Har noen på forumet her erfaringer med å byttet ut sirkinger i komponenetene? Da for eksempel "HiFi Supreme fuses". Videre erfaring med å smøre inn koblingspunkter på kabler og apparater med "Contact enchancer"?
Fra beskrivelsen (HIFI TUNING FUSES SUPREME SMALL SLOW at Music Direct):
"HiFi Tuning & Mundorf Teamed Together to Create these Supreme Fuses
HiFi Tuning Supreme Fuses are truly special and offer quality of sound which far exceeds any fuse available on the market. Made from Mundorf’s proprietary blend of ultra-pure silver and gold, Supreme fuses deliver outstanding speed, jaw-dropping resolution and a gorgeously smooth tonal balance. Treat your gear to the best, HiFi Tuning Supreme Fuses.
HiFi Tuning has long been a fan of Germany’s legendary Mundorf capacitors. Revered in audiophile circles for creating gorgeous sounding no-compromise capacitors which grace some of the world’s best electronic designs, Mundorf capacitors are built using a special conductive material. Ultra-pure silver is impregnated with gold creating a material with gobs of resolution and golden warmth; glorious tonal color with truly outstanding dynamic shading, essentially the best of both gold and silver and absolutely no compromise. Each Supreme fuse uses this special material for its end-caps and conductive filament and pure silver solder connects everything. Inside the ceramic casing, Supreme fuses further distinguish themselves by receiving proprietary resonance and quantum treatments. Can a fuse really make a difference? Are Supreme fuses worth it? One listen will erase all doubt."
"Contact enchancer" fra Furutech (NANO LIQUID | FURUTECH). Koster ca en tusenlapp for 2 milliliter. Fra beskrivelsen:
"High End Performance NANO Liquid Contact Enhancer
Revives old connections and improves new connections
Incredible Nano Liquid’s molecules are so tiny they
“fill up” any air bubble holes left during the plating process when brushed onto connectors.
The result is much better contact between metal surfaces.
Nano Liquid is a result of Furutech’s Total Attention to Detail regarding every aspect of signal transmission. Use only a little!
This product is super-micro particle(with nano-meter technology) made by two material i.e. pure Gold and pure Silver.
The particle diameter is 8 Nm Max., i.e. 8/1,000,000mm.
2CC/PCS
Illustration of the Nano Liquid Efficiency:
1. Squalene Oil can remove oxide...etc, form the surface of metal, make the surface clean and free of pollution, activate metal surface.
2. Apply the principle of atomic adsorption to make gold & silver super-micro particle can be adhered to metal surface averagely; Fill concave-convex section on surface, increase electric conduction area and debase impedance (Ω).
3. Meanwhile, stable Squalene Oil can form a layer protective film on the surface of metal to prevent oxidation happen again. Utilize it’s excellent adsorbed effect to make gold & silver super-micro particle average and adhere to surface of metal stably."
2CC/PCS
82.5 KB Visninger: 303
8.2 KB Visninger: 247
