Anthem PVA 2 effektforsterker selges. 200W 2018mod.
Nypris 13.990. Kjøpt på Oslo Hifi Center.
link til spesifikasjoner :
https://www.anthemav.com/products-archived/model=pva-2/page=specs Link til test; https://www.soundstagenetwork.com/revequip/anthem_pva2.htm OTHER SPECIFICATIONS: HEADROOM 1.25 db (8 Ω); 2.13 db (4 Ω) POWER BANDWIDTH 10 Hz - 80 kHz (125 W @ 8 Ω) FREQUENCY RESPONSE 20 Hz - 20 kHz (-0.20 db); 5 Hz - 100 kHz (-2.5 db) THD + N <0.002% @ 1 kHz; <0.03% @ 20 kHz (100 W into 8 Ω) INPUT SENSITIVITY 1.12 VRMS for 125 W into 8 Ω INPUT IMPEDANCE 10 kΩ DAMPING FACTOR 200 @ 1 kHz (ref. 8 Ω) S/N RATIO 122 db, A-weighted (ref. 125 W) CHANNEL SEPARATION >65 db (100 Hz - 10 kHz) VOLTAGE GAIN 29 db SLEW RATE 28 v/µs POWER REQUIREMENTS 500 W @ maximum power output (8 Ω load) DIMENSIONS (H x W x D; heights include feet) 5-7/8" (14.9 cm) High x 17-1/4" (43.8 cm) Wide x 11" (28 cm) Deep WEIGHT (Unpacked) 26 lb (11.8 kg)
Vipps
Se mine referanser
Vipps
Se mine referanser
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
