How to Build a Hackintosh
G
Gjestemedlem
Grei oppskrift for den som av uviss grunn måtte ønske seg en fullblods Mac, men ikke er villig til å betale dobbel pris i forhold til komponentene i den:
http://lifehacker.com/5351485/how-to-build-a-hackintosh-with-snow-leopard-start-to-finish
http://lifehacker.com/5360150/install-snow-leopard-on-your-hackintosh-pc-no-hacking-required
Price Comparisons
Most Hackintosh enthusiasts will say you shouldn't build a Hackintosh primarily to save money, as it's more than just an insert-disc-and-click install. Still, I always enjoy looking at the price differences between my Hackintosh and Apple's current offerings. At the moment, the cheapest Mac in the Apple store is a Mac mini sporting a 2.0GHz Core 2 Duo processor, 1GB of RAM, and a 120GB hard drive. For $300 more, I'm running a 3.0GHz Quad-Core processor, 8GB of RAM, a 1TB hard drive, and a damn saucy video card. I could have made this build much cheaper by skimping on hardware and still ended up with a great little machine, but I liked aiming for around the $800 price point from my last build—plus I really wanted to make it fly.
The most expensive iMac, by comparison, has only a 3.06GHz Core 2 Duo with 4GB of memory for $2,200 ($1,300 more than my build, but it is built into a monitor), while the cheapest Mac Pro has a single 2.66GHz Quad-Core processor, 3GB of RAM, and a 640GB hard drive—and it costs $2,500 ($1,600 more than mine, though it's a different and better processor and DDR3 rather than DDR2 RAM). In short, my $900 "Hack Pro" sports nearly as good or better hardware than any Mac that Apple sells short of the $3,300 8-Core Mac Pro (which can, incidentally, get more expensive, but it won't get much better).
ePi
Burde ikke Snow Leopard, iLife og billigste 8GB minnepenn bli tatt med i prissammenlikningen? Noe annet blir som å si at man kan bygge sin egen BMW M6 for 350 000,-, bare uten alt ekstrautstyret da.... (og jada, jeg VET at man ikke kan velge bort det som følger med en eplemaskin).
Gøy artikkel forøvrig. Har vurdert noe slikt selv, men har endel annet som skal realiseres først :)
Just4Fun
Sauda
Bygge M6 for 350 000 ??? Har du sett deleprisene til Bavaria? ;D
Rhesus
Koster jo bare 1490, eller 1990 for family-pack.
Ikke noen showstopper, når man ser på hva slags ytelser vi får for penga,
Hackintosher funker supert også. Dette skrives på en av slagsen. Men jeg valgte denne mest fordi apple ikke har noen netbook.
N
nb
Skjermene på iMac er vel ganske bra så vidt jeg har fått med meg, så man bør regne noen kroner for en tilsvarende om man skal sammenligne. En ok skjerm er dog veldig billig, og den duger til det meste.
Wright
Hovedpoenget bak å kjøpe Mac for en del av oss er de egenskapene som ikke passer pent inn i en tabell, kjapt oppsummert:
Ikke ment som nok et Apple-er-Gud-innlegg (selv om Steve Jobs selvsagt er nøkkelen til Nirvana!), bare at en bør tenke over flere sider ved datakjøp enn de som er direkte sammenlignbare spesifikasjoner. Om en der ender opp med et Windows-system, Hackintosh, Linux eller noe fra Cupertino får være opp til enhver. Og jeg har spesielt stor forståelse for de som velger å kjøre Mac OS på netbooks. Hvis en ønsker fleksibilitet med tanke på oppgraderinger er jo heller ikke Apples maskiner noe særlig (med unntak av Mac Pro, men den er for de mer enn spesielt interesserte i utgangspunktet), og om den uansett skal stå i et mørkt hjørne skader neppe kabinettet stort?
G
Gjestemedlem
Jo man kan vel kjøpe en ordentlig PC og heller kjøpe skjerm, mus og tastatur fra Apple og så får man best of both worlds. Man trenger jo ikke ha kabinettet stående fremme om man ikke liker det. Skjønt det tastaturet der, pent som det er, minner meg mest om en Spectrum 48 i bruk. Man musen er jo artig da, hvis det kommer drivere til den en gang. Og pene skjermer begynner å dukke opp fra mange produsenter etterhvert også.
så .. tja,..,
novgarod
Her ligger vel egentlig sakens kjerne...
Noen synes det er godt nok å ha noe som får jobben gjort:
Mens andre, på sin side, er villige til å betale for noe mer:
Så får det være opp til den enkelte å gjøre sine valg.
Å gjøre en ren Pris/ytelse-sammenligning uten å ta høyde for andre parameter enn toppfart/akselerasjon, blir for meg helt håpløst... ::)
trex
Er delvis enig i at Mac handler også en god del om design, eierfølelse og andre ting enn bare OSX, men linkene på toppen fungerer ypperlig hvis man skal ha en kraftig Mac til musikkproduksjon eller videoredigering, for å nevne 2 ting som krever god ytelse, og ikke har lyst til å punge ut for en Mac Pro, for de er dyre kontra å bygge en kraftig maskin selv. Man må bare passe på at bitene fungerer mot OSX, ikke alle duppeditter som gjør det.
Eller for en som har en OK maskin og har lyst til å prøve OSX uten å måtte kjøpe en Mac først.
coolbiz
Sydvestlandet
Morsomme bilder, novgarod, men bil-analogien din halter. Hackintosh er ikke et BMW-karosseri med Trabant-innmat. Det er omvendt: BMW-innmat i et Trabant-karosseri. :)
Takk for linkene, Deph!
Wright
Billigste Apple-skjerm (24"), Snow Leopard m/iLife, mus og tastatur fra Apple: 11000. Billigste iMac med 21.5" skjerm, tastatur, mus, Snow Leopard og iLife: 9500. Uten at det undergraver poenget ditt om at det finnes en del tilfeller der Mac OS på ikke-Apple-maskiner gir god mening, selvsagt.
For min del blir Apple greit priset fordi jeg kjøper forholdsvis enkle modeller og beholder maskinene en stund lengre enn jeg ville gjort med Windows-maskiner fra diverse andre produsenter. Men jeg skal ikke spore av tråden din mer nå, Gjestemedlem. Lover! :)
Brasse
Rhesus: Fortell gjerne mer om Hackintosh-netbooken din!
Rhesus
Det er en Dell Mini 9, med 2G ram og 16G SSD. Installerte etter denne metoden http://osx.mechdrew.com/guides/nbi1.shtml
Stec SSD disken som kom fra Dell er litt liten og treg, men til netbookbruk er det greit nok. Den kan oppgraderes, Runcore lager noen store og kjappe typer. All hardware og funksjoner fungerer utmerket. Ingen hiccups i drift, men en sjelden gang vil den ikke boote på første forsøk.
Mini 9 er gått ut, kanskje du kan få tak i Vostro A90, som er samme maskin. Dell Mini 10v er visst også en svært egnet netbook å hackintoshe. Den har 160G harrdisk, så den er kanskje litt mer egnet til litt mer dataintensive ting som f.eks. iphoto enn Mini9.
Edit: Dell mini 9 er uten vifte, dvs. 100% uten bevegelige deler, og derfor 100% støyfri. ;D Super til musikkavspilling. 10v har heller ikke vifte, men den har en bitteliten harddisk.
Wright
Bare for å gjøre det veldig klart: det er stor forskjell på Dell Mini 10 og 10V i så måte. Uten V duger det visst ikke.
Rhesus
Riktig.
