Noen som har prøvd dette ?
Jeg er ganske så grønn på dette, men det virker i utgangspunktet genialt enkelt dersom man å denne måten "lurer" SB til å streame flac-filer som egentlig inneholder DSD. Det forutsetter seff at man har en DAC som kan konvertere DSD.
Playing DSD with any players including Squeezebox Touch
Some things sound too good to be true, but it is true.
With help from a fellow computer audio friend, I found a killer app that allows any playback software to stream DoP to a DSD DAC that supports DoP.
Since Friday, with an open sourced encoder, I have been playing DSD files encapsulated within FLAC files with my Squeezebox Touch outputting to a dCS.
The Squeezebox thinks it is outputting 176.4 PCM files;
The dCS reads the encapsulated stream as DoP streams and happy unpack it and play it as DSD files.
This dream software was discovered by a clever friend. I asked aloud that it would be so nice if the Squeezebox Touch could output DoP streams. He went ahead and did a 10 minute research and came up with below software.
It is a Foobar plugin so you will need Foobar 2000 to run it.
https://docs.google.com/file/d/0B4jZ...ByNUdjdDg/edit
The software is quite easy to run. Even a Windows audio dummy like me was able to get it working.
You will need DSD files (DSF,DFF or ISO), outputs will be FLAC files which you can tag, and/or convert to other formats like AIFF or ALAC files. So yes even iTunes can play DSD files without Pure Music or Audirvana.
Try it, you will be pleasantly surprised.
