Parasound har visst kommet med en integrert forsterker i Halo-serien
Utifra specs er jeg redd den blir DYR!
Product Lines > Halo > Halo Integrated Amplifier
Power Amp Section
• 160 Watts @ 8 Ohms, 240 Watts @ 4 Ohms (Both channels driven)
• Power amp circuit topology designed by legendary John Curl
• High bias Class A/AB operation
• Oversized toroidal power transformer with independent windings for each channel
• Dual-Mono power supply and power amp sections
• 40,000uF power supply filter capacitance
• 12 high voltage/high current bipolar output transistors (6 per channel)
• Heavy-duty 24k gold-plated 5-way speaker binding posts
• Over temp and short circuit relay protection
Preamp Section
• Built in Wolfson DAC with USB, Optical and Coax inputs
• USB, Coax and optical accept all sampling rates up to 192 kHz, 24-bit
• Analog bass management with variable high and low pass crossovers
• Home theater bypass input for surround sound integration
• Front panel subwoofer level control
• Dedicated high current headphone amplifier (TI TPA6120)
• 5 pairs RCA line level inputs
• 1 pair XLR balanced input (parallels Input 5 RCA jacks)
• Low noise Phono input for MM & MC cartridges with 100 Ω or 47k Ω load
• Front panel Aux input with automatic +12 dB gain stage
• Balanced XLR and RCA left and right preamp outputs
• 1 balanced XLR and 2 RCA subwoofer outputs
• Bass & treble controls with relay bypass from remote or front panel
• Headphone jack with 10 ohm output impedance can drive 600 ohm 'phones
• Rear panel IR input and IR loop output jacks
• 12 V output to trigger power amplifiers and other devices
• Automatic turn on with 12 V trigger or AC power
• Fixed level record output
• Premium motor-driven Alps potentiometer volume control
• Left/Right balance control
• Remote control with discrete on/off power buttons
• 0.5w standby power consumption meets Energy Star & European Union spec s
Power Amp Section
Preamp Section
73.2 KB Visninger: 996
