Pylon Diamond Monitor - Topptest hos Hifi pig!
Pylon lanserte for noen måneder siden Diamond Monitor. Meget flotte stativhøyttalere basert på samme oppskrift som de gulvstående storebrødrene.
Nå er de blitt testet i Hifi Pig og omtalen taler egentlig for seg. Testen kan leses i linken under, men her er noen utdrag:
"I was instantly in love and that was even before they had any running hours on them, so the best was yet to come. "
"Over a period of some weeks I had almost gone through my entire CD collection and each one was a revelation at how much satisfying music is stored on those little silver discs."
"my own verdict is that for under a £1,000.00 they are a genuine hifi bargain, especially so when they gave the ATC SCM 19’s which Dan and I compared them to, a run for their money at less than half the price. "
"So, to summarise then, this is an affordable awesomely good sounding speaker that I am more than positive will be putting as big a smile on many owner’s faces as it has mine throughout my time with them. They fit in well with most room decors and the dedicated stand included in the price makes it even more of a hifi bargain."
"They are very expressive, full of tonal colours, textures and fine details, pumped well out into the room, which of course may not suit every kind of listener. Bass had a wonderful taut solidity with no boom at all, plus a deep growl and thump to it, manifested well in kick drum beats which smacked you squarely in the solar plexus with the right kind of recording, the Pylon Diamond Monitors even showed up my big floor standing resident speakers somewhat with their bass output and fast dynamics."
Hele testen kan leses her:
Pylon Diamond Monitor Loudspeakers Review | Hifi Pig
Mer info om priser her:
Pylon Diamond Monitor - Oljet sort matt Eik - Mala Audio
Sst
Og her må det legges til at de glimrende ATC SCM 19 i utgangspunktet er like bra som dobbelt så dyre konkurrenter. Spennende høyttaler, dette.
Finnes den på lager allerede?
MalaAudio
Asker
Vi får inn de første parene på neste sending fra Pylon, så ikke kommet inn til oss helt enda :)
BeetleBug
Hei Mala,
Vurderer dere også å ta inn den glimrende Pylon Opal monitoren med de tilhørende stativene?
BB
MalaAudio
Asker
Disse er ikke bestilt inn, men kan bestilles om du skulle være interessert? Vi har sett dem hos Pylon og det er meget lekre høyttalere som også låter bra.
Vi har valgt å satse på Diamond Monitor i stedet da prisforskjellen ikke er så enorm, og Diamond Monitor er ett godt nivå opp :)
Hei Mala,
BB
BeetleBug
Jeg liker hvordan dem får det relativt rimelige bass/mellomtone elementet til å fungere og jeg mener dem er meget musikalske.
Send meg gjerne prisen på Opal Monitor sammen med leveringstid.
BB
MalaAudio
Asker
BB
Du har fått PM nå :)
P
parafinoksen
Beklager å vekke en gammel tråd til live ...
Er det noen som har erfaring med hvordan Pylon Diamond Monitor 18 spiller på lag med Rega? Brio-R i mitt tilfelle. Jeg har et par toveis Troels Gravesen gulvstående høyttalere med samme Seas-mellomtone som Diamond (veldig god), men diskanten er et Seas-element i aluminium. Dette låter fint, men en touch friskt / mer sibilans enn ønskelig. Jeg vurderer også å gå over til stativhøyttalere, og tenkte at kanskje Diamond Monitor kunne vært en god kandidat. Resten av elektronikken er Rega (CD og DAC). Rommet er rett over 20 m2.
MalaAudio
MalaAudio sine annonser
Axxess lanserer flere spennende produkter!
Under merkevaren Axxess finner du et økosystem av forsterkere, høyttalere og ulikt tilbehør. Du kan nå sette sammen et komplett Axxess-oppsett fra ditt strømuttak og helt frem til og med...
SE VÅRT UTVALG AV BRUKTE HØYTTALERE!
Brukt hi-fi er et godt alternativ. Vi har et stort og variert utvalg i vår bruktavdeling. Her kan du gjøre virkelig gode kjøp! Vi får stadig inn både nyere og litt eldre utstyr...
Mala Audio på Vestlandsturné - Stavanger-Haugesund-Bergen!
  • 8
Mala Audio på Vestlandsturné! Vi vil ha med flere spennende oppsett på turen, og det vil være mulig å oppleve høyttalere og elektronikk fra blant annet: Børresen, Aavik, Axxess og Marten. Vi har...
Opplev X-serien fra Børresen under vårmessen!
Børresen sin X-serie består nå av fire modeller - X1, X2, X3 og X6. X-serien har en unik prestasjon i forhold til pris og imponerer anmeldere og kunder over hele verden. Kom innom for en demo og...
I morgen starter vårmessen hos Mala Audio!
  • 1
Fredag og lørdag 12.-13. april blir det tradisjon tro vårmesse hos Mala Audio! Kom innom å opplev en rekke spennende oppsett og produkter. Det vil også bli et stort bruktmarked! Åpningstider...
Få med deg Marten Quintet2 under vårmessen 12.-13. april!
Marten Quintet 2 spiller under vårmessen sammen med flaggskipene i BHK serien fra PS Audio. Dette er en meget vellykket kombinasjon som må høres...
