Diverse Kjøpt ny sub, men fulgte med rar dings?
GSi-Turbo
Heisann har kjøpt meg en Klipsch sw-311. Og i esken lå det en "ARC-M1" Adaptive Room Correction Microphone. Antar den skal kobles inn i subben, såpass glup er jeg. Men der stopper det. Hva skal jeg så gjøre?
Laban MK3
Plankebyen
Vil tro mic skal inn på sub på panelt bak :) så kjører du subwoofer kalibrering til rommet igjennom menyen på sub .
Vill gjetting
GSi-Turbo
Vill gjetting
Joda koble til bak er greit, men har ikke bruksanvisning. Så hvor skal denne målemiccen være? oppå subben eller?
jorwed_
Audio Arkeologen
Nordre Follo
Huff det ble jeg opptatt ett par timer med lesing ser jeg, men takk for hjelpa :) Syns egentlig den spiller veldig bra som den gjør da. Bare flaks jeg fant den miccen når jeg skulle fjerne tom-eska isted.
Sånn:
"“Room Correction”
- This screen is used to activate the automatic room correc- tion feature.
Plug the supplied microphone into the “MIC IN” jack on the sub- woofer’s rear panel and place it in the intended listening position.
Press the Enter ( ) key to start the room correction sequence. “Measuring” will be displayed along with the frequency being measured and a graph of the measured sound level.
When the measurement is complete, “Analyzing” will be displayed while the subwoofer analyzes the effects of the room’s acoustics and compensates for them.
A bargraph will indicate the progress of the correction. When the correc- tion has been successfully applied, “Room Correction <ON>” will be displayed. If the room is noisy or the mic is disconnected or not operating correctly, “Correction Unsuccessful” or “Please Check Mic” may be displayed. If this occurs, check the microphone placement, try to reduce the noise in the room, and run the correction procedure again. The procedure duration may change depending on how much correction must be applied. To cancel the procedure, press any key."
AOC
Kjører du med veska hengende på uttrekt shoke-spak også, eller? ;-)
Reaksjoner: LMC
GSi-Turbo
Sånn:
"“Room Correction”
Så da skal jeg legge miccen på sofaputa der jeg sitter når jeg hører musikk med andre ord. Ja kan hende jeg prøver det imorgen. Takk for hjelpen uansett :)
GSi-Turbo
Ja kan ikke si annet, sminkespeilet er også nedfelt så her går det bra skjønner du :)
SvenO
Eydehavn/ Arendal
Sånn:
"“Room Correction”
Herregud man, en slik kalibrering kan gjøre noe veldig bra. Tar vel ca. 1 til 2 min å utføre......
