Endpoint Audio
Butikk Cube Audio Nenuphar - Nye - uåpnet Solgt
Gulvhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Vestfold
Pris
Kr 60.000
Kjøpt av
plinius
Annonse beskrivelse
Annonse nummer: 241295
Nye og ubrukte Cube Nenuphar i sort piano selges billig - skal ut.
Dette er høyttalere som drives med nesten ingenting av effekt og passer for rom opptil ca 40 kvm. De anbefaler selv rørforsterkere fra 3W og opp - og klasse A forsterkere generelt.
Nypris hos Hagto er 169.900,-
Privatsalg.
Cube Audio Nenuphar is a single driver loudspeaker based on Cube Audio F10 Neo drivers. State of art fullrange drivers combined with very effective TQWT enclosure results in real extraordinary experience. Modern, elegant design and high-quality black or white piano finish make the loudspeaker a beautiful addition to every style of interior. All drivers and loudspeakers are handmade in Poland. Pursuing the highest quality and longevity, the manufacturing process involves both artisan craftsmanship and modern precise computer-controlled CNC machines.
The Nenuphars are dedicated for rooms of 20 - 40 square meters. They are a perfect match for a tube amp with at least 3 Watts per channel. Our personal preference is somewhere around 2A3, Px4, 45 tube-based amps. Nonetheless, most solid-state amps (especially those working in A-class) are also an amazing match for the Nenuphars. When it comes to placement, they can be placed both forward and placed right against the back wall. They like about 5-10 degrees of toe-in.
All of Cube Audio fullrange drivers gain huge benefits from many innovative technologies and solutions used in those speakers. The proof is not only in the sound but can be easily noticed in measurements of both speakers. Frequency response is outstanding not only on the "on-axis" measurement. The results are unprecedented.
Originalemballasje
Ja
Orig. kvittering
Nei
Forsendelse
Kan sendes
Endpoint Audio
Torget karakterer
Vurderinger (40)
Andre annonser av Endpoint Audio
