Streame DSD med Squeezebox Touch
Trane
Noen som har prøvd dette ?
Jeg er ganske så grønn på dette, men det virker i utgangspunktet genialt enkelt dersom man å denne måten "lurer" SB til å streame flac-filer som egentlig inneholder DSD. Det forutsetter seff at man har en DAC som kan konvertere DSD.
Playing DSD with any players including Squeezebox Touch
Some things sound too good to be true, but it is true.
With help from a fellow computer audio friend, I found a killer app that allows any playback software to stream DoP to a DSD DAC that supports DoP.
Since Friday, with an open sourced encoder, I have been playing DSD files encapsulated within FLAC files with my Squeezebox Touch outputting to a dCS.
The Squeezebox thinks it is outputting 176.4 PCM files;
The dCS reads the encapsulated stream as DoP streams and happy unpack it and play it as DSD files.
This dream software was discovered by a clever friend. I asked aloud that it would be so nice if the Squeezebox Touch could output DoP streams. He went ahead and did a 10 minute research and came up with below software.
It is a Foobar plugin so you will need Foobar 2000 to run it.
https://docs.google.com/file/d/0B4jZ...ByNUdjdDg/edit
The software is quite easy to run. Even a Windows audio dummy like me was able to get it working.
You will need DSD files (DSF,DFF or ISO), outputs will be FLAC files which you can tag, and/or convert to other formats like AIFF or ALAC files. So yes even iTunes can play DSD files without Pure Music or Audirvana.
Try it, you will be pleasantly surprised.
Akapaz
Sørreisa
Spent på mere informasjon om dette. Hvis dette funker ordentlig blir det DSD DAC på meg etterhvert :cool:
Er på leten etter SACD-ripper (PS3) for tiden og har en i kikkerten.
mteinum
Øya
Det var spennende! Kanskje jeg skal finne fram Touch'en og se om dette fungerer med Mytek dac'en.
Liotheles
Skjønte ikke helt hva Foobar har med avspilling fra Squeezebox Touch å gjøre?
Noen som kan forklare nærmere?
marsboer
Phobos
Du trenger Foobar2000 for å encode filene til formatet som trengs før du kan spille dem gjennom Squeezebox'en. Du kan ikke bruke DSD-filene dine direkte.
Liotheles
Takk for info, Marsboer. Blir på en måte at den tar over for SOX da, for det finnes vel ikke nyere SOX som takler DSD eller?
Steinar_Lund
Hvalstad, Asker
Jeg har en Accuphase DAC-30 installert i min E-450 integrerte forsterker. Jeg har prøvd å kontakte Accuphase, men der er kontakt-mailadressen stengt til 18.august.
De henviser til den lokale forhandler, som i Norge er Tor Aamodt i Lyric Hifi.
Da spørger jeg dere; Takler denne dac'en DSD? Jeg finner ingen ting om det på Accuphases nettsider Accuphase Laboratory, Inc. DAC-30, så jeg er ikke særlig optimistisk.
Men altså: Noen som vet?
Steinar_Lund
Hvalstad, Asker
Hehe. Jeg liker slike klare og konsise svar. Takker.
Edit: Eller var dette et svar på spørsmålet "Noen som vet?";)
Bjørn 66
Jeg kan bekrefte at Squeezebox Touch kan spille FLAC-filer som inneholder DSD/DSF med DOP-flagget satt. FLAC er her kun en container og Touchen tror den spiller en vanlig PCM-fil på 24/176. Hos meg er Touchen koblet videre til en Teac UD-501 DSD-dac som tar imot DOP på USB-porten. Litt knotete å få til og fungere, men utrolig elegant når Teac DACen veksler fra PCM til DSD på displayet og godlyden kommer ut i 2.8 MHz oppløsning.
Liotheles
Spennende saker Bjørn. Og velkommen på forumet :)
Hva består "knotet" i ?
Også spennende den DAC'n din. Hva slags lydsignatur har den og hvor kjøpes denne i Norge?
Vil den gjøre noe positivt med normale flac filer også eller skjer "magien" bare med DSD formatet?
Si gjerne noe om resten av anlegget ditt også Bjørn.
Bjørn 66
Det er ikke helt rett frem (plug&pray) å få brukt SBT til å spille DSD-filer, men for den som har en DAC som støtter DOP så er dette en veldig fin "kokebok". How to use the Squeezebox Touch to play DSD files on a DoP compatible DAC
Jeg måtte også kable Touchen før avspillingen ble uten noen rebuffering.
Anbefaler først å teste ut bruk av Foobar og spille vanlig hires PCM eller DSD-filer. Musikk i DSD-format selges heller ikke på hvert gatehjørne, men for den som har SACD-plater så kan man rippe de med enkelte modeller av første generasjons Sony PS3. Jeg har skaffet meg to slike "spillemaskiner", i tilfelle en av de skulle finne på å begå harakiri (YLOD for de som kjenner PS3).
Jeg lette en stund etter forhandlere av Teac i Norge, men ga opp til slutt og fikk tak i en UD-501 i Berlin. Fikk tom. tilbake en del kroner i moms på flyplassen :)
DACen har fått strålende kritikker og støtter det meste av oppløsninger som finnes. DXD med oppløsning på 24/352 spiser den med velbehag. Men som for alle andre, så er også det meste av den digitale musikken min i 16/44 FLAC og der gjør også DACen en god jobb.
nma
Denne softwaren er bare et unødvendig mellomtrinn. Det eksisterer patcher som gjør at LMS kjenner igjen native DSD filer. Er ikke i mainline tror jeg, men det kommer nok. Squeezelite pr. versjon 1.4 støtter også DSD over DoP.
Bjørn 66
Men greier Touch å skjønne/spille nativ DSD? Ingen ting hadde vært bedre enn hvis man kunne spille DSF-filer direkte med riktig tagging og cover-bilde. Jeg er litt skeptisk, men blir veldig fornøyd hvis noen overbeviser meg med en elegang løsning. Squeezelite skal vist nok (har ikke prøvd) kunne kjøres på Touch slik at man ikke trenger å blande inn en egen pc med Linux. Man, har du prøvd dette?
nma
Det er selvsagt ikke umulig å lage en logikk slik at LMS konverterer DSD til PCM før den sendes til Touch, og at det evt sendes som DoP til touch hvis man har spesifisert dette (og f.eks samtidig slår den da automatisk av volumkontrollen). Man trenger ikke å kjøre squeezelite på touch for å bruke DoP. Fordrer selvsagt at man bruker EDO-plugin med USB DAC som støtter DoP.
Bjørn 66
Da har jeg kommet "helt" i mål med DSD og Squeezebox Touch. Løsningen ligner på det som Man nevner, LMS konverterer DSD til DOP før det sendes til Touch. For å få det til måtte jeg vente til LMS versjon 7.8.0 ble tilgjengelig på Vortexbox der LMS kjører. Nå slipper jeg å konvertere DSF-filer til Flac og tagging og grafikk fungerer perfekt. For å kunne finne igjen DSD-filene så bruker jeg Tag&Rename til å tagge DSF-filene slik at Genre settes til DSD. Da er det enkelt å liste opp alle album med DSD i Squeezebox.
janerlen
Er det kun Touch av Logitechs streamere man kan benytte som transport til dsd dac på denne måten? Jeg har Transporter, og vurderer kjøp av DSD-dac. Finnes det ikke måter å overføre DSD på fra Transporter via PCM-porter til ekstern DAC? Hva med Hirez flac? Klarer Transporter å sende fra seg dette over SPDIF?
Kan jo alltids nedgradere til Touch dersom DSD skulle ta av, men Transporter har på papiret klar fordel pga asynkron klokke og bedre jitterkontroll. Nervene ville ikke likt å matche en DAC til prisen av flere bruktbiler med Touch. Mulig det er ubegrunnet frykt, men om Touch er like god transport, må det i så fall begrunnes teoretisk.
Finnes det andre praktiske måter å streame fra kilde (PC) til hovedstue på, utenom klienter som Touch, Transporter eller Sonos, når PC er 15 m fra hovedanlegg? USB-strekk og androidstyrt foobar eller lignende? Finnes det, og er det gjennomførbart?
Bygger nytt hus, og har mulighet til å integrere det meste inkl skjult kabeltrekk, NAS-disker, plassering av nettverkspunkter osv, så tips mottas med takk.
PS! Dagens anlegg er PC, nettverksstrøm til Transporter, og rett i Effekt. Ved kjøp av ny DAC, vil denne ha analog pre, og sannsynligvis være DSD kompatibel (da jeg har 10.
Bjørn 66
Transporter støtter ikke høyere oppløsning enn 24/96. Det gjør egentlig ikke Touch heller, men med EDO-Plugin installert så støtter Touchen plutselig 24/192. Så Transporter skal kunne sende fra seg Flac (PCM) med 24/96 oppløsning enten ut på analog utgang eller SPDIF til Dac.
Jeg ville ikke kalle det nedgradering å bytte ut Transporter med Touch. Hvertfall ikke hvis analog-konverteringen tas hånd av en asynkron Dac. Da er det Dacen som "bestemmer" jitter og klokking. Men utseendemessig så er det klart en nedgradering å gå vekk fra Transporter.
