Accustic Arts Power ES
2x 90 W 8 ohm.
Audiophile integrated stereo power amplifier with high output performance
4 selected MOS-FET output transistors of highest quality
330 VA toroidal core transformer of premium quality for high output reserves; separate windings for preamp section, for power amp section and for right and left channel
Very good smoothing thanks to more than 50,000 µF power supply capacity
High damping factor for perfect speaker control
Integrated protective circuit switches ascents off when clipping,
HF oscillations or too high DC offset occurs
Constant low operating temperature due to generously dimensioned heat sink
4 x unbalanced high level inputs (RCA)
1 x unbalanced input (RCA) configured as "SURROUND-BYPASS"
Premium quality relays and premium quality rotary switch with gold-plated silver contacts for the input selection
Encapsulated high grade volume potentiometer including remote-control
Full metal housing for optimum shielding
Front panel made of brushed aluminium; turning knobs made of massive and chromed brass
Optional high quality phono stage (MC/MM); RIAA precision: +/- 0,15 dB
ACCUSTIC ARTS® POWER ES is "Handmade in Germany"
www.NordicSoundDesign.com
4.2 KB Visninger: 411
3.1 KB Visninger: 409
