Budsjettkabel
Ta kontakt for tilbud
Twist Loudspeaker Cable
Twist is the perfect cable for your first hi-fi music system. Its low cost does not prevent you from enjoying very high quality sound.
Available in 3 metre or 5 metre pairs.
Its special quality is the 1.2mm silicone rubber insulation, thicker than most other loudspeaker cables so as to reduce ‘Proximity Effect’ distortion due to the magnetic fields in each conductor affecting the current flow in the other.
In addition, cores are twisted to reduce distortion effects from radio frequency interference.
“beautifully designed and so easy on the ear, with a remarkable price“ - Hi-Fi World
“Twist delivers voices and guitars in a fluid and effortless style. A well thought out cable that will bring a touch of class to budget systems ” Hi-Fi Choice
The result is clearer sound of a quality rarely experienced from its price.
Specification below:
- 2 core twisted pair loudspeaker cable
- 0.75 sq. mm tinned copper conductors
- 1.2 mm silicone rubber insulation
- Terminated in gold plated Z plugs
- Available in 3m and 5m lengths.
- For other lengths or terminations please contact the Sales Office
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
