Larsen 9 i demo i butikken
Alle Larsen høyttalerne er basert på Stig Carlsson sine orthoakustiske prinisipper. Høyttalerne er laget i Sverige. Lydsignaturen er unig på grunn av det spesielle designet. Siden elementene er vinklet oppover og innover minimerer man mange av de problemene vanlige høyttalere har med tidlige refleksjoner fra side og bak vegg og gjør dem lettere å plassere.
2021 Editors' Choice Awards: Loudspeakers $10,000 - $20,000 - The Absolute Sound
Larsen Model 9
$14,995
This is the latest and best embodiment of the Larsen concept: using wall placement and woofers near the floor combined with wide dispersion of the higher frequencies to generate a sound with minimal early reflections but impressive uniformity over the room. The sound of your listening room is replaced by the sound of the original recording venue to a surprising extent. The speakers needs minimal fuss about exact placement and little or no room treatment to achieve independence of the listening space. The Model 9 is superbly finished and surprisingly compact, considering its bass power and extension.
Fra produsenten:
Fundamental understanding of Stig Carlsson’s ortho acoustic principles paired with Nordic furniture tradition and the best loudspeaker drivers on the market, Larsen 9 is a very potent 2.5 way loudspeaker system in a smooth and soft bentwood suit. By virtue of its highest quality drivers, their unique placement and angles, flanked by absorbers, the Larsen 9 creates a rich three-dimensional sound stage, the ability for you to hear the smallest details and a life like ambience.
The two bass drivers working together below 300 Hz gives a rich, deep and precise bass with very low distortion all the way down to 22 Hz. The low distortion and wide but controlled energy dispersion in the high frequencies makes the Larsen 9 loudspeaker sound true to the musical performance in a larger listening area in the room compared to traditional loudspeakers. The two upwards facing ambience tweeters, same as the Larsen 8, helps reproduce ambience and depth to the sound stage for recordings where this is actually present.
The two 7 inch drivers together with their mirror images in the wall due to the close proximity equals a driver piston area, (SD), larger than a 12 inch driver, hence the effortless deep low frequency performance. There is not a need for a separate subwoofer to reproduce everything on your records.
Just listen and love it!
Effect 200 W
Sensitivity 88 db
Impedance 4 ohm
Bass driver 2 x 184 mm
Width 300 mm
Height 930 mm
Depth 378 mm
Weight
Larsen Model 9
$14,995
Fra produsenten:
Effect 200 W
Sensitivity 88 db
Impedance 4 ohm
Width 300 mm
Height 930 mm
Depth 378 mm
Weight
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
