APL Hi-Fi.
  • SAL
    SAL
    SAL
    Hei!
    Fikk litt mere info fra Alex angående funksjoner på DSD-Master samt noen bilder av innsiden på APL HAS-Master!
    Hello Stein,
    Here is a link to the Facebook page; we have some new pictures uploaded, including Power Units without top cover and some manufacturing/assembly pictures as well. Hope you like it!
    http://www.facebook.com/pages/APL-Hi-Fi/515119481859549
    About Roysen's post on the thread:
    The DSD-Master "acts" as an usual DAC, but with a "twist". Below are some additional points of explanation how it works:
    1. It accepts AES/EBU balanced digital, as well as two Coaxial S/PDIF digital inputs, just like the DAC-Master. Both can process rates up to 192kHz/24bit PCM.
    2. PCM data is being converted to DSD at the rates I've already mentioned. The result is astonishing - best I've heard from a CD!
    3. The "twist" is that:
    a) PCM is converted to DSD64 or DSD128 at unusual, higher rates DSD. And BTW, I have experimented with even higher rates DSD (256, 512, etc) and found that that the most natural sounding is DSD64, and some might also enjoy DS128. Any higher DSD rate results in unnatural sound, IMHO!
    b) The proprietary USB interface accepts DSD64 and DSD128 only, no PCM. There is a current solution for Windows that converts PCM to DSD on the fly, but I am really waiting for the real time PCM to DSD converter from JRiver. According to my findings, the JRiver PCM to DSD converter is one of the very best I've auditioned, if not the best. In other words, with the DSD-M, audiophiles can stream PCM-to-DSD converted data, or stream real DSD64/DSD128 files from the computer. Our proprietary "DSD Only" USB interface is a first.
    c) Similar to I2S, the DSD-M can optionally accept DSD data from another DSD source. There is a product available that is basically an audio player, but the media is an SD card (it also takes up to 128GB SDXC cards). This product provides DSD data at the I2S output that is made around RJ45 (LAN) connector. Audiophiles interested in using such device/digital SD card transport can request such DSD input. And that is DSD only, no PCM.
    d) As you already know, the heart of the DSD-Master is my own-designed DSD-to-Analog converter. It is quite unique in every respect, offering unmatched sound quality from every source, even MP3.
    Bottom line, the DSD-Master D/A converter is a very unique product that accepts both PCM and DSD while offering sound quality that is beyond anything I've personally auditioned to date. Namely, the sound character is not only the closest to analog (read vinyl), but it actually outperforms it in some ways since, due to it's nature, vinyl is very non-linear source.
    The DSD-Master provides the same natural flow of music that is totally free from any digital glare, while being ultra-linear, unlike any other analog source available I know of. :)
    Of course, the last word about the sound quality is yours, and I can't wait to hear about it!
    Hope this explains it!
    Best,
    Alex
    Alex Peychev
    +1 707 320 2367 - USA
    +359 899 225 411 - BG
    www.aplhifi.com
    Håper dette forklarer hvor genialt og heftig dette er!
    Som jeg nevnte tidligere i tråden har jeg bestilt DSD-Master, blir meget spennende.
    Mvh.
    SAL
    SAL
    Hvordan ligger det an med APL riaaen? Har noen av dere fått hørt på den enda?
    Hei gut_man!
    Alex har hatt litt for mye å gjøre, den er litt forsinket! Skal sjekke, kommer tilbake på den snart.
    Mvh.
    SAL
    Hei igjen!
    Snakket med Alex tidligere i dag angående RIAA'n. Han mangler kabinetter men skal lage ett demo eks. med plexiglass front og bakplate som vi kan ha på test/prøve!
    Jeg gir beskjed så fort den dukker opp.
    Mvh.
    SAL
    K◡kera
    Gratulerer SAL ♪ ˘◡˘)))♪♫...
    Mvh.【ツ K◡kera
    Takker så mye!
    Har du fått din HAS-Master i hus?
    Mvh.
    SAL
    Hei SAL,
    Ja, jeg har fått mitt HAS-Master♪♫
    Dessverre jeg er på ferie og må vente med den.
    Mvh.【ツ K◡kera
    Gratulerer så mye! Da kan du glede deg til ferien er over!
    Mvh.
    SAL
    Tusen takk ♪ ˘◡˘)))♪♫...
    Mvh.【ツ K◡kera
    K◡kera
    Sommerlig hilsen til alle venner♪ ˘◡˘)))♪♫...
    Mvh.【ツ K◡kera
    SAL
    Gratulerer nok en gang!
    Moro å se HAS-Master på plass i racket, passer perfekt. Hva synes du om oppgraderingen?:cool:
    Mvh.
    SAL
    K◡kera
    Takk, takk!
    Ja racket passet perfekt. Hva synes jeg om...
    Jeg er verdens gladeste mann! ~˘◡˘)))♪♫...
    Mvh.【ツ K◡kera
    K◡kera
    Piano man Brian Culbertson loves the sound of K◡kera APL Master System too!! ~ ♥˘◡˘)))♪♫...
    Mvh.【ツ K◡kera
    hato
    Gratulere med HAS Master. Ekstreme saker, passet utmerket i racket
    soundboy
    Veldig bra DVD av Brian Culbertson :)
    Espen L
    Skien
    Vis vedlegget 209452
    Mvh.【ツ K◡kera
    Grattis med et flott system, tøft at du tar det helt ut med et merke hele veien må jo bli en flott synergi av d.
    Hadde vært gøy og hørt høyttallerene en gang må si jeg er spent på hvordan de er.
    Skal SAL en tur igjen å besøke deg så håper jeg at jeg kan få slengt meg med :)
    Mvh: Espen L
    Må si jeg gleder meg til å få hørt dette oppsettet. Tror det blir en liten høynaere i sommer... :)
    K◡kera
    Tusen takk Hato!
    ja de er ekstreme saker,og for en fantastisk lyd! ~ ˘◡˘)))♪♫...
    Jeg tror du er nestemann med HAS-MASTER, eller.....
    Du er velkommen for å høre hele systemet.
    Mvh.【ツ K◡kera
    K◡kera
    Mvh.【ツ K◡kera
    Mvh: Espen L
    Tusen takk Espen L!
    ja ett merke hele veien. Jeg tror du vet hvorfor. En profesjonell musiker gjør aldri kompromisser med sitt instrument og lyden.
    Jeg har vært på leting, og prøvde å finne den rette Hi-Fi-instrumenter, for å spille min favoritt musikk i nesten 60 år.
    Nå er det over og jeg er veldig glad. ~ ˘◡˘)))♪♫...
    Ja du kan ta en tur sammen med SAL eller alene. Du er altid velkommen for å høre høyttalerne og hele systemet.
    Mvh.【ツ K◡kera
    K◡kera
    Jøsses! Gratulerer! Ser du liker Gino Vanelli også!
    Tusen takk impulse!
    ja jeg liker musikken og stemmen til Gino Vanelli veldig mye, og denne plata er bare fantastisk.
    Du er velkommen for å høre hele systemet. ~ ˘◡˘)))♪♫...
    Mvh.【ツ K◡kera
    K◡kera
    Wishing You The Finest Jazzy Evening!˘◡˘)))♪♫...
    Mvh.【ツ K◡kera
    Espen L
    Skien
    Takker så mye for gratulasjoner og gode ord gutter!:)
    Legger ut et par bilder til. Jeg måtte bare en rask tur ut i garagen og dreie nye bein til racket, la på 100 mm for å få 2A3 rørene til å gå klar av vangene under topplaten samt gi fin lufting for varmen.
    Controller`n på plass i racket.
    Vis vedlegget 206567
    Vis vedlegget 206569
    Mvh.
    SAL
    Hei SAL
    Hvordan går det med innspillingen av de nye smykkene dine fra APL? er du fortsatt like imponert?
    Artig vis du hadde lagt ut litt inntrykk nå som de har fått litt "lunk" i seg :)
    Mvh: Espen L
    SAL
    Hei Espen!
    Ja, nå begynner rørene å nærme seg 100 timer og det har helt klart "løsnet" litt! Det har myknet litt i topp og øvre mellomtone samt blitt ennå strammere i bunn, overtoner og utklinging er helt fantasisk i mine ører. Rommet blir tegnet opp stort, presist og detaljert med en kropp og sjel på instrumenter jeg ikke har hørt her før, vokalen er ekstremt troverdig. Krefter, hurtighet og dynamikk som bare imponerer.........perfekt!
    Det blir mye skryt her nå, men jeg er ekstremt fornøyd med Alex sine siste kreasjoner! Skal vi tro Alex kommer det mer når elektronikken får ytterlige timer på seg.........:)
    Kommer ett sett signal og høytalerkabler fra APL som skal inn i systemet, blir spennende.
    Edit. Glemte å nevne oppløsning, den er ut av en annen verden!
    Mvh.
    SAL
    Espen L
    Skien
    Hei Espen!
    Mvh.
    SAL
    Hei SAL
    Høres spennende ut, kommer du til å teste høyttalerene til APL også ?
    Mvh: Espen L
    K◡kera
    ╠╣appy Birthday Satchmo! ♥ ♪♫...
    Mvh.【ツ K◡kera
    soundboy
    Fornøyd bruker fra USA.
    Bra nyhet for bruk av komplett APL Hi-Fi system fra Alex :p
    "I have the HAS-M amplification system and there is good news and bad news. Please note that at the moment there are only about 15 hours on the tubes, so break in continues.
    The good news is for Alex. Had I heard any HAS-M but mine, and in any system but mine, I would very likely attempted to strangle Alex. It is that good. From highs to lows, there is more detail, and more music. The bass is truly palpable, and I feel it with each pluck of an acoustic bass. The highs truly soar, and the overall presentation feels relaxed and unconstrained. It seems effortless. At the same time, the music sparkles, and it feels like a lambs-wool fleece has been removed from in front of the speakers. I am constantly being made aware of details, piano pedals, an accordion sucking in wind, the nature of air passing over a reed, a hand accidently hitting an instrument, in very familiar recordings that I have never heard before. Each CD is now a revelation.
    The bad news is for me. I have hundreds of CDs and now I have to play everyone in order to hear what it really sounds like.
    It is a privilege to own this amp system. Thank you, Alex. You succeeded beyond my wildest dreams. It was worth the wait, and more!
    Jeff"
    Link : APL-HiFi Forum View topic - Reference HAS-Master hybrid amplification system on the way
    Kjedelig for dem som har mange hundere CD`plater..hehe:cool:
    Jeg har fått æret til å lytte på komplett APL, kan rett & slett ikke beskrives. Må oppleves!
    K◡kera
    Jeff"
    Ja, jeg er totalt enig med Mr. Jeff Birren.
    Mvh.【ツ K◡kera
    SAL
    Jeff"
    Godt det finnes folk som er flinkere enn meg til å beskrive hvordan ting låter!
    Det låter helt utrolig bra her med Verity Lohengrin II:cool:, og for å svare på Espen L`s spørsmål så er planen å få ett sett APL høytalere på plass i stua her også for en liten "shootout"! Alex mener han vet hvordan det går..........:)
    Mvh.
    SAL
    januscp
    Det er det vel neppe noen bombe å forutsi:rolleyes:;)
    Jeff"
    Vis vedlegget 210640
    Mvh.【ツ K◡kera
    Ei blått til lyst.... fin rigg det der!
    D
    DL
    Jeff"
    Mvh.【ツ K◡kera
    Jeg er helt sikker på at Alex lager ett sett til deg, med den fargen du enn måtte ha lyst på, på alle dioder og display :)
    DL
    soundboy
    DL
    Er 120% sikker på at det ikke er noen problem for Mr Peychev, fra Ruse :D:cool:
    ICE_84
    Gjøvik
    Her er nok et synspunkt fra jbirren på APL-Forumet:
    "I am constantly amazed by way the amps increase the music's presence in the room. I have found another down-side to it however. When I get home, all I want to do is listen to the system. Chores, reading, everything else seems to be put on hold because I can't wait to listen. Going to the office seems like a very unwelcome obligation that gets in the way of listening.
    I consider myself extremely fortunate to own it."
    Jeg har selv hatt gleden av å høre det komplette APL-systemet til Kukera og jeg finner ikke gode nok ord til å beskrive opplevelsen!
    Jeg sitterer derfor litt mer fra Jbirren:
    "It is that good!! From highs to lows, there is more detail, and more music. The bass is truly palpable, and I feel it with each pluck of an acoustic bass. The highs truly soar, and the overall presentation feels relaxed and unconstrained. It seems effortless... the music sparkles."
    K◡kera
    K◡kera
    Life was made for celebrating love and friendship every day.♥
    Mvh.【ツ K◡kera
    SAL
    Hei!
    APL Hi-FI på Horten-Messa med selveste Alex Peychev tilstede!
    Best Western Horten Hotell, Rom: "Frisørsalongen" 26-27 oktober 2013
    Systemet vil bestå av:
    APL DSD-Master
    APL HAS-Master
    APL Gravitas NB-Master
    SAL
