Ymirs audiofile liv
  • ymir
    @Drossel Selvfølgelig må der pauser og mat til på en slik tur. Geologi kart for området benyttes også flittig. Når den ene i tur følge også er biolog går det litt tid der også.
    Men lang var turen og @Audiophile-Arve alder og kg merkes. Og en ting er å gå oppover og bortover. Noe annet er å gå nedover.
    Ca 640 høydemeter på så kort distanse var vondt. Langfoss var for siste gang sa fruen.
    Godt hun sa det så jeg slapp 😁
    ymir
    Svært interessant lesning med mye referanse til Rønnberg .
    The Propagation and Interaction of Supraharmonics from Electric Vehicle Chargers in a Low-Voltage Grid
    During the measurements, another type of interaction between devices is observed in the form of “frequency beating” and intermodulation, in some cases resulting in the tripping of residual current devices. This interaction is further analyzed in order to better understand the possible impact it can have on the grid.
    On the other side, the immunity of end-user equipment to supraharmonic disturbances has already been studied to some extent [19]. Most electronic equipment uses EMC filters with capacitors to remove high-frequency noise from the input. However, capacitors absorb the high-frequency components as their impedance is inversely proportional to frequency according to
    with C being the capacitance and with the frequency f in Hz. This can lead to extensive heating and decreased lifetime (up to 40%) of those components, resulting in degradation of the equipment itself [20].
    Furthermore, (linear) load-flow models that are useful for modeling the behavior of “classic” harmonics are not accurate enough to model the propagation of supraharmonics because they are often not directly linked to the fundamental frequency and their behavior in grids is difficult to predict. Interaction between the grid and EMC filters influences the amount of current absorbed by other devices and changes resonant frequencies [21].
    2.2. Sources of Supraharmonics
    There are different sources of supraharmonic emissions. In general, all devices with converter-based power electronics emit supraharmonics to a certain extent, as an artifact of the conversion from AC to DC or vice versa. In this research, only the effects on the power quality at the AC side are presented. Nevertheless, effects on the DC side can be present but fall outside the scope of this research.
    By switching between grid and microgrid mode, the grid impedance Zg and background distortion in the voltage change. This can lead to a change in the emission of each connected device. Furthermore, it is assumed that the inverter impedances ZPV and Zbat are not constant for the different operation modes. This makes modeling difficult.
    For low-voltage networks, the resistance is dominating, especially close to equipment. Hence, for low frequencies (<2 kHz) it can be assumed that Zg is largely resistive. However, for higher frequencies the reactance of the cable will increase and can become dominant and the influence from impedances of neighboring equipment can play a role due to their capacitive nature.
    Adding extra devices will create a different impedance seen by the device and will possibly affect supraharmonic emission. However, it is important to note that for each frequency, this model has different parameters, as device impedances (often capacitive due to filters) and grid impedances (often inductive due to cable and transformer characteristics) change with frequency. By superposition of all individual harmonic load-flow models per frequency, the total supraharmonic emission to the grid from the system can be determined. In this linear model, no interaction between devices or other effects are included.
    Tenk å gå i to timer for så lite ☹
    Men fin tur var det nå allikevel 🙂
    ymir
    Kor mykje molte treng du plukke for å vere lukkeleg?
    Og; kva brukar du molta til?
    Har du prøvd å lage moltevin?
    3/4 liter, da er jeg nøgd. Kan da kjøpe, så det er ikke noe stort problem. Men det handler jo litt om å ha plukket selv til moltekremen, og resten til syltetøyet. Syltetøyet får jeg ha for meg selv, er bare jeg som er glad i det 😁.
    Moltevin er ikke prøvd. Er ikke noen ekspert på slikt. Er litt KRESEN, så slik overlates til ekspertene i Rhône dalen FR. Har bare lykkes med ølbrygging 1 gang
    Og det ølet var tenkt å gå i mottingen.
    Var litt tilfeldig at det ble smakt på rett før det ble slått ut. Var det beste ølet jeg har smakt. Men klarte ikke å gjenskape det ved neste forsøk.
    Så alkoholholdig drikke kjøper jeg på polet, til meg. Fruen liker best øl så det blir handlet inn på coop'n🙂
    Audiophile-Arve
    Men moltelikør er no stas å lage sjølv. Plukk eit Norgesglass med molte. Slike saftige, gule, søte.. Fyll så sukker i den grad det er plass til mellom moltene. Fyll så på 60% til det er fullt. Lat stå så lenge du orkar (kort tid gjev rein moltesmak og mykje sødme, lang tid gjev ein nøttesmak pga. moltefrøa).
    Sil frå moltene og bruk dei i moltefromasj.
    (skal du ha oppskrift på moltefromasj også? Vi brukar det kvar jul)
    ymir
    Likør er fruen sin hobby 🙂 om enn ikke så veldig. Skal foreslå det. Hun liker jo multelikør. Broren leverer 60%'n😁.
    Ser for meg ikke for lang lagring.
    Moltefromasj.. det må prøves, så dersom du vil dele familiens oppskrifter så hadde det vært kjekt 🙂
    ymir
    I dag "Såtå, Såto, Såta" alt etter hvor en kommer fra
    Men stereoen er ikke frisk.
    Stemmer lokaliseres laaangt til venstre,
    også fra vinyl. Byttet om på kabler. Ingen forandring til det bedre.
    inpain1968
    Nesten som alle andre…
    Spreke folk, men det ser ut som det gjorde seg med en liten pust i bakken…:)
    ymir
    Sprek er jeg ikke, men de to andre er veldig spreke. Og pusten i bakken varte en time. Solen varmte godt, vinden suste i gresset og kom med angen av gulaks. Og rundt omkring hørtes sauebjeller. Altså nærmest perfekt
    Bedre enn å henge på sentralen hele dagen 😁
    ymir
    Hmm, ioniq vs e C4
    ymir
    Og det var den dagen, helt uten musikk 🙂
    Beinhard oppstigning, men etter noen timer er belønningen flott utsikt over Sunnhordland bassenget.
    Dagens derpå, ny topptur
    ymir
    Fire måneder siden det skjedde noe på prosjektet "en god DIY koster bare noen plankebiter" sies det. Torsdag er handle dag. Stakk innom Monter og hentet noe 2x4.
    Resten er rester..
    Kabel for high end streaming?
    Går nå fremover dette og. Sikkert ferdig før mitt prosjekt 🙂
    ymir
    Kveldens høydepunkter.
    En spesiell setting å spille uten publikum.
    Påvirket helt sikkert fremførelsen.
    Takk til Espen Ås.
    The man in Black var kveldens høydepunkt.
    Vikebygdingen Aadland #2.
    Mannen er en genial Dylan oversetter og i tillegg er han god til å fremføre.
    Og så ble sendingen forstyrret av inntrengere som måtte holdes ute.
    Og så selveste mor Åse da. Kanskje kveldens Dronning
    ymir
    Blyant, vinkel, metermål, linjal,
    Og noen plankebiter skal være nok til en duganes høyttaler sies det.
    Vel, i dag ble det målt og streket.
    Er jeg heldig så kan det bli lyd neste sommer,
    eller sommeren deretter 😛
    ymir
    Leste på NRK om Lise Davidsen.. så ett program på NRK 2 for en god stund siden.
    Så da måtte nysgjerrigheten tilfredsstilles.
    Klarte ikke å rive meg bort fra dette.
    Resultat ble utsatt middag.
    En mektig forrett
    ymir
    Det nærmer seg med det ene og det andre.
    Ikke rart at det var kaldt på fingrene for slikt arbeid.
    Forberedelse til den store dagen på lørdag
    ymir
    Denne har ligget klar på Qobuz en stund.
    I dag var tiden kommet for en lytt.
    Starten falt ikke i smak, men det tok seg opp fra spor tre.
    ymir
    Herren være lovet, som gir meg vellyd.
    Blir svært behagelig lyd når forsyningstrafo belastes med 10-15kw ren ohmsk last.
    Kanskje snart på tide å bytte trafo i preamp mens det enda er litt støy der ute.
    Litt vanskelig å høre noen virkning av R core trafoen dersom det ikke er noe som påvirker.
    Lyden var tilbake som i morges når jeg kom hjem fra luftetur, heller litt mot det lyse.
    ymir
    Må bli litt kjent med lyden uten filter/støydemingstrafo. Var da ikke såå mye arbeid å koble bort filteret 😁
    Høres ut som det er bedre uten.
    Kan sikkert stemme siden støydempningstrafoen slipper igjennom en god del støy under 10khz. Noratel sier 5-6khz,men demping en er nok ikke helt topp helt nederst i dette området. Filteret har også sine begrensninger ved så lave frekvenser.
    Så får det spilles slik en stund. Har annet å gjøre som er kjekkere 🙂
    Svært tørr sommer har gitt lite knoller og flatskurv på potetene.
    Klarer bare en rad til dagen før ryggen sier stopp☹
    edit:
    Bedre uten filteret?
    tja..bassområde er bedre, men fioliner og når det blir mange stemmer er det vel en liten degradering i det området.
    Spilte denne i går, og nå mener jeg det ikke er som i går.
    Sånn,nok for i dag.På med turskoa og siden det ikke blåser..paraply,det er mer behagelig enn dermizax
    ymir
    En engasjert Math Bollen, og ingen som våger å stille spørsmål
    Dårlig vær? Nei
    Fyllingsgraden og strømprisen?
    Utjevning
    Lurer inn dagens luftetur.
    Det var da mye mer skodde enn bildet tilsier.
    ymir
    Litt lek med XTZ room analyzer og RTA måling.
    1: Gamle kurs, 10A høy kildeimpedans = lang kabel til sikring og hovedinntak med Conconanse PW-1 filter
    2: Ny dedikert kurs,16A, 1.3m lav kildeimpedans uten filter.
    3: Som over, men med filteret.
    Siste med filter gir mer støy, ref.level.
    Installasjonen må vel sies å være "støyfri" under måling.
    Muligens at det fremdeles ser noe slik ut målt i stereo kursen uten filter der den første resonansen er varmepumpen. resterende er utenfra.
    ymir
    Stemmer ikke helt hva angår varmepumpen.
    Fant målingen der varmepumpen er avslått,
    oransje kurve. Gir redusert støy. Første resonans blir helt borte.
    Starter rundt - 90bB og så stigende oppover i problem området supraharmonics
    Amir sitt veggstikk.
    - 75bB og sterkt fallende kurve her
    Ikke mye å dempe her
    Roberth
    Jeg regner med du har det måleinstrumentet der på ønskelisten til jul?
    ymir
    Bzzzzzzzz, var vikingene på primærside som var i motfase.
    Spiller på en helt annen måte med R core.
    Kanskje litt soft i bassen men heller det enn slik det var. Nå, en mellomtone som spiller som en drøm. Så får i se hva som skjer når bilen skal lades.
    Her tømmes bygget for å gi plass til nytt datasenter for kryptovaluta ut på nyåret 😡
    Tenk å svi av 10 MW på slikt idioti,
    Og ingen utnyttelse av spillvarm.
    Slikt skulle ikke vært lovlig slik situasjonen er i dag.
    Her er også 1 stk 25Hz generator. 😁
    Kjekt å ta lufteturen i nysnøen
    ymir
    Etter litt lytting og lesing på div forum tegner det seg ett litt tydeligere bilde ang årsakssammenheng mht støy og lyd.
    John Curl har jo de siste 25 - 30 år frontet EI og C-core transformator til preamp og kilde, og nå R-core. Han sier også at en del konstruktører henger etter i utviklingen og holder på ringkjerne trafo.
    Parasound har lenge brukt R-core.
    Det kom også frem at f. Eks Accuphase og Luxman heller ikke bruker ringkjerne.
    Så da ser jeg det slik etter å selv ha byttet fra ringkjerne til R-core at hemmeligheten mht støy og lyd for det aller meste ligger i valg av trafo og i litt mindre grad av etterfølgende komponenter.
    Denne lille trafoen min kostet ca 33 euro.
    og gjør en betydelig bedre jobb enn Noratel støydempingstrafo, PS audio ppp regenerator og alle nettfiltre jeg har prøvd.
    PurePower leverte ett like støyfri tt resultat, men med en lyd som hellet betydelig mer mot det lyse. Noratel gjorde egentlig ingen ting mht lyd, hverken positivt eller negativt.
    Filtrene var avhengig av kildeimpedansen og det generelle støybilde.
    R-core trafoen virker å gi det beste resultat,
    og er det rimeligste verktøy for å gi god lyd der støy er ett problem, noe som vil gjelde hos svært mange.
    Synes heller ikke bassen er på den myke siden lenger. Lyden totalt anderledes nå, også sett i forhold til lyden tidligere når den var på sitt beste.
    Så kanskje valg av transformator skal være første prioritet for så å eventuelt "sy" sin egenklang til elektronikken basert på dette valget?
    ymir
    Litt vinyl for første gang etter trafobytte.
    Gratis PS Audio P20 og NO Odin til alle komponenter eller denne lille C-core trafoen til 3-400 kr? Sistnevnte uten tvil 😁
    Har lagt merke til at Accuphase har godt over til ringkjerne og selger regenerator.
    Er det bedre butikk?
    Drossel
    Jeg forstår det sådan, at årsagen til at R core giver bedre lyd er, at primær og sekundær vikling sidder på hver sin halvdel af trafoen, og derved overføres mindre støj fra primær til sekundær. På ringkærne sidder sekundær ovenpå primær.
    P.S. jeg ser at du ikke snor ledningerne (AC). Det kan afgjort give en masse støj.
    ymir
    🤫 Er aldrig så lite flaut det der. Får se om jeg får tvinnet de en gang, noe som i praksis betyr aldri 😁. Har ikke lyst å lodde de ut igjen. Skjøre greier dette når en ikke har bedrevet slikt siden midten av 80 tallet.
    Hadde svært lite forventninger til trafo bytte.
    Hadde jo liten og ingen virkning av støydemingstrafoene til Noratel, så det var overraskende at utbytte ble så stort.
    Beste investering noen gang.
    Først nå låter preamp som en 50kkr preamp
    R-core transformers are currently used in mid- to high-end consumer electronics equipment from Japan. In the US, they are still quite uncommon and almost as expensive as toroids, but I hope this will change as they become more popular here. The R-core transformer has the potential to become the predominant choice for use in audio equipment, providing all of the benefits of toroidal transformers at a lower cost.
    ymir
    Sikkert ikke riktig fremgangsmåte. For å komme opp på 53.6dB måtte potmeter opp til ca Kl 3.
    Målingen det sammenlignes med er fra innlegg # 1348, dedikert kurs 16A uten nettfilter og med ringkjernetrafo
    Potmeter den gang vil jeg tro var i området Kl 12 - 13. Potmeter burde vel stått likt, og da ville dagens måling fått ett Ref level mye lavere enn 53.6dB.
    Området 8kHz og opp kan en sikkeret ta med en klype salt,men effekt messig er det ikke mange watt til det området.
    Men tendensen er som på tidligere målinger, ett stort fall.
    Nederste måling er med R - core trafo
    ymir
    Ubeskrivelig. 21 år tok det.
    Men har lært mye.
    ymir
    Så kom kvelden vi ville (kunne) på altibox fibernett da datter var oppom en tur.
    Passord helvete og innlogginger ☹
    Mener at viasat gir bedre bilde.☹
    Dårlig wifi på altibox? Fungerte "bedre" med d link streamet fra Bigblu 10kbs.
    Lastet ned denne
    Ser ut til at jenta ikke fikk til dette.
    Lastet ned som flac fil og ønsket den over til harddisken med rippede cd'er.
    Koblet hardisken tilbake i bluesound.
    Den gikk i hvit lys og "no items found"?
    Du får fyre opp priusen? @breuer 😁
