Høyttalere Hva rettferdiggjør de ekstreme priser på mye utstyr, spesielt høytalere?
Virgo
Hvor mye koster egentlig en Mega $ høytaler å produsere/lage og hvor dyre komponenter rettferdiggjør noen tildels sinnsyke priser ? Jeg fant denne:
As expected Hi-End multi-ways loudspeakers costing in excess plus 20,000 dolars, use cheap drivers, which cost few dolars for a pair of floor standing loudspeakers.
Example:
Peak Consult Zoltan - MRSP 34,995/pair
Tweeter - ScanSpeak Soft Dome with SD-2 magnet - approximately $200
Midrange - AudioTechnology 5" midrange - approximately $275
Woofer - AudioTechnology 7” woofer - approximately $500 each x 2
Total cost of drivers per pair = $2950
Joseph Audio Pearl - MRSP 23,500/pair
Tweeter – Seas Millennium - approximately $185
Midrange – Seas Excel 7” Magnesium Cone w/Copper Phase Plug - approximately $165
Woofer – Seas Excel 8” Magnesium Cone w/Copper Phase Plug – approximately $190 x 2
Total cost of drivers per pair = $1460
Wilson Audio Watt Puppy - MSRP 27,900/pair
Tweeter – Focal Tioxid Dome - approximately $100
Midrange - Scan Speak Carbon Fiber 6.5” – approximately $150
Woofers – Dynaudio 9” (21W-54)* - approximately $150 each x 2
Total cost of drivers per pair = $1100
*(Dynaudio no longer supplies drivers to the loudspeaker industry; however, they continue to supply a few manufacturers with whom they had a previous relationship)
Eggleston Works Andra 2 - MSRP 19,500/pair
Tweeter – Dyaudio Esotar – approximately $325
Midrange – Morel 6” MW166 - approximately $105 each x 2
Woofer – Dynaudio 12” – approximately $200 each x 2
Total cost of drivers per pair = $1870
Avalon Eidolon Vision - MSRP 23,950/pair
Tweeter – Accuton 1” C12 Ceramic Dome – approximately $190
Midrange – Accuton 3.5” C90 Ceramic – approximately $280
Woofer – Eton 11” Hexacone – approximately $275
Total cost of drivers per pair = $1490
Verity Audio Sarastro - MSRP 29,995/pair
Tweeter – Raven R1 – approximately $250
Midrange – AudioTechnology 6” midrange – approximately $390
Woofer – AudioTechnology 11” woofer – approximately $550
Total cost of drivers per pair = $2380
Sikkert flere her inne som har sett den, men er dette gjennomgående i flere dyre produkter? Mye av det megadyre jeg hørte på Munchen var imponerende ja, men skyldes dette høytalerne, ekstremt dyre forsterkere, cdrigger, strømrensing, rommet, eller comboen av alt det..hvordan hadde billige høytalere hørt ut, med mye av det utstyret? kanskje like imponerende?
Noe av det mest imponerende, var ofte de små systemene, med langt billigere utstyr. Er høytalere til enhver tid verdt det, som produsenter antagelig vet at ultrarike uansett vil betale for et par? Nye Coltrane til en million ser jo flotte ut, men låt ikke særlig bra..synes jeg da..Hvilke produsenter bruker komponenter, som faktisk rettferdiggjør en milliondollar priser?
Syncrolux
Jeg vil tro komponentprisen som produsentene faktisk betaler er langt lavere enn dette også, da det kan se ut som "butikkpris" for DIY-markedet er oppgitt i eksemplene over?
Virgo
Lavere enn dette også..hmm..
Er det da eventuell ideutvikling over lang tid, betaling av arbeidere og utstyr til bruk i utviklingen som står for det meste av kostnadene? Jeg prøver bare forstå hva som egentlig gjør at noe koster 100k og 1 million, uten at derved lydforskjellene er marginalt bedre på den dyrere..
kortvarig
Banned
Danmark
Du skal gange det producenten for med mellem 5 og 10 gange for at få butiksprisen.
Så midi hi fi er faktisk relativt billigt, du kan lave det samme regnestykke med landmandens korn , her betaler du også ca 10 gange mere i butikken for et kilo korn end det landmanden for.
Sådan er det desværre , der er en masse "snyltere" på vejen fra producenten og til dig. forhandler, grossister, staten moms afgifter osv.
Og min erfaringen er at ingen bliver stinkende rige af hverken at producerer eller sælge hi-fi , pengene bliver bare brugt.
Syncrolux
Det kan du jaggu lure på.
Det er kabinettet som er den dyreste komponenten i en fancy høyttaler, ofte langt mer inn resten av innmaten.
baldrick
Mark Levinson/Beyma:
Siden jeg holder på med JBL Everest kopier vet jeg litt om delepriser på de og det er ikke billig. Synes likevell det var stor forskjell også der på deler og komplett deler men på langt nær så ille som dette overfor. Ferdig JBL Everest høyttaler koster i Norge ca 450.000, de fleste delene (uten kabinett) kommer på ca 125.000.
Virgo
Magico har nanoteknologi, kanskje bare det koster flesk å lage? Det er nok ikke noe nytt emne jeg kommer med, men tenker litt på det med priser til tider. Merker at det er lett i denne hobbyen å stadig ville ha dyrere ting, men helt ærlig, mye av det langt dyrere jeg har hørt å testet, har ikke vært særlig "bedre", men kanskje gitt enda mer eierglede mht design og denslags..for 658k kunne jeg kanskje bygget et noenlunde perfekt lytterom, og satt inn et "middelmådig billig utstyr" ?:)
Syncrolux
La oss nå si at du kjøper den Beyma 18P80nd bassen rett fra fabrikken, noe en høyttalerprodusent selvsagt kommer til å gjøre. Hva tror dere den koster? Jeg tipper ca 1000 kr.
Audiomix
Rart du ikke nevner fisk og olje......................
Langt mer en 10x og noen blir veldig rike.
Virgo
Snakket med en medarbeider av ham som står bak Gaudner akustik i Munchen. Han sa det var brukt Cray supercomputing i utformelsen av designet, som nesten hadde stått konstant å beregnet i 6 måneder hvordan lyden i kabinettet oppførte seg...så bare der kan jeg være enig i at kabinettdesginet og det videre praktiske arbeidet for å lage dette, er temmelig dyrt..?
J
Jim.I.Hendriksen
Utsikt over BMW welt, koster penger å holde dette i gang.....
J
Jim.I.Hendriksen
Koster ca. 560-600k....
Koster 698k....
Den dagen Magico begynner å produsere høyttalere i serier på 100000 går nok prisen ned der også...
Da stiger den nok enda mer skal du se. Og når man vet at ca. halvparten av bilprisen er avgifter så ser det enda dummere ut.
Og bare så det er sagt, har ingenting med Magico spesielt å gjøre, det er haugevis med eksempler der ute.
W.Sand
moelv
Bli klok på pris?
Vann på flaske koster ca 20 kr/l. Bensin kr 15,xx. Høyttaler er ikke volumvare og krever mye håndtering (volum/frakt x flere ledd). Ingen gullgruve for de som gidder.
Strategisk prising er så mangt.. Hype, status, målgruppe , redde momsen-salg osv. (går det, så går det- metoden ?)
Audiomix
En skal ikke tro på alt det en hører.
Ikke når det gjelde HiFi heller:)
Laksevåg - Bergen
At noen tjener mer penger enn andre er helt klart. All handel/fortjeneste går neppe kun for seg "oppå bordet". Denne yachten ligger for tiden i Bergen - ser rett over på den der den ligger utenfor Sandviken. Den heter "Eclipse", og eies av Roman Abramovich. Han eier også fotballklubben Chelsea. Båten har et mannskap på 70, har 2 helikopterdekk, 4 "småbåter" ombord, og er ellers stappfull av luksus. Den kostet 340 millioner Euro i 2011. Skulle du være så uheldig å overta denne båten med tomme dieseltanker, er det ikke bare å svinge innom en marina å be om "foull tank ja" - Tankkapasiteten er 375000 liter x ca.13,50 pr.l. ---- kr 5,062500,-. Men været får han ikke gjort noe med. Han har 10 +, regn og vind han også :)
chris33
Østlandet
Hvem her kunne kjøpt elementene, simulert, bygget kasse og delefilter og fått til noe like vellydende? For ikke å snakke om finish.
Liten digresjon, men Gillette gjemmer seg alltid bak FOU biten når det stilles spørsmål rundt forskjellen på produksjonskostnad og utsalgspris. For min del kunne de lagt ned den avdelingen og heller senka prisen til en fjerdedel.
Syncrolux
Det første punktet er ikke så vanskelig. Det andre er betraktelig værre... å få en industriell finish hjemme i garasjen er ikke helt enkelt. Men på den annen side kan man lage noe helt unikt som ikke er mulig å produsere industrielt.
DagT
For min del har jeg noe, men ikke nok, kunnskap om elektronikk og akustikk til å få det til uten å lese meg opp på området, om jeg skulle lage noe som var bra. Så om jeg skulle ta den timeprisen jeg bruker på jobben og gjetter på hvor mange timer jeg ville brukt på å laget et godt sett med høyttalere, så finner jeg fort ut at det er mer lønnsomt å jobbe for å tjene nok penger til å betale for mer effektivt produserte høyttalere.
Syncrolux
Alt blir veldig mye enklere hvis man starter i riktig ende; dvs bruker aktiv deling og DSP.
Passiv deling er bare et kompromiss rent teknisk og lydmessig, men dessverre nødvendig for at det skal være mulig å selge høyttaleren som en uavhengig komponent.
Ulf-B
Hva koster en dings?
1. Den koster det noen er tøff nok til å forlange, og noen er villig til å betale - altså en markedspris
2. Den koster det noen synes den er verdt å betale for - en opplevd nytte. I hifi blir det rimeligvis primært snakk om en opplevd lydforbedring, men nytte kan jo også ligge i opplevd eierglede, og - naturligvis - opplevd status.
3. Den koster det produsenten finner ut at den koster å få solgt. Lønn og materialer - men også produktutvikling, markedsføring, salg og distribusjon, fininsiering, garantikostnader etc. etc.
Den som selger et produkt vil vanligvis være interessert i å velge den tilnærmingen til hva en dings skal koste, som gir høyest fortjeneste. Mens den som kjøper, normalt er ute etter å argumentere for den tilnærmingen som gir lavest pris.
Det er sånn markeder fungerer - også hifi-markedet.
vibberg
Dette blir offtopic, men du begynte ;) Jeg tror mange tilhengere av analoge kilder vil være uenig med deg her.
R.E.S.
Den villeste produsenten jeg har vært borti når det gjelder høyttalere var Xavian. Ikke vilt med tanke på at det var stor avstand mellom delepris og utsalgspris, men det stikk motsatte.
I en høyttaler som kostet rundt 16.000 kroner (husker ikke modellbetegnelsen) fant jeg elementer som om jeg kjøpte dem løst ville kostet nesten 7000 kroner. I tillegg var det et utrolig flott kabinett. Jeg skjønner fremdeles ikke hvordan de klarte å få det til å bli butikk.
Vanlig beregnet er som mange skriver er 10x delepris.
PS. Å lage en Fiat 500 koster visstnok bare 10.000 euro mindre enn å lage en Volvo XC90. Forskjellen i utsalgspris er litt mer enn det...
Roy
Syncrolux
Fordi man gjerne vil holde signalveien 100% analog? I såfall har man et veldig begrenset utvalg av musikk å høre på, i det vinyl har vært mastret digitalt veldig lenge....
Joppe
Sydpolen
det som forsvarer prisene er de som er villig til å betale dem.
man kan vel egentlig spørre seg om ikke hypex nc400 er dyr også, hvis man ser på komponentprisen isolert. grunnen til den relativt høye prisen og at den ikke bare slappes i et greit fint kabinett og selges i massivt volum er vel fordi de tjener mer på å la den være litt kostbar og så tjener godt på oem-delen samtidig. om nc400 og nc1200 (ble sluppet fritt og) ble solgt med lavere margin og relativt billig, så er det jo mye som tyder på at det ville kannibalisert markedet ekstremt. det er en terskel for å kjøpe nc400 fordi man må legge til litt selvinnsats og man må source kabinett, kontakter og alt mulig.
det hypex har, som de andre eksemplene i tråden nok ikke har er dokumentert ytelse som kan forsvare den da komparativt sett lave prisen.
eksemplet med mark levinson er kledelig og mannen fremstår som en stor bløffmaker.
selv har jeg blitt mindre og mindre hifi etter å ha begynt med dsp og diy, og er nå så lite hifi som man kan få blitt. jo mer glorete og desto finere innpakning noe har, desto klarere blir det for meg at det er optimalisering av perceived value og ikke nødvendigvis den funksjonelle ytelsen som står i fokus.
hifiguru
Porsgrunn
JBL har visst bygd ny "lab" for utvikling av f.eks waveguides til 75 mill usd og de pengene skal de vel ha igjen et sted. F.eks i M2 som er den store siklesaken for min del som er to drivere, en waveguide og ei firkanta kasse til 150.000,- Uten delefilter!
HC
Hmm, I call bullshit. Har de kjøpt en Cray eller leid tid? Og 6 mnd prosessortid høres mildt sagt ut som bs.
Syncrolux
Hmm, I call busshit. Har de kjøpt en Cray eller leid tid? Og 6 mnd prosessortid høres mildt sagt ut som bs.
Det kommer nok an på hvor mye CPU-ressurser man er tildelt på maskinen også. Man har jo ikke hele maskinen for seg selv.... med lite nok ressurser så kan det jo i teorien ta så lang tid.....
Trondmeg
Se på lønnsslippen deres og vurder hva arbeidsgiver får tilbake og se det relatert til denne diskusjonen. Alle sier de er underbetalt, men sannheten er sannsynligvis det motsatte. Hehe
chris33
Østlandet
Det er det som er greit med offentlig sektor, alle kan være overlønna i forhold til innsats uten risiko for konkurs.
Imagine
osøyro
Ja det er dyrt og kjøpe hifi , men nå har vi alle våres måte og kjøpe hifi på :) Jeg angrer ikke på noe jeg har kjøpt + heile veien har jeg kjøpt nytt innen hifi , utenom denne dsp for subbene den kjøpte jeg brukt men fikk med 3 års garanti ;) Skal tippe det er mangen her inne som får hifi billigere enn antatt ny pris i butikk ;)
Imagine
Trondmeg
Vis vedlegget 324586
Koster 698k....
Vis vedlegget 324587
Masseproduksjon og solgt mengde. Gjett hva prisen på den BMWen hadde vært om den solgte i samme antall som høyttalerene, jeg tipper vi snakker om 100 gangeren eller mer.
selv om Ferrari er kostbart i utgangspunktet så lager de også noen one-off customs. De er dyre :). Antall/utviklingskost og markedsstrategi bestemmer nok prisen og ikke råvarene.
Syncrolux
Noen som jobber i offentlig sektor her som bruker "ledig" arbeidstid på å designe høyttalere? Kanskje derfor utviklingskostnadene er så store...
vibberg
Jeg har en god del skiver fra før 1980. Og det er endel her inne som sitter på analoge mastertaper. Og... en A/D-konverter som brukes i konvertering av analoge innspillinger for utgivelse er vel endel unna de du får kjøpt over disk. Men igjen, off-topic.
HC
Det som vel er sannsynlig er at noen i Gaudner på ett eller annet tidspunkt har studert ved et universitet som har hatt tilgang på litt CPU-tid og at man i ettertid bruker dette for alt det er verdt. Det å komme med "Cray computer" i sales pitchet er i seg selv noen som man sist hørte på 80-tallet.
hifiguru
Porsgrunn
Litt teit å blande biler inn her da man har lett for å tenke gatepris i Norge med avgifter. De Levinson/Daniel Hertz-kassene fikk jeg lyst til å bygge!
Class
Vestfold
Typisk tullete ting å si som ikke gir noen rell mening.
Cray lager superdatamaskiner.
Når man leier tid på en av disse maskinene velger man hvor mange 'compute nodes' eller CPU/GPU kjerner man trenger.
Det er et stykke fra å leie noen få cores til å beregne noe til å hinte til at man brukte hele clusteret til oppgaven.
J
Jim.I.Hendriksen
Koster 698k....
Og så? 600-700k er 600-700k og hvis man har det til overs så bruker man det på det man vil. Synes bare det er artig å sammenligne. Har ikke sagt det er feil verken med høyttaleren eller bilen.
