Endpoint Audio
Butikk Canor DAC 2.10 demomodell Solgt
D/a konverter
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Vestfold
Pris
Kr 27.000
Annonse beskrivelse
Annonse nummer: 252654
Jeg rydde opp og skal selge ut endel utstillingsutstyr.
Canor DAC 2.10
D/A converter with tube-based output
CANOR DAC 2.10 uses the dual mono configuration of the ES9038Q2M digital-to-analogue converters from ESS Sabre, which ensure high sound quality.
Dette er en særdeles god DAC, som virkelig har overrasket! Har du en cd spiller eller en streamer så vil denne garantert gi deg en oppgradering.
Denne kan testes hjemme!
Product features
thanks to used converters, it is possible to play files in PCM formats up to a sampling frequency of 768 kHz and for DSD format up to Native DSD512 via the USB input, thus covering most digital files that you can normally play, buy or stream.
it uses the dual mono configuration of the ES9038Q2M digital-to-analogue converters from ESS Sabre, which ensure high sound quality.
the analogue output is a buffer, which is solved by a high-quality electronic connection
dual converter wiring uses separate signal paths for the left and right channels.
there are seven digital converter filters for PCM format and one proprietary for MQA format, which is set automatically during MQA playback.
the last (eighth) item in the digital filter menu “Oversampling Bypass” can be selected. But it’s not a digital filter, as it’s turning off digital filtering for the ability to compare audio without filtering…
the signal from the digital inputs is processed by a powerful multi-core XMOS microcontroller with an advanced Multi-Core RISC architecture.
Frequency Response at Fs=192 kHz +/- 0,03 dB at 20 Hz to 20 kHz
Output impedance < 200 Ω
THD+N 1kHz at 0 dBFs > 0,008%
THD+N 1kHz at -6 dBFs > 0,004%
XLR output voltage at 0 dBFs 4 V RMS
XLR: SNR 20 Hz to 20 kHz at 0 dBFs < 108 dB
RCA output voltage at 0 dBFs 2 V RMS
RCA: SNR 20 Hz to 20 kHz at 0 dBFs < 95 dB
Analogue outputs 2 x XLR / 2 x RCA
Supported PCM sampling rates 44,1k / 48k / 88,2k / 96k / 176,4k / 192k / 352,8k / 384k / 705,6k / 768kHz
DSD over PCM support DoP DSD 64/128/256/512
DSD Native support Native DSD 64/128/256/512
MQA support Full MQA decoding by hardware from all digital inputs
S/PDIF Optical input 2 x (24bit / 192kHz)
S/PDIF Coaxial input 1 x (24bit / 192kHz)
AES/EBU input 1 x (24bit / 192kHz balanced)
Digital to Analogue converter 2 x ESS9038Q2M (dual mono)
Filter settings 8 x digital filter
Display LCD TFT
Tube complement 4 x 6922
Power 230 V / 50 Hz / 44 VA
Dimensions (w x h x d) 435 x 120 x 405 mm
Weight (net) 12 kg
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Endpoint Audio
Torget karakterer
Vurderinger (40)
Andre annonser av Endpoint Audio
