Pga. flytting selges uptodate surround pakke bestående av Pioneer VSX-2020 & BDP-LX52 med high end hdmi kabel m.m.. Valgte denne pakken da det spiller meget bra i Stereo også. (se tester).
7 x 150w. 192 kHz / 24-bit DAC. Bluetooth. Internet radio. THX Select 2. Ipod/phone ready. mm.
Dette er prisvinnende, griselekre og velspillende topp modeller fra Pioneer. Kun 3 år gamle. Med alle tenkbare in og utganger +spec. Nypris 15000!
Det er nesten ikke brukt i det hele tatt pga. tidsklemma og ren stereo prioritering.
http://www.lydogbilde.no/test/pioneer-bdp-lx52
http://www.trustedreviews.com/pioneer-bdp-lx52-blu-ray-player-review
http://www.pioneer.eu/eur/products/archive/VSX-2020-K/page.html
http://www.otest.co.uk/p/pioneer-tests/vsx-2020-reviews.html
Specifications
Specifications
Main Features | VSX-2020-K |
Output Power per Channel | 150W |
Impedance at Output Level | 6? |
Input Connections | ? 6 x HDMI (1080p upscaling) (1 Front Input) ? 4 x Composite ? 2 x Component ? 2 x Coaxial ? 3 x Optical ? 1 x USB host ? 1 x iPod/iPhone Digital via USB (cable included) ? 1 x Ethernet ? 1 x Bluetooth adapter port for AS-BT200 |
Output Connections | ? 2 x HDMI ? 1 x Composite ? 1 x Component ? 1 x Optical |
HDMI Repeater | Yes |
On-Screen Display (GUI) | Easy-to-use GUI, available in English, French, Italian, German, Spanish, Dutch and Russian |
Internet Radio | Yes |
Remote Control | Glow-key, preset remote control (learning) |
Weight | 13,1 kg |
Input & Output connections | VSX-2020-K |
Bluetooth Adapter Port | Yes |
Composite Input/Output | 4/1 |
Digital Optical Input/Output | 3/1 (assignable) |
Digital Coaxial Input/Output | 2/- (assignable) |
Ethernet | 1 |
HDMI Input/Output | 6 (assignable)/2 |
Headphone | Yes |
Number of Channels | 7 |
Signal / Noise Ratio | 103 dB |
AM/FM Tuner with RDS | Yes |
Tuner Pre-set Stations | 63 |
HD Audio Formats | Dolby TrueHD, DTS-HD Master Audio |
Audio Return Channel | Yes |
Control with HDMI | Yes |
Dimensions (W x H x D) | 420 x 173 x 433 mm |
Pre-amp Output | Yes (SW) |
Speaker A/B | Yes |
USB Host (Front) | Yes |
Apple Compatibility | VSX-2020-K |
Works with iPod | Yes, via digital direct USB connection (included) |
iControlAV | Yes |
iPhone Control Button | Yes |
Compatible Generations | 5th Generation, Nano and above, iPhone (including 3G) |
Supported Functions | Audio & Video (Video with the supplied iPod/iPhone Video + USB Audio cable), On-Screen Album Art |
Surround Sound Formats | VSX-2020-K |
Dolby Digital | Yes |
Dolby Digital EX | Yes |
Dolby Pro Logic IIx | Yes |
Dolby Pro Logic IIz | Yes |
Dolby True HD | Yes |
DTS-ES | Yes |
DTS Neo: 6 | Yes |
DTS-HD High Resolution Audio | Yes |
DTS-HD Master Audio | Yes |
Audio Features | VSX-2020-K |
Midnight Listening Mode | Yes |
Standing Wave Control | Yes |
Stream Direct | Yes |
Symmetric EQ | Yes |
Virtual Surround Back | Yes |
X-Curve | Yes |
Construction | VSX-2020-K |
Pioneer Hybrid Amplification | Yes |
AV Front Input | Yes |
Bi-Amplifier | Yes |
Component Video Input/Output | 2/1 (assignable) |
IR In/Out | 1/1 |
Large speaker terminals | Yes |
Works with iPhone | Yes |
Dolby Digital Plus | Yes |
Dolby Pro Logic II | Yes |
DTS | Yes |
DTS 96/24 | Yes |
DTS-Express | Yes |
WMA 9 Pro | Yes |
THX Certified | Yes |
DTS Neural Surround | Yes |
Surround Modes | 13 + 1 (Action, Drama, Sci-Fi, Mono Film, Entertainment Show, Expanded Theater, TV Surround, Advanced Game, Sports, Classical, Rock/Pop, Unplugged, Extended Stereo + Phones Surround) |
Auto Level Control | Yes (Multi-channel) |
Auto Surround | Yes |
Dialogue Enhancement | Yes |
Digital Noise Reduction | Yes |
Dynamic Range Control | Yes |
Front Stage Surround Advance | Yes |
Jitter Reduction | Yes |
Loudness | Yes |
Multizone Function | Yes (3) |
Phase Control | Yes |
MCACC | Yes (Advanced, 9-band) |
PQLS | Yes (Multi-channel ) |
Sound Delay (LipSync) | Yes |
Advanced Sound Retriever | Yes (Multi-channel) |
Sound Retriever AIR | Yes |
Video Features | VSX-2020-K |
Deep Colour | Yes |
3D Ready | Yes |
x.v.Colour | Yes |
HD Digital Film Direct 24 | Yes |
Power Output | VSX-2020-K |
Power output per channel | 150W |
Condition | 1kHz, 1% THD, 6? |
Rated Power Output | 150W per channel |
Input (Sensitivity/Imp.): LINE | 350 mV / 47k? |
Frequency Response: LINE | 5 Hz - 100 kHz +0/-3 dB |
Signal-to-Noise Ratio: LINE (DIN) | 103 dB |
Power Requirements | AC 220 - 230 V / 50/60 Hz |
Power Consumption (in use / standby) | 410 W / 0.30 W |
Digital Signal Processor | Freescale |
Amplifier Specifications | VSX-2020-K |
Front L & R Bi-Amplifier Function | Yes |
D/A Converter | 192 kHz / 24-bit |
A/D Converter | 192 kHz / 24-bit |
