APL Hi-Fi.
  • SAL
    Spennende SAL! Det blir vel første gang et komplett APL anlegg presenteres i Norge?
    Takk yasman, ja dette blir virkelig spennende!
    Blir første gang for APL i Norge. Den nye DSD-Master riggen blir presentert der, lurer på om det faktisk blir verdens-premiere for den!
    Mvh.
    SAL
    Espen L
    Skien
    Hei!
    APL Hi-FI på Horten-Messa med selveste Alex Peychev tilstede!
    Best Western Horten Hotell, Rom: "Frisørsalongen" 26-27 oktober 2013
    Systemet vil bestå av:
    APL DSD-Master
    APL HAS-Master
    APL Gravitas NB-Master
    SAL
    Dette blir spennende SAL
    Artig at Alex også dukker opp.
    Mvh: Espen
    SAL
    Hei!
    Fikk litt mere info fra Alex!
    Hi!
    APL Hi-Fi will be attending the Horten Hi-Fi Show this October 26th and 27th.
    This will be "The World Premiere" of the entire APL-ILLUMI-FI audio system, first in Norway!
    The audio system will consist of the following:
    1. Gravitas NB-Master Reference Speaker System. It features a sealed sub-bass enclosure with one active and one passive Scan-Speak Revelator drivers. Paper-cone Revelator mid-bass units. Silk dome Revelator tweeters and Ribbon super-tweeters.
    2. DTR-Master digital transport prototype with our proprietary PCM-to-DSD converter. The transport also has "Pure DSD" stream coming from SACDs and DVD-R with recorded DSF files on it.
    3. DCT-Master computer audio transport prototype, capable of streaming DSD and PCM-to-DSD converted data to the DSD-Master via USB. It has Windows 8 (x64) with Intel quad-core processor without integrated graphics, 32GB RAM, 128GB SSD for the Windows operation system, and two mirroring 3TB HDDs for audio files only. USB-2.0, USB-3.0 and any memory card or external drive can be connected. e-Sata connection also available. Control through any hand-held device or keyboard. Internet connection is wired only through RJ-45 LAN connector.
    4. DSD-Master D/A converter with two S/PDIF inputs and one AES/EBU balanced, accepting up to 192kHz/24bit, that is further converted to DSD by our proprietary PCM-to-DSD converter with DSD64, DSD128 and DSD256, user selectable. Special triple-balanced DSD-only input for connecting the DTR-M transport, proprietary asynchronous DSD-only USB interface accepting DSD64 and DSD128. The DSD-M also features our own proprietary "Pure DSD" double-differential D/A converter. No off-the-shelf DACs. The balanced tube output stage with custom OFC audio output transformers made by Lundahl is also intact.
    5. PHS-Master phonostage prototype and my highly upgraded Technics SL-1210M5G with Dynavector XV-1s cartridge. The phono stage is MC-only with Lundahl OFC transformers and JFET/MOSFET input, followed by MUSES01 OpAmps and high-current MOSFET output stage, all working in "Class A". RIAA EQ is a split-type; half passive, half active.
    6. HAS-Master 3-piece hybrid amplification system with 6SN7, 2A3 or 300B tubes and IGBT high-current power converters. It has three RCA inputs and one XLR. The built-in attenuator unit is very unique, featuring Opto-controlled devices and non-magnetic resistors.
    7. Custom Power cables and Power Splitting Device.
    8. Audio Racks by Music Tools, Italy.
    Hope to see you there! We will have some great fun! Make sure to bring some of your favorite tunes for audition. CDs, SACDs and any other memory card or USB device containing any audio format will work. :)
    Best wishes,
    Alex
    I mine øyne blir dette stort!
    Her blir det noe for en hver smak når det gjelder kilde på øverste hylle, bakket opp av ekstremt bra komponenter!
    For dere med gode kunskaper når det gjelder elektronikk skulle det være mulig å få "bryne" seg litt på Alex også vil jeg tro?
    Mvh.
    SAL
    K◡kera
    Bra jobbet SAL!
    APL DAC-S in action..
    Mvh.【ツ K◡kera
    K◡kera
    ╠╣ello September!
    May it be a colorful month full of sunshine, joy and music. ~ ☼˘◡˘)))♪♫...
    Mvh.【ツ K◡kera
    SAL
    Endelig er APL DSD-Master klar!
    Jeg får min overrakt på Horten-Messa hvor Alex kommer til å benytte den som en av tre kilder!
    Gleder med som unge, dette blir et voldsomt løft.:cool:
    Mvh.
    SAL
    SAL
    Litt info om DSD-Master:
    Proud to announce the long-awaited
    finalization of the new DSD-M converter.
    The sound quality achieved is, in a
    word, magical.
    Features include:
    1. Proprietary PCM to DSD
    conversion engine with DSD64 (3.37MHz), DSD128 (6.75MHz) and DSD256 (13.5MHz),
    user selectable.
    2. Proprietary asynchronous USB input accepting DSD
    only in DoP format. You can stream native DSD64 and DSD128 files, as well as PCM
    to DSD converted files. The new JRiver 19 converts any file to DSD in real-time.
    3. Proprietary Pure DSD D/A converter. No off-the-shelf DACs.
    4.
    DTR input for connecting the DSD-only transport. Esoteric UX-1 or X-01 can be
    converted to such transport and stream Pure DSD from SACD or PCM-to-DSD
    converted CD data at DSD256 rate.
    5. Pure DSD input via RJ-45 jack. This
    input connects directly to the D/A converter for pure DSD processing.
    6.
    Redesigned/refined power supply and tube output stage with pair E182CC tubes and
    Lundahl audio transformers.
    Mvh.
    SAL
    impulse
    Hølen
    GRATULERER!
    Jeg kan vanskelig tenke meg at det finnes mange kilder som kommer opp mot denne. Så nå er det bare å begynne den festlige syvhundretimers-reisen mot ferdig innkjørt produkt, da.....:cool:
    januscp
    Gratulerer med ny digital spiller SAL, gleder meg til å høre dette!
    8x12_TOM
    Gratulerer!
    Er dette samme spilleren som Hato spiller på til daglig?
    ganilsen
    Porsgunn
    Gratulerer SAL, gleder meg til å høre denne.
    Takker også for lytten i går. Virket som om de nye ampene fungerte godt. :D
    Geir Arne
    POB
    Kulturhovedstaden
    Slenger meg på gratulasjonene.
    Skal bli artig å ta dette i nærmere øyensyn på messa.
    Reaksjoner: SAL
    K◡kera
    Geir Arne
    Fungerte godt?
    Vent til du hører de nye forsterkerne sammen med Gravitas NB-Master Reference Speaker System i Horten. ◔◡◔)))♪♫...
    Mvh.【ツ K◡kera
    SAL
    GRATULERER!
    Takker så mye Impulse!
    Men for en reise, den begynner på et nivå som bare er så mye bedre enn man skulle tro var muig, og så blir den bare bedre og bedre!:cool:
    Mvh.
    SAL
    SAL
    Gratulerer!
    Takker så mye!
    Nei dette er DSD, faktisk ett par knepp opp i lydkvalitet, blant annet ennå mere analogt og naturlig!:cool:
    Mvh.
    SAL
    SAL
    Godt?? Det må være årets understatement! ;)
    Det er kanskje lurt å begynne der. Du vet aldri når det kommer en mulighet for oppgradering til ekstremt mye bedre;)
    Som for eksempel når dere for ente gang har klart å ratte den snorrette kurven ennå rettere?:cool:
    Eller når man må veie to "identiske" DPèr for å finne ut om de er levert med like store strømforsyninger......;)
    Mvh.
    SAL
    SAL
    Geir Arne
    Takk for det Geir Arne!
    Bollene du hadde med var helt greie.:cool:
    Mvh.
    SAL
    SAL
    Her er APL DTR-M Transport!
    Kommer snart, denne driven skal løfte ennå ett knepp!
    And here is how the new DTR-M transport will look like. It works together with the DSD-M sending pure DSD from SACD and CD data converted to DSD256 via special connection. We built a special linear power supply for the audio computer. This resulted in an amazing improvement. However, the DTR-M transport still has the edge.
    Mvh.
    SAL
    ganilsen
    Porsgunn
    Det var da voldsomt. :D
    Jeg sa vel ikke akkurat noe negativt om ampene? Etter en snau halvtime med lytting syntes jeg dem virket gode på det meste men jeg føler det er upassende å komme med voldsomme lovord etter en så begrenset seanse. Ampene har god kontroll og er av veldig god byggekvalitet, ingen tvil om det. Det blir spennende å komme innom igjen når ny kilde er på plass om ikke lenge. Da med vesentlig mer avsatt tid. :D
    Mvh.【ツ K◡kera
    Blir imponert om dem topper toppmodellen fra Verity Audio hos SAL, da disse etter min mening er meget gode.
    Skal også bli morsomt å vurdere dette opp mot TAD-systemet vi tar med på messen. ;)
    Geir Arne
    Espen L
    Skien
    Mvh.
    SAL
    Ser virkelig frem til Horten messa og få lyttet til et komplett APL :) Elektronikken har jeg lyttet en del til og den er etter mine ører helt i toppklasse, det jeg er spent på er høyttalerene ? er de bare i nærheten av klassen til elektronikken så kan dette bli rett så gøy :)
    Herlig at det kommer et TAD system også på messen, har blitt meget imponert over TAD på Munchen messen så Horten messen i år ser jeg frem til :)
    Mvh: Espen L
    gismo
    Finnskogen❤️
    Væssia i Grue.
    Mvh.
    SAL
    Denne er lekker!
    Tiltalende er en svakt ord :cool: .....og om den presterer som "dere gutta" lover kan det vel ikke bli bedre?
    Blir artig å høre dette i Horten;)
    gismo
    Edit: sorry det var vist DSD-M vi skulle få høre der:cool:...viktig med kontroll på tastaturet....
    Reaksjoner: SAL
    SAL
    Mvh.
    SAL
    Denne er lekker!
    gismo
    Takk Gismo!
    Du har jo rett, bare at det DSD-Master`n med DTR-M driv!
    Litt usikker på om det kun blir en prototyp driv, kabinetter er i produksjon.
    Mvh.
    SAL
    Rintintin
    Kommer ikke APL med oprtisk a ?
    QUOTE=SAL;1675967]Litt info om DSD-Master:
    word, magical.
    Features include:
    user selectable.
    4.
    6.
    Mvh.
    SAL[/QUOTE]
    Rintintin
    Optisk
    Mente om den ikke kommer med OPTISK
    word, magical.
    Features include:
    user selectable.
    4.
    6.
    Mvh.
    SAL[/QUOTE]
    word, magical.
    Features include:
    user selectable.
    4.
    6.
    Mvh.
    SAL
    [/QUOTE]
    K◡kera
    Maestro Alex Peychev og hans APL-ILLUMI-FI lydsystem i Horten
    Mvh.【ツ K◡kera
    Reaksjoner: SAL
    SAL
    Det var veldig interessant å lytte til desse produkta. Eg vart ganske så hekta, særleg under "buskspelinga" om kvelden.
    Masse kred for lyden!
    Takker så mye Audiophile-Arve, veldig hyggelig å hilse på deg!
    Artig med vinyl vs. cd seansen synes jeg.:) Flere som likte den...
    Mvh.
    SAL
    Gjallarhorn Audio
    Heggedal, Asker
    Takk for noen fine lyttetimer i rommet til APL lørdag kveld/natt, SAL. Klokka ble vel 2 før vi gav oss, noe som nok skyldtes både kvaliteten på musikken og det gode selskapet :)
    Oppsettet til Alex spilte i mine ører usedvanlig vellydende og fremstod meget balansert. Og med SACD som kilde, så var det heller ingen tvil om at det i tillegg var veldig oppløst uten å bli analytisk.
    Alan
    SAL
    Takk det samme Alan, meget hyggelig selskap!
    Du/dere er velkommen til Porsgrunn for ytterligere inntrykk......:)
    Mvh.
    SAL
    Espen L
    Skien
    Synes dette spilte flott på messa med fin homogenitet og åpent å oppløst. Gleder meg til å høre dette i et noe bedre rom da vil jeg tru man vil få en enda dypere bass med mer dynamikk. Hørte at disse høyttalerene er målt helt ned til 19Hz men tviler på at de gikk noe særlig lenger ned en til 30Hz i dette rommet. Bra at Alex selv også stillte opp og svarte på spørsmål som man lurer på. For meg var det en hyggelig og fin opplevelse den tiden jeg var på dette rommet.
    Mvh: Espen L
    Gjallarhorn Audio
    Heggedal, Asker
    Ja, etter litt diskusjon kom vi vel frem til at de rullet av rundt 30 Hz.
    Til tross for det, så var det lite å utsette på lyden. Det tonale var innertier for meg og det låt som du sier åpent og flott.
