Sporing av Lyra pickuper?
Laban MK3
Plankebyen
Håper jeg rekker å eie en Mørch DP6 eller 8 før lokket legges trygt på plass :unsure:
Construction:
Radial arm with interchangeable armtubes.
Bearing principle:
DP-6 and DP-8: Dual bearing
UP-4: Unipivot.
Effective mass of complete tonearm with armtube:
Light (green):
Medium (red):
Heavy (blue):
All armtubes can be used with all models.
4 g
7.5 g
14 g
Fundamental resonance (depending on armtube):
8 - 14 Hz (for DP-8 N/A for the horizontal mode of motion)
Bias compensation:
Watch spring with string - adjustable while playing.
Azimuth:
Azimuth is adjustable for correct channel separation.
Cueing mechanism:
Piston in U-pipe, damped with silicone fluid.
Distance between pivot and center of turnable platter:
9" tube: 212 mm (8 3/8")
12" tube: 294 mm (11 9/16")
Overhang:
9" tube: 18 mm (11/16")
12" tube: 13.3 mm (1/2")
Effective length:
9" tube: 230 mm (9 1/16")
12" tube: 307.4 mm (12 1/8")
Diameter of hole for mounting arm base:
20 mm (13/16")
Rear overhang from pivot:
70 mm (2 3/4")
Offset angle:
24 degrees.
Lateral tracking error:
0 degrees at 66 mm and 120.9 mm from center of record.
Pivot point:
Pivot point is in level with the record surface.
Bearing Friction:
Bearing friction less than 0.04 mN in all directions.
Balancing:
Four (4) different balancing weights.
Internal wiring:
19 strands of ultra pure silver insulated with Teflon.
Capacitance per channel:
28pF for all models.
Tonearm Cord:
Balanced. Extremely purified copper strands that are heavily silver coated. Halogen free insulation.
Moerch tonearm connector with Cardas RCA connectors.
Capacitance per channel: 100pF.
Terminals:
All terminals throughout the arm are gold plated.
Bearing concept of model DP-6 and DP-8:
One internally damped, precision ball-bearing assembly for the horizontal mode of motion.
Two pivoted sapphire bearings for the vertical mode of motion.
Bearing concept of model UP-4:
Hardened steel pivot resting on a concave sapphire, and damped for all motions with silicone fluid.
DP-6 and DP-8 finish:
24 carat GOLD or CHROME.
UP-4 finish:
CHROME or at special order GOLD.
Weight of DP-8 arm base w/sideweights w/o counterweights and cord:
580 g
Weight of DP-6 arm base w/armbush w/o weights and cord:
280 g
Weight of UP-4 arm base w/armbush w/o weights and cord:
240 g
Weight of a set of counterweights:
120 g
The right to change specifications without notice is reserved by the Manufacturer.​
YesJens
Musikkelsker og Livsnyter😊
Under stjernene
[QUOTE = "Laban MK3, post: 3381823, medlem: 26937"]
Håper jeg rekker å eie en Mørch DP6 eller 8 før lokket legges trygt på plass :usikker:
Konstruksjon:
Radialarm med utskiftbare armrør.
Peilingsprinsipp:
DP-6 og DP-8: Dobbel lagring
UP-4: Unipivot.
Effektiv masse fullstendig tonearm med armrør:
Lys (grønn):
Middels (rød):
Tung (blå):
Alle armrør kan brukes med alle modeller.
4 g
7,5 g
14 g
Fundamental resonans (avhengig av armtube):
8 - 14 Hz (for DP -8 N/A for den horisontale bevegelsesmåten)
Bias kompensasjon:
Klokkefjær med snor - justerbar mens du spiller.
Azimuth:
Azimuth er justerbar for korrekt kanalseparasjon.
Cueing -mekanisme:
Stempel i U-rør, dempet med silikonvæske.
Avstand mellom pivot og sentrum av dreibart fat:
9 "rør: 212 mm (8 3/8")
12 "rør: 294 mm (11 9/16")
Overheng:
9 "rør: 18 mm (11/16")
12 "rør: 13,3 mm (1/2")
Effektiv lengde:
9 "rør: 230 mm (9 1/16")
12 "rør: 307,4 mm (12 1/8")
Diameter på hull for festearmsokkel:
20 mm (13/16 ")
Bakre overheng fra sving:
70 mm (2 3/4 ")
Forskyvningsvinkel:
24 grader.
0 grader ved 66 mm og 120,9 mm fra midten av rekorden.
Svingpunkt:
Dreiepunktet er i nivå med rekordoverflaten.
Bærende friksjon:
Bærer friksjon mindre enn 0,04 mN i alle retninger.
Balansering:
Fire (4) forskjellige balanseringsvekter.
Interne ledninger:
19 tråder av ultrarent sølv isolert med teflon.
Kapasitans per kanal:
28pF for alle modeller.
Tonearmledning:
Balansert. Ekstremt rensede kobbertråder som er sterkt sølvbelagte. Halogenfri isolasjon.
Moerch tonearmkontakt med Cardas RCA -kontakter.
Kapasitans per kanal: 100pF.
Terminaler:
Alle terminaler i hele armen er gullbelagte.
Peilingskonsept av modell DP-6 og DP-8:
En innvendig dempet, presisjons kulelagermontasje for den horisontale bevegelsesmåten.
To svingbare safirlagre for den vertikale bevegelsesmåten.
Peilingskonsept av modell UP-4:
Pivot i herdet stål som hviler på en konkav safir og dempet for alle bevegelser med silikonvæske.
DP-6 og DP-8 finish:
24 karat GULL eller KROM.
UP-4 finish:
CHROME eller på spesialbestilling GULL.
Vekt på DP-8 armbase m/sidevekter uten motvekter og ledning:
580 g
Vekt på DP-6 armbase m/armbush uten vekter og ledning:
280 g
Vekt på UP-4 armbase m/armbush uten vekter og ledning:
240 g
Vekt på et sett med motvekter:
120 g
Retten til å endre spesifikasjoner uten varsel forbeholdes av produsenten.​
[/SITAT]
Så bra at det brukes RCA kontakter😊
Snuset litt på DP-6 for 3-4 år siden, od da ble den levert med 5 pins DIN kontakt.
plinius
Drammen
Ok jeg tror jeg forstår hvorfor du ikke forstår hvad jeg mener. Du har en af de nyere versioner af Mørch-arme hvor der er forkromet hele vejen rundt i toppen af armens plexiglas fatning? Og så kan du selvfølgelig ikke se hvor armrøret ender.
I så fald tror jeg du i udgangspunktet bare kan måle 5mm bagud fra centrum af fingerskruen og der bør armrøret ende, med mindre Mørch har ændret målene på sin arm hvilket jeg ikke ved noget om.
Ja stemmer at jeg ikke ser hvor røret slutter fordi jeg har en nyere versjon av armen.
