med å se at HFS er så fælt som flere påstår, det handler om hvilke tråder jeg velger å lese.
    Se i tråden til gismo nå, TOMZ, viktig info til deg. 8)
    Karmana
    Hvis man velger sin favorittforvrengning og favorittråder vil det vel helst gå bra ;)
    Svanå er lagret til en rolig stund senere, men kom igjen, er det diffusore eller absorbenter jeg leter etter?
    _RoDa_
    Med dine høyttalere, som er snillere/mørkere/varmere enn Miles III, så er det diffusjon.
    Demper du så blir det døll lyd, og døll er ikke gull.
    Karmana
    Takker, RoDa! :) Blir det døll lyd hvis jeg demper førsterefleksjonene oppover i frekvens (hvis noe sånt finnes da). Tenker ikke på bassabsorbenter. Er sikkert helt på jordet angående akustikkprinsipper ;)
    gismo
    Finnskogen❤️
    Væssia i Grue.
    Støttes, du skal bare spre refleksjonene litt for vinden, altså til alle kanter, ikke drepe dem;)
    Diffusor paneler
    Se på S-wing, finnes i flott lett papp i sort mannefarge, ikke helt sjuke priser heller på papp utgavene.
    Fikk pris på 2 stk til rett under 2K om jeg husker rett:)
    120x60x18cm
    gismo
    Karmana
    Takker for forslag, gutter! Kjekt å få lov å være lenge oppe på en hverdag og leke med de store guttene ;)
    Karmana
    Hvis noen skulle lure så kan jeg rapportere om at maltwhisky og peanøttsmør er en noe uheldig match!
    _RoDa_
    Både gismo og meg er nok av de mykeste menn som finnes her på HFS, så det er vi som skal takke for at vi får leve ut akustikkdrømmene gjennom deg. ;D ;D ;D
    tkr
    Nede i fjæresteinene
    Det er entydig diffusjon du er ute etter.
    Hadde ikke tenkt å svare egentlig, etter at du disset champagnefargede komponenter. Men kall meg storsinnet: Har besluttet å overse slike bagateller.
    MVH
    Karmana
    MVH
    Kona sier at jeg sjeldent ler høyt, men nå lo jeg i hvert fall ;) Takker, tkr! Med det storsinnet, er jeg sikker på at utbygging av Sotrabroen er unødvendig for deg, du går lett og uanstrengt på vannet ;)
    tkr
    MVH
    Madammen brukte 2,5 timer hjem fra jobb i Biskopshavn idag. Det hadde vært et uhell på RV 555 kl 1230, og det var køer frem til kl 1730.....:p Jeg hadde stekt ferske kamskjell til lunsj, som var iskalde og seige før hun ramlet inn døra. Er glad at jeg hadde vett nok til å fortære min del av lunsjen mens den fremdeles var varm. Du vil ikke vite mitt standpunkt når det gjelder politikere og veiutbygginger utenfor Oslogryta, trust me!
    Mhp storsinn vil jeg ta noen famlende skritt ut på Høgøykylleren i morgen tidlig. Iført badebukse i tilfellet vannet ikke bærer meg ennå.
    Karmana
    MVH
    Er en grunn til at øyen din ikke er på listen vår når vi skal hjemover og må se oss etter et sted å bo :p
    For min skyld, sats på tørrdrakt! Har en illsint tysk deputy på jobben, men har en snikende følelse om at det andre kjønn derifra kan være tøffere å møte i gitte situasjoner ;)
    tkr
    MVH
    For å være litt seriøs: Nytt fastlandssamband er planlagt ferdigstilt i 2021.:p Det er man kan gjøre varpene her ute...Når det nye fastlandssambandet er ferdig, vil du måtte betale Fana- priser for hus her rundt tkr Towers.
    HAH!
    Du snakker med en veteran med ikke mindre enn 40 års erfaring, ikke med en, men med to tyske madammer....bloody, but unbowed er vel rimelig dekkende....;)
    Er ordtaket "its better to kneel then to bend over.." noe for dere to striler? :).
    Akustiske remedies, få lånt og test. En kjøper ikke svindyre vinger uten å teste det i eget rom. For min del 2016 prosjekt, om jeg gidder. Hilsen en som ikke gidder fremstå som myk, men er det. I rett sammenheng.. ;-)
    Karmana
    HAH!
    Hehe, tysk deputy og min tidligere halvt tyske samboer blir trumfet rått av din hånd. Eg slenger meg ;)
    Du har nok helt rett ift. prisene på Sotra. Sitter likevel litt langt inne for en tidligere Fanagutt å bosette seg på et sted med 56-nummer :cool:;)
    John Garcia fredag 26 juni i Hilversum........
    Stone rock fra palm Springs? Er for myk jeg til å ha nok sorte klær... Hehe... Spørs om noe lyder bra etter å fått blåst øregangene med "El Taco rocko".. Konsert er uansett alltids kult men ikke min sjanger helt..
    Karmana
    Tror kona må ha hørt noe gnag om diffuserere i går. I dag kom hennes bidrag :D
    Fikk et innspill fra siden som høres fornuftig ut. Låne et par diffusore, deretter sjekke forskjellene i forhold til demping ved å henge opp tykke tepper på sidene. Enkelt og greit. God plan!
    Bjørn.H
    Er så heldig at jeg kan kjøpe mye godt i glasset til en billig penge siden jeg jobber i Nato. Hvis jeg ikke skal forsøke noe nytt, havner jeg gjerne tilbake på Jura Superstition. Er vel ikke nødvendigvis helt billig på polet, men her fåes den til gi bort pris. Kjekke ting :)
    Aaah, se der; Jura er det ikke alle som greier å bli venn med, kanskje på grunn av de tydelige undertonene av saltvann.
    Whiskyen er vel en av få ting øya har å slå i bordet med også, med unntak av at George Orwell bodde på øyas eneste hotell mens han skrev "1984", og antagelig
    nøt den lokale drikke underveis..... ;)
    Så anbefaler jeg absolutt å prøve ut denne, 16åringen, den er riktig lekker:
    Vis vedlegget 322692
    / Morten
    Kommer!
    _RoDa_
    Hyggelig kone, og nei, det er ikke en god plan.
    Tepper kan ikke sammenlignes med ordentlige dempeplater. Dempeplater demper over et bredere frkvensområde og mer lineært enn tepper. Så det så.
    Men så lenge du skal ha diffusorer så er saken biff. :)
    R
    Karmana
    / Morten
    Kommer!
    D
    Dåbbel J
    Heeey... jeg er her enda... og du bør EVNT drikke opp før jeg ankommer 8)
    Karmana
    Ikke bekymre deg! ;)
    Litt skuffet, hadde trodd du skulle reagere på John Garcia som kommer til Hilverstaden. Er sikkert bare kjeften med deg likevel :cool:
    The meaning of seven roses.. I am taken with you... Søtt Tomz, tror kona di liker deg jeg... :)
