Endpoint Audio
Butikk Lampizator Baltic 4 - Balansert + SE
Digitale avspillere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Vestfold
Pris
Kr 94.000
Annonse beskrivelse
Annonse nummer: 251158
På lager for umiddelbar levering.
Sølvfarget med sort topp/sider.
En high end dac som jeg mener spiller bedre enn alt i sin klasse og godt over.
You get tons of very cool features here, at a price that is almost too good to be true: phenomenal digital engine ELEVEN, triode output stage, DC coupling of all stages, double thickness front panel, new engraved rear end, tube based, choke filtered power supply with directly heated dual diode - 5C3S or 5U4G or 274B or GZ37 or 5W4R. Add Copper Caps, balanced circuit - all in one neat package.
The Baltic project is our attempt on the pinnacle design made with octal tubes. The whole octal tube kingdom is the biggest one, with tens of tube models and thousands of brand / version variations. These tubes today can cost as little as 2 Euro or as much as 500.
Our highest level DACs, in order to surpass the quality of noval tubes by a small margin, had to come from DHT kingdom, but Baltic, a result of our 13 years efforts and experiments and prototyping - push the octal design to the limits. It makes the Baltic-4 our newest model with octal tubes. One could argue that the Baltic-4 is in fact the turbocharged Amber 4 on steroids, but there is more than meets the eye.
Volume controlled model has a display, remote, auxiliary analog inputs - SE and XLR for other sources like turntables, tuners, reel-to-reel etc
5 years warranty
W x H x D = 430 x 130 x 500 [mm] Weight net 13 kG, gross 19 kg.
Output impedance 300 Ohms
Choice of inputs ( a sum of four is maximum) S/PDIF RCA, AES/EBU, Toslink, USB.
ORDER
Balanced Tube DAC
In our endless efforts to research and design DACs, we arrived at this design. Combining everything we know about DAC designing,
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Endpoint Audio
Torget karakterer
Vurderinger (40)
Andre annonser av Endpoint Audio
