Finnes det noen "tweaks" som er så "over the top" at ingen går på de?
  • bambadoo
    “When building cables at the Synergistic Research factory, we listen to spools of individual conductor strands to determine their audible signal direction or, should the conductor run in the direction it’s pulled from the spool, or in the opposite direction when worked into a cable? The differences heard are the difference between a more solid and focused sound, and one that is phasy and incoherent. Other differences include, correctness in timbre for instruments, and the presents or a lack thereof of ringing in high frequencies.
    Ted Denney
    Lead Designer— Synergistic Research Inc.”
    Når (den gang da, hver gang når) vi er inne på samme high-tech firma.
    After fine-tuning the mass and the suspension, we voiced the record weight with an internal UEF element and an external UEF option that allows you to choose between two sonic balances in the form of a Red and a Blue HFT specially voiced to deliver air and detail or warmth and liquidity.
    Drossel
    Det kunne man da på Steen Duelund fladvalset sølv. Ikke at jeg bruger det mere. Dårlig idé å valse det.
    Snickers-is
    30 lapper for glass-sikringer er da ikke ille? Bare pass på at pilen peker rett vei, ellers låter de visst skikkelig dårlig.
    Drossel
    Kan godt høre lidt forskel på sikringer. Men det er i små tings afdelingen.
    PeriodeLytter
    Oops, I didn't know there were arrows on the fuses, I responded. Okay, I pulled out my little magnifier and did see the arrows on these mini (20 mm long) QSA fuses. Tsang suggested each should point inward toward the component (if your fuses face sideways, experimentation is required). Upon pointing all four fuses inward, I turned on my Behold BPA-768 amps, turned on some music listened for a few minutes before hearing some notable changes over my initial impressions.
    Når man leser slike anmeldelser så undrer man seg om hele teksten er skrevet som en spøk?
    Snickers-is
    Det som er spesielt interessant er at ingen har en forklaring på dette, man har bare kommet frem til det ved rene tilfeldigheter. Da fremstår koronakonspirasjonsteoretikerne som rene guruene i forhold.
    SiSt
    Hamar
    Placeboeffekten er godt forstått da.
    Drossel
    Der er jo helt klart nogle af medlemmerne her som får andre til at flygte. På visse forum bliver man smidt ud asap hvis man opfører sig som jer.
    Pink_Panther
    Ok? Er det galt å være en smule skeptisk til noen av påstandene til "high-end eksperter"?
    DagT
    I mitt miljø er det folk som ikke ville nærme seg "hifi-miljøet" med ildtang på grunn av all svadaen de forbinder med det. Selv om de i og for seg har bra anlegg og liker god lyd.
    HasseBasse
    Hjortshøj, Danmark.
    Efter 106 siders indlegg må svaret på tråden vel desværre være .... NEI.
    Det findes ingen tweaks, der er så "over the top", at der ikke er noen, der går på dem likevel....:(
    Pink_Panther
    Jeg har hørt mange ungdommer si at de gidder ikke å kjøpe stereoanlegg fordi det er så mye styr og dyrt. De blir skremt av alle svada-påstander om high-end ditt og high-end datt de må ha for å i det hele tatt få lyd i anlegget.
    Kabelpushere og sikringfreaker har skremt mange vekk fra hobbyen.
    Drossel
    Nejda men synes efterhånden der er for mye skepsis. Kanskje bare nogen som ikke har godt udstyr til å høre forskel, eller er for stresset til at koncentrere sig ordentligt.
    Pink_Panther
    Hvis du har så godt utstyr, hvordan kan det da ha seg at sikringene gir bedre lyd? Anleggene deres må tvertimot være veldig dårlige når absolutt alt av remedier gir bedre lyd.
    Drossel
    Ikke alt giver bedre lyd. Sikringer kan i ganske få tilfælde høres. Men det er absolut i småting afdelingen. Jeg bruger fortrinsvis dem med almindelig sølvtråd som jo er i helt almindelige sikringer.
    Barbaresco
    Ditt utsagn stemmer dårlig med loven om det minskende utbytte. Med et så godt anlegg som du forutsetter, blir det nesten umulig å innføre en relativ endring som er hørbar. Med et anlegg i den lave ende vil alle forbedringer bety en prosentvis stor og hørbar forbedring. Dette at "jeg/du har ikke godt og dyrt nok anlegg til å høre denne gode og dyre forbedringen" er en i utgangsspunktet smart spissformulering, som forbrukerne nå begynner å gjennomskue. Selvsagt til økonomisk fortvilelse for dem som pusher kvakksalverløsninger og kvasifysikk.
    DagT
    Utrolig hvor dårlige kabler og kontakter folk kjøper når de trenger sånt :cool:
    PeriodeLytter
    Audio Grade ABS resin. Hvordan skal det kildesorteres? Er det restavfall eller kan jeg sortere den sammen med annen plast?
    SiSt
    Hamar
    Rart hvordan så mange av produktene i dette segmentet tilfeldigvis retter seg mot de delene av kjeden som folk håndterer selv. Kabler, kontakter, vekter, føtter, kabelholdere (forbannet være dagen jeg lærte at dette fantes), kvanteresonatorklistremerker...
    Skulle tro det viktigste var hva som foregår inni komponenter og fysiske egenskaper ved rommet høyttalerne står i, men dette tyder jo på at så ikke er tilfelle.
    Pink_Panther
    Må jo være bra. Nano Crystal Formula, eller NFC.
    DagT
    Tenker at innovasjonsavdelingen hos Furutech har det hysterisk morsomt :ROFLMAO::LOL::ROFLMAO:
    En slags innovasjon er det jo :cool:
    Forøvrig ser det ut i videoen som om da har en platespiller på en eller annen plate for å fjerne vibrasjoner. Deretter setter de "dingsen" direkte på benken, ikke på den vibrasjonsdempende platen, og overfører da effektiv vibrasjoner fra benken og opp i platespilleren via kablene. På en eller annen måte må da det motsi deres egne argumenter?
    PeriodeLytter
    Ted Denney er ei klyse så det holder, men akkurat den utfordringen var vel ganske square and fair, var den ikke det?
    He he :) Ser du gjengen bak ham. Ikke tilfeldig de poserer slik, "du er velkommen her for å få litt skikkelig bank".
    Noen med wikipedia passord kommer kanskje til å oppdatere denne listen en dag ;)
    En viss Robet Stuart burde kanskje vært på den listen også ;)
    Singh
    Jeg har lagt merke til at flere kabelprodusenter har kontakter som er unormalt store og tunge og som ofte blir hengende bak stereokomponentene. Strøm og høyttaler kabler kan og være tjukke og uhåndterlige. Og da må man ty til støtter, nøyer meg med klosser i eik under noe av strømkontaktene og det holder i massevis.
    P
    parafinoksen
    Jeg slettet innlegget mitt fordi jeg fant ut at jeg ikke orker å engasjere meg / diskutere feider.
    Pink_Panther
    Cables are treated with a process called Quantum Tunneling. This is a process that changes the way a cable conducts the signal at the sub atomic level affecting the entire cable assembly- connectors (RCA, XLR, Spade, or Banana), solder joints, dielectric and signal and ground conductors are all transformed and integrated as a single unit. By applying a two million volt extreme high frequency signal to a cable at a specific pulse modulation and frequency for an exact duration of time, Synergistic Research alters the entire cable at molecular level through a phenomenon called Quantum Tunneling. The before and after is startling with a lower noise floor and major improvements in inner detail, air, low frequency extension and overall transparency and signal speed.
    Quantum Ground Lifter - Synergistic Research
    Quantum tunnelling - Wikipedia
    Finnes det virkelig noen som går på dette?
    Han la ut den videoen etter at det er en "rettslig" sak mtp at kontakten mellom "partene" foregår via advokater.
    Selvsagt vet han at svaret må bli nei. Den videoen er ikke noe annet enn pur ondskap for å sette Gene Dellasala i dårlig lys.
    Snickers-is
    Kunne vært interessant å sette opp et in-room stereoopptak av et stereosystem, spilt inn med og uten dette tullet, og sammenliknet filene etterpå.
    Uansett, bare rundt 1000kr stk for plastmynter må være et kupp...
