Kassett-spillernes venner
  • Terje-A
    Chaiya, Thailand
    Terje-A: Jeg har brukt alle mine. Men du kan nok regne med at den Technicsen holder noen år- selv jeg bruker direktedrevent mer enn jeg hadde trodd jeg skulle gjøre her. Spørs bare om du fikk den for betalbare penger. Kjenner jeg deg rett, så gjorde du det Grattis, Jeg har faktisk hatt øya ute etter en av de der selv. Og vurderer en SL1900 også..
    Betalte godt under tusenlappen, frakt og moms kommer i tillegg, disse er billige foreløpig. De har gått under radaren i motsetning til f.eks. Sony ES, Nakamichi, Pioneer og Akai.
    4 innlegg på Tapeheads;
    "All this series of Technics decks, 565, 665, 765, 965, 707, 808, 828, are designed around the same IC for rec/playback/line amp and muting/switching."
    "RS B565/555 is considered to be best sounding in those models, probably because the simplest signal path, there is no notorious 4066 switching ICs, only AN7351K and Philips TEA0665 Dolby IC."
    "The RS-B models were superior to their equivalents in the later RS-BX series. Better heads and better construction to begin with. Of course you have to compare apples with apples. For example I used to own an RS-B905...which was the direct replacement of their highly sought after B100...and the B905 was IMO a better (if not much better) deck than the BX828 and 808. I have never compared it to a B965 but that is not a BX piece.
    True the newer ones may have some nicer features and perhaps be more stable and reliable on the electronics side, but overall the 1990s saw many if not all manufacturers cheapening their cassette decks (electronically and mechanically) and often masking the quality with better marketing."
    "In its original state the RS-B565 is better sounding deck by far than any other deck of the BX- series. Main difference are: dolby chips and presence/absence of the 4066 switches. The 555/565 has better dolby chips and not even a single 4066 cmos switch. One of the best playback decks out there (sold my 3 head Naks to make more place for those 555/565 ;-) "
    Terje-A
    Chaiya, Thailand
    Ang vectoren så har jeg nå døpt denne fjæren:
    Vis vedlegget 549587
    til Artigfjæren
    Den er H I N S I D E S morro og montere tilbake i mekanismen.. Ingen sure miner i det HELE tatt når den ramler av og gjemmer seg nede i leamikken for 17 gangen på 1 time.. Bare fryd og gammen så langt øyet kan se..:mad:
    Denne har forøvrig et annet problem jeg oppdaget når når jeg prøvde å ta opp på dette decket. Erase hodet virker ikke.. Men det var faktisk noe så enkelt som at en lodding hadde løsnet under selve hodet. Nå greide jeg faktisk all form for vedlikehold uten å ta ut transporten men da blir det en runde imorgen med full demontering skjønner jeg. Får håpe på dritvær.
    Jomjom79
    He-he, been there, done that, bytta reim på en Onkyo og hadde akkurat det samme sirkuset med den. Du får telle til ti og tenke på noe hyggelig:)
    Auditor
    Terje-A, Frog: Vel, det ser ut til at alle får fiksa det de setter seg fore her. Og både Vector og Technics lever videre. Ikke verst, bare det. Har fått bekreftet overtagelse på de siste 85x av normalpartiet idag, så nå er det ikke lenge til høsten bare kan dukke opp for min del:cool:
    Terje-A
    Chaiya, Thailand
    Er det TDK D du har inngående eller er det Maxell UR?
    Auditor
    Terje-A:
    Maxell UR, 1998, såkalt "Original UR" i rød/grønn foil x35. Made in Korea, skulle jeg tro.
    Maxell UR, slik vi ser den på Clas Ohlson idag (uviss versjon, mest sannsynlig Panggung, Indonesia) x50. Disse kan også være Saehan- eller ungarskproduserte
    Emtec FE-I-90, kinesiskproduserte, x30. Spansk parti, fra Tarragona, ES.. I tillegg har vi fortsatt igjen litt av Henderson-partiet med samme type timesbånd.
    Totalt: 115 stykker på ingång. . Alle er halvannentimere, forøvrig.
    Selvfølgelig hadde det vært rått om dette var amerikanske TDK D´s eller inhemske, japanske Denon DXer, men så svære partier er umulige å oppdrive for betalbare penger. Da må jeg slå sammen flere, og ta inn 200 i gangen. For minst 5000,- Too much for Type 1´s...Da har du langt større sjans for det med en kartong HF eller to..
    Når høsten er godt igang, og prosjektets fase 1 er over- five years in the making-, sitter jeg med totalt 110 normaler, hvorav 50 Maxell og 60 Emtec.pluss en del RAKS, Fuji DR og TDK D på annet sted, uten foil, ubrukte.
    Type II har jeg da 135x av, Type IV nesten 60...Det har gått HARDT utover chrome-beholdningen her de siste fem år. Men jeg greier fortsatt å holde et anstendig antall.
    frog79
    Vector in ordnung
    Nesten...
    Tok ut transporten og måtte fjerne alle de fjærbelastede knappene i tillegg for å komme til slettehodet... "Sproiiinng!"
    Det ble noen timer for å sette sammen det puslespillet da jeg ikke har service manualen med diagram over delene, men jeg greide det tilslutt.. Loddingen gikk også greit og nå sletter den som den skal gjøre.
    Som en litt morsom fotnote så tok jeg dette opp med en kamerat der jeg fortalte at Sandra ble tatt opp over Paul Hardcastle uten at noen av delene ble slettet. Han foreslo at jeg burde ta opp noe Dark Ambient over alt dette slik at jeg kanskje åpnet en portal til helvete.. Ingen 80s fan denne mannen nei.
    Greide derimot å grise ut capstan beltet med olje under montering så måtte rense det med iso med det resultatet at beltet røk under rens. Var ingen symptomer på at beltet var slitent før det røk. Men det er forsåvidt greit at det ryker nå før jeg evt selger det og en annen erfarer det 2-3 mnd etter kjøp.
    Nytt belte bestilt ifra Thakker.
    Gleder meg allerede til å erfare Artigfjæren på nytt igjen.....
    Frog79
    Terje-A
    Chaiya, Thailand
    Thakker fungerer bra. Så det ordner seg nok.
    He-he, nå har jeg 970ES og A3ES i benken og gleder meg til å få B565 inn døra. Artig med noe å mekke på igjen. Sonyene er jo ship-shape. Skal prøve å poste noen innlegg om denne da dette kan være en billig inngangsbillett til kassetthobbyen. Det er ikke nødvendig med en super duper Sony eller Nakamichi til ti tusen for å ha glede av dette sære greiene vi driver med.
    Det har dumpet inn noen kassetter de siste dagene men jeg tenkte å samle alt sammen til en feit post senere.
    Auditor
    Terje-A, Frog: Masse moro både i Technics og Vector. Glem å bruke type IV, så går det nok helt knall, det...ALLTID nye gummideler der det er mulig, gutter...
    torstej
    Hei alle!
    Jeg nylig blitt interessert i kassetter og kassettspillere igjen. Er en konsekvens av at jeg har blitt inspirert av Techmoan på Youtube, kombinert med at jeg liker å reparere ting som er ødelagt og ønsker å gjenoppleve litt av barndommen, men med i denne kontekst ingen økonomiske hindringer for å teste det man vil (i barndommen var jeg som regel blakk). Og gøy å oppleve hvor god lyd man kan få fra en hifi-kassettspiller med gode opptak.
    Jeg har fått tak i en defekt Sony TC-K711S som jeg har gjort følgende med:
    • Byttet alle 3 beltene
    • Byttet begge pinch rollers
    • Byttet capstan-motor (tilsynelatende defekt lager på den gamle)
    Nå er den i gang igjen, men det er støy på linja. Jeg mistenker at det er p.g.a. den nye motoren, som er en billig kinesisk kopimotor. Jeg vil uansett kvitte meg med den, for det er ikke mulig å justere den så lavt ned at jeg får riktig hastighet. Jeg vurderer å kjøpe en motor fra Pacific Stereo på tapeheads, men ser for meg at det blir ganske dyrt. Det er ikke tilfeldigvis noen av dere som kan ha en brukt fungerende motor liggende, som jeg kan kjøpe? Original-motoren er merket MMI-6S2LKS (lappen er revet opp på bildet under, men det var det nummeret jeg leste av før jeg "lekte" meg litt med den)
    Motorhome
    Sunndalsøra
    Hei alle!
    Vis vedlegget 549864
    Vis vedlegget 549865
    Vis vedlegget 549866
    Jeg har også en slik SONY kasettspiller:)
    Auditor
    Torstej: Sony-mannen over alle andre her er Terje-A. Hvis den motoren finnes, vet han hvor den er å få tak i. Så spørs det, da, hvor mye annet som eventuelt er problematisk med den. TCer og ESer er ganske så forskjellige dyr , hva angår mekanisk kvalitet.
    Terje-A
    Chaiya, Thailand
    Hei,
    Jeg har bl.a denne; Er fra en 3 hoders, 2 motors maskin fra Sony rundt år 2000, muligens litt før. En TC-K sak i hvertfall
    torstej
    Ja spennende å se hvor bra den blir til slutt. TC og ES er nok forskjellige dyr ja, men TC-K711S har i det minste TCM200-transport som er samme type som mange av ESene har. Da jeg byttet belter brukte jeg denne videoen av en TC-KA3ES som steg-for-steg-guide. Ellers har jeg skjønt at ESene generelt gjerne har bedre hoder, bedre motor (quartz controlled direct drive) og generelt bedre elektronikk.
    Det jeg bekymrer meg mest over er at jeg ikke har utstyr for å fininnstille transporten, har lest man må må gjøre dette etter at man har byttet venstre pinch roller. I det minste fininnstille høyden på pinch rolleren. Så langt har jeg bare grovjustert høyden på den slik at lyden høres ok ut i mine ører, kassettbåndet går fint, og kalibrering og opptak fungerer ok.
    Skulle ønske jeg hadde et ordentlig måleverktøy sånn som denne WHS-300A. Hvis jeg får tak i en motor og alt annet er ok, så kan det hende jeg hoster opp pengene. Men det sitter langt inne...
    Terje-A
    Chaiya, Thailand
    Har denne også.... Du kan jo sjekke litt til:)
    Edit,
    Ser nå at det er samme motoren..:p men bilder pynter vel opp litt uansett.
    torstej
    Ja, og bildet illustrerer godt (en av grunnene til) hvorfor jeg i utgangspunktet ikke kan bruke den som en ren erstatning, man kan se den oransje hastighetsjusteringsskruen på kretskortet - den er ikke på selve motoren :)
    Auditor
    Torstej: Kontakt Teletor i Oslo, du...Koster litt , men det KAN være verdt å få ham til å se på den.
    frog79
    Hold et øye med denne siden
    https://elektronik-lavpris.dk/p140463/mmi-6s2lk-dc-motor-12v-34x25mm/
    De er tomme for øyeblikket men det kan jo hende de får inn på lager igjen. Jeg ville sendt de en mail.. Jeg kjøpte en tilsvarende ifra de for et år tilbake eller noe slikt, endte vel opp på litt over 200 lappen sendt ifra Århus.
    Det er igrunn en ganske vanlig motor dette så det kan hende man kan kjøpe et billig deledeck og bruke motoren derifra og. Jeg skal si ifra om noe dukker opp. Har du prøvd en liten dråpe olje på den originale motoren?
    Jomjom79
    torstej
    Ja det er sikkert det lureste. Men foreløpig er det altfor gøy å prøve ting på egenhånd.
    torstej
    Terje-A: Kunne du tenke deg å kvitte deg med en av MMI-6H2LWK-ene for en liten sum? Jeg har lyst til å prøve og se om jeg kan lage en fungerende motor ut av de to. Flytte kretskortet fra min MMI-6S2LK over i MMI-6H2LWK-en. Muligens bytte børstene også dersom de i MMI-6H2LWK-en er bedre og samme type.
    frog79
    Jeg har "fikset" noen bråkete motorer ved å dryppe en liten dråpe symaskinolje rett i lageret under trinsen. Men ikke overdriv.
    Koble den opp på en ekstern strømforsyning og la den gå i 1/2 time etterpå med motoren liggende flatt på et bord.
    Verd ett forsøk om ikke annet.
    Edit: Ok, så videoen nå og det der er verre enn de jeg har holdt på med så mest trolig fubar. Men prøv uansett. Blir ikke mer ødelagt enn ødelagt.
    Jomjom79
    frog79
    Prøvde du forresten motoren med de nye beltene? jeg har vært borti motorer som lager et helvetes leven uten last men som har blitt stille når de får noe å jobbe med.
    Jomjom79
    torstej
    Jomjom79
    Nei, jeg avfeide den som defekt uten å vie den noe mer oppmerksomhet. Mulig det var en feil, men gjort er gjort. Nå er den demontert :)
    Auditor
    Torstej: Vær forsiktig, så du ikke risikerer for mye...
    Terje-A
    Chaiya, Thailand
    Vis vedlegget 549981
    Det går bra, det blir broren til gratis:D, men den må jo komme til deg på en eller annen måte. Jeg sender deg en PM.
    torstej
    Takk for tipset! Tingen er at jeg har 2 stk 711er, og den jeg leker meg med nå kjøpte jeg i utgangspunktet for å ha som delemaskin for den andre. Så tenkte jeg at jeg ville få liv i den igjen, både for å se hvilke deler som er brukbare, og for å lære meg hvordan en kassettspiller fungerer. Dersom jeg skulle ødelegge noe på den i prosessen, så er det ikke noen krise. Det er en kalkulert risiko :)
    torstej
    Nå har jeg forsøkt å lage en fungerende motor ved å flytte kretskortet fra min herjede MMI-6S2LK over i en MMI-6H2LWK som jeg kjøpte av Terje (håper du koste deg like mye med seigmennene som jeg gjorde med dette lille prosjektet :) ).
    På den positive siden så endte jeg faktisk opp med en motor som gikk rundt:
    Den negative siden, som egentlig er mest gøy, er at den høres slik ut. :D
    Det var vanskelig å sette sammen motoren uten å skade de syltynne børstene (eller hva man nå skal kalle de). Kanskje andre ting som gikk fløyten i prosessen også. Nå har jeg bestilt ny motor fra pacific stereo.
    Utover at det var gøy å prøve, så fant jeg ut noe nyttig også. Det var den billige kina-kopimotoren som forårsaket støy på linja som jeg har slitt med, for den støyen var borte etter at "frankenstein-motoren" ble montert inn.
    Terje-A
    Chaiya, Thailand
    Vi får prøve et innlegg til, denne gang forhåpentligvis med bildene riktig vei. (Slettet forrige innlegg)
    Igår dukket min nye billige kassettspiller opp fra det store utland. Denne kom med eBay frakt (Pitney & Bowes, de ordner alt sammen og alt sammen betales via eBay/Paypal). Dette fungerer aldeles strålende til en grei pris. Men jeg var spent på om spilleren var ok, (selger mente at den var i 100% working order.) Pakket opp i dag, sjekket pinchroller og lydhode, så litt møkkete ut, fant frem litt fra skuffen, og jepp, det var møkkete så det holdt. Legg merke til de audiofile bomullspinnene i ekte tre fra Audio Technica;)
    Nå var det tid for å koble opp, slik ser spilleren ut når vi blottlegger hoder og pinchroller.
    Satt inn en Sony HF tape med Chet Atkins og Mark Knopfler, det låt virkelig bra. Helt topp. Fikk bare testet med headsett da jeg venter på kabler som gir meg mulighet til å koble rca til xlr. Da denne må kobles til en av de balanserte inngangene på C49. De 3 andre rca inngangene er opptatte, greit med mange innganger, det gir muligheter til å ha mange gosaker tilkoblet:)
    For meg ser dette ut til å være en skikkelig "Bang for the buck" sak. Ser at det ligger flere på eBay til rundt tusenlappen, jeg ga litt mindre for denne, men vi snakker om spillere som kommer totalt på 1500-2000 kroner. Egentlig bare peanøtter i denne hobbyen. Blir spennende å sjekke mer når jeg har fått koblet opp denne til anlegget og prøvd forskjellige typer tape. Så langt høres og ser det bra ut;)
    Auditor
    Terje-A: De der har visst gode Type IV-opptak også...Men poenget med den er og blir direktedriften. Grattis. Ganske utrolig hva litt lett vedlikehold avstedkommer. Pioneeren min måtte renses, den og. Det så forøvrig ut til å ha vært et kilo partikler på lydhoder og rollers der. Men siden den rensen har den da også funka helt gull. Det tipper jeg Techncsen der gjør også. Lagt ut etter å finne en 810 til, forresten...
    Terje-A
    Chaiya, Thailand
    Takk for det Auditor, tror nok det kan være greit å få tak i det man trenger snarest, både av tape og spillere. Det går tusenvis av spillere på fyllinga, og tapen blir ikke akkurat billigere med årene.
    Auditor
    Terje-A: Jeg har reima også, hvis den må skiftes..
    Det er nettopp derfor lagreret mitt er såpass stort og omfattende..hehe--Jeg har decks av forskjellig beskaffenhet også.
    Siggen84
    Fersking
    Nakamichi MR-1
    Hei!
    Første post her. Har en Nakamichi MR1 som nylig sluttet å spille på den ene siden. (det er lyd i begge sider når jeg lytter direkte til kilden jeg skal ta opp gjennom spilleren) Den har også litt små issues: noen ganger virker ikke rewind knappen (må hjelpes litt i gang) Led meteret virker ikke, noen kasetter støyer/rister endel når de går rundt og varispeed funksonen er av og til uforutsigbar. Jeg har vært litt inne på tanken på å kjøpe en ny spiller siden jeg ikke har nok kunnskap selv til å fikse den, men aller helst vil jeg få den reparert da det var fantastisk gøy å høre på den da den fungerte. Jeg har bla.a. hørt med dalens elektronikkservice osv, men de ville ikke ta på seg oppdraget. Er det noen her inne som har et tips til hvem som kan se på denne evt har lyst til å prøve å fikse den? Mvh Sigurd
    Terje-A
    Chaiya, Thailand
    Hei!
    Teletor tar den, han holder hus rett bak Aker sykehus.
    Teletor
    Auditor
    Siggen84: Bare å levere den til Teletor først som sist. Koster litt, men det er den der verdt. Kassettspillere i den klassen- med XLR og det hele- er sjelden vare, og de som er skal og må tas vare på...Omtrent bare Naka og Tascam-Teacs proffmerke- har implementert XLR til avspilling av MC-formatet.Og det høres også....
    Siggen84
    Fersking
    Takker for svar. Da er jeg vel mere eller mindre overbevist om at det er verd å bruke litt penger på å få den i stand. Kanskje et vanskelig spørsmål å svare på, men har noen her erfaringer med hva en slik service hos Teletor kan komme på? 2-4 tusen kan jeg vel strekke meg til å forsvare, men går det mye over det kan jeg jo kjøpe en veldig bra nyoverhalt kasettspiller i stedet. Mens jeg først er her; er det noen som har en god kilde til (gode) optakskasetter? nettbutikk eller lign.? Det jeg har funnet til nå er kun ebay og det kan fort bli dyrt (ca200kr) for en uåpnet metal type kasett. mvh Sigurd
    Terje-A
    Chaiya, Thailand
    Det du kan strekke deg til holder er min erfaring :D, og det finnes ikke noe sted å finne rimelige metal tape kassetter. Jeg har handlet en gang fra en butikk i Florida for flere år siden. Da ble det en kartong med Sony XR metal tape som kom fra det amerikanske forsvaret. Det er lenge siden. De siste årene har eBay vært min kilde for metal tape. Cassettecomeback og Tapeline har noe vanlig, chrome og metal på sine nettsider. Nå er det bare eBay for meg....
    Auditor
    Siggen84: Hvis du kun vil ha type IV, forbered deg på å betale MYE for hver av dem...Nakamichi er ett av merkene som for eksempel storkoser seg med bånd fra TDK. Det var nemlig TDK som produserte bånd for Nakamichi. Fordelen med MAene derfra (TDK) er at de fortsatt er tilgjengelige i anstendige kvanta. Jeg har for eksempel atten av dem selv- ink en MA-XG. Dessuten er de veldig fleksible. Men ,altså, relativt kostbare. En MA-XG koster 1000 kr stk. MA60, MA110 går for 600 kr stk. Da kan det være like bra å søke krombåndet SA-XS....ca 300 kr stykk...De har jeg tjue av.
    Terje-A: Hva skjedde med den XR-eska du overtok fra meg?
    Terje-A
    Chaiya, Thailand
    Siggen84: Hvis du kun vil ha type IV, forbered deg på å betale MYE for hver av dem...Nakamichi er ett av merkene som for eksempel storkoser seg med bånd fra TDK. Det var nemlig TDK som produserte bånd for Nakamichi. Fordelen med MAene derfra (TDK) er at de fortsatt er tilgjngelige i anstendige kvanta. Jeg har for eksempel atten av dem selv- ink en MA-XG. Dessuten er de veldig fleksible. Men ,altså, relativt kostbare. En MA-XG koster 1000 kr stk. MA60, MA110 går for 600 kr stk. Da kan det være like bra å søke krombåndet SA-XS....ca 300 kr stykk...De har jeg tjue av.
    Står i hylla med god musikk på selvfølgelig :D
