Forsterkere Parasound Halo Integrert forsterker
Eirik84
Drammen
Parasound har visst kommet med en integrert forsterker i Halo-serien :)
Utifra specs er jeg redd den blir DYR!
Product Lines > Halo > Halo Integrated Amplifier
Power Amp Section
• 160 Watts @ 8 Ohms, 240 Watts @ 4 Ohms (Both channels driven)
• Power amp circuit topology designed by legendary John Curl
• High bias Class A/AB operation
• Oversized toroidal power transformer with independent windings for each channel
• Dual-Mono power supply and power amp sections
• 40,000uF power supply filter capacitance
• 12 high voltage/high current bipolar output transistors (6 per channel)
• Heavy-duty 24k gold-plated 5-way speaker binding posts
• Over temp and short circuit relay protection
Preamp Section
• Built in Wolfson DAC with USB, Optical and Coax inputs
• USB, Coax and optical accept all sampling rates up to 192 kHz, 24-bit
• Analog bass management with variable high and low pass crossovers
• Home theater bypass input for surround sound integration
• Front panel subwoofer level control
• Dedicated high current headphone amplifier (TI TPA6120)
• 5 pairs RCA line level inputs
• 1 pair XLR balanced input (parallels Input 5 RCA jacks)
• Low noise Phono input for MM & MC cartridges with 100 Ω or 47k Ω load
• Front panel Aux input with automatic +12 dB gain stage
• Balanced XLR and RCA left and right preamp outputs
• 1 balanced XLR and 2 RCA subwoofer outputs
• Bass & treble controls with relay bypass from remote or front panel
• Headphone jack with 10 ohm output impedance can drive 600 ohm 'phones
• Rear panel IR input and IR loop output jacks
• 12 V output to trigger power amplifiers and other devices
• Automatic turn on with 12 V trigger or AC power
• Fixed level record output
• Premium motor-driven Alps potentiometer volume control
• Left/Right balance control
• Remote control with discrete on/off power buttons
• 0.5w standby power consumption meets Energy Star & European Union spec s
Wishmaster
Interessant sak, tipper den havner på rundt 20K.
decibelius
Bislett
Etter nærmere studier av spec tror jeg 20k blir snaut, men jeg vil gjerne ta feil her.
PowerMetal
Hvis pris i USA blir rundt 10 000 så ender den vel opp på 20 000 her i landet. Er vel ingen produkter som har like stort påslag i Norge som Parasound?
TrondW
Bergenser i Ålesund
Samme pris som Musical Fidelity M500si, som også er helt ny. Skulle vært spennende og sett/hørt disse mot hverandre. Og evt ta med Hegel H300 som hadde omtrent samme pris (24000?) ved siste salg.
mikefish
Noen som vet når den blir tilgjengelig i Norge ? Spennende forsterker dette,har hatt et Parasound effekttrinn tidligere som jeg savner fælt.
mvh.s
Edit : Ser at den er kommet på OHC's sider.Bør kanskje ta en telefon dit.
Lyden av Opplevelser
Stavanger - Kirkegaten nr.43.
mvh.s
- Når du får denne demonstrert...- så be OHC om å sammenlikne den med en Klasse A + AB integrert forsterker !!! ?
Mvh. - en som har hatt JC-1 mono-blokker i innspilt tilstand !
PowerMetal
mvh.s
- Når du får denne demonstrert...- så be OHC om å sammenlikne den med en Klasse A + AB integert forsterker !!! ?
Alle Halo forsterkerne kjører A + A/B.
A21 kjører vel 10 watt i klasse A før den går over til A/B (High bias A/AB). Vet ikke om jeg husker rett men mener å huske at den bruker 150watt når den er skrudd på, uten signal. Denne nye integrerte er oppgitt til 70 watt forbruk når den er skrudd på, så den bytter vel over til A/B raskere. Jeg har sett at Cambridge Audio 840W som jeg er oppgitt til 180 watt uten signal og jeg kjenner at den blir ganske varm.
JC-1 er oppgitt til Class A power output, 20Hz - 20 kHz:
25 watts, bias set to high, 8 Ω
10 watts, bias set to low, 8 Ω
Så du kan vel velge hvor mye du vil ha i klasse A vs hvor mye varme du vil lage. Greit med ekstra fyring om vinteren!
Hva som er forskjellen på den her type klasse A mot single ended som Pass Labs har er det nok noen andre som er mer tekniske diskutere.
MusicBear
Lurer på hva Parasound hadde solgt her i Norge, dersom prispåslaget for dette merket ikke hadde vært så stort som det er i forhold til andre merker som produseres utenfor våre landegrenser og selges her hjemme. Du også PowerMetall er jo inne på det samme. Samtidig som vi har lest her på forumet at mange har importert direkte fra USA som følge av dette...
Jeg tror Parasound ville solgt i bøtter & spann som følge av deres ytelser, med lavere priser men fortsatt med god nok avanse til importør, men dette må jo importøren selv velge om fortjenesten skal velges ut i fra "bøtter & spann" eller færre enheter til høyere priser.
Fredrik.J
2500 USD i USA (16500) mot 25 000 kr i Norge, er det så stor forskjell da? Husk at de ikke har 25 % mva i USA som her i landet, og at det koster å shippe over... Legg til frakt og igjen mva oppå dette så er du såppass nær at du skal ikke se bortifra at du får prutet en ny i Norge ned til det samme. Vet om merker som er betydelig mer overpriset enn Parasound i Norge i forhold til andre land...
At du må gange dollaren med 10 istedenfor kursen (ca 6,5) for å få norsk pris er vet meget vanlig på det meste av produkter.
Redigert: Men jeg må legge til, tviler ikke på at importøren får en god del av kaka. Sånn er det stort sett alltid med HiFi i Norge. Ser jo hva OHC har tilbud på Parasound i ny og ne, og tviler på at de selger med tap...
jonas
Vil tro en B Holter Hegel H160 vil bli vanskelig å slå, med tanke på at denne faktisk er underrpriset her til lands, mens Parasound er overpriset. Synes også display er en stor fordel når forsterkere har digitale innganger osv... Blir spennede å lese tester, men håper Hegel gruser Parasound, selv om jeg liker begge merker.
TrondW
Bergenser i Ålesund
Har NAT en bruker her på forumet som kan kommentere dette prispåslaget som har vært en del omtalt her? Om slike påstander blir stående ukommentert har det en tendens til å bli en sannhet. Det kan være riktig som mange har ment, det kan også være flere sider av saken...
PowerMetal
Veil. pris på Parasound A23 i USA er 5600 kr. Det er er ikke innkjøpspris men prisen etter at butikkene har lagt på de prosentene de skal tjene på salget. A23 har også en switch som kan bytte mellom 110v og 220 v. Synd A21 ikke har det samme. Det kan hende at det ikke er så unormal prising og at jeg bare sutrer litt :)
Hvis man søker på hifishark så får man oversikt over hva de forskjellige går for brukt og nytt rundt om i europa og usa
skorob
Brumunddal
Enig. Samtidig så har vi den kritikerroste Gato til 30000kr. Mer kraft, og et design som t.o.m. fruene må like!!! Er veldig spent på Hegel sin også!
Eirik84
Drammen
Prisene ville vel ligget på nivå med Emotiva sine forsterkere. Mange prater nedlatende om Emotiva pga deres priser, men saken er at jeg tror vi hadde sett mye hyggeligere priser fra mange produsenter dersom vi kunne kjøpt rett fra produsent uten andre mellomledd som skal sine påslag..
MusicBear
For ordens skyld fra meg; har absolutt IKKE i mot importører som tjener penger, i resonnementet i mitt innlegg. Om noen skulle tro det.
Ei heller kritiserte jeg importøren, fremsatte kun noen tanker de selv kanskje (?) kunne tjent mer penger på, samtidig som forbrukerne hadde gjort det samme - også med "bi-effekt" bedre lydgjengivelse i stua :)
Er vel også importører som fastsetter utsalgspriser, og ikke forhandlere.
Focalius
Arendal
Man må også huske at i Norge har man 5 års reklamasjon.
Så f.eks hvis du kjøper NAD, Hegel, Cambridge osv så må forhandleren dekke reperasjoner/nytt produkt osv etter normalt 2 år. Det koster litt det også når man legger det sammen.
Parasound HAR jo allerede 5 års garanti, så det burde ikke være noe problem i denne sammenhengen.
Parasound P5 selges for ca 10-11.000. Noe som går for å være utrolig mye for pengene. Noe lavere blir jo nesten galskap.
Forsikring på shippinga koster også en del hvis du som forhandler skal importere fra USA.
Tjener du 600.000 i Norge er ikke det noe folk himler i øyene av. Men tjener du 600.000 i USA er du regnet som rik. Så prisene kan ikke helt sammenlignes.
Føler Parasound sine priser er fair.
Focalius
Arendal
Parasound blir så vidt jeg vet satt sammen i Kina, men designet og konstruert i USA.
Bruker de norske folk på Hegel fabrikken, design osv så skal de ha temmelig mye mer i lønn og utgifter enn det Parasound betaler i Kina.
Om Hegel velger å sitte igjen med lite overskudd for å være snille, eller om produktene er fylt med bare dyre godsaker tør jeg ikke å spekulere så mye på.
Mr.SQ
Aust-Agder
Det er veldig lett for utenforstående å kritisere Norske importører/distributører for å være grådige. Selv om det eksisterer noen med kunstige påslag, så er dette en utdøende trend. Tilgjengelighet over nett er selvsagt en svært stor del av årsaken til dette.
Det er flere grunnen til at produkter blir dyrere i Norge, enn f.eks USA:
1. Husk at alle priser som blir oppgitt på nett eller magasinet er uten Amerikansk moms. Også for Amerikanere påløper moms hvor størrelsen avhenger av hvilken stat du kjøper produktet.
2. Fraktkostnader til Norge er høye. Noen importører avhjelper dette ved å bestille Drop Shipments rett fra fabrikk i Østen. På dyrere hjemmeelektronikk kan det derimot kreve alt for store MOQ til at enkelte selskaper har økonomisk ryggrad, eller omsetning til å gjennomføre dette. Fraktbelastningen ved container frakt fra USA kan for medføre en ekstra kostnad på 7-10% pr produkt. Flyfrakt kan fort bli høyere.
3. Det er veldig dyrt å drive firma i Norge. Det er ikke uvanlig at et selskap innen denne bransjen har en driftskostnadsprosent på 30% eller mer. Enkelt forklart betyr det at du må ha en gjennomsnittsfortjeneste på 30% på alt du selger for å gå i null. Det å gå i null er ikke et mål i seg selv.
Amerikanske firma har helt andre driftskostnader, inkludert lønn, og kan derfor drive på lavere marginer.
Tar man for seg NCMS AS som importerer Parasound ( Altså ikke NAT som blir antydet tidligere i tråden) så er det ingen ting i deres regnskaper som tyder på grådighet. Selskapet hadde ikke overskudd i 2013, og det var ingen urimelige lønnskostnader. Det har heller ikke vært tatt ut utbytte på flere år. Ergo så har NCMS AS gjort det påslaget som er nødvendig for å drive selskapet.
Dette var for å gi et mer korrekt og nyansert syn på prising.
Eirik84
Drammen
Nei tror ingen importører har grådige påslag heller, mente bare at disse importørene de skal jo leve av det de gjør også - ergo må jo prisene bli høyere enn om man kjøper et produkt rett fra produsenten. Som du selv skriver så har de jo både lønnskostnader og andre driftskostnader for å kunne generere inntekter, så såklart blir det dyrere ut til forbrukeren når produkter må innom dette mellomleddet i stedet for at forbruker får kjøpe rett fra produsent til samme pris som importøren..
mikefish
Fikk nettopp mail om at Soundgarden kjører 20 prosent avslag på lagerførte varer nå i helga.Da får man 4400 kr i avslag på H 160'en.Men den er ikke aktuell for meg da jeg jeg trenger en kraftigere sak for å drive mine Focus 260.
mvh.s,
TrondW
Bergenser i Ålesund
Takk for en nyansert oppsummering av bl.a. (rett) importør. Nettopp slike vurderinger jeg har etterlyst etter å ha lest mange innlegg om grådighet spesielt rundt Parasound. Det gir jo gjerne en bedre smak i munnen når man legger ut ikke ubetydelige summer med penger og håper på god valuta for de pengene.
lydbjørn
De kunne vel egentlig tatt hva de vil, så lenge de får toppkarakter uansett produkt!
TrondW
Bergenser i Ålesund
Noen kjøpere av denne forsterkeren som vil fortelle litt om inntrykk så langt?
Er interessert i lyden fra den, ikke bare fortjenesten... ;-)
